100 -
Everything posted by James Dawson Design
I have created a model of a small courtyard that contains hardscapes and extrudes converted to Auto Hybrid objects. When I view the model in Top view I see everything. When I toggle to Top Plan, some of the AutoHybrid objects disappear. All the AH objects are essentially the same. Created as follows. 2D object -> Extrude -> AutoHybrid. With all 3 object types created on the same class for the object. I have attached 2 screen captures to demonstrate. The missing items are some of a pergola structure that sits over a square deck area. The highlighted objects on the perspective is what is missing.
Saved Views - classes turned off
James Dawson Design replied to James Dawson Design's topic in General Discussion
Thanks, so wont apply for automatically created classes , like when you import an architects drawing, or use a new wall type? I may have to take "line-weight" approach and manually make the change after the import of base drawing info.- 10 replies
I have had this problem for ages, at least with VW 2024, but I think also 2023. Been working with VW support in Australia, no solution. My current workaround is to select menu item Tools>Workspaces and select the workspace you currently use. This seems to reload things. First I started thinking it had something to do with Mac operating system or video card on my Mac Mini I think we now have a bug.
Hi, I have started using pre configured saved views in an attempt to streamline my workflow. The area of most value has been the setting up of which layers and classes I have visible. What I have discovered is that during the process of drawing, any newly created classes are set to 'not visible' by default. For example, when I choose a particular wall type not used before and classes are created, they are turned off in all the preset saved views. Is there a way to set the default to have newly created classes 'visible' Or am I going to have to create a new template file thaws these walls and other objects in them? TIA James Dawson
- 10 replies
Hi I am not sure if this is a question for VW or Lumion. I am using the VW-Lumion live sync and loving it. At the moment I am limiting myself to creating the renders in one session as I cannot work out how to reopen and continue at another time. I save VW project and save the Lumion file, from there I have no idea how to open up things and continue.
q
You may want to check this out.
Assign class to a plant
James Dawson Design replied to James Dawson Design's question in Wishlist - Feature and Content Requests
@Frank Brault Ah, I have landscape areas set up as "red symbols". It is how I want the plants to work. I have created a red symbol from a plant object as as a plug-in object and set the assigned class to "Design Plants". However, when I place the symbol, it is placed on the active class (in this instance "Design Building"), not the assigned one. I have attached my Create Symbol settings. (added later)...I have completed more investigation and confirmed that the Assign to Class option does not work for landscape areas either. How I get landscape areas to be assigned a class is to edit the 2D component of the red symbol and set the class there. This class is held and used when you place a landscape area, no matter the active class. I am unable to this with the plant. I can edit the 2D component, however cannot change the class from 'none'. -
James Dawson Design posted a question in Wishlist - Feature and Content Requests
Hi, I would love to be able to place a plant and it automatically assigns to a class, regardless of the current class setting. -
Keynotes sort function missing in 2020
James Dawson Design replied to James Dawson Design's question in Troubleshooting
Got it, thanks. -
Was the remove gaps function on the OIP allways around? I have never seen it before and would use the old and now missing Sort button on the keynote manager. Thanks James -
Hi, The Keynotes sort function seems missing in 2020. I n previous versions I would use this to clean up erroneous lines that appeared. I have attached a screen capture showing what I have. Good old "Sort" would clean these up. My workaround is to change all callouts back from keynotes then add them again. Thanks James
Worksheet creation for symbols with records
Sorry for the late reply Pat. Here is the conversation I had with Julian at OzCAD, I thought this would be better than trying to clearly explain the solution. ME Hi Julian, Thanks for the help over the weekend. Unfortunately, I am still wracking my brains over this. I have attached a file that has the lighting symbols and records. I have spent the morning trying to create this simple worksheet. The trouble I am having is getting all the record items with the same name, i.e. ID to appear in the same column. i.e ID Description Amount L1 Accent Light 4 L2 Pond Light 2 Any thoughts? maybe I need to take a different approach? JULIAN My initial thought is, why do you have all those separate light records with identical fields? This is just going to make everything much harder and the worksheets trickier to program. What you should have is a single record with one additional field where you set the type (Accent, Path, Hanging, etc). Then in the worksheet you could sort by the type field so that each type would be grouped together. Is there a reason not to do this? ME Oh, maybe I am not understanding records correctly. If I attach a generic lighting record to a specific lighting symbol and then populate the fields with values for that specific light, will the values entered remain each time I use the symbol? JULIAN Yes. Record data is unique to either the symbol definition if using symbols, or any object on the drawing you attach the record to, including symbol instances. If you want to build a set of lighting symbols with data already attached, then you do it by editing the symbol and with NOTHING selected within the symbol, attach and edit the record. By design, this will NOT affect data in existing instances of that symbol, so you need to set all this up before you start placing the symbols. ME Great, thanks! Reading this, I don't even know why I did what I did! -
No responses required. My question has been resolved by the good people at Ozcad. -
James Dawson Design posted a topic in General Discussion
I have created a series of landscape lighting symbols that have records attached. For example; ACCENT LIGHT symbol has ACCENT LIGHT record attached POND LIGHT symbol has POND LIGHT record attached Each unique record type have the same fields, eg. ID, Item, Supplier, Model, etc. But the fields differ in values. I am trying to create a report that tables the symbol record field values and quantities. i.e ID Item Supplier Model Amount L1 Accent Light Acme lights 1234 4 L2 Pond Light Alpha lights 5678 2 I have just sent this through to Ozcad support, but thought I would cast the net a little further. Maybe I need to take a different approach? I have attached a file that shows the symbols and records. Thanks in advance James Drainage sandpit 1.vwx -
I would like to create a drawing list for the cover sheet of a plan set. I see there is a preformatted report for VAA title blocks, however, I use Title Block Borders. I have tried to create my own report but am really stabbing in the dark wrt the record values. The list will display Drawing No. Drawing Name, Scale thanks in advance
Is there any ability to control the opacity of the landscape area fill without impacting the it's tag?
VW 2018 Crashes when using Revise/Issue/Print function
James Dawson Design posted a question in Troubleshooting
Running VW 2018 on Windows 10. Revise Issue Print function does not work. Behaviour is that it indicates "Not Responding" on the dialog and you get the spinning blue circle of death. Need to force quit to exit. Happens when printing one or multiple sheets, happens when printing to printer or generating a PDF. Pretty much unusable at the moment. I am still running VW2017 and the same function works fine. -
Hi, I thought I would treat myself to a new workhorse and get things specified right up to get into some serious rendering. As part of the upgrade I chose a Gigabyte GeForce GTX1080 G1 8GB card. I thought I would now be able to set the display preference to "Best Performance" having always used "Best Compatability". Trouble is I see no change in the redraw/refresh. I am still seeing residue when moving lines, plant tags etc. That only go away when I return to best compatibility. Was I asking too much?
Computer Specifications
Thanks, it's a great help. -
Hi, I am planning to build a desktop PC, part out of interest, part economics. Looking for advice from anyone who has been down this road before, particularly in recent times. There is a lot of advice out there wrt video editing machines, but not much wrt CAD & 3D modelling. No budget yet, that will come once I understand what range I need to spend in. One thing I do want to do is to future proof it as best I can. Thanks in advance. James
Yes, you should be able to. I did. best to contact Ozcad, the VW reseller. They advised me.
- 7 replies
- for sale
- vw 2017 designer
(and 4 more)
Tagged with:
I have created a number of landscape areas containing specific plants and added them to a resource library to call on when placing ground-covers or mass plantings. When I use them on a project there is a strange behaviour. I draw the shape and when complete the shape appears elsewhere. It doesn't appear to be a consistent shift. It appears to be an issue with my project template and I don't see the behaviour when I create a landscape area in a blank document. I have even tried creating a new landscape area plugin within the file. The new landscape area still behaves the same way. I have attached a file that contains a landscape area. You can see the behaviour if you create a LA with this.
