The sole improvement in the user interface of version 9 over version 8 was the ability to draw or select an object, then open (double-click) the Object Info palette to look at data on the selected object, and then be able to use a shortcut key to change to the appropriate tool (as determined by that data) without first clicking on the drawing window, so that the next mouse click would be the beginning of some action on the selected object.
In version 8, it was necessary to click on the drawing window before the Tool shortcuts would work.
If you had just drawn the object, that meant either:
-- clicking quickly twice in the same place to get out of the drawing tool without drawing another object, and then clicking again to re-select the object that had been de-selected by that double click; or
-- clicking and holding while pressing the shortcut key for the Selection tool, and then clicking again to re-select the object that had been de-selected by that procedure; or
-- clicking on the frame of the drawing window to re-activate the drawing window without de-selecting the target object, and then pressing a Tool shortcut key and beginning the action.
If you had just selected the object or objects, that meant either:
-- clicking on one of the selected objects to maintain the selection set, and then pressing a tool shortcut key; or
-- clicking elsewhere in the drawing and then re-selecting the objects, then pressing a shortcut key; or
-- clicking on the frame of the drawing window to re-activate the drawing window without de-selecting the target objects, and then pressing a shortcut key.
That was all very tedious and annoying, but I assumed it was necessary because the Object Info palette is a different window as defined by the Windows operating system (if I remember correctly, this didn't happen on the Mac in versions 6, 7, and 8).
Then version 9 came along and corrected the problem, proving that it wasn't necessary. As long as no data is changed in the Object Info palette, the drawing window stays fully active and the letter keys are still interpreted as Tool shortcuts. Opening the Object Info palette doesn't interrupt the drawing process.
Now, version 10 has re-instituted the tedious and annoying process described above.
Version 10's user interface has several very gratifying improvements over that of version 9, but could you possibly restore this one advantage of the version 9 interface? Thank you.
jan15
4 answers to this question
