Junglejim
12 -
Reputation
0 NeutralPersonal Information
Occupation
landscape designer
Location
Modesto Ca.
I had problems with this and I had to make a 12.5 drawing and place all the plant symbols in this. and open in 2009 and save as 12.5 plants symbolsand add the drawing in favorites in the resource browser. I have been able to use them here althoughn I have not done much in changing colore etc. You do have to make any changes in tags, etc before using them it seems like. fwiw as a novice You get what you paid. jim
I am having the same problem with Macbook running 10.5.6. Clicking on the probram icon it bounces a couple of times and quits with no message. 2 ghrz intel duo
I am using VW for simple plans. Yesterday, I switched to a irrigation sheet. all my plant symbols disappeared except for the center cross. I have been trying to get them back and did all kinds of things with classes views sheets and nothing so far gets them back. As I look at the the plan now there is a highlighted rectangle in the center and I can drag it around and the plan moves with it. I can not select anything on the plan I tried to cut and paste in a new file and it doesn't work.It thinks i am trying to cut and paste a viewport. I have a back up that contains most of my work but what did I do??? also a few days ago my main file contained only what I had at my first save. the VW backup contained the complete file. what hqppened here
I upgraded to vw landmark 2009 from 12.5. Using vw 12 and 12.5 I was able to do simple landscapes designs by just playing with the program I am having problems doing the same with 2009 version. I am not using viewports just design layers. I start the drawings and can find the same tools and they seem to work much the same. this morning I was working on a plan and I couldn't click on line or arc objects to select. I clicked on something and a line seemed to be chosen but when I resized it a different line resized. If I drew a circle it showed up way offset from where I drew it. Other problems I have run into is at some times I can only draw lines that are longer than 4.5 ' The snap distance makes it impossible to always draw lines where I want them. the snap grid is set at 6" display at 5' but it seems to try to snap at something like 4 or 5' to end points or mid points or ??? some times plant objects loose their symbol and show as a cross. at this point these are my main problems and I realize that there are probably settings I have wrong but looking the documentation over I haven't found where they are. as I mentioned some of these behaviors seem consistent snap grid and others seem to just show up suddenly. Presumably because I did something but what? I upgraded because I am using mac 10.5 and 12.5 has display problems Jim Rogers
I am transfering from 12.5 to 2009 and am having some problems that I suppose if I understood things I might be able to figure out by myself. However I was doing a real simple landscape to try 2009 out and I used some plant symbols. I open and closed it ok several times but eventually 3 of the 4 plant symbols i used displayed as a simple cross. now all the plant symbols display as a cross when used. In my previous post I asked also about importing the 12.5 plant symbols into 2009. The response I got was to load a file with the 12.5 symbols save and reopen in 2009 close and open and then I can load into resource browser. However I haven't been able to see how to import them into the resource browser. I can use a template that shows the symbols but shows them as used in the design which I can work with butis less than ideal. As an aside if I use a plant symbol for one plant and want to use it for a different plant that is a different size when I edit the symbol the old symbols change to the newly edited size etc. This is different than 12.5 Jim
Thanks I will try this.
The plant symbol list for vw 2009 is only about 10 symbols. 1) How can I add or move the symbols from 12.5 2) how can I make symbols that stay with new files that I open. Jungle Jim
Using Mac os 10.4.11 on a mac book 2 gz intel core duo with 2 gig ram
several months ago the open recent has quit working. After closing VW and reopening open recent is empty. I am guessing that there is a permission problem and it can't write to a file yes no/ where is it or what can I do It has worked before. I am using landmark 12.5.3but am thinking it is a VW fundamental problem. I did try searching but ???
I am using landmark 12 and just started to try using it on an intel Imac ..When ever I try to use the hardscape tool and set it to path mode the program crashes. I can set up the line and if I ok it as a boundary and it seems ok. If I ok it either when I create it or go back to the object palette it crashes. Is this a known bug? something I am doing wrong. jim
I am just started using v12 and in 11.5 when I used a plant group there was a line between the plants. In v12 there isn't. I would like help getting the line back Jim
I am a new user of landmark vw 11.5 on a mac system x When i am on a network I regularly get notices that someone else is using the license number. This is not possible because it is loaded only on one computer. It is on a laptop and I have used it at home on an airport netgwork with my computer the only one hooked up with the same results. what might be happening. Juungle Jim
