29 -
Everything posted by neurain
This is where the problem continues to occur intermittently recently. The situation happens so randomly that I don't know exactly what the problem is, but when I complete the drawing, organize the viewport, and publish it, the page suddenly switches from landscape to portrait and breaks. If anyone has experienced this problem, I would appreciate your advice.
After creating vectorworks schematic views, I have a question. Right now I left the image while uploading it, but the whole object seems to be rotating. I want my fixtures to look like they are in 3D, but I'm wondering how to do that. (In 2D state...)
Where should I ask for equipment asset requests? I'm not sure if I should ask a question here, but I'll ask. The version I am currently using is vectorworks2022 (Spotlight). I would like to request assets for ETC Halcyon Platinum, Chauvet Rogue Outcast 1L, and CKC V15. 2, should it be called 3D drawing? I'm not sure what we define as, but I need an instrument symbol, where should I request it? I'd like to make it available in Vision. "CAD File X" 1. ETC Halcyon Platinum https://www.etcconnect.com/Products/Automated-Lighting/Halcyon/Features.aspx 2. Chauvet Rogue Outcast 1L https://www.chauvetprofessional.com/products/rogue-outcast-1l-beam/ 3. CKC V15 http://www.ckclighting.com/chanpinxilie/ygxl/2021/0604/227.html
Hello, I have a question regarding DMX set transform, so I post it on the forum. As shown in the photo material, changing the XForm Rotation Axis completely flips the position of the set. Also, when operated with the console, it is impossible to rotate in place. In this case, I would like to ask if there is a solution. In-place rotation is possible when a normal rectangle is placed, but I would like to know how to rotate in-place when there are so many geometries.
I am using Vision Unlimited and I have a question.
neurain replied to neurain's topic in Vision and Previsualization
Sorry I found that function. Thanks for the quick reply :) -
I have a license related question. I want to switch my license from my current laptop to a Mac Pro. What should I do? It keeps running in demo mode. The vision has been deleted from the previous MacBook.
Confirmation is required. It may be my greed, but the strip-type LED tape is different from the actual expression. For example, the Martin VDO Sceptron 10 (320mm/1m) looks different from real lighting because it doesn't affect the real environment. In fact, what I want is to influence the surroundings like an LED Bar. (Of course the light on the VDO will be soft though.)
I'm talking about your LED tape. There is a situation where you need an asset that can be partially turned on as a pixel type.
I didn't ask because of other issues, but I was told that there are limitations to practical lighting. So, the idea was that if the scale of the lighting provided by the current vision was reduced and installed on the set, it would be possible to solve it.
Is it possible to resize the fixtures in the vision? I wonder if there is a way to set an arbitrary scale and make it smaller.
I want to know if the universe of Vision is limited. I would like to know if there is a space or parameter limit in the vision as it uses less fixtures than when operated with other previs systems. And I'm testing the Elation chorus line 16, and there is a system delay when using only the equipment. I wonder if polygons or other sources are optimized. I ask for a solution.
Will there be a way to drive the projector in Vision?
I want the clear light from the projector to look like a illuminator. And if this is solved, I think that projection mapping can be implemented more precisely. -
It has been confirmed that the vision has a laser function. Currently, there are only basic green lasers or RGB lasers, so I was wondering if there is a library for the product I linked to. https://minuitune.com/products/ivl-square/
Will there be a way to drive the projector in Vision? I checked the area due to the NDI output, but I tried using the projector symbol in Vectorworks, but it is recognized only as an area, not a projector. The projector should be buried in the projection the same as the light, but it is not expressed that way, so I ask a question.
Thank you also for your first reply 🙂 It was a light source that has not been developed yet. After researching the forums, more and more people are using light sources such as LED bulbs, tubes, and strips. It looks like an update is needed, is there any scheduled period? In the near future, besides fixtures, I would like to use such a small light source in a performance previs system as well.
It is not that I did not think of this method, but it is the same as the tube lights provided internally by Vision. And the line itself only has light, it doesn't affect the surrounding environment. I would appreciate it if you could guide me on how to do it if I want to get the effect of illuminating the surroundings when the neon is turned on.
When using Vectorworks Vision, it turns itself off when a signal is given I used the Martin VDO Sceptron 10 1000 provided by Vectorworks, and when I click the device, it crashes for an unknown reason and ends. The same thing happens when you give a signal via Artnet. I want to know the reason. IMG_7802.MOV
