Pascaldh Posted December 12, 2023 Share Posted December 12, 2023 I am using single label in my project. The problem I am having is that the labels rotate with the fixtures. I couldn't found a way to prevent this from happening. I want all my labels to be straight (like channels 101 & 104). Is there a way to make this happen? Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted December 13, 2023 Vectorworks, Inc Employee Share Posted December 13, 2023 If you are using a label legend then you should select 'Right Reading' Are you using a label legend? However, that looks like it could be a data tag. Let us know. Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted December 13, 2023 Vectorworks, Inc Employee Share Posted December 13, 2023 Oh, I don't think this functionality is available with the legend set to single label. Is there a reason you need to set to single label? Data Tags may work better in this instance Quote Link to comment
Pascaldh Posted December 14, 2023 Author Share Posted December 14, 2023 On 12/13/2023 at 12:32 PM, TomWhiteLight said: Oh, I don't think this functionality is available with the legend set to single label. Is there a reason you need to set to single label? Data Tags may work better in this instance The reason I wanted to use single labels, is because they are faster to create and look better in my opinion. I didn't know about the data tags function. I just tested it out and I think it will work for my case. Thank you! 1 Quote Link to comment
