ecoteri
    4
Everything posted by ecoteri
  1. the Vectorworks Service Select video can be found here http://serviceselect.vectorworks.net/training/tips-tricks Partway down the page - Origins in Vectorworks. Teri
  2. Hi Troy there is a knowledge base article that you should read about origins - it helps to explain all the different bits (and why moving the page a long way from the original origin is not recommended) http://kbase.vectorworks.net/questions/1147/Origins+and+Large+Coordinate+Values Also, if you import ONE file and centre after import, then import the next file, the second file should align properly (don't centre the second file?. when you centre the FIRST file, it moves the user origin. then when you bring in the second file it uses the MOVED origin to line up. Teri
  3. James, how did this testing go? we have a school interested in using Vectorworks and then later moving some files to WYSIWYG and I am looking for insights to share with them.
  4. try going iApplications>VectorWorks 12.5.3>Plug-Ins>VW_Arch>Data> In this folder there are probably a series of folders called Prefs_01, Prefs_02, etc, as well as a folder called Prefs_Def Drag all but the Prefs_Def out to another location. relaunch VectorWorks. See if you now have the options in your space object Regards Teri
