setting active class
What is the vectorscript function to change the active class? I have written a script to make several parts and would like them to take on the class attributes. when I move them to with SetClass(H2, 'LAMINATE' ); for example, They move to the correct class but do not take on the pen colors.
You probably also need to use the ByClass functions to set the object to use the Class attributes:
LSByClass - Line Style
LWByClass - Line Weight
FillColorByClass
FPatByClass - Fill Pattern
OpacityByClass
MarkerByClass
PenColorByClass
Or if you have already created the object there are Set functions (SetLSByClass, etc) that you can use to change an existing object to use the Class attributes.
Search for ByClass in the Function Reference to see all the options.
