Vectorworks, Inc Employee klinzey Posted February 17, 2023 Vectorworks, Inc Employee Share Posted February 17, 2023 Vectorworks, Inc. has released a Service Pack for Vision 2023 (SP3.1). This Service Pack includes targeted fixes to address a file saving issue. Vision SP3.1 fixes file saving issues with XFroms and when using non-default textures. Users should use Save As when saving a file after the file has been opened in Vision SP3.1. If a file is opened with SP3.1 and textures are missing, the textures will need to manually assign in the document. When opening a file saved in Vision SP2/3 in SP3.1 and everything looks correct, Save As should be used to ensure the file is saved properly with the textures embedded. If textures are missing, you can fast track the manual restoration process by placing all missing textures in a textures/scene folder alongside the .vsn and then reopening the file, this should cause the textures to automatically load into the file. This requires the textures to be identical to the ones in the original file(same hash) so it may not always work (if you no longer have the exact texture used). Save As should also be used in this case to save repaired file. This Service Pack is available for all licenses as a downloadable updater. To install the Service Pack, please select "Check for Updates" from the Vision menu (Mac) or Help menu (Windows) or download the full installer from your customer portal. Quote Link to comment
