Hey There, this is behavior I've noticed since 2021 but figured I should bring this up as I'm starting to make the transition to 2023 and this is the first thing I've tested.
When adding Data Tags to a viewport annotation layer the auto placement only seems to work on views that are using orthogonal view. If the viewport has any kind of perspective view (like Normal or Wide view) the data tag association seems to completely break and things the objects you're looking at are still in some other orthogonal seeming view. Basically attempting to attach data tags to a viewport that is not orthogonal is extremely annoying if not impossible due to the object highlights not appearing where the objects you're looking at are on screen actually are.
techecc
Am I missing something here?
440792885_DataTagPerspectiveError.vwx
0 answers to this question
