I am trying to change the color of multiple doors on an entire floor at the same time. I use the select similar tool and select the door which selects all of the doors, and In the object info panel, it says 144 door objects in walls are selected. I then click the settings button in the object info pallet to open the door settings box. From here I tell it to set the panels to use material and select the material I want the doors to be (in this case a red oak). I then click the ok button and it returns to the active drawing, but it only updates the Item that I initially Selected. My question is, is this normal operation and if so is there an easy way to go about updating my doors all at once or am i going to have to do each door individually or delete and re-insert all of them?
gangotti
1 answer to this question
