irenao Posted May 4, 2023 Share Posted May 4, 2023 If I change the Text Style for Sys-CircuitNumbers I have to nudge every single cable for this change to be visible. Is there another way to update all circuits when I change the text style for circuits? Quote Link to comment
Pat Stanford Posted May 4, 2023 Share Posted May 4, 2023 Try the Reset All Plug-ins command. Screen shot is from VW2023 Designer workspace. 1 Quote Link to comment
irenao Posted May 10, 2023 Author Share Posted May 10, 2023 Thank You very much! It worked. Now I have to read more about plug-ins because I really do not understand why it worked. Quote Link to comment
Pat Stanford Posted May 10, 2023 Share Posted May 10, 2023 You probably shouldn't have to do this. If you change the Style that is used by a PIO instance, it should automatically apply that change. Nudging the PIO forces it to reset itself. ResetAll just forces that reset on all the PIOs instances in the drawing. It is just a way to force VW to make sure everything is up to date. Kind of like double tapping the H key (standard workspaces) or double clicking the Pan tool forces a screen redraw. Quote Link to comment
