Jeff.Sullivan Posted November 10, 2022 Share Posted November 10, 2022 What am I doing wrong with Modular frames? This is not what the help tells me should be here or even how it should work. The only workaround I have found is that I can change the height of the frame, and it will squash in like the router above. Quote Link to comment
Edward Carlson Posted November 10, 2022 Share Posted November 10, 2022 It looks like you haven't made a frame, but a module. The top of the Object Info palette probably says "Equipment Item." You're setting the number of slots your equipment takes up, not creating a frame with 21 slots. In Tool Sets > Layout tab > Rack Frame tool, you can create a frame and define the RU height and slots. Then drag the equipment item into the slots like you would with rack items. 3 Quote Link to comment
Jeff.Sullivan Posted November 10, 2022 Author Share Posted November 10, 2022 Thanks That worked! 1 Quote Link to comment
