Steven Morgan Posted May 1, 2023 Share Posted May 1, 2023 Is there a way to detect when a file is saved in an Event Based plugin? Looking to export a XML file anytime the document is saved. Or a DoMenuTextByName('Save',0) = TRUE then execute but I know that's not the correct syntax. Thanks! Quote Link to comment
Hippocode Posted May 1, 2023 Share Posted May 1, 2023 Vectorscript based tools/menu commands only live within their own event. They can't catch other events unless they are triggered. You can do this with the SDK. You could still keep the XML export as a vectorscript and make a small SDK project that triggers a vectorscript/menu command on a specific event. 1 Quote Link to comment
