Bruce Pittard
Double polys and lines
How about an option when creating double polygons or double lines if they kept their information so the width, cavities etc can be modified in the object info. This would be very handy with variations.
4 answers to this question
quote:
Hi,
Why not use walls instead? They have exactly this property you described.
[]s
Alexandre
Bruce, if you group a particular set of walls you can select them all and adjust their properties simultaneously. They even stay healed pretty well when adjusting thickness. The 2D reshape tool works on them too. Only thing I can see that might be lacking is that when altering thickness they adjust on either side of the CL. I don't think you can specify an adjustment relative to a specific side.
Delmer - being able to change wall thicknesses and specify the 'anchor' point is a definate need.
