spettitt Posted September 27, 2022 Share Posted September 27, 2022 Hello, I have just made a set of hoists in our library to match our company standards. Quite often in the lifespan of a rigging plot, it's necessary to swap hoists to a different type (ie availability). However, I can't see any easy way to, say, select all 5 hoists on the LED screen truss and replace a '1T Video Down' with '1.6T Video Down'. All I can see is to manually redraw them, but this looses all of the user-inputted data (ie Hoist ID and other bits) for those hoists. Is there an equivalent to the 'Replace Lighting Device...' hidden somewhere? If not, can I put it in as a feature request please? Having done probably thousands of rigging plots, I can say that this is a feature that would be used *a lot*. Thanks, Simon Quote Link to comment
PatW Posted September 28, 2022 Share Posted September 28, 2022 With the new hoist you can use the "Select Symbol" Button in the OIP. If these hoists are legacy vectorscript Hoists they can be upgraded with the command: Tools->Utility->Convert Old hoists. regards, Patrick Quote Link to comment
spettitt Posted September 28, 2022 Author Share Posted September 28, 2022 Ah perfect thanks! I thought that would just replace the visual representation with that of another symbol, but does indeed do what I want. Thanks! Simon Quote Link to comment
