Marc Powell Posted March 27, 2024 Share Posted March 27, 2024 Hey Folks - I'm assuming that the only answer here it a script of some sort, but here it goes: Issue - I've created a record format that has a few fields that is needed to map to symbols created with another command. I need to be able to take something like 150 instances of the same data tag/callout, attach a record format to them and then get the information referenced in the data tag/callout into fields in the record format. Any ideas? Explanation - I'm using Sam Jones' truss tape tool to create truss tapes. A designer has put data tags where all universes begin on each instrument where it begins (and callouts at the end of each truss for cable breaks) and I want to be able to print those out on the truss tape. To have a symbol or other object translated to the truss tape, it needs a record attached to it. Whatever information shows up in the symbol on the tape must be in the record. Any suggestions are welcome. Quote Link to comment
Pat Stanford Posted March 27, 2024 Share Posted March 27, 2024 I think you may be able to accomplish this using the Data Manager. Quote Link to comment
