Paolo Posted October 14, 2023 Share Posted October 14, 2023 Recently I have released a plugin through Gumroad® called Arches. This plugin written in Python contains a licensing algorithm that queries Gumroad through an url request. The Python modules required are the following: import certifi import ssl import json from urllib import request, parse, error and the core request is the following: def licenseCheck(license_key, user_email, productID): context = ssl.create_default_context(cafile=certifi.where()) webConnection = testInternet() url_ = "https://api.gumroad.com/v2/licenses/verify" pf_permalink = productID params = {'product_permalink': pf_permalink, 'license_key': license_key} data=parse.urlencode(params).encode('ascii') req = request.Request(url_, data=data) try: response = request.urlopen(req, context=context) get_response = json.loads(response.read()) except: # error.HTTPError as e: get_response = json.loads(e.read()) get_response ={'success': False, 'purchase': {'email': user_email, 'license_key': license_key}} status = False if get_response['success'] and get_response['purchase']['email'].lower() == user_email.lower(): status = True else: get_response = "Failed to verify the license." return status, get_response , license_key, webConnection I have deeply tested it on my Mac and upon success I started to sell it. Nowadays I collected some customers and just one of them got the message ModuleNot FoundError: No module named 'certifi I am in contact with this user and I know he runs VW2023 / Windows 10 Pro OS. I have let him make some tests and the weird thing is that while receiving the module not found message, neither he is able to install it (through Marionette.VerifyOrGetLib) because certifi is already installed. I am still waiting other tests I have requested, and in the meanwhile I am asking @Vlado or @K.Lalkovski or any other expert, if the simple script: import certifi vs.Message(certifi.where()) gives error (module not found) or, as in my case (macOS) the module path inside Vectorworks / Python: /Applications/Vectorworks 2023 IT/Vectorworks 2023.app/Contents/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/certifi/cacert.pem Thank you in advance Quote Link to comment
DomC Posted October 14, 2023 Share Posted October 14, 2023 (edited) Maybe you make something like this and skip the certificate update? Maybe it is not necessery to import certifi on windows and the request will work without certifi? And then skip the ssl context part. Edited October 14, 2023 by DomC 1 Quote Link to comment
Paolo Posted October 15, 2023 Author Share Posted October 15, 2023 (edited) I should have fixed the problem avoiding to use the 'certifi' module: context = ssl.create_default_context(cafile=certifi.where()) has been replaced with: context = ssl.create_default_context() context.check_hostname = False context.verify_mode = ssl.CERT_NONE On my mac works well, I am waiting the result on the VW2023 / Windows 10 Pro OS that was giving trouble… P.S.: I have just received a positive response that the new code works fine also on Win 10. Edited October 15, 2023 by Paolo Updated info 1 Quote Link to comment
Vectorworks, Inc Employee K.Lalkovski Posted October 16, 2023 Vectorworks, Inc Employee Share Posted October 16, 2023 Hi @Paolo, I saw you have already found a solution, but here is an example on Windows that finds package certifi. Just open vwx file and run find certifi node. The problem with the module not being found is that certifi for VW2023(Win) is not a direct descendant of the 'site-packages' folder and just the path to certifi needs to be added at runtime. testcertifipresence.vwx 1 Quote Link to comment
