trevorgooch Posted March 20 Share Posted March 20 Hello, my very clever friends! TLDR: Is there a way for the clip cube to inform the result of the criteria "is visible"? I have specifically tested it in the context of a worksheet database criteria, though not yet in a script. Backstory: I have a worksheet that is populated by the criteria "is visible" to give me a quick report of the current on screen elements in table form. (I have a script to recalculate active worksheet that's triggered by my stream deck) I often click on a row and "select item" -> fit to obj -> select similar -> clip cube ->... ??? -> profit wildly -> recalculate active worksheet to see what's around the elements I'm investigating. Anyway - I *think* I'd like to be able to use the clip cube as part of a worksheet criteria. Have a great day. Quote Link to comment
JBenghiat Posted March 20 Share Posted March 20 Short answer -- no. The clip club is just essentially a view. The criteria is actually looking at a visibility flag that's set on objects (which really dates from pre-viewport days) and their containers (i.e. whether their containing layer is set to visible). Your worksheet isn't going to change if you're zoomed in on a group of objects, for example. The Clip Cube doesn't change any visibility flags, it just filters what gets displayed on screen. From a script standpoint, you could retrieve the clip cube, get its location and dimensions, then parse objects and test if they exist within the cube -- but that is not a small task. 1 Quote Link to comment
trevorgooch Posted March 20 Author Share Posted March 20 I really appreciate the “like a view perspective”. It helps it make sense. I don’t think it’s worth the effort to me this month to dig deeper- it’s most important to be nimble. Thanks, Josh! Quote Link to comment
