1,890 -
Posts posted by Tamsin Slatter
You can create terrain by drawing a polygon and running the Site Model from Boundary command. Once created, you can edit the 3D surface of the terrain, and use the sculpting tools to create swales, berms, raise and lower points, edges and triangles. You can push and pull an area with a set radius and falloff value.
All of these changes will update the 2D also, and maintain track of the cut and fill.
And then Livesync to Lumion...
What are we missing?
Ah - I see it's a third party product. I note that their contact details are on the listing. I think it's probably best to contact them directly and see what they have.
I'm afraid I don't - I will look into it.
Vectorworks 2020 imports Sketchup files up to version 2019. In Sketchup, save the file as a 2019 file and it will import into Vectorworks.
- 1
Window > Palettes > Visualization
Are all the light sources turned on? By default, Lighting Instruments contain light sources that are not turned on.
3 hours ago, Pat Stanford said:
You can use the Fundamental workspace even if you have a Design series license, so it is not unusual that it would work for you.
I am certain the VW will give you an upgrade price if you want to go back to Architect as an adder to the Fundamentals you already have.
Correct - switching to the Fundamentals workspace when you have an Architect licence will still give you access to Architect functionality - it is the serial number that determines this, not the functionality. I can assure you that this functionality has not been removed from Fundamentals.
Rotate Plan is Design Series functionality and has never been available in Vectorworks Fundamentals. Here is the article in Vectorworks Help that describes the functionality. The D beside the heading denotes this as a Design Series (Designer, Architect, Landmark or Spotlight) capability.
If you now have Vectorworks Fundamentals only, but can see the tool, it may be that you have migrated your user folder and workspaces from an earlier version, but the tool will not work in Fundamentals. I'm afraid it has never been part of the Fundamentals package.
This architect in Vectorworks Help lists all commands and tools and their availability in the different design series products:
http://app-help.vectorworks.net/2020/eng/Commands_Tools2020.pdf
- 1
I am unable to reproduce this - my Existing Trees pop straight to the surface of my site model (and I have not experienced a problem with this in the past either). I don't have to use Send to Surface.
If you would like to post the file, I will take a look tomorrow.
Edit the tag properties of the Existing Tree and make sure the tags are assigned to a separate class from the Existing Tree itself. Then make that class invisible.
- 1
If you don't specifically need the GIS stuff, this should be fine. Just make sure that you have the same user coordinates over the internal origin, across all the project files.
But... if you are interested in looking at the opportunities that the GIS options offer, please let me know and we can schedule some time in the diary to take a look.
If you would like me to talk you through georeferencing in more detail, please let me know.
HI
Yes - in 2020, the template files are georeferenced by default. In a Georeferenced file, the Easting and Northing reports the coordinates from the geographic coordinate system, rather than the equirectangular X and Y cartesian coordinates. But, there are two options you can take to resolve this:-
Retain the georeferencing (in UK files, the default is EPSG 27700 - British National Grid), and align the User Coordinate System: Tools > Origin > User Origin - and choose the option Set User Origin to Match the Georeferencing Coordinate System.
OR - If you don't want the georeferencing at all, choose File > Document Settings > Georeferencing, and uncheck the first checkbox.
All the best
- 1
Select all the individual plants of the same type, then run Landmark > Change Plant Grouping. This will convert them to a group with a single tag.
I can help you with this Lisa! I'll give you a shout...
- 1
Spot on @Pat Stanford
In 2020, the Easting and Northing values are reported from whichever GIS coordinate system is active in the file (new in 2020).
But it's easy to resolve. If you are not using GIS, go to File > Document Settings > Georeferencing and uncheck the very first option at the top of the dialogue. The Stake will now display Easting and Northing the same as X and Y.- 2
Forgive me if I have misunderstood the question, but would Model > Volumetric Properties help? This command gives you the option to include a 3D Locus at the centre of the geometry as well as providing other information such as surface area and volume.
Absorption distance is the setting that gives darker effects on glass when it's viewed from different angles. Have a look at that setting. If you change it to zero you may be able to remove the effect you're seeing on the fillets.
Oh excellent! I'm delighted to hear all is well.
- 2
Would you be able to share the file? I'd like to take a look.
- 1
To stop the values summing, click on the small arrow at the column header. Then, uncheck Sum values.
On 5/26/2020 at 5:12 PM, fabrica said:
brilliant! virtual pint on the way to you once pubs open again!
Can I come, even though I failed to solve it?
- 1
Genius @Pat Stanford! Thanks for resolving this. I had a go at it, and got as far as reporting on all the fields available in the Wide Flange record, but didn't explore the idea of the Custom Size to get the data into the relevant fields. Thanks so much for your help.
Caitlin, is the polygon closed? If so, try drawing it as a polyline and have it not quite closed. Then convert it. Does that make a difference?
Terrain --- Sandbox
Posted
Just re-read your comment... have you used the sculpting tools in Vectorworks? What is it that you don't find easy about them?
