J P
    8
Everything posted by J P
  1. @Pat Stanford Hello Pat, I am not sure why either since I am using the formula I got from somewhere else! I would love to know if there is more efficient way of writing formula for such purpose. Please see attached below. Thank you so much again! WS sample.vwx
  2. @Pat Stanford Hello Pat, I am working on a dynamic text to display a list of wall components and thicknesses on a Graphic Legend. However, it seems the components thickness round up and down to nearest 1/2. The formula I am using for each components is as below: #WS_IF(VALUE(OBJECTDATA('component', 'thickness', 1)>0), 'a.', '')# #WS_COMPONENTTHICKNESS(1)#@#WS_COMPONENTTHICKNESS(1)#>0:' ' @#WS_COMPONENTTHICKNESS(1)#>0:' ' #WS_OBJECTDATA('component', 'name', 1)# Do you know is there anyway to fix this issue? I am attaching the photos below as well. Thank you!
  3. @Pat Stanford@MullinRJ@Vlado I have another question for Vectorworks Experts... Is there any way to attach a door frame symbol to a door object? I want to create a schedule of door frame types used in a project. However, I have not found a way to do this in an automated way. Currently, I just have a text-based worksheet with empty cells for door frame schedule to place symbols on top afterwards. It is a long shot, but I thought I might ask... Thank you!
  4. @Pat Stanford @MullinRJ @Vlado Thank you so much everyone! It is working great !
  5. Thank you @Pat Stanford Attached File is the one with the door schedule worksheet and scripts you provided in it. I noticed that I had a typo in the script name, but even with the correct name it does not show up the rating as in the wall data. I am wondering if the wall data has to be integer only? Template 230803.vwx
  6. Thank you @Pat Stanford so much for the script! However, I am not sure if I have my fire rating data embedded into the walls correctly. It is not showing up on the door schedule worksheet. Do you have any idea why? Below is the worksheet I am working on - ignore the WallFR column. The column (Column V) with WallFireRatingForDoor is the far right one. I have also attached a screenshot of the object info palette data tab of the wall that door is sitting in.
  7. @Pat Stanford @Matt Panzer Hello, I came across this forum thread trying to get Wall Fire Rating of that contains the door to show up on the door schedule worksheet. Is there any function similar to getspaceforobj for doors? For example, getting the wall fire rating for door?
  8. Hello, I am wondering if there is any way to display the fire rating of the wall that door is sitting in on the door schedule worksheet. Is there any function similar to getspaceforobj for doors? For example, getting the wall fire rating for door?
