Jayme McColgan Posted September 25, 2023 Share Posted September 25, 2023 is it possible to make a tool pallet that has text fields and buttons and all that jazz? One of the plugins I'm building talks to external gear and I need to dial in some settings every time before sending commands. I originally thought about using a point object but some of the commands require me to select lighting devices in the CAD before sending so I wouldn't be able to select the lights I need and hit a button in a point object OIP. I guess I could do a menu command and have a dialog box pop up every time before sending but that sounds clunky to me... thoughts? Quote Link to comment
Pat Stanford Posted September 25, 2023 Share Posted September 25, 2023 I don't think there is a way to do what you want. You could make the object Event Enabled and then put a button in the OIP that calls a dialog box to do your setup. But I don't think there is a way to have a "tool palette" that shows when an object is selected or created. Maybe with the SDK. I have created scripts that checked for a modifier key when they start and do different things (in my case opened a preferences dialog box) if the Option key is held down when the script it run. Would something like that work for you? Quote Link to comment
Jayme McColgan Posted November 1, 2023 Author Share Posted November 1, 2023 On 9/25/2023 at 11:25 AM, Pat Stanford said: I don't think there is a way to do what you want. You could make the object Event Enabled and then put a button in the OIP that calls a dialog box to do your setup. But I don't think there is a way to have a "tool palette" that shows when an object is selected or created. Maybe with the SDK. I have created scripts that checked for a modifier key when they start and do different things (in my case opened a preferences dialog box) if the Option key is held down when the script it run. Would something like that work for you? yeah, I basically just need to make a tool pallet of buttons and text fields that trigger a script. i didn't think there was a way to do that, thought id ask though. Quote Link to comment
