Indentation inside PythonExecute procedure
Hi everybody,
I'm trying to use Python code inside Vectorscript using PythonExecute procedure. It works, but when I need to use indentation I receive this error:
Quote
IndentationError: expected an indented block
I tried with different space counts, using tab, and with unicode \u0009 (tab) but nothing works. Indentation characters seems to be ignored. This is the sample code:
procedure test_pythoncontext;
VAR
	check:BOOLEAN;
BEGIN
	check:=true;
	PythonBeginContext;
	PythonExecute('import vs');
	PythonExecute('check_py = vs.GetVSVar("check")');
	{INDENTATION CODE THAT GENERATE AN ERROR}
	PythonExecute('if check_py == true: ');
	PythonExecute('    check_py = false');
	PythonEndContext;
	message(check);
END;
run(test_pythoncontext);
Anybody can tell me if indentation is admitted in "PythonExecute"?
Thanks!
Well, with Pat's input, I'll try again. 😉
Short answer, YES. Python uses indentation, even when submitted from Vectorscript. I typically build my Python code in a text block, then execute it all at once.
However, in your simple case you can do this, which works. It avoids the need for indentation. Not an answer, but more of a crutch.
PROCEDURE test_pythoncontext;
CONST
	Tb = c h r(9);		{ remove extra spaces before running code }
	CR = c h r(13);		{ remove extra spaces before running code }
VAR
	check :BOOLEAN;
BEGIN
	check := true;
	PythonBeginContext;
		PythonExecute('if check_py: check_py = False');
		PythonExecute('vs.SetVSVar("check", check_py)');
	PythonEndContext;
	message(check);
END;
Run(test_pythoncontext);
OR, build everything ahead of time, then execute it like this:
CONST
VAR
	check :BOOLEAN;
	PyCode :Dynarray of Char;
BEGIN
	check := true;
	PyCode := concat('import vs', CR);
	PyCode := concat(PyCode, 'check_py = vs.GetVSVar("check")', CR);
	PyCode := concat(PyCode, 'if check_py:', CR);
	PyCode := concat(PyCode, Tb, 'check_py = False', CR);
	PyCode := concat(PyCode, 'vs.SetVSVar("check", check_py)', CR);
	PythonBeginContext;
		PythonExecute(PyCode);
	PythonEndContext;
	message(check);
END;
One benefit of building your python code this way is you can print your PyCode variable to examine it while you are debugging.
For short snippets, use:
AlrtDialog(PyCode);
Or for longer snippets, use:
MoveTo(0,0);
CreateText(PyCode);
When it looks correct, then you can execute it.
HTH,
Raymond
Edited by MullinRJ
