Wire Labels
Spitfire
15 hours ago, Spitfire said:
Hi Nikolay,
That worked, but... I needed to 'bump' (move) the objects in order to see the changes.
- You can try using Reset All plug-ins menu command for easier redrawing of the circuits. We will see if we can make this happen automatically without the need of reset (move, bump).
13 hours ago, Nikolay Zhelyazkov said:
Hello @Spitfire,
The cable field is using the circuit object class, so whatever class your circuit is in, this is the class you can add text style to in order to modify this text.
P.S. By default, circuits go in the CC-Circuit-Signal-<circ signal> classes.
Best Regards,
Nikolay Zhelyazkov
Hi Nikolay,
that worked, thanks.
