JonKoch Posted December 3, 2023 Share Posted December 3, 2023 (edited) Hello! This is the first time that this has happened to me so I'm not entirely sure what the source of the problem is really. I am attaching a screenshot of my rendering that is done in "fast renderworks" and the patio area where the to silhouettes are standing appears wavy and undulating. When I switch the hardscape to a style such as brick, I don't see this result. I did make the texture on Architextures.org and then created a material and hardscape so I'm not sure if theres a setting in there that I may have overlooked or maybe it's just the shadows playing tricks on my eyes. It could also be just the orientation of the joint pattern relative to the surrounding hardscape textures? I'm not sure but I'd appreciate any thoughts! I can try and attach a file too if that's helpful but it's quite big. Thank you! Edited December 3, 2023 by JonKoch I solved the problem Quote Link to comment
JonKoch Posted December 3, 2023 Author Share Posted December 3, 2023 I realized I had added noise to the texture used and once I removed it, the surface looks as it should. Quote Link to comment
