Daniel Dickman Posted October 18, 2022 Share Posted October 18, 2022 Is there any easy way to find and select all the devices of the same make and model? I'm thinking similar to the Spotlight find and modify tool, but I can't seem to use that tool for ConnectCAD devices. Using VW2022. Quote Link to comment
Pat Stanford Posted October 18, 2022 Share Posted October 18, 2022 Take a look at Custom Selection in the Tools menu of the default workspaces. It will let you specify a criteria and then select objects that meet that criteria. This is one (or more) steps up from Select Similar. If you think you will need to use that group of objects again, make sure you save it as a script so you don't have to set the criteria every time. HTH Ask again if you need more info. 3 Quote Link to comment
Daniel Dickman Posted October 18, 2022 Author Share Posted October 18, 2022 Thanks Pat! Quote Link to comment
