neurain Posted December 5, 2022 Share Posted December 5, 2022 (edited) I have a license related question. I want to switch my license from my current laptop to a Mac Pro. What should I do? It keeps running in demo mode. The vision has been deleted from the previous MacBook. Edited December 5, 2022 by neurain Quote Link to comment
Vectorworks, Inc Employee bbudzon Posted December 5, 2022 Vectorworks, Inc Employee Share Posted December 5, 2022 When you installed Vision on the Mac Pro, you should've been given an option to provide a serial number. If you did, then Vision should spawn a dialog at startup that requests that you Activate the license. That is all that should be required. If you installed Vision without providing a serial number, then you can launch into Demo Mode and go into the Vision Preferences. In there, is a Session tab. Here, you can provide your serial number. Vision will likely spawn a dialog that asks you to Activate the license, which is required to get things working. If you are having trouble inserting your serial number into Vision or activating your license, you can try contacting VW Tech Support. They should be able to help you further. I hope this helps! Quote Link to comment
