Travis Pagels Posted March 14, 2023 Share Posted March 14, 2023 I am sure this is simple fix but I have researched extensively, and I cannot seem to find a solution. I am making this as simple as possible to try and nail down the issue... I add three truss sticks, three hoists and two lights. Change trim to 20' and ensure hoists are connected. "System check all objects" and everything is green and connected. However in the calculation overview, hoist workload is showing 0%. And when I add a hoist data tag containing Load, it shows 0lbs. The truss system shows the correct "Total Hung weight" but the I cannot get the hoists to display the loads. I am trying to get this nailed down on a small scale before implementing on a large project with much more involved. 1777654789_BWTest.vwx Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted March 15, 2023 Vectorworks, Inc Employee Share Posted March 15, 2023 The system check command doesn't do a braceworks calculation, it only checks that the system is ready for calculation by looking for errors like disconnected hoists or lights. You need to run a full Braceworks calculation for the system to calculate the loads on each hoist and hanging point. Quote Link to comment
Travis Pagels Posted March 15, 2023 Author Share Posted March 15, 2023 I read that in another thread but I cant seem to find that command anywhere in the Braceworks menu or workspace editor. Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted March 15, 2023 Vectorworks, Inc Employee Share Posted March 15, 2023 All the Braceworks calculation commands should be in the Braceworks menu, the top 4 options in the menu Calculate all objects Calculate load combinations Calculate visible Calculate selection Are you using a custom workspace? Quote Link to comment
Travis Pagels Posted March 22, 2023 Author Share Posted March 22, 2023 I don’t have those options and I don’t see them in workspace editor to add them. Yes I am using a custom workspace. Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted March 22, 2023 Vectorworks, Inc Employee Share Posted March 22, 2023 Normally the only reason these commands don't show up is if you don't have a Braceworks license, but since the Braceworks menu is displaying you should have Braceworks. I'm sorry but this is not something that I can help with here on the forum, please contact the US tech support Either use the link below https://www.vectorworks.net/support/help or phone 443-542-0411 or email tech@vectorworks.net Quote Link to comment
