ryanww Posted August 9, 2023 Share Posted August 9, 2023 I'm finally trying this whole cable path thing. When I insert data tags, or generate the annotated riser sheet, I am not getting any of the path run data back. Any ideas? Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted August 9, 2023 Vectorworks, Inc Employee Share Posted August 9, 2023 Hello @ryanww, The data that you see in the tags is just a placeholder. It is stored in attached records in the cable paths. You can edit tag data from the data tags to enter the data that you want or edit the attached records of the cable paths directly or from a worksheet report. Once entered, the data there will remain until you modify it. Let me know if this helps. Best Regards, Nikolay Zhelyazkov Quote Link to comment
ryanww Posted August 9, 2023 Author Share Posted August 9, 2023 Thanks @Nikolay Zhelyazkov - I found that record now attached to the cable paths. The documentation around this is still pretty slim, and where it does exist, it is rather basic.. It would be great to see more videos on this up in the training site, and it would be nice if those can have a filter to explicitly select ConnectCad videos/courses, as they get buried in the other random courses. 2 Quote Link to comment
