MT-Lighting
    7
Everything posted by MT-Lighting
  1. Hey Conrad, Completely mist this one, sorry! Talking about labels for sockets indeed. I wanted to label the ports of a switch with the vlans.
  2. Hi all, I have question about reshaping multiple cables from the cabletool, hope someone knows the answer here! With 3d polygons I can select multiple lines, and use the reshape tool to select multiple vertices and move them all at once. With regular cables I don't have that option. Would this be possible in any way? I also tried the cables from AutoplotTools, and these do have the option to select multiple vertices and move them. Would really help me, as I'm in a project with about 300+ cables.. Thanks in advance! regards, Mark Tober.
  3. @Conrad PreenI will ask in the Spotlight section, good to know it is the same tool!
  4. This works for circuits, but I'm looking for cables in 3d space, if I understand you correctly.
  5. Hi all, I have question about reshaping multiple cables. With 3d polygons I can select multiple lines, and use the reshape tool to select multiple vertices and move them all at once. With regular cables I don't have that option. Would this be possible in any way? I also tried the cables from AutoplotTools, and these do have the option to select multiple vertices and move them. Would really help me, as I'm in a project with about 300+ cables.. Thanks in advance! regards, Mark Tober.
  6. Found the solution in the end, trick is to edit the label style of the socket ('skt_txt_') and add the linked text in this symbol. Still would be nice to have the ability to add custom label styles, so I can make a style for switches, audio-equipment, etc. cheers, Mark.
  7. Hey everybody, I have a question about adding linked text: I have a switch and sockets with the user-parameter 'vlan'. If I add a linked text to the socket with this user-parameter, it doesn't show up once I'm in the device-level. Does anyone have a solution for this? cheers, Mark. Switch example.vwx
