Bernat
27 -
Everything posted by Bernat
3DConnexion SpaceMouse Makes Big Jumps
Bernat replied to JimDenaultASC's question in Troubleshooting
Hi, I used the uninstall app without troubles. But 3d space mouse continues to jump. Not so often but is not over yet. /Bernat -
Hi Mark, Thank you for last days! Hope everything fine with you 🙂 I saw they've update the beta driver. Do you think it's important to uninstall the driver first? Bernat -
What about your 10 am? works for you?
Yes I'm interested but I can't talk now my my kids are sleeping now 🙂 . Can we contact tomorrow earlier? What time is in your place now? I'm playing with the Nurbs, after composing and creating the loft surface I get a group. ant in the group each arch is group again. As you say is easyer to show that...
Aha so if I want to change the curve I just double click and edit the composed nurbs?... I'll try.
Indeed 🙂 ...An animation in the visualizer program. One day will this happen!
Yes exactly is just a piece of fabric in a grey color not yet determined. Att the end the fabric will hang from the highest pipe, that will rise att the same distance as the fabric , around 16 m.
Hi, thanks for your example, this was a good point of view, I'll dig on the Nurbs curves and the loft surfaces. I now understand that this workflow makes it cleaner and easier. The fabric is a silk and will be released from each pipe at a given moment and at the end of the show, the fabric will hung on just one pipe. That's when nurbs surfaces will give me a good help for the wrinkles that will appear! I'll post my file after experimenting with this tool! PS: My the circadian rhythm has got bananas, we have just few sun hours this month and this year has been cloudy since november. That's why I'm staying late at night ...too late 🙂
Hi, thanks for your example, this was a good point of view, I'll dig on the Nurbs curves and the loft surfaces. I now understand that this workflow makes it cleaner and easier. The fabric is a silk and will be released from each pipe at a given moment and at the end of the show, the fabric will hung on just one pipe. That's when nurbs surfaces will give me a good help for the wrinkles that will appear! I'll post my file after experimenting with this tool! Ps. My the circadian rhythm has got bananas, we have just few sun hours this month and this year has been cloudy since november. That's why I'm staying late at night ...too late 🙂
By the way the Idea taking a picture is great! I'll try 🙂
I extrude arc curves, do you think is better with nurbs?
I realize that the diameter of the pipes is not correct, but in the end the important thing is how to modify the fabric! Gauze_2020.vwx
Hi, This is the schematic Idea, but I want to make it better, the Fabric is a kind of silk.
Gauze.pdf Gauze.vwx
HI 🙂 Obviously not! 🙂 What I am trying to do is to design a huge gauze 18 x16 m that hangs in different horizontal pipes hanging in different highs , in each pipe, there is an x number of magnetic load/release devices that have clamps that hold the gauze. I can make it schematic version of course, but I would like to make it more dynamic to visualize the wrinkles caused of the clamps and the curve that the fabric gets in between pipes. Hope you understand what I mean. By the way, the tutorial link you shared with me is superb! I think it describes what I'm looking for, I'm discovering how this tool behaves. But I'm not there yet!
@mjm Thank you !
Hello I made the mistake of installing the latest update for mac big sur (11.1.) Which I very much regret .. Despite the 3D spacemouse still does not work in Big sour. So now I have many rendering problems. I attach wireframe opengl and Hiden Line with the same view. You may notice that all layers and classes are on.
- 3 replies
- big sur
- big sur 11.1
(and 2 more)
Tagged with:
Hi, is there a way to simulate how the fabric behaves? And by that I mean, for example, when it hangs from different points (think of two people holding a blanket, how you get the curve for the fabric and how it folds). Bernat
Yes this is in 2021 sp1!
- 3 replies
- schematic views
- accessories
(and 1 more)
Tagged with:
HI, I've attach a scroller on a lamp and the accessory doesn't shows in the schematic view. How do I make this to work? Do I need to attach a record to the light? /Bernat
- 3 replies
- schematic views
- accessories
(and 1 more)
Tagged with:
Hi Mark, That was perfect! Many thanks for the video and the file, that was self-explanatory. Now I realise that when I offset the lamps from the hanging position, I have to update the geometry, otherwise the boundaries of the hanging position geometry follows the first offseted lamp and blocks other lamps to offset beside. Maybe is this a bug or is just like it is as it is. I wish I could add an offseted lamp inside the hanging position it makes the plot interpretation easier to understand :). Bernat
HI Mark Thank you for this great video! I have struggled with the offset function the whole day. In my schematic view some lamps will move and take the footprint mark, some of them not. I can't understand what's the reason for that. In the example below you can see that 2 lamps have the footprint mark but the third lamp won't get it. he lamps behave different each time . I have an other question! In the tutorial you're using the accessory removing tool, removing the clamp of a lamp symbol. I tried to make the same but doesn't work for me, regardless of whether I edit the 2d symbol with the accessory information you describe. My question is have do you attach before the clamps and then removing them with the tool? This is the only way tha works for me. I'm using the Niethammer profiles and the symbol have a clamp attach. I have to edit and delete the clamp in the 3d symbol menu in order to hang the lamp properly. /Bernat
I 've placed 2 x lamps in a truss one with address and the other one with the default "0" address and I've pick upp the XYZ coordinates into the worksheet. Test data 2wayy.vwx
That's god to know. The parameters I mention, are picked from the "Record - Lightning - Device" Menu. This is why expected to have feedback from xyz.
