subtect
    2
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    intern architect
  • Homepage
    www.epistemography.com
  • Location
    vancouver
  1. In case anybody has continued having issues with this since 2004, I wanted to mention a fix I just found. Sadly, we are still using 10.5 (on mac), so for any other users with cobwebs on their software, this may help. We had no success with the "rasterize print output" in the "vectorworks" print options dropdown menu, which was the fix mentioned above. However, in the "output" dropdown menu, if you check "save to file" and then select postscript instead of pdf, the resulting file (which will convert to a pdf when opened) is produced with a "round pen", with consistent weights for diagonals and curves. At least, that's our experience. hope this helps. derek
  2. In case anybody has continued having issues with this since 2004, I wanted to mention a fix I just found. Sadly, we are still using 10.5 (on mac), so for any other users with cobwebs on their software, this may help. We had no success with the "rasterize print output" in the "vectorworks" print options dropdown menu, which was the fix mentioned above. However, in the "output" dropdown menu, if you check "save to file" and then select postscript instead of pdf, the resulting file (which will convert to a pdf when opened) is produced with a "round pen", with consistent weights for diagonals and curves. At least, that's our experience. hope this helps. derek
