Ed Wachter Posted June 15, 2023 Share Posted June 15, 2023 A "Framing Member" can model a wood I-Joist is we choose Wood Floor Truss under Type and select Use Solid Web. However it appears that we need to select Rafter under Type to get plumb cuts at the ends of a sloped I-Joist. Have you found an easy way to model a sloped I-joists with plumb cut ends? Thanks, Ed Quote Link to comment
