It seems that walls that have their view properties set when they are below the cut plane stop obeying viewport override settings.
In this example I have a stem wall thats is below the cut plane and has its attributes set to a different class as the wall. In a plan viewport I have that class set to override the fill and it doesn't seem to update the visual properties. This persists even if I change that walls class to said class for below the cut plane.
Is anyone able to replicate this issue? I've attached an example file to demonstrate.
TaylorK
Wall Cut Plane Example.vwx
Edited by TaylorKLink to comment
0 answers to this question
