DeuxDesign
New Cinema4D plugin problem
Hello,
I'm curious if any one has received the new version of the
plug in and it's working fine? Maxon tech support is looking into it but I was wondering what others experience if any has been. My set up is Mac 10.3.4, VW 11 and Cinema4D 8.5.
The older plugin works fine but the new version after the export wil not open in C4D, it says the file is of unknown file format. Does anyone have a machine running similar configuration and everything exports and opens ok? If anyone doesn't know the plug in is a free upgrade, you only pay shipping and handling.
Maxon support only has machines running 10.2.8, so they
can't fully test the problem to see if it Os related? Has anyone
at VW tested the plugin under 10.3.4?
Dennis Dix
Deux Design
Cincinnati,Ohio
The only thing I can offer is to double check and make sure that you are opening it with C4D 8.5 as this will happen if you try and open a file created with the R2 plug in with 8.2.
Also open your prefences in C4D 8.5 and check and see if there is an option for scaling. This will indicate that it is the correct R2 plug in and installed correctly.
C4D when I go to about says v8.503 oxygen.
Checked the preferences and for VW Import :
Default Texture Projection set to spheric
Scale Factor set to 0.
At the present time I have the R1 plugin running in VW
and any file I export from VW works fine.
If I switch and use the R2 plugin the export seems
as It is working normally but C4D will not oppen the files
giving a warning unknown file format!
I'm surprised that Maxon tech support doesn't have a
machine running 10.3.4, they said it a paid upgrade so
they can't put it on their machine, It would seem as much as
C4D costs they could afford one copy of panther to test
problems. I hope the sames not true at VW tech support?
So is the problem in OsX 10.3.4 or VW 11 - C4D 8.5?
I'm having the same unknown format error. just upgraded to C4D 8.5 and exchange R2. Yes! I put the appropriate file in the VW folder and my workspace option works. itsreading the file in C4d that is the problem. Anyone have success yet?
No problems here. I had another user on the phone yesterday with the problem described above. I made him trash (a) all the plugin parts related to VW in the C4D plugin directory and (b) all the plugin parts related to C4D in the VW plugin directory, © made him launch the plugin installer again, this time SELECTING the C4D folder (installation target), (d) made him put the correct plugin parts in the VW plugin directory and (d) made him rebuild the workspace in VW. Worked like a charm. All the other users (around 20 with the new plugin) never reported the described problem.
Cheers,
BaRa
Bara,
Once again you save the day. trashing and re-installing worked like a charm. Thanks
BaRa,
Maybe I'm missing something, but I went through everything you
stated above- removed everything from both VW and C4D that
related to the plugin plus before re-installing I had the installer
run the uninstall program just to be sure. Then reinstalled the
plugin copied the plugin to the VW plugin folder made a new
work space and I still get the same Unknown file format? This
brings me back to my question I notice ola is running VW 10.5.1
and this worked for them but I'm running VW 11.0.0 and I keep
having the same problem opening the file in C4D? Also I noticed
that down in the left corner of the export dialogue box it says:
Cinema4D export verision 10.5.5, does this mean that it isn't
reading VW11 files correctly?
ola's set up shows OsX 10.3.4 isn't the problem, so does someone using VW11 not have this problem?
Curious BaRa what version of software are you running?
I found out the problem!!!
There was another folder that needed to be removed.
I had thought I removed everything but I was only looking
and dealing with the "exchange plugin" folder and there
was another in the following search path:
\ Maxon \ Cinema_4D_R8 \ plugins \ VW_Imports_R8
remove it but leave the folder that says VectorWorks if
you have installed the R2 plugin.
On a side note trying to workout this solution I came across
a thread about changing the units in both programs to similar
formats ie: centimeters, inches , it helps the correctness of
scale on imports/exports. Makes sense!
Denis,
I'm glad you got things to work. where can I find the scaling information you describe? Thanks
in C4d when i go to preferences/ import/export / import vectorworks - the field is balnk, there are no options for scale. whats up with that?
I am trying to export from VW11 to Cinema 4d 8.5 and Vectorworks keeps crashing, is this part of the same problem that is described above or is this a different issue. Any help gratefully received, I have an urgent project to complete and am slightly stuck
many thanks
Dan
