xlp3336 Posted June 18, 2023 Share Posted June 18, 2023 How to arrange multiple identical buildings on one site, when one of them is modified, the others are automatically adjusted. thanks! Quote Link to comment
Pat Stanford Posted June 18, 2023 Share Posted June 18, 2023 Others will probably explain this better, but three possible solutions 1. Make the Building a Symbol. But then you have to Edit the Symbol to be able to make changes. 2. Draw the building using the layers and classes you need and then create a multiple Design Layer Viewports to place the buildings on site. 3. Similar to 2, but draw the building in a separate file and use Referenced Design Layer Viewports to bring in as many copies as you need. 4 Quote Link to comment
xlp3336 Posted June 19, 2023 Author Share Posted June 19, 2023 5 hours ago, Pat Stanford said: Others will probably explain this better, but three possible solutions 1. Make the Building a Symbol. But then you have to Edit the Symbol to be able to make changes. 2. Draw the building using the layers and classes you need and then create a multiple Design Layer Viewports to place the buildings on site. 3. Similar to 2, but draw the building in a separate file and use Referenced Design Layer Viewports to bring in as many copies as you need. I used to do this only by arranging blocks, but I didn’t expect that buildings can also do it.Thank you so much! Quote Link to comment
