Ride
353 -
Posts posted by Ride
I upgraded VW2019 to SP5.3 recently, and now the program hangs a lot. It doesn't completely crash, but I get the spinning wheel repeatedly, and things slow to such a crawl it might as well have crashed. Waiting it out until it catches up to last couple of inputs takes too long - better to just force quit, lose the work and try again.
Can someone tell me how to revert back to 5.2, or even 5.1. This didn't happen with those service packs.
Are there any more updates coming for 2019? Or is this as good as it gets (which isn't good).
Thanks
VW 2019 sp5.3
Macbook Pro mid-2015 Mojave
Hi @Kevin McAllister, I can live the results after un-checking the Display 2D Components. Thank you.
But it doesn't make a lot of sense as this is not a 2D component. Plus, why would this be controlled by the Ceiling>Main class when my section line is looking down? Seems counter-intuitive.
See attached file. There is a line in my viewport (looks like a sill, or header) but I can't get rid of it. Can someone shed some light on this?
Vectorworks 2019 Architect, InteriorCAD, SP5.3
Macbook Pro mid-2015, Mojave
Thanks
Edited original post to include information I should have the first time. Sorry about that.
I recently updated to SP5.2 for VW2019 (from SP5.1). Now it crashes constantly. Anyone else? Totally random, can't replicate it. Just wondering if I'm the only one, and if someone might have figured out why.
Macbook Pro, late 2015
VW 2019.SP5.2, InteriorCAD
MacOS 10.11.6 El Capitan
Done. Thank you.
- 1
I was afraid that was going to be the answer I got. Really, I thought this was supposed to be real, professional software. Can't even change grain direction on something??
Crazy. Maybe the next Teaser Tuesday can show that basic functionality is now working!
Thanks for your reply....
Me too. Hard to replicate. Generally fixed by a re-start. Not awesome.
I didn't. And I don't know what changed but it started working again. I had tried it about 5 times and kept getting this message. Lot's of strange things happening with VW for me lately. I hope it stops.
For whatever reason, the first 10 times I did this, nothing happened. This time it worked. Not sure what I was doing wrong previously, but at least I can move forward now.
Thank you.
For the love of god would somebody please change the grain direction of the header of this frame to be horizontal?
Why does it have to be so difficult?
Thanks.
Bug report submitted.
7 hours ago, MullinRJ said:
Also worth noting is that the problem does not present itself when using the PRINT menu to Print-To-PDF option.
Raymond
Strange, it works through printing. Either way I would submit the bug report - but I actually don't know how to. I can't post to the known issues section, so will a moderator see it here and move it? Or is there a separate section for bug reporting?
EDIT: Nevermind, I spoke too soon. I found it...
Thanks for looking into it. I will file a bug report today....
Thanks, all. Here is a file, and the resulting PDF export from the file...
13 hours ago, MullinRJ said:
What version of VW? What computer? What OS? You really need to add a signature with these items to get the best answers.
TIA,
Raymond
Sorry, I usually put that in at the bottom. Yes, I need to get a signature going.
Specs:
VW2019 SP3.1
Macbook Pro mid 2015 OS 10.11.6
Well, it's supposed to be Helvetica. And the lower 3 is, but the 2 isn't. It's tall and off-centre. I'll live with it before changing fonts, but this didn't happen in previous versions. And as mentioned, it looks proper on screen, it just doesn't print/export properly...
5 hours ago, ASagatovVW said:
@Ride I believe I am able to replicate what you are saying here. To confirm, are you only running into this specifically when naming the PDF "temp"?
I wasn't personally familiar with this, but I did find another report of this in our systems here, so I have added some additional information to the submit.
Wow. Yes, only when using "temp" as the filename. Other filenames work fine.
I do this A LOT when I'm working to generate a quick set of drawings to the desktop that I can open on my second monitor. It saves me having a bunch of PDF files as 'temp' just keeps overwriting the previous file. Plus with a filename of temp, I'm never afraid of deleting it.
I guess my new go-to filename will be temp1. Funny behaviour though.
No, no error at all. In fact it just skips the whole process, like you never did it. Doesn't even start updating viewports....
I can't seem to publish drawings to PDF with a different name than the name of the file. If I try to create a file, say named "temp", it does nothing. But if I leave the default file name (the name of the file), then it published normally.
I used to be able to name the PDF whatever I wanted. Something has changed.
VW2019 SP3.1
Macbook Pro
Revert back to earlier service pack
in Troubleshooting
Posted
Thanks. Trying this now....
