199 -
Everything posted by MartinBlomberg
Filter views with different objects
MartinBlomberg replied to MartinBlomberg's topic in General Discussion
Cheers Tamsin, much appreciated! -
Thanks! I'll try that one out as well as the other tricks. Cheers! -
This is probably a no-brainer, but I can't seem to find out how to do this. When I work with a project, I want to work with one thing at a time once in a while. So, how do make only i.e all hoists visible? The "Active only" option for classes doesn't really do the trick since it's not including colors, info and so on since they're on different classes. Hope that makes sense. In short I'd like to work with hoists, trusses, lights, slabs, walls and so on individually. Cheers!
Streamdeck integration.
MartinBlomberg replied to Matster's question in Wishlist - Feature and Content Requests
Amazing, thanks buddy! -
Wow, awsome!! Thank you so much! May I ask, is there a way to get these icons from you, or can I extract them from the SD somehow? Thanks! -
Hi, So, a couple of thoughts: 1. If I combine all walls, slabs, pillars and stuff to one piece of combined solid, will this make a lighter file? 2. If so, how do I do this? I want to make one piece of solid made out of all the walls and slabs I've created. 3. Is this even a good idea? I'm making an arena, so there's gonna be a lot of stuff in the final file, so it needs to be lightweight and easy to understand. Thanks!
Thanks Ian, much appreciated! 😃
- 6 replies
- 2021
- quick search
(and 2 more)
Tagged with:
No, I'm in design layer. It works when I click the menu but not with the quick search. Obiviously a bug, according to Ian Lane. Cheer!
- 6 replies
- 2021
- quick search
(and 2 more)
Tagged with:
Thanks Ian for the response. I'll change the command for now then. Warm regards, Martin
- 6 replies
- 2021
- quick search
(and 2 more)
Tagged with:
Hi, When I use the quick search (thank you for this feature, love it!) the result comes up grey most of the time, but not all the time. Why is this? For this example I want to change the lighting options, but it's grayed out, please see image. thanks!
- 6 replies
- 2021
- quick search
(and 2 more)
Tagged with:
Is this really the performance one could expect?
MartinBlomberg replied to MartinBlomberg's question in Troubleshooting
I followed a tip from another member here on the forum. The tips was to consolidate geometry, make symbols of repeating objects and so on. I did, I replaced 2662 extrusions to one symbol i.e. I guess that's great but the flow is far from good, not even close I'd say. Any more suggestions from anyone? I'm kinda desperate here since this is dragging my work down... Cheers all for your time and support!! -
That's really sad to hear. To release a slow motion-product isn't really optimal, imho. -
Hi, thanks for the reply! It's already set on "Low" actually. I can try the symbol change, but that doesn't cut it when I'm about to present it to the client. And I want to be able to make adjustments with the original chairs present. -
Hi again Paul, Would you mind taking a look at the files and videos I posted here? Since you're far more expert then I'll ever be, can you please make sure that I'm not missing anything? For the time being I just can't work with projects for my clients, it's more or less impossible with graphic latency like this. Thanks again mate! 😃 -
I tried your camera option solution on another project I'm working on. All I'm trying to do here is pan from left to right. This takes f o r e v e r . Sure, it's a bigger project for sure, but still, this is totally unacceptable. For a freeware maybe, but after spending thousands of bucks? No way. Here's a video showing how slow this thing is. Come on now, I must do something wrong here, because this can't be the way it's suppose to be, right? Cheers, 2020-09-09 14-32-44_Trim.mp4 -
I'm happy to hear you're working on improvements, looking forward to that. But still, I should be able to join curtain walls without this experience? I mean, walls usually stand together in a construction and not alone. This same latency goes with seating sections. I takes more or less forever to make a seating plan for the arena I'm working at. Every single moment I do need some processing. Click, wait, click, wait. It's driving me more or less insane. It it's not working smoothly, just delete the feature. I think I speak for a lot of people in the VW-community when I say we need a more responsive and easy-flowing software. I'll have a look at the new features of 2021 now. Cheers. -
That's good to know. Though, how come it takes aprox 1 minute to change the wall thickness? I thought all this was some kind of bug, but it's obviously the same for you guys. This is way under what you could expect imho. Is there going to be a change to these kind of issues in the near future? Thanks! -
I used the Titleblock tag since I'm doing the editing when the titleblock was present. Maybe it was not necessary, not sure 😃 -
Thanks Frederic for your checkup on this! I think this is ridiculous, to put it mildly. So, this is obviously the performance you could expect from VW2020. Wow. The file I'm working on isn't big at all, the operation isn't anything super special and it's even a built in feature. Still, a minute to make a curtain wall thinner? Seriously? To the staff at Vectorworks: For future versions of Vectorworks, please just make the software stable, responsive and quick. No more features that will take forever to perform and might just crash on you (happens more then any other software I've bought, ever). I love the event design part of VW, that's the sole reason I bought it. But to work with a software that's this unresponsive isn't gonna be a keeper. Thanks for understanding! -
Sure! No sensitive info at all, just some Swedish classes and stuff. For this I've deleted references and deleted some other info that would've dragged down the speed. Thank you for taking a shot at this! Curtain wall slowness.vwx -
Thank you! I did this, shot a video when I made an example of a curtain wall. Please check this clip out and tell me what you think. More then a minute to change the thickness of a wall? What's up with this? I know OBS is taking some power of the CPU as well, but it's the same when I don't record. Cheers all! 😃 vlc-record-2020-09-07-10h01m44s-2020-09-07 09-57-12.mp4-.mp4 -
That's probably my lack of knowledge in the software, will change this behaviour of mine 😃 Thanks! Though, my trouble still exist, check the video down below in next thread. -
Thanks Pat! I'm not really a PC user (use Mac all the time but on my work computer), so, how do I check this on a Windows 10 machine? Cheers! EDIT: Google helped me out, sorry for my ignorance. Still no change though... -
MartinBlomberg posted a question in Troubleshooting
Honestly, is this what one can expect from VW? Please have a look at the video attached. LINK TO VIDEO: https://photos.app.goo.gl/vCbW8r4R4SMqHK5d8 I'm doing a seating plan for the arena I'm working at. And the file isn't too complex yet, size around 50mb. I've also shot the Task manager as well, so you can stats while I'm cliking about. I'm not doing to much stuff here as you can see, but still really slow. Please let me know why occure and if there's some kind of fix to it. Many Thanks! INFO: VW 2020, SP5, 64-bit Windows 10 Pro CPU: Intel i7 9700 3,00GHz 16GB RAM NVIDIA GeForce RTX 2060 Super -
Thanks Dave for getting back! Ok, any clue which format I should use for export to make it visible? Or is there a workaround? Cheer!
- 3 replies
- twinmotion
- symbol
(and 3 more)
Tagged with:
