Matthew M Posted May 9 Share Posted May 9 Dear all, I'm working on a 3D model which is using slider doors in walls. I recently changed some of the settings to some of the doors. When these adjustments were made the plan view of the door in wall updated and the wall appears to now run through the opening. In 3D view it appears to be ok. Please see the attached for reference. Has anyone come across a solution for this issue? Thank you, Quote Link to comment
Tom W. Posted May 9 Share Posted May 9 (edited) What does it say in the OIP for the Door in the 'Break' setting? It should be set to 'Full break with caps'. Edited May 9 by Tom W. 1 Quote Link to comment
Matthew M Posted May 10 Author Share Posted May 10 Tom, Many thanks for your prompt reply. Yes, this appears to have done the trick. I wasn't aware of that check box in the OIP. Thanks again, Matt Quote Link to comment
