Josh_M_Gill Posted December 8, 2023 Share Posted December 8, 2023 Hello, Is there a way to display both Name and Size within the same Title Block? as of now I have linked text that displays each sheet size name and then have to enter custom text for the size. In the Title Block Manager under Sheet Size Name I see options for Name and Size but not both. Also, I want the unit in "Inches" but when I choose this option it displays decimals up to 3 places. e.g. "24.000/18.000" Would be fantastic if I could customize it to show "US Arch C 18x24" Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted December 11, 2023 Vectorworks, Inc Employee Share Posted December 11, 2023 Hello @Josh_M_Gill, Thanks for the feedback! On 12/8/2023 at 8:56 PM, Josh_M_Gill said: Also, I want the unit in "Inches" but when I choose this option it displays decimals up to 3 places. e.g. "24.000/18.000" Would be fantastic if I could customize it to show "US Arch C 18x24" - I will add a bug about this. There should be no trailing zeroes in the sheet size name display. On 12/8/2023 at 8:56 PM, Josh_M_Gill said: In the Title Block Manager under Sheet Size Name I see options for Name and Size but not both - I will add a wishlist item for this and consider it for future updates. Best Regards, Nikolay Zhelyazkov Quote Link to comment
Tom W. Posted May 28, 2024 Share Posted May 28, 2024 @Nikolay Zhelyazkov if I edit the names of the Sheet Size Names in the TBM (change 'ISO A1' to 'A1' for example), does this get migrated to new VW versions or do I need to edit it again each time I upgrade? Thanks. Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted May 29, 2024 Vectorworks, Inc Employee Share Posted May 29, 2024 14 hours ago, Tom W. said: @Nikolay Zhelyazkov if I edit the names of the Sheet Size Names in the TBM (change 'ISO A1' to 'A1' for example), does this get migrated to new VW versions or do I need to edit it again each time I upgrade? Thanks. The options are saved in the user folder. You can copy them from your old user folder manually if you want to. Is the migration manager not copying them correctly? Quote Link to comment
jpkna Posted October 3, 2024 Share Posted October 3, 2024 Is the option to change 'ISO A1' to 'A1' a new feature? I am using VW2021 and don't seem to have the 'Sheet Size Name' settings in the TBM. Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted October 4, 2024 Vectorworks, Inc Employee Share Posted October 4, 2024 17 hours ago, jpkna said: Is the option to change 'ISO A1' to 'A1' a new feature? I am using VW2021 and don't seem to have the 'Sheet Size Name' settings in the TBM. - Yes, it was added in VW2023 I think. 1 Quote Link to comment
