I am using a section line from the defaults, which is adding the drawing title as we normally find fine. On this scheme we have a seperate client drawing number, which I have included by adding a field to the sheet data, and referenced this on the title block from linked text. However, I don't seem to be able to reference the same text from the section line text, as the only option from the drop down menu only seems to allow the original 'sheet number' to be included. I have tried editing the text between the 2nd #'s to say 'Gassco Dwg no.' in the hope it would find that field but with no luck.. I could swap the numbers from the 'sheet number' and 'gassco dwg no' fields in the sheet data, and then modify the title block to suit, but would have to do this for every sheet, and there are a lot..... Any suggestions.
LeeElston
0 answers to this question
