TonyBalogna Posted December 5, 2023 Share Posted December 5, 2023 I could really use a helping hand figuring out to color a Data Tag based on Data Visualization. This particular use case is coloring a Data Tag that is getting info from the Circuit Name and/or Circuit Number of a Lighting Device. I'm able to color the lighting devices by Circuit Name via Data Visualization with no problem, but I just cant figure out how to get my Circuit Data Tag to take the color instead of the lighting device. In a perfect world, I'd like to get a Data Tag to visualize the Circuit Name and Circuit Number like this based off the parameters of each fixture. Quote Link to comment
markdd Posted December 5, 2023 Share Posted December 5, 2023 It's a bit of a convoluted process and involves two data tags and two data visualizations but it can be done! I'll leave you to take a look at what I did. I feel sure that you will be able to improve on this. Data Vis.vwx 2 Quote Link to comment
TonyBalogna Posted December 6, 2023 Author Share Posted December 6, 2023 Thank you Mark. I'll go through this and see what I can learn. I really appreciate the help. Quote Link to comment
