ElliotAmps Posted February 28 Share Posted February 28 Hi, How do I edit the images so they are all the same in reports? I want them all horizontal? Thanks! Quote Link to comment
0 Pat Stanford Posted February 29 Share Posted February 29 For the rotation, I think you will have to edit the symbols and rotate the objects in them to be horizontal in the definition. Which means that you will have to edit every place you use them in your drawing. For size, you can select the database header row cell and edit the Cell formation for Image. Best option will probably be fixed size, but that will make your different length poles all show the same. Maybe you want to use the Layer Scale or a Fixed Scale, but I you have objects that are very different sizes in the drawing then some of them will probably appear too large or too small. The image functions work best with objects that are all of similar sizes. 1 Quote Link to comment
ElliotAmps
Hi,
Thanks!
1 answer to this question
