Daniel Dickman
Content Count
65 -
Community Reputation
10 GoodAbout Daniel Dickman
Rank
Apprentice
Personal Information
Occupation
Lighting Designer
Location
United States
Recent Profile Visitors
589 profile views
Yes that's it! Excited to see where you head with this!
In the instance of devices inside an enclosure, I think I'm less concerned with where it is inside. Just that fact that it IS inside. But it is an interesting thought regarding designing an enclosure layout. It would be cool to design their layout similar to how we do CTP panels with a front view. As far as the Location hierarchy goes, Buildings would be at the top level... Inside Buildings are Rooms.....and Inside rooms are Racks or Enclosures.
Just sent you an email.
Hey friends, I'm working on a show where we have a number of devices in Hoffman style enclosures. Is there way where instead of placing gear inside a rack, I could define another location? (In this case an enclosure. Also along these lines, in addition to room/rack/enclosure I'd like to define a building where specific rooms are located. How would I go about this? I imagine I could just use custom parameters to define some of these locations, but it would be cool to have other versions layout room tool for buildings or enclosures. Thoughts?
Speaking of Arrow Connections.... I've been working on drawing up lots and lots of fiber cable and associated OTPs. I'm curious, is there a way for me to use 1 arrow connection for multiple circuit lines? For example lets say I have a 24 strand fiber cable, in ConnectCAD I would like to show each strand landing at it's respective port on an OTP but for clarity I am bussing the circuits together to better indicate that this is indeed just 1 cable. Here is an example of what I'm thinking (this is mocked up). My thinking is that I would like the ability to have 1 arrow connection for all strands in that cable, and the arrow text would indicate what OTP it is landing at and the associated ports. Currently using arrow connections looks like this. At first glance this could be mistaken for 24 different cables. Any tips for using arrow connections on multi-circuit cables?
Custom Workspace - Spotlight+ConnectCAD
Daniel Dickman replied to Daniel Dickman's topic in ConnectCAD
Here is the combined Spotlight-ConnectCAD workspace if anyone would like to use it. Spotlight+CC.vww -
That did the trick! So what exactly is happening there that allows 1 menu item in the workspace editor to then appear as 8 different menu items in the actual menu? Thanks Conrad! -
I'm working on building a custom workspace that combines Spotlight and ConnectCAD. I've recreated all toolsets and menu items but I can't figure out how to add the various report commands to the documentation menu. I imagine these are either scripts or plugins.. does anyone know how to add these to a menu in the workspace editor?
Is it possible to create a report that shows which devices are connected to a particular device? The specific example I am thinking of is for network switches. I would like to create a report that tells me which device is plugged into which port on the network switch. The challenge here is that VW/ConnectCAD will need to ignore the passive devices such as Data Term Panels that are between the switch and the end devices. Any thoughts on how to accomplish this?
Great, thanks Nikolay
Hey friends, I'm experimenting with the rack frame tool in ConnectCAD 2021. I've added a couple frames and populated them with gear. When I attempt to create a rack frame report, the worksheet is always empty. What am I missing here?
Hey VW team, Where can we find a comprehensive list of new features and improvements for ConnectCAD 2021?
Grouped "Term Panel" sockets do not update circuit lines
Daniel Dickman replied to Matthias Sch.'s topic in ConnectCAD
+1. Would love to see this -
In the image below, I have a data cable created from the "Make Data Chain" function. As you can see the cable is 7'2" long but VW is breaking it into two 5' cables instead of one 10'. Is this expected behavior?
Schematic View 3D Rotating (Booms)
Daniel Dickman replied to Daniel B. Chapman's topic in Entertainment
Thanks @markdd! I finally have this working. The part that I was not understanding was that I needed to convert to hanging position in plan view with the ladder flat on the ground prior to rotating into place. I now realize that, that this particular detail was what started this entire thread from the beginning. But for some reason even after reading all of these posts for the last couple months, I just could not comprehend drawing 3D geometry in this way. Thank you everyone for all of your help in this thread.
