User parameter of socket in device not showing
MT-Lighting
  • 2 months later...
@MT-Lighting The modern way of adding extra linked text is the same for devices and sockets, in fact for all object that draw the contents of their profile group.
Just enter the profile group, add a text object. In the object info palette find the section ConnectCAD Linked Text Data and check the Is Linked Text box. Select the parameter or attached record file that you want to display. Exit the socket and the linked text shows the value.
You can use the Data Manager to automatically attach a record to all new sockets. There's a video on that in the Did You Know section of this forum. You can edit the symbols Skt_L, Skt_R etc. to incorporate your extra text.
Hope this helps.
Conrad
