matteoluigi
460 -
Posts posted by matteoluigi
obviously in VW Ger all Functions have been translated in german and now 2022 has problems translating 2021 datamanager sets in german...
Hi,
we coded a bunch of datamanager-functions with find commands. Now it seems, that "find" is not available any more in the 2022 Datamanager. Now instead more functions are possible with wildcards (*) and maybe (?)? for just one field?
All in all, one regression and a great improvement, right? ^^
Hi,
when will smartpaste be working on Vectorworks 2022 as well?
Unfortunately just copying the plugin-files from VW2021 to VW2022 didn't work and the download-button on http://smartpaste.co.uk doesn't work either.
Thank you
Just now, DBrown said:
You are out of luck
yeah, that's what I actually "was afraid of"... I mean, in university and every technical drawing school you learn that you have to show all objects, covered ones and invisible ones (above the cut plane) in different dashed line types. Now the future is BIM and now I have to draw everything in lines again? Why do I do BIM then? Sounds to me quite antiquated... pity but, somehow symptomatic for many tools in Vectorworks, good ideas but half baked 😞
- 1
In general objects, which are above the normal floor plane cut plane (in general the height in Europe is 1m), are shown with a dashed line. I remember that this idea has ended as a new feature a few years ago.
However it only seems to work partially to me.
- Wallll-objects UNDER the cut plane (especially walls) work fine.
- Walls and Slabs over the cut plane instead don't work.
- Slabs also aren't shown with their material hatch when in cut plane and aren't shown dashed, when they lay above the cut plane.
- Walls aren't shown dashed, when they are situated above the cut plane.
So actually I think I have to model every wall above the cut plane as a 3d-volume and create an autohybrid symbol from it, in order to integrate it as good as possible in our BIM-Model. Right?
Quote
Nothin' lasts forever
And we both know hearts can change
And it's hard to hold a candle
In the cold November rain
(Guns'n'Roses - November Rain) 😉 -
On 8/23/2021 at 9:00 PM, zoomer said:
Somehow it already feels like end of August ....
well, 2021/08/31 is still end of august, and it's tuesday 🥁
- 1
13 hours ago, Pat Stanford said:
My understanding is that WinDoor will be distributed with VW2022 (at least in the English versions, I can't say if localized versions will include it or not)
might be possible, that it will be delivered but not included in any german workspace, seems, that it only does support walls with one component, or at least isn't able to react on more wall components in a more detailed way
4 minutes ago, Christiaan said:
https://www.ozcad.com.au/training/training-videos.php - don't know how long that video will last, as they're seem be moving things to vectorworks.net
hmm, so now I'm curious what is best: Vectorworks-Doors, ComputerWorks-Doors/Windows or WinDoor 😄
- 1
On 7/19/2021 at 4:51 PM, Christiaan said:
WinDoor
What is Windoor? never heard off... Now getting curious (although we "only" do have architect-licenses)
On 7/19/2021 at 4:48 AM, Jeremy Best said:
is offset even a fair distance from the Internal Origin (distinct from the User Origin)
as far as i remember, there are no objects to far away from the internal origin. However I am aware of that issue.
well it's a 8 story-bulding with 2 lower levels for parking, storage which all in all consists of 6 separate houses, one supermarket and 2 level parking under all houses (dwelling)
it's an 2017 iMac 27" with a 4GB VCard and 16GB Ram..., bot, who knows
One of my colleagues actually has the problem, that activating objects in multiple view pane mode is not possible (or something similar, it's about activated objects and the Object Info Palette, which don't behave as usual), when 3 or more panes are open. Might that be a performance issue?
Suddenly there appeared an error message by trying to access the PS-Server, that sais sth like "Couldn't contact the Server", when I now switch inside the "URL"Drop-Down-Menu from "http://xxx.xxx.xxx.200" to "http://xxx.xxx.xxx.200:22001" everything works fine again, but why? Why do I suddenly need to verify on which port the ps server works? Could it be, that our IT switched the port?
Hi folks,
there exist two commands in VW which help me by joining walls. A "join"-command, which also can join lines for example from the menu and a "join walls"-Command from the tool-set (which of course is more apropriate for joining walls, because I can chose the way I want to join those walls (T, L, X, merge wall-components or do not merge wall components).
However I am questioning myself wether I make a mistake when I join walls with CMD-Shift-J or CMD-J.
What is the technical difference?
yeah, the only problems are when rendering the OpenGL viewports. Of course, my college mentioned, that he didn't have problems from the beginning...
Now, he's working on the 2013 and 2015 iMac simultaneously. 😉
We have problems with some OpenGL viewports, which suddenly cannot be rendered any more. Instead they turn white. I can't upload the file, because it's a secret architecture competition.
However, can that be a performance-issue?
The slower machine is a 2013, the faster a 2015 iMac 😉 not the fastest ones, but, however, the viewports aren't heavy - 8.xx x 8.xx inch at 300 dpi = 2584 x 2584 dots
The faster machine seems to handle the renderings (until now)
second crash ~ 20 minutes later..., same issue, third try successful
QuoteProcess: Vectorworks [1164]
Path: /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/Vectorworks
Identifier: net.nemetschek.vectorworks
Version: 26.0.3 [588748] (26.0.3)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Vectorworks [1164]
User ID: 502
Date/Time: 2021-05-19 09:27:10.470 +0200
OS Version: Mac OS X 10.15.7 (19H1030)
Report Version: 12
Bridge OS Version: 5.3 (18P4556)
Anonymous UUID: DF008156-D81C-0F7B-7656-2B9CD710AF70
Time Awake Since Boot: 2100 seconds
System Integrity Protection: enabled
Crashed Thread: 0 CrBrowserMain Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
Pure virtual function called!
Application Specific Signatures:
{"sn":"XXXXXX-XXXXXX-XXXXXX-XXXXXX", "ts":"179837578d1", "platform":"MAC", "os_ver":"10.15.7", "vw_ver":"2021 SP3 R1 [26.0.3(588748)] (64-Bit app)", "error_reporting_mode":3}
Thread 0 Crashed:: CrBrowserMain Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff7229c33a __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff72358e60 pthread_kill + 430
2 libsystem_c.dylib 0x00007fff72223808 abort + 120
3 libc++abi.dylib 0x00007fff6f482458 abort_message + 231
4 libc++abi.dylib 0x00007fff6f481e92 __cxa_pure_virtual + 18
5 libTD_Root.dylib 0x00000001619dd766 OdRxClassImpl::reset() + 70
6 libTD_Root.dylib 0x00000001619dd4b5 OdRxClass::~OdRxClass() + 37
7 libsystem_c.dylib 0x00007fff721fe13c __cxa_finalize_ranges + 319
8 libsystem_c.dylib 0x00007fff721fe412 exit + 55
9 com.apple.HIServices 0x00007fff36525052 ExitToShell + 11
10 net.nemetschek.vectorworks 0x000000010940a937 0x107ac2000 + 26511671
11 libc++abi.dylib 0x00007fff6f481887 std::__terminate(void (*)()) + 8
12 libc++abi.dylib 0x00007fff6f484387 __cxa_rethrow + 99
13 libobjc.A.dylib 0x00007fff70fac93d objc_exception_rethrow + 37
14 com.apple.AppKit 0x00007fff35861874 -[NSMenu performActionForItemAtIndex:] + 158
15 com.apple.AppKit 0x00007fff358617cd -[NSMenu _internalPerformActionForItemAtIndex:] + 82
16 com.apple.AppKit 0x00007fff35861617 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 101
17 com.apple.AppKit 0x00007fff357f1d30 NSSLMMenuEventHandler + 908
18 com.apple.HIToolbox 0x00007fff36e508ff DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1254
19 com.apple.HIToolbox 0x00007fff36e4fd8d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 329
20 com.apple.HIToolbox 0x00007fff36e6547e SendEventToEventTarget + 39
21 com.apple.HIToolbox 0x00007fff36ec540b SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 368
22 com.apple.HIToolbox 0x00007fff36eec065 SendMenuCommandWithContextAndModifiers + 45
23 com.apple.HIToolbox 0x00007fff36eec00d SendMenuItemSelectedEvent + 346
24 com.apple.HIToolbox 0x00007fff36eebe59 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96
25 com.apple.HIToolbox 0x00007fff36eec88e MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 603
26 com.apple.HIToolbox 0x00007fff36eec598 _HandleMenuSelection2 + 460
27 com.apple.AppKit 0x00007fff35694c0d _NSHandleCarbonMenuEvent + 215
28 com.apple.AppKit 0x00007fff35694a7a _DPSEventHandledByCarbon + 54
29 com.apple.AppKit 0x00007fff354bceca -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2962
30 net.nemetschek.vectorworks 0x0000000107f057e1 0x107ac2000 + 4470753
31 com.apple.AppKit 0x00007fff354ae58e -[NSApplication run] + 658
32 com.apple.AppKit 0x00007fff35480396 NSApplicationMain + 777
33 net.nemetschek.vectorworks 0x0000000107dfe381 0x107ac2000 + 3392385
34 libdyld.dylib 0x00007fff72154cc9 start + 1
Thread 1:: ThreadPoolServiceThread
0 libsystem_kernel.dylib 0x00007fff7229eb96 kevent64 + 10
1 org.chromium.ContentShell.framework 0x000000011f5c84b8 cef_time_delta + 2912120
2 org.chromium.ContentShell.framework 0x000000011f5c8366 cef_time_delta + 2911782
3 org.chromium.ContentShell.framework 0x000000011f55d993 cef_time_delta + 2475091
4 org.chromium.ContentShell.framework 0x000000011f5332b3 cef_time_delta + 2301299
5 org.chromium.ContentShell.framework 0x000000011f5663bd cef_time_delta + 2510461
6 org.chromium.ContentShell.framework 0x000000011f578164 cef_time_delta + 2583588
7 org.chromium.ContentShell.framework 0x000000011f5ad637 cef_time_delta + 2801911
8 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
9 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 2:: ThreadPoolForegroundWorker
0 libsystem_kernel.dylib 0x00007fff72295dfa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff72296170 mach_msg + 60
2 org.chromium.ContentShell.framework 0x000000011f5bc183 cef_time_delta + 2862147
3 org.chromium.ContentShell.framework 0x000000011f56f378 cef_time_delta + 2547256
4 org.chromium.ContentShell.framework 0x000000011f56fccd cef_time_delta + 2549645
5 org.chromium.ContentShell.framework 0x000000011f56f8dd cef_time_delta + 2548637
6 org.chromium.ContentShell.framework 0x000000011f5ad637 cef_time_delta + 2801911
7 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
8 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 3:: ThreadPoolBackgroundWorker
5 org.chromium.ContentShell.framework 0x000000011f56f84d cef_time_delta + 2548493
Thread 4:: Chrome_IOThread
5 org.chromium.ContentShell.framework 0x000000011e2bc6af cef_zip_reader_create + 26554431
Thread 5:: MemoryInfra
3 org.chromium.ContentShell.framework 0x000000011f5bbf7f cef_time_delta + 2861631
4 org.chromium.ContentShell.framework 0x000000011f5131b7 cef_time_delta + 2169975
5 org.chromium.ContentShell.framework 0x000000011f55d993 cef_time_delta + 2475091
6 org.chromium.ContentShell.framework 0x000000011f5332b3 cef_time_delta + 2301299
7 org.chromium.ContentShell.framework 0x000000011f578164 cef_time_delta + 2583588
8 org.chromium.ContentShell.framework 0x000000011f5ad637 cef_time_delta + 2801911
9 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
10 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 6:: NetworkConfigWatcher
2 com.apple.CoreFoundation 0x00007fff3824d9d5 __CFRunLoopServiceMachPort + 247
3 com.apple.CoreFoundation 0x00007fff3824c4a2 __CFRunLoopRun + 1319
4 com.apple.CoreFoundation 0x00007fff3824b91e CFRunLoopRunSpecific + 462
5 com.apple.Foundation 0x00007fff3a8e71a8 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 212
6 org.chromium.ContentShell.framework 0x000000011f5b6871 cef_time_delta + 2839345
7 org.chromium.ContentShell.framework 0x000000011f5b55d2 cef_time_delta + 2834578
8 org.chromium.ContentShell.framework 0x000000011f55d993 cef_time_delta + 2475091
9 org.chromium.ContentShell.framework 0x000000011f5332b3 cef_time_delta + 2301299
10 org.chromium.ContentShell.framework 0x000000011f578164 cef_time_delta + 2583588
11 org.chromium.ContentShell.framework 0x000000011f5ad637 cef_time_delta + 2801911
12 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
13 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 7:: NetworkConfigWatcher
Thread 8:: CompositorTileWorker1
0 libsystem_kernel.dylib 0x00007fff72298882 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff72359425 _pthread_cond_wait + 698
2 org.chromium.ContentShell.framework 0x000000011f5ac7d4 cef_time_delta + 2798228
3 org.chromium.ContentShell.framework 0x00000001207dc66d cef_time_delta + 21868845
4 org.chromium.ContentShell.framework 0x000000011f5ad637 cef_time_delta + 2801911
5 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
6 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 9:: ThreadPoolSingleThreadForegroundBlocking0
4 org.chromium.ContentShell.framework 0x000000011f56f36a cef_time_delta + 2547242
5 org.chromium.ContentShell.framework 0x000000011f56fccd cef_time_delta + 2549645
6 org.chromium.ContentShell.framework 0x000000011f56f93d cef_time_delta + 2548733
Thread 10:: ThreadPoolSingleThreadSharedBackgroundBlocking1
5 org.chromium.ContentShell.framework 0x000000011f56fa48 cef_time_delta + 2549000
6 org.chromium.ContentShell.framework 0x000000011f56f87d cef_time_delta + 2548541
Thread 11:: ThreadPoolSingleThreadSharedForegroundBlocking2
6 org.chromium.ContentShell.framework 0x000000011f56f90d cef_time_delta + 2548685
Thread 12:
2 ThreadPool.tx 0x0000000174a87f6b OdRxThreadPoolImpl::OdApcThreadImpl::threadMain() + 139
3 ThreadPool.tx 0x0000000174a87ed9 OdRxThreadPoolImpl::OdApcThreadImpl::threadProc(void*) + 9
4 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
5 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff3565f954 _NSEventThread + 132
6 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
7 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 29:
0 libsystem_kernel.dylib 0x00007fff72295e36 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff720fbaed _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff720fbfbf _dispatch_semaphore_wait_slow + 98
3 net.nemetschek.vectorworks 0x0000000108b90145 0x107ac2000 + 17621317
4 net.nemetschek.vectorworks 0x0000000108b93b0e 0x107ac2000 + 17636110
5 net.nemetschek.vectorworks 0x0000000108b93256 0x107ac2000 + 17633878
6 net.nemetschek.vectorworks 0x0000000108b90840 0x107ac2000 + 17623104
Thread 30:
0 libsystem_kernel.dylib 0x00007fff7229e0fe __select + 10
1 libcurl.4.dylib 0x00007fff6fdefb6b Curl_poll + 623
2 libcurl.4.dylib 0x00007fff6fdeab01 Curl_multi_wait + 609
3 libcurl.4.dylib 0x00007fff6fde2d0b curl_easy_perform + 296
4 net.nemetschek.vectorworks 0x00000001098a73d0 0x107ac2000 + 31347664
5 net.nemetschek.vectorworks 0x00000001098ad94a 0x107ac2000 + 31373642
6 net.nemetschek.vectorworks 0x00000001098acf84 0x107ac2000 + 31371140
7 net.nemetschek.vectorworks 0x0000000108b939cd 0x107ac2000 + 17635789
8 net.nemetschek.vectorworks 0x0000000108b93256 0x107ac2000 + 17633878
9 net.nemetschek.vectorworks 0x0000000108b90840 0x107ac2000 + 17623104
10 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
11 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 31:
4 net.nemetschek.vectorworks 0x0000000108b93874 0x107ac2000 + 17635444
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
0 libsystem_kernel.dylib 0x00007fff72298756 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff7221beea nanosleep + 196
2 libsystem_c.dylib 0x00007fff7221bde4 usleep + 53
3 net.nemetschek.vectorworks.Renderworks 0x000000015c583baa cineware::IpKillThread::Main() + 58
4 net.nemetschek.vectorworks.Renderworks 0x000000015c546c9e cineware::BaseThread::Action() + 62
5 net.nemetschek.vectorworks.Renderworks 0x000000015c546b99 cineware::BeginThread(void*) + 9
Thread 45:
1 com.datalogics.DL150PDFL 0x00000001545cb2b0 CTThreading::OSSemaphore::Wait() + 16
2 com.datalogics.DL150PDFL 0x0000000154588334 CTThreading::ThreadSafeQueue::Dequeue() + 22
3 com.datalogics.DL150PDFL 0x0000000154588794 CTThreading::WorkerThread::Start() + 38
4 com.datalogics.DL150PDFL 0x00000001545880f6 CTThreading::PthreadStart(void*) + 14
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
Thread 51:
Thread 52:
Thread 53:
Thread 54:
Thread 55:
Thread 56:
Thread 57:
Thread 58:
Thread 59:
Thread 60:
Thread 61:
0 libsystem_kernel.dylib 0x00007fff7229a766 kevent + 10
1 net.nemetschek.vectorworks 0x0000000108933bb6 0x107ac2000 + 15145910
2 net.nemetschek.vectorworks 0x00000001089337a5 0x107ac2000 + 15144869
3 net.nemetschek.vectorworks 0x0000000108933451 0x107ac2000 + 15144017
4 net.nemetschek.vectorworks 0x000000010996f373 0x107ac2000 + 32166771
5 net.nemetschek.vectorworks 0x000000010996ed46 0x107ac2000 + 32165190
6 net.nemetschek.vectorworks 0x0000000109974fde void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, std::__1::__bind<void (sio::client_impl::*)(), sio::client_impl*> > >(void*) + 62
Thread 62:
2 net.nemetschek.vectorworks 0x0000000108933876 0x107ac2000 + 15145078
4 net.nemetschek.vectorworks 0x0000000108936f9f 0x107ac2000 + 15159199
5 net.nemetschek.vectorworks 0x0000000108936f30 boost_asio_detail_posix_thread_function + 16
Thread 63:
0 libsystem_pthread.dylib 0x00007fff72354b68 start_wqthread + 0
Thread 64:
Thread 65:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x000000011c8c0dc0 rcx: 0x00007ffee813c998 rdx: 0x0000000000000000
rdi: 0x0000000000000307 rsi: 0x0000000000000006 rbp: 0x00007ffee813c9c0 rsp: 0x00007ffee813c998
r8: 0x00007ffee813c860 r9: 0x00007ffee813ca30 r10: 0x000000011c8c0dc0 r11: 0x0000000000000246
r12: 0x0000000000000307 r13: 0x0000003000000008 r14: 0x0000000000000006 r15: 0x0000000000000016
rip: 0x00007fff7229c33a rfl: 0x0000000000000246 cr2: 0x0000000160f247e0
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x107ac2000 - 0x10c3126c7 +net.nemetschek.vectorworks (26.0.3 [588748] - 26.0.3) <3B1F86B4-7F81-3109-AD3B-C0D381117196> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/Vectorworks
0x10d601000 - 0x10dd1efff +libdcu2d68.dylib (0) <34875B1B-E7D8-34EF-81F5-7AB310580706> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libdcu2d68.dylib
0x10dff4000 - 0x10e34afdf +libPSServer.dylib (0) <268993E4-8BED-33DA-AA14-8E01809C2282> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libPSServer.dylib
0x10e499000 - 0x10e49bfff +libboost_system.dylib (0) <FD3A0297-3214-3F2C-95BE-FAAC54953B5E> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libboost_system.dylib
0x10e4a4000 - 0x10e4c9ff7 +libosdCPU.2.5.0.dylib (0) <D1EBC34A-EFA2-3362-A101-5EC18DE33AF7> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libosdCPU.2.5.0.dylib
0x10e4ea000 - 0x10e71ffff +org.python.python (3.8.2, [c] 2001-2019 Python Software Foundation. - 3.8.2) <D386999B-3D21-310C-8015-1D3910C0D271> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/Python.framework/Versions/3.8/Python
0x10e861000 - 0x10e866ff3 +net.nemetschek.VWMM (1.0 - 1) <9161DCCF-969B-3DF4-ACE1-AF90799E940F> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/VWMM.framework/Versions/A/VWMM
0x10e875000 - 0x110b72ffb +libPDFNetC.dylib (0) <BA85CBD4-038A-34F5-AAD3-F391F4E2A192> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libPDFNetC.dylib
0x110ebf000 - 0x110ec4fff +libpsassemblyrep.dylib (0) <371326E4-7EFF-3CB4-B79A-FB72AC3A8868> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsassemblyrep.dylib
0x110eda000 - 0x110fc6ff7 +libpsgeneric.dylib (0) <65D8D9EB-4A83-3226-9E80-EAF0D9DA8E58> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsgeneric.dylib
0x111074000 - 0x111096ff7 +libpsiges.dylib (0) <105E4244-4FDC-3DCE-86D1-FE7B8651644E> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsiges.dylib
0x1110da000 - 0x1110fefff +libpsinterop.dylib (0) <230A5B0A-2A01-3041-8034-B811D5427172> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsinterop.dylib
0x11113e000 - 0x111141fff +libpspropertiesbase.dylib (0) <87F2D2A3-69F8-3B19-83BA-0F8434EDB065> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpspropertiesbase.dylib
0x111151000 - 0x1111e0fff +libpsxlatorbase.dylib (0) <E0300163-6169-321B-8C1F-B88C7FD65EFE> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsxlatorbase.dylib
0x1112a3000 - 0x1112a7fff +libpspropertiesbrepimporter.dylib (0) <5529F23C-F06C-3ACF-9838-63DF72C495D4> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpspropertiesbrepimporter.dylib
0x1112b7000 - 0x1113b1ff7 +libpsxcore.dylib (0) <540B4087-333F-3F2B-AAFB-54348AF41D3D> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsxcore.dylib
0x1114a4000 - 0x111621ff7 +libpsxiges.dylib (0) <781C9EB0-1A0A-3AEA-A5D3-F3135038B8AF> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsxiges.dylib
0x111762000 - 0x111784ff7 +libpsxmil.dylib (0) <12F432FD-C5F8-32DB-A50C-28CEA5AE70F9> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsxmil.dylib
0x1117ba000 - 0x1154f8ffb +libpskernel.dylib (0) <E0EEFF6B-9BEE-351B-978D-CF397FF3AFCA> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpskernel.dylib
0x1158a7000 - 0x1158aafff +libmessagehandler.dylib (0) <82C3A773-8BE3-3ED5-9313-2D65FEB1D161> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libmessagehandler.dylib
0x1158b5000 - 0x1158edfff +libHSIMac.dylib (0) <6D170DB2-9A66-30AD-9F23-2E7B4950C8F9> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libHSIMac.dylib
0x119d69000 - 0x119d6bff3 com.apple.CloudDocsFileProvider (1.0 - 698.17) <C03D572A-4C6B-3DFA-8AA9-064B4808BA72> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
0x11a817000 - 0x11a81a047 libobjc-trampolines.dylib (787.1) <88F9B648-C455-36F8-BBB9-7D1A9F57D073> /usr/lib/libobjc-trampolines.dylib
0x11a88e000 - 0x11aa50ff7 com.apple.AMDRadeonX6000GLDriver (3.10.19 - 3.1.0) <4D8D93FA-4065-3BAE-8EDD-FFA80770A2E8> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/AMDRadeonX6000GLDriver
0x11ae14000 - 0x11b0ddff7 +de.computerworks.vectorworks.3D-Hilfspunkte auf Modell CW (D26.0.0 R1 505805+/11731+ - 1.0) <C57B6086-A361-397B-B1FF-623434EEF335> /Applications/Vectorworks 2021 SP3/*/3D-Hilfspunkte auf Modell CW
0x11b3ec000 - 0x11b548fff +net.nemetschek.vectorworks. (1.0) <4819D7BE-223C-3725-A6F5-E5D56D0B536F> /Applications/Vectorworks 2021 SP3/*/3DS Library
0x11b62a000 - 0x11b92bfff +de.computerworks.vectorworks.Achsen CW (D26.0.0 R1 505805+/11731+ - 1.0) <E7904E1E-B982-30BB-B38B-F491BB5DE7FD> /Applications/Vectorworks 2021 SP3/*/Achsen CW
0x11bc64000 - 0x11bd9effb +net.nemetschek.vectorworks.AlignDistribute (1.0) <715BCA7F-5982-3C39-8BEC-C47F79159384> /Applications/Vectorworks 2021 SP3/*/AlignDistribute
0x11be4b000 - 0x11be9cfff +net.nemetschek.vectorworks.AlignLayerViews (1.0) <AE0369CC-FE6A-387C-871A-99D83BA17C7B> /Applications/Vectorworks 2021 SP3/*/AlignLayerViews
0x11bec6000 - 0x11c078ff7 +net.nemetschek.vectorworks.Animation (1.0) <EE9873B9-83F1-3527-9928-FAAD8ADE9D29> /Applications/Vectorworks 2021 SP3/*/Animation
0x11c16c000 - 0x11c436fff +de.computerworks.vectorworks.Ansichten CW (D26.0.0 R1 505805+/11731+ - 1.0) <9F8C4A76-49DD-3E28-9737-8ABD30A8B792> /Applications/Vectorworks 2021 SP3/*/Ansichten CW
0x11c753000 - 0x11c7a1ffb +net.nemetschek.vectorworks.BluebeamConnect (1.0) <423F4281-3529-3809-9865-42E80433E2DB> /Applications/Vectorworks 2021 SP3/*/BluebeamConnect
0x11c7c7000 - 0x11c7cefff +libjson-c.4.dylib (0) <D6C6E3AB-4359-391A-BA6D-3452B6825579> /Applications/Vectorworks 2021 SP3/*/libjson-c.4.dylib
0x11c7d3000 - 0x11c7deff7 +libboost_iostreams.dylib (0) <016DD517-E69F-3E7B-9018-FEEE409DBAA8> /Applications/Vectorworks 2021 SP3/*/libboost_iostreams.dylib
0x11c7f2000 - 0x11c7f3ff3 +libTD_Alloc.dylib (0) <B481BEEC-F960-3A1E-81DF-D376CF096D9C> /Applications/Vectorworks 2021 SP3/*/libTD_Alloc.dylib
0x11c7f6000 - 0x11c887f47 dyld (750.6) <1DCAF85D-70A4-3405-A868-25AF3DC1F32B> /usr/lib/dyld
0x11c8fb000 - 0x124aa8f9f +org.chromium.ContentShell.framework (84.2.6.0 - 6.0) <C95E00B6-94B0-3E90-8755-9CD5B3E43624> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
0x125539000 - 0x125883ff7 +net.nemetschek.vectorworks.ArchitecturalObjects (1.0) <A5C0CF4B-0D82-3333-AB48-3BA40F0B4FDD> /Applications/Vectorworks 2021 SP3/*/ArchitecturalObjects
0x1259bb000 - 0x125af7ffb +com.ingenicad.ArtlantisExportEN (26.0.1 - 1.0) <3E7261D4-C660-35BB-ACC7-026BA82DA509> /Applications/Vectorworks 2021 SP3/*/Artlantis_Export_EN
0x125b9b000 - 0x125cc6ff7 +com.abvent.fr.catl (9.0.0 - 9.0.0 for Artlantis 2020) <FF2281EE-7C45-314E-9D06-A73C389E2DB3> /Applications/Vectorworks 2021 SP3/*/CATL.framework/Versions/V9/CATL
0x125f96000 - 0x1260d2ffb +com.ingenicad.ArtlantisExport (25.0 - 1.0) <50BAC4E2-86E3-3E95-9F04-1AF6B34627C3> /Applications/Vectorworks 2021 SP3/*/Atl6_Export_Lib_2021_EN
0x126178000 - 0x1262e2fff +com.abvent.fr.catl (6.5.0 - 6.5.0 for Artlantis 6.5) <3E96835D-DD4D-32A0-8DB1-142BFB36B451> /Applications/Vectorworks 2021 SP3/*/CATL.framework/Versions/V6.5/CATL
0x126426000 - 0x126562ff7 +com.ingenicad.ArtlantisExport (25.0 - 1.0) <E0CA9167-0291-3746-9D89-EC395112C60F> /Applications/Vectorworks 2021 SP3/*/Atl8_Export_Lib_2021_EN
0x126608000 - 0x126786ff7 +com.abvent.fr.catl (8.0.0 - 8.0.0 for Artlantis 2019) <24812299-F4A7-319A-931B-55FE9B990E0B> /Applications/Vectorworks 2021 SP3/*/CATL.framework/Versions/V8/CATL
0x126a68000 - 0x126daeffb +de.computerworks.vectorworks.Attr suchen und aendern CW (D26.0.0 R1 505805+/11731+ - 1.0) <B915C483-DB41-3746-B3E5-35BA74C0B373> /Applications/Vectorworks 2021 SP3/*/Attr suchen und aendern CW
0x12714c000 - 0x12740dfff +de.computerworks.vectorworks.Attribute zu Grundeinst CW (D26.0.0 R1 505805+/11731+ - 1.0) <C4E0E0E5-84E7-331B-9EAB-8A0ADC436819> /Applications/Vectorworks 2021 SP3/*/Attribute zu Grundeinst CW
0x12770d000 - 0x1279cbff7 +de.computerworks.vectorworks.Attribute zu Klassenattr CW (D26.0.0 R1 505805+/11731+ - 1.0) <24AA765E-C4C1-3933-9EEC-4401E10C3CFD> /Applications/Vectorworks 2021 SP3/*/Attribute zu Klassenattr CW
0x127cc9000 - 0x127fc7ff7 +Ausserh Bereich loeschen CW (D26.0.0 R1 505805+/11731+ - 1.0) <1C979AD6-B652-3808-B937-718752CDEE5E> /Applications/Vectorworks 2021 SP3/*/Ausserh Bereich loeschen CW
0x1282fa000 - 0x12866efff +de.computerworks.vectorworks.Baugrube Aufschuettung CW (D26.0.0 R1 505805+/11731+ - 1.0) <8258A925-9068-3315-B281-78394245E4A6> /Applications/Vectorworks 2021 SP3/*/Baugrube Aufschuettung CW
0x128a06000 - 0x128ce1ff3 +Baumgruppe CW (D26.0.0 R1 505805+/11731+ - 1.0) <4DF93DD2-72DD-346E-8DB6-F1B6CE34AC53> /Applications/Vectorworks 2021 SP3/*/Baumgruppe CW
0x128ffb000 - 0x1292baff7 +Bemassungsgenauigkeit um CW (D26.0.0 R1 505805+/11731+ - 1.0) <B67D0FF3-0E73-35B4-A509-9F9983C54C56> /Applications/Vectorworks 2021 SP3/*/Bemassungsgenauigkeit um CW
0x1295ba000 - 0x12970fffb +net.nemetschek.vectorworks.BIMobject (1.0) <44934C0C-3254-322B-9753-AD4263D07C61> /Applications/Vectorworks 2021 SP3/*/BIMobject
0x1297ce000 - 0x129aa5ff3 +Blatt einrichten CW (D26.0.0 R1 505805+/11731+ - 1.0) <3F30CE47-1016-3D65-8E1A-6E4F6BA4B811> /Applications/Vectorworks 2021 SP3/*/Blatt einrichten CW
0x129dc1000 - 0x12a0daff7 +Boeschung CW (D26.0.0 R1 505805+/11731+ - 1.0) <16510560-91C0-38B3-B321-4B86D16DF828> /Applications/Vectorworks 2021 SP3/*/Boeschung CW
0x12a424000 - 0x12a81dfff +com.deersoft.braceworxs.braceworxsvwxplg (0.13.2) <C425A62F-E43F-3A22-9599-D13E5AB962A5> /Applications/Vectorworks 2021 SP3/*/BraceWorxsVwxPlg
0x12aa4c000 - 0x12ada7ffb +de.computerworks.vectorworks.buildup CW (D26.0.0 R1 505805+/11731+ - 1.0) <A28EB3B5-AB27-3246-AC24-428D9E3F8459> /Applications/Vectorworks 2021 SP3/*/buildup CW
0x12b126000 - 0x12b2d8ffb +com.deersoft.CableTools (1.0) <D8CBE759-70E0-34AA-8D62-F5F8B99402E6> /Applications/Vectorworks 2021 SP3/*/CableTools
0x12b410000 - 0x12b573ff3 +com.cesyam.ARLM (25.0 - 1.0) <6D898099-6883-3CF7-A21F-BB1498DB4D8A> /Applications/Vectorworks 2021 SP3/*/CE_ARLM
0x12b63a000 - 0x12b835fe7 +com.cesyam.CE_Base (25.0.2 - 1.0) <4135F4C9-CE67-3598-9E2E-A4936D756217> /Applications/Vectorworks 2021 SP3/*/CE_Base
0x12b919000 - 0x12ba5affb +com.cesyam.Cotations (25.0 - 1.0) <7EBF7FB1-73E4-3B30-9DA6-F90F4231BC7B> /Applications/Vectorworks 2021 SP3/*/CE_Cotations
0x12bb05000 - 0x12bcf0fe7 +com.cesyam.infoslicence (25.0 - 1.0) <5C0C993D-910C-352E-8CCF-B48F958037BF> /Applications/Vectorworks 2021 SP3/*/CE_Infos_Licence
0x12bdc4000 - 0x12bf15ffb +com.cesyam.CE_PathPIM (25.0 - 1.0) <FA43A9C8-F910-37B0-8F80-FB358F660EDD> /Applications/Vectorworks 2021 SP3/*/CE_PathPIM
0x12bfd0000 - 0x12c0bbfff +com.cesyam.CE_Tubages (25.0 - 1.0) <288C73F2-95B0-3C43-B802-489C9897E178> /Applications/Vectorworks 2021 SP3/*/CE_Tubages
0x12c12a000 - 0x12c212ff3 +net.nemetschek.vectorworks.CeilingGrid (1.0) <48B13BF9-9458-33C1-8A06-114AB3CD7F40> /Applications/Vectorworks 2021 SP3/*/CeilingGrid
0x12c28a000 - 0x12c2dbffb +net.nemetschek.vectorworks.TesterModule (1.0) <F621059A-807D-3667-B3D5-83CE73DA1375> /Applications/Vectorworks 2021 SP3/*/CheckForUpdates
0x12c305000 - 0x12c37ffff +net.nemetschek.vectorworks.CheckSpelling (1.0) <F66DCD1A-B35D-3E3A-9BC8-E174F7C23448> /Applications/Vectorworks 2021 SP3/*/CheckSpelling
0x12c3b5000 - 0x12c507ff3 +net.nemetschek.vectorworks.ColorPalettes (1.0) <8FEDB744-B401-34B0-8E1A-B34230984A90> /Applications/Vectorworks 2021 SP3/*/ColorPalettes
0x12c5b8000 - 0x12c906ff7 +com.connectcad.connectCAD (1.0) <E2EABB42-CD57-3FE9-85F5-CDFCFADB400B> /Applications/Vectorworks 2021 SP3/*/connectCAD
0x12cb8e000 - 0x12cea7ff3 +de.computerworks.vectorworks.CWLibrarySondereinheiten (D26.0.0 R1 505805+/11731+ - 1.0) <F16D308E-27B9-3F96-84C0-A214EB9ACAE7> /Applications/Vectorworks 2021 SP3/*/CWLibrarySondereinheiten
0x12d1f7000 - 0x12d4ddfff +de.computerworks.vectorworks.CWLibraryUniversal1 (D26.0.0 R1 505805+/11731+ - 1.0) <DE986672-4849-3CB5-BDFC-DE130F11166B> /Applications/Vectorworks 2021 SP3/*/CWLibraryUniversal1
0x12d82b000 - 0x12dc41ff3 +Daemmung CW (D26.0.0 R1 505805+/11731+ - 1.0) <276E1B8D-CDCC-317F-92AE-198BE40D699E> /Applications/Vectorworks 2021 SP3/*/Daemmung CW
0x12e023000 - 0x12e262ff7 +net.nemetschek.vectorworks.DataTag (1.0) <CDCDD99B-E252-3CC4-AF79-10A07E7C478F> /Applications/Vectorworks 2021 SP3/*/DataTag
0x12e3b7000 - 0x12e75aff7 +Datei Info CW (D26.0.0 R1 505805+/11731+ - 1.0) <89FA14B8-D0D0-3960-973D-C2CF7F408124> /Applications/Vectorworks 2021 SP3/*/Datei Info CW
0x12eb59000 - 0x12ee40ff3 +de.computerworks.vectorworks.Datenbank abgleichen CW (D26.0.0 R1 505805+/11731+ - 1.0) <6C34E83B-03B7-3795-9F1C-4F69796BCB9C> /Applications/Vectorworks 2021 SP3/*/Datenbank abgleichen CW
0x12f175000 - 0x12f41cff3 +net.nemetschek.vectorworks.DebugModule (1.0) <5970E116-0BCC-31DE-B46F-A56F08ED4A49> /Applications/Vectorworks 2021 SP3/*/DebugModule
0x12f571000 - 0x12f5c6ff7 +net.nemetschek.vectorworks.DesignLayerViewport (1.0) <5D36F87E-7EAD-3C5E-ACF8-AA9E1248BCB0> /Applications/Vectorworks 2021 SP3/*/DesignLayerViewport
0x12f5f4000 - 0x12f6e5ffb +net.nemetschek.vectorworks.DetailCallout (1.0) <C7D3BB28-7611-3734-B96D-214B4232F01A> /Applications/Vectorworks 2021 SP3/*/DetailCallout
0x12f763000 - 0x12fa31ffb +Dokument einrichten CW (D26.0.0 R1 505805+/11731+ - 1.0) <B1EE2119-468A-3CE4-862D-AB7D7882535A> /Applications/Vectorworks 2021 SP3/*/Dokument einrichten CW
0x12fd3a000 - 0x12fe22ff7 +net.nemetschek.vectorworks. (1.0) <A410B1F5-3393-30BB-B729-0F55DDD4EB7D> /Applications/Vectorworks 2021 SP3/*/Duplicate Along Path
0x12fe90000 - 0x12ff66ffb +net.nemetschek.vectorworks. (1.0) <DC1DEC55-8A12-3E00-868F-71BFB976AFC6> /Applications/Vectorworks 2021 SP3/*/Duplicate Symbol In Wall
0x12ffd1000 - 0x1302c5ff3 +de.computerworks.vectorworks.Duplizieren an Pfad CW (D26.0.0 R1 505805+/11731+ - 1.0) <1DE446DA-BD08-3D02-ACB9-760FC7805BB2> /Applications/Vectorworks 2021 SP3/*/Duplizieren an Pfad CW
0x1305f9000 - 0x1308d1ffb +de.computerworks.vectorworks.Duplizieren auf Ebenen CW (D26.0.0 R1 505805+/11731+ - 1.0) <15F48CCD-7CFB-3B97-ACC5-56049A8A5054> /Applications/Vectorworks 2021 SP3/*/Duplizieren auf Ebenen CW
0x130beb000 - 0x130ec1ff3 +de.computerworks.vectorworks.Durch Symbol ersetzen CW (26.0.3 - 1.0) <12CDBC82-674A-35F3-9367-27FCC60B65CE> /Applications/Vectorworks 2021 SP3/*/Durch Symbol ersetzen CW
0x1311d4000 - 0x1342bdff7 +net.nemetschek.vectorworks. (1.0) <953F5C77-88AE-3412-B67C-63238BBACFC6> /Applications/Vectorworks 2021 SP3/*/DWG Library
0x135404000 - 0x135751ffb +EbenenKlassen Manager CW (D26.0.0 R1 505805+/11731+ - 1.0) <E0A33922-F995-3E9F-85CC-13F9AC519370> /Applications/Vectorworks 2021 SP3/*/EbenenKlassen Manager CW
0x135ad1000 - 0x135b29ff3 +net.nemetschek.vectorworks.EditShader (1.0) <4E3B32F6-06EC-310E-8009-558BCC6E6EA7> /Applications/Vectorworks 2021 SP3/*/EditShader
0x135b57000 - 0x135f00ff7 +Einzelstempel CW (D26.0.0 R1 505805+/11731+ - 1.0) <8FB01A83-7D1F-34A8-B4B8-A7E9170B6FE2> /Applications/Vectorworks 2021 SP3/*/Einzelstempel CW
0x1362f9000 - 0x1364dcff7 +de.computerworks.vectorworks.Electrics (1.0 - 1.0) <409425A3-4A25-38D1-912A-77FD10ED186C> /Applications/Vectorworks 2021 SP3/*/Electrics
0x1365f0000 - 0x1369c0fff +net.nemetschek.vectorworks.EnergyAnalysis (1.0) <B4FA0312-7375-3198-8E3E-C9F9737E6AA9> /Applications/Vectorworks 2021 SP3/*/EnergyAnalysis
0x136bff000 - 0x13829bfff +net.nemetschek.ExcelLibrary (1.0 - 1) <E8C574F3-746C-3002-B6E8-5B4CD828B934> /Applications/Vectorworks 2021 SP3/*/ExcelLibrary
0x1390b0000 - 0x1394ebff7 +de.computerworks.vectorworks.Export AufmassKoordinaten (D26.0.0 R1 505805+/11731+ - 1.0) <3BB9F4D2-A1BB-306C-8D98-71A4781A3766> /Applications/Vectorworks 2021 SP3/*/Export AufmassKoordinaten
0x1399b9000 - 0x139ca2ff3 +de.computerworks.vectorworks.Export easyjob CW (D26.0.0 R1 505805+/11731+ - 1.0) <AC6CC7EB-C94B-323E-884D-0911B0F69BA3> /Applications/Vectorworks 2021 SP3/*/Export easyjob CW
0x139fc5000 - 0x13a3fbffb +de.computerworks.vectorworks.Export Objektdaten CW (D26.0.0 R1 505805+/11731+ - 1.0) <D3AAB450-C549-3C67-9412-B894F6B5338A> /Applications/Vectorworks 2021 SP3/*/Export Objektdaten CW
0x13a8a7000 - 0x13a9fcff3 +net.nemetschek.vectorworks.Export3DPDF (1.0) <1E6D3807-4702-3547-9275-7BF3B41A23B3> /Applications/Vectorworks 2021 SP3/*/Export3DPDF
0x13aab0000 - 0x13ac29ffb +net.nemetschek.vectorworks.TesterModule (1.0) <03870DFC-255B-3807-8CBC-BED54BEAFE69> /Applications/Vectorworks 2021 SP3/*/ExportWebGl
0x13acdc000 - 0x13add1ff7 +net.nemetschek.vectorworks. (1.0) <E6104257-A0DC-3AFE-874A-807CEB8A970B> /Applications/Vectorworks 2021 SP3/*/ExtrudeAlongPath
0x13ae4d000 - 0x13af91ffb +net.nemetschek.vectorworks. (1.0) <56832557-F5BD-3A72-A6B6-C2605AD469FD> /Applications/Vectorworks 2021 SP3/*/Eyedropper Tool
0x13b035000 - 0x13b2f6ff3 +de.computerworks.vectorworks.Farbtest CW (D26.0.0 R1 505805+/11731+ - 1.0) <C37957B6-2F90-3163-827F-848639921C13> /Applications/Vectorworks 2021 SP3/*/Farbtest CW
0x13b5f2000 - 0x13b8b4ffb +Farbverlauftest CW (D26.0.0 R1 505805+/11731+ - 1.0) <1E71098C-29CE-334D-98A4-939CF879B227> /Applications/Vectorworks 2021 SP3/*/Farbverlauftest CW
0x13bbb7000 - 0x13c3e8ffb +de.computerworks.vectorworks.Fenster CW (D26.0.0 R1 505805+/11731+ - 1.0) <D2D2B2ED-0F54-3B77-B3FF-1C5F6029A1BF> /Applications/Vectorworks 2021 SP3/*/Fenster CW
0x13cd13000 - 0x13cd64ff3 +net.nemetschek.vectorworks. (1.0) <0BF86EF0-498F-3588-9BC6-A7A6DF0D0340> /Applications/Vectorworks 2021 SP3/*/Fit To Objects
0x13cd8e000 - 0x13ce81ff7 +net.nemetschek.vectorworks.FitWallsToRoof (1.0) <B40E2949-A621-3EE6-A640-B4CB6732152F> /Applications/Vectorworks 2021 SP3/*/FitWallsToRoof
0x13ceee000 - 0x13d1d9ffb +de.computerworks.vectorworks.Fixieren CW (D26.0.0 R1 505805+/11731+ - 1.0) <F4CF4F19-CA77-3CE0-9FED-9947A7EFB8C0> /Applications/Vectorworks 2021 SP3/*/Fixieren CW
0x13d50a000 - 0x13d67effb +net.nemetschek.vectorworks.FramingMember (1.0) <EB56F633-3E82-39BC-9455-56B34C181FEF> /Applications/Vectorworks 2021 SP3/*/FramingMember
0x13d75f000 - 0x13da1eff7 +de.computerworks.vectorworks.Fuellmustertest CW (D26.0.0 R1 505805+/11731+ - 1.0) <C655F573-9706-3BAC-93CE-F61E64F2EFA9> /Applications/Vectorworks 2021 SP3/*/Fuellmustertest CW
0x13dd20000 - 0x13deedff7 +net.nemetschek.vectorworks.Fundamentals (1.0) <BA4CF6FB-868D-33FE-9117-E04E7C3B6E1F> /Applications/Vectorworks 2021 SP3/*/Fundamentals
0x13dfef000 - 0x13e48cff3 +Gebaeude CW (D26.0.0 R1 505805+/11731+ - 1.0) <46D190D1-3DF4-38E8-B533-D451406F8671> /Applications/Vectorworks 2021 SP3/*/Gebaeude CW
0x13e8ec000 - 0x13ec17fff +Gefaelle Ansicht CW (D26.0.0 R1 505805+/11731+ - 1.0) <5F8D717F-8FA4-3B97-BA05-E07F821FC518> /Applications/Vectorworks 2021 SP3/*/Gefaelle Ansicht CW
0x13ef71000 - 0x13f2e6ffb +de.computerworks.vectorworks.Gefaelle Grundriss CW (26.0.3 - 1.0) <BFE912CF-FE68-3F73-9962-E2BE2942A46F> /Applications/Vectorworks 2021 SP3/*/Gefaelle Grundriss CW
0x13f68b000 - 0x13fa08ff7 +de.computerworks.vectorworks.Gelaendeschnitt anlegen CW (D26.0.0 R1 505805+/11731+ - 1.0) <5EBDC479-FD21-3FCB-A3BB-891F4CBA46BB> /Applications/Vectorworks 2021 SP3/*/Gelaendeschnitt anlegen CW
0x13fdce000 - 0x13ff04ff3 +net.nemetschek.vectorworks.GeometryLib (1.0) <BB77D9A5-15FF-3795-BF72-B5CFB45F4CCB> /Applications/Vectorworks 2021 SP3/*/GeometryLib
0x13ff8e000 - 0x1402afff7 +Gesamtflaeche CW (D26.0.0 R1 505805+/11731+ - 1.0) <D8E65BDD-ACDC-3EAA-B26A-505DB589486E> /Applications/Vectorworks 2021 SP3/*/Gesamtflaeche CW
0x140606000 - 0x140926fff +Gesamtumfang CW (D26.0.0 R1 505805+/11731+ - 1.0) <665019EF-C4D0-344F-B4D3-28BEC8117EE8> /Applications/Vectorworks 2021 SP3/*/Gesamtumfang CW
0x140c7d000 - 0x140edcff7 +net.nemetschek.vectorworks.GIS (1.0) <F2EDFF8B-B033-3D13-A24D-25C586727B05> /Applications/Vectorworks 2021 SP3/*/GIS
0x141009000 - 0x142479ff7 +libgdal.27.dylib (0) <7AFBEF2A-5F4B-3249-800B-336155E7DC28> /Applications/Vectorworks 2021 SP3/*/libgdal.27.dylib
0x142a89000 - 0x142addfff +libwebp.7.dylib (0) <41532BC1-E0E7-35D2-9C48-8817CBA0F274> /Applications/Vectorworks 2021 SP3/*/libwebp.7.dylib
0x142aec000 - 0x142ca5ff7 +libxerces-c-3.2.dylib (0) <C2E80F85-9838-340C-873F-A346CC6A186D> /Applications/Vectorworks 2021 SP3/*/libxerces-c-3.2.dylib
0x142dfe000 - 0x142e35ffb +libopenjp2.7.dylib (0) <924BA0E8-2E7E-3E3C-81F1-68FF596414E4> /Applications/Vectorworks 2021 SP3/*/libopenjp2.7.dylib
0x142e3f000 - 0x143074ff3 +net.nemetschek.vectorworks.GridAxis (1.0) <138236C2-C968-38B7-89D6-4173A6F4E299> /Applications/Vectorworks 2021 SP3/*/GridAxis
0x1432a8000 - 0x143576ffb +de.computerworks.vectorworks.Grundflaechenzahl CW (D26.0.0 R1 505805+/11731+ - 1.0) <2108267F-DF2F-3373-AEC0-4C3689EF379C> /Applications/Vectorworks 2021 SP3/*/Grundflaechenzahl CW
0x14388b000 - 0x1438dcfff +net.nemetschek.vectorworks.Guides (1.0) <29659711-B281-3B0E-9A51-C728A8E567A2> /Applications/Vectorworks 2021 SP3/*/Guides
0x143906000 - 0x143a59fff +net.nemetschek.vectorworks.Heliodon (1.0) <95403F91-3643-379B-A18D-0264E7E9A7E2> /Applications/Vectorworks 2021 SP3/*/Heliodon
0x143b22000 - 0x143b7efff +net.nemetschek.vectorworks.HelixSpiral (1.0) <B18FA991-E892-37DF-B74F-C1C0715C2E02> /Applications/Vectorworks 2021 SP3/*/HelixSpiral
0x143bb1000 - 0x143e8cffb +de.computerworks.vectorworks.Hilfslinien CW (D26.0.0 R1 505805+/11731+ - 1.0) <B24ABAC1-B8C2-39F5-8971-F2FD85E80AC3> /Applications/Vectorworks 2021 SP3/*/Hilfslinien CW
0x1441b9000 - 0x1442b0ff3 +net.nemetschek.vectorworks.HSETUEnergyExport (1.0 - 1.0) <9C364BF9-87A8-30D8-B42E-73CF2A75D77E> /Applications/Vectorworks 2021 SP3/*/HSETUEnergyExport
0x144321000 - 0x1444b3ff7 +net.nemetschek.vectorworks.HumanFigure (1.0) <80BC64B5-8622-3173-A657-B14D54FD9379> /Applications/Vectorworks 2021 SP3/*/HumanFigure
0x14455e000 - 0x1448cbff7 +Hyperlink CW (26.0.3 - 1.0) <A7C1656E-E94A-30A9-BB72-4013A8B54958> /Applications/Vectorworks 2021 SP3/*/Hyperlink CW
0x144c6f000 - 0x14554bffb +net.nemetschek.vectorworks.IFCLibrary (1.0) <D1C87729-F6D9-367A-A686-98F17921D643> /Applications/Vectorworks 2021 SP3/*/IFCLibrary
0x1457db000 - 0x145bfdfff +de.computerworks.vectorworks.Import AufmassKoordinaten (D26.0.0 R1 505805+/11731+ - 1.0) <A810DF8C-6CBD-3C9A-B5F6-C5D3FC05813B> /Applications/Vectorworks 2021 SP3/*/Import AufmassKoordinaten
0x146097000 - 0x14635effb +Import Farbpalette CW (D26.0.0 R1 505805+/11731+ - 1.0) <49804B83-1F6C-3D39-9C32-A7CB23A91AAB> /Applications/Vectorworks 2021 SP3/*/Import Farbpalette CW
0x146667000 - 0x146960ff7 +de.computerworks.vectorworks.Import mtextur CW (26.0.3 - 1.0) <2E12B822-1878-3828-88E7-F0A5BD5D14D4> /Applications/Vectorworks 2021 SP3/*/Import mtextur CW
0x146c8a000 - 0x146e0ffff +net.nemetschek.vectorworks.ImportBCF (1.0) <718EFD35-B33A-300E-B5E7-98ADD7F56970> /Applications/Vectorworks 2021 SP3/*/ImportBCF
0x146ec8000 - 0x14719dff3 +de.computerworks.vectorworks.In Kanten umwandeln CW (D26.0.0 R1 505805+/11731+ - 1.0) <9BD69C1C-AC73-3805-9BCB-1C7DF7EB7779> /Applications/Vectorworks 2021 SP3/*/In Kanten umwandeln CW
0x1474af000 - 0x147793ff7 +de.computerworks.vectorworks.In Polylinie umwandeln CW (D26.0.0 R1 505805+/11731+ - 1.0) <CD25E534-FD8F-31ED-BAB8-D206EF0F0D5F> /Applications/Vectorworks 2021 SP3/*/In Polylinie umwandeln CW
0x147ab9000 - 0x147dc2ffb +de.computerworks.vectorworks.In Wand umwandeln CW (D26.0.0 R1 505805+/11731+ - 1.0) <3ABA8892-71FE-3439-9DE1-9A062749EBDA> /Applications/Vectorworks 2021 SP3/*/In Wand umwandeln CW
0x1480fa000 - 0x148442fff +Info CW (D26.0.0 R1 505805+/11731+ - 1.0) <0E7A5974-E662-31AE-B15C-FD4E1F53AB3B> /Applications/Vectorworks 2021 SP3/*/Info CW
0x1487b7000 - 0x148b2cffb +de.computerworks.vectorworks.Kantenausbildung CW (D26.0.0 R1 505805+/11731+ - 1.0) <590E5E61-DF91-339B-95B4-F078F86D6B70> /Applications/Vectorworks 2021 SP3/*/Kantenausbildung CW
0x148ec0000 - 0x1491a0ff7 +de.computerworks.vectorworks.Klotoiden CW (D26.0.0 R1 505805+/11731+ - 1.0) <A65E71A8-1CA0-3C3B-BDD4-2181361E39CE> /Applications/Vectorworks 2021 SP3/*/Klotoiden CW
0x1494c0000 - 0x1497b0ffb +de.computerworks.vectorworks.Korbbogen CW (D26.0.0 R1 505805+/11731+ - 1.0) <2A74DD0E-BC77-3C59-B502-6F63442F3BBC> /Applications/Vectorworks 2021 SP3/*/Korbbogen CW
0x149ae3000 - 0x149ee7ff3 +de.computerworks.vectorworks.Kotenbemassung CW (D26.0.0 R1 505805+/11731+ - 1.0) <C06882EA-6705-3DD5-B4B2-A4F0F927E095> /Applications/Vectorworks 2021 SP3/*/Kotenbemassung CW
0x14a321000 - 0x14ab22ff3 +net.nemetschek.vectorworks.LandscapeModule (1.0) <742C4178-D2B2-349C-BE0A-D21875D121CC> /Applications/Vectorworks 2021 SP3/*/Landscape
0x14ae42000 - 0x14b0c4ffb +net.nemetschek.vectorworks.LandscapeIrrigation (1.0) <622D82CE-D5AE-3E4F-922B-17515D4E3645> /Applications/Vectorworks 2021 SP3/*/LandscapeIrrigation
0x14b20a000 - 0x14b5e9ff7 +Legende CW (D26.0.0 R1 505805+/11731+ - 1.0) <A727223A-9848-3224-92BE-E47BF3E8ED82> /Applications/Vectorworks 2021 SP3/*/Legende CW
0x14ba03000 - 0x14bd63ff7 +de.computerworks.vectorworks.Lichtschacht CW (D26.0.0 R1 505805+/11731+ - 1.0) <BF212EB8-BABF-32DA-BEF9-D9D4E9998E23> /Applications/Vectorworks 2021 SP3/*/Lichtschacht CW
0x14c0f2000 - 0x14c264ff7 +com.BenghiatLighting.LightingPipe (2.0.2 - 78) <F161E8A9-7ED7-35F4-9B61-C39024D6DB64> /Applications/Vectorworks 2021 SP3/*/LightingPipe
0x14c333000 - 0x14c5f2ffb +Linienartentest CW (D26.0.0 R1 505805+/11731+ - 1.0) <37266C71-CAD9-37A3-A6D4-BA3A08145FF5> /Applications/Vectorworks 2021 SP3/*/Linienartentest CW
0x14c8f1000 - 0x14cbaeff7 +de.computerworks.vectorworks.Linienendz skalieren CW (D26.0.0 R1 505805+/11731+ - 1.0) <62B7536B-2A08-34E5-AEC6-D3037DAD0B74> /Applications/Vectorworks 2021 SP3/*/Linienendz skalieren CW
0x14ceac000 - 0x14d08dff3 +net.nemetschek.vectorworks.Marionette (1.0) <B96E7CB5-54F1-3120-81E8-0A71BFCF48FA> /Applications/Vectorworks 2021 SP3/*/Marionette
0x14d186000 - 0x14d4e6ff7 +net.nemetschek.vectorworks.Markers (1.0) <EDF95F2D-2EF3-36AB-83A5-5774FEDD1DA2> /Applications/Vectorworks 2021 SP3/*/Markers
0x14d87d000 - 0x14dc52ff7 +de.computerworks.vectorworks.Massendokumentation CW (D26.0.0 R1 505805+/11731+ - 1.0) <D4A149D9-13BE-3257-97B6-6BB1A68FB920> /Applications/Vectorworks 2021 SP3/*/Massendokumentation CW
0x14e02c000 - 0x14e396ff3 +Massstabsbalken CW (D26.0.0 R1 505805+/11731+ - 1.0) <25A2279C-8763-30F4-B2FE-3F49E88DE691> /Applications/Vectorworks 2021 SP3/*/Massstabsbalken CW
0x14e720000 - 0x14e9e0ffb +de.computerworks.vectorworks.Material zu Klassen CW (D26.0.0 R1 505805+/11731+ - 1.0) <6E1BB1FF-DA4E-3A97-9B59-E650B22A069B> /Applications/Vectorworks 2021 SP3/*/Material zu Klassen CW
0x14ece2000 - 0x14eff3ffb +Mittelachse CW (D26.0.0 R1 505805+/11731+ - 1.0) <40E01168-2DE6-3B17-8E57-55729F4811AE> /Applications/Vectorworks 2021 SP3/*/Mittelachse CW
0x14f336000 - 0x14f472ffb +net.nemetschek.vectorworks.MOSAImport (1.0) <31203588-9BB6-3B06-901A-A265C68ADEC5> /Applications/Vectorworks 2021 SP3/*/MOSAImport
0x14f514000 - 0x14f5e7fff +net.nemetschek.vectorworks.MovePage (1.0) <44F7BB72-3206-3FB8-B4DA-887023B3156A> /Applications/Vectorworks 2021 SP3/*/MovePage
0x14f652000 - 0x14faecff7 +de.computerworks.vectorworks.Multistempel CW (D26.0.0 R1 505805+/11731+ - 1.0) <B21EB2F2-6A44-3AA4-980C-60683300C6A9> /Applications/Vectorworks 2021 SP3/*/Multistempel CW
0x15001c000 - 0x15016dff7 +net.nemetschek.vectorworks.NBSChorus (1.0) <F7831404-2B32-3771-A9F3-690DA01D2644> /Applications/Vectorworks 2021 SP3/*/NBSChorus
0x150218000 - 0x15048fff3 +net.nemetschek.vectorworks.NotesManager (1.0) <C19F948B-2024-33DB-B2D2-3987BA85FCF8> /Applications/Vectorworks 2021 SP3/*/NotesManager
0x1505b0000 - 0x1508a6ff7 +de.computerworks.vectorworks.Nullpunkte CW (D26.0.0 R1 505805+/11731+ - 1.0) <72EF4F63-FF74-35F0-A78C-EFC219147953> /Applications/Vectorworks 2021 SP3/*/Nullpunkte CW
0x150be6000 - 0x150ea7ff3 +de.computerworks.vectorworks.Objektinformationen CW (D26.0.0 R1 505805+/11731+ - 1.0) <E6A1E83E-F928-3A0B-8306-99AA52B73675> /Applications/Vectorworks 2021 SP3/*/Objektinformationen CW
0x1511a8000 - 0x15130ffff +net.nemetschek.vectorworks.TesterModule (1.0) <2109A406-FEB6-3639-A153-90E865999ED8> /Applications/Vectorworks 2021 SP3/*/OBJExporter
0x1513c7000 - 0x151783ff3 +libexiv2.26.0.0.dylib (0) <A0D2724E-5C06-34F8-A2CE-FC59EAA59046> /Applications/Vectorworks 2021 SP3/*/libexiv2.26.0.0.dylib
0x1518de000 - 0x1519ceff7 +net.nemetschek.vectorworks. (1.0) <F5205C48-1146-380F-BEEA-71811F46EE48> /Applications/Vectorworks 2021 SP3/*/Offset Tool
0x151a3e000 - 0x151a91ff3 +net.nemetschek.vectorworks.TesterModule (1.0) <D5333E9D-F866-3CE0-8697-F8DC06BB522B> /Applications/Vectorworks 2021 SP3/*/OnlineResources
0x151abe000 - 0x151ba1ff3 +net.nemetschek.vectorworks.PDFPage (1.0) <98881FEB-F37F-3093-8497-AB73088FF6E2> /Applications/Vectorworks 2021 SP3/*/PDFPage
0x151c18000 - 0x151d3cff7 +net.nemetschek.vectorworks.PDFUtilityLib (1.0) <8AD6BACC-93AA-35CB-AFC9-2B676B3CEF44> /Applications/Vectorworks 2021 SP3/*/PDFUtilityLib
0x151db6000 - 0x1523b5fff +DL150AGM (150.4.5) <B7691260-B02D-3622-A950-30C5FD27DAB0> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150AGM.framework/Versions/A/DL150AGM
0x15262c000 - 0x152b7dff7 +com.datalogics.DL150CoolType (DL150CoolType 15.0.4.4 - 15.0.4.4) <519B6A8C-8F9D-3AB4-9131-1DDD1BD70417> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150CoolType.framework/Versions/A/DL150CoolType
0x152d73000 - 0x153ab8fff +com.adobe.ICUData (4.0 - 4.0) <A60A8D26-47CF-3168-9AD1-B73BF8C00BCA> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x153ae9000 - 0x153b0dff7 +DL150BIBUtils (150.4) <55D27617-ECB8-3752-856B-9C1A30D6D973> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150BIBUtils.framework/Versions/A/DL150BIBUtils
0x153b2b000 - 0x153b4bfff +DL150BIB (150.4.2) <FF98B725-5100-3A13-8C0C-9BA684408B93> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150BIB.framework/Versions/A/DL150BIB
0x153b66000 - 0x153c6ffff +DL150PDFPort (0) <D66B8CA9-8EDE-3CC8-8870-9259043A9F28> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150PDFPort.framework/Versions/A/DL150PDFPort
0x153cc3000 - 0x153e05ff7 +com.datalogics.DL150ACE (DL150ACE 15.0.4.3 - 15.0.4.3) <1C8E3EB4-BA18-3D46-8778-BF8341E532DA> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150ACE.framework/Versions/A/DL150ACE
0x153e51000 - 0x153f0bff7 +com.adobe.ICUConverter (4.0 - 4.0) <4C37F627-6A96-3301-8889-28CCD7FF3DB6> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x153f3a000 - 0x153f74ff7 +DL150ARE (150.4) <A740923E-D319-3FA7-BA78-24470FE5990F> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150ARE.framework/Versions/A/DL150ARE
0x153f9a000 - 0x153fb6ff7 +DL150PDFSettings (1) <0527B161-E666-3BE4-87D6-288F708324E3> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150PDFSettings.framework/Versions/A/DL150PDFSettings
0x153fcf000 - 0x15402bfff +DL150AdobeXMP (150.4.1) <7BB747E6-0806-39E5-83EE-929A7CC0CB58> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150AdobeXMP.framework/Versions/A/DL150AdobeXMP
0x15404f000 - 0x15406fff7 +DL150AXE8SharedExpat (150.4) <80786033-A108-35B8-8E5A-9BE5B3073984> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150AXE8SharedExpat.framework/Versions/A/DL150AXE8SharedExpat
0x154082000 - 0x154113ff7 +DL150JP2KLib (150.4.1) <2D461F81-8570-3C85-8E09-0C4DF584678B> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150JP2KLib.framework/Versions/A/DL150JP2KLib
0x154132000 - 0x154895fff +com.datalogics.DL150PDFL (DL150PDFL 15.0.4.9 - 15.0.4.9) <27AF6E78-DCCD-3973-BE38-F4F002B8D176> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150PDFL.framework/Versions/A/DL150PDFL
0x154b4b000 - 0x154fdeffb +Pflanze CW (26.0.3 - 1.0) <140B1893-B14E-342A-9FA7-22EFACCF1E1B> /Applications/Vectorworks 2021 SP3/*/Pflanze CW
0x15547d000 - 0x1557dcffb +de.computerworks.vectorworks.Pflanze VBvisual CW (26.0.3 - 1.0) <CFCD7A60-6E89-3C63-948E-6B01A376D17E> /Applications/Vectorworks 2021 SP3/*/Pflanze VBvisual CW
0x155b62000 - 0x155bb3ffb +net.nemetschek.vectorworks. (1.0) <D47702E3-9E29-3E63-B119-7473A5FBD794> /Applications/Vectorworks 2021 SP3/*/Plug-In Support
0x155bde000 - 0x156e35ff3 +net.nemetschek.vectorworks.PointCloud (1.0) <8F510CB1-65EA-37C2-8DE0-017294C3666E> /Applications/Vectorworks 2021 SP3/*/PointCloud
0x15798a000 - 0x157998ff7 +libboost_filesystem.dylib (0) <C0B2798E-A574-34AD-A26B-DAC75A957FE4> /Applications/Vectorworks 2021 SP3/*/libboost_filesystem.dylib
0x1579a8000 - 0x1579acfff +libboost_date_time.dylib (0) <5D7561CA-432F-30FF-AC5B-5E5DC954E61C> /Applications/Vectorworks 2021 SP3/*/libboost_date_time.dylib
0x1579ba000 - 0x1579bbffb +libboost_chrono.dylib (0) <8375BBCB-192F-30D8-B9D2-8EB41923457A> /Applications/Vectorworks 2021 SP3/*/libboost_chrono.dylib
0x1579c3000 - 0x1579e6ff7 +libboost_serialization.dylib (0) <D85DDBA8-89F3-3BB6-9F84-C7CCB59C4799> /Applications/Vectorworks 2021 SP3/*/libboost_serialization.dylib
0x157a22000 - 0x157a24fff +libboost_system.dylib (0) <E4B85D84-F1BC-37E1-BB95-E9648104446E> /Applications/Vectorworks 2021 SP3/*/libboost_system.dylib
0x157a2c000 - 0x157b01ff3 +net.nemetschek.vectorworks.TesterModule (1.0) <DC15B462-3CA3-30A9-9A8F-2385254C0823> /Applications/Vectorworks 2021 SP3/*/PointTools
0x157b6b000 - 0x157e4efff +de.computerworks.vectorworks.Polygon oeffnen CW (D26.0.0 R1 505805+/11731+ - 1.0) <347B68EE-6E31-33A2-AE6C-E3A8123F1B6F> /Applications/Vectorworks 2021 SP3/*/Polygon oeffnen CW
0x158169000 - 0x158429ff7 +de.computerworks.vectorworks.Polygone triangulieren CW (D26.0.0 R1 505805+/11731+ - 1.0) <1FDAA354-F271-3269-B274-D8DF9DC35F1B> /Applications/Vectorworks 2021 SP3/*/Polygone triangulieren CW
0x158725000 - 0x1589e6ff7 +de.computerworks.vectorworks.Polypunkte reduzieren CW (D26.0.0 R1 505805+/11731+ - 1.0) <6E577278-1439-3A64-8279-F59208C8ABD8> /Applications/Vectorworks 2021 SP3/*/Polypunkte reduzieren CW
0x158ce9000 - 0x158fb2ff3 +de.computerworks.vectorworks.Polypunkte umnummerieren CW (D26.0.0 R1 505805+/11731+ - 1.0) <737BAA12-FDB5-3AEF-9B9F-8463C5745CD9> /Applications/Vectorworks 2021 SP3/*/Polypunkte umnummerieren CW
0x1592c3000 - 0x15939afff +net.nemetschek.vectorworks. (1.0) <CA2CCAF6-A475-3F15-BB61-5B7AEFA0BFA8> /Applications/Vectorworks 2021 SP3/*/Protractor Tool
0x159405000 - 0x1597e0ff7 +de.computerworks.vectorworks.Railing CW (26.0.3 - 1.0) <722C8C02-6BCD-3660-B800-4D39CB626D59> /Applications/Vectorworks 2021 SP3/*/Railing CW
0x159bb6000 - 0x159fb1ffb +de.computerworks.vectorworks.Rampe CW (D26.0.0 R1 505805+/11731+ - 1.0) <C7046A1E-EF0B-334B-86C3-9973B5BC4356> /Applications/Vectorworks 2021 SP3/*/Rampe CW
0x15a347000 - 0x15a6caffb +de.computerworks.vectorworks.Raster CW (D26.0.0 R1 505805+/11731+ - 1.0) <B765D46B-354B-3B81-8177-729C98065E62> /Applications/Vectorworks 2021 SP3/*/Raster CW
0x15aa86000 - 0x15ad4cfff +de.computerworks.vectorworks.Rasterbild einpassen CW (D26.0.0 R1 505805+/11731+ - 1.0) <9C091D29-DA79-3E02-AF21-E92A9BABEBA1> /Applications/Vectorworks 2021 SP3/*/Rasterbild einpassen CW
0x15b054000 - 0x15b61fff3 +Raum CW (26.0.3 - 1.0) <D9FE4FB7-6584-3A0A-976F-3D75887FB7B3> /Applications/Vectorworks 2021 SP3/*/Raum CW
0x15bba5000 - 0x15bf40ffb +de.computerworks.vectorworks.Rechtwinkelbemassung CW (D26.0.0 R1 505805+/11731+ - 1.0) <0731E812-0C62-3004-9CF9-FC36899077B2> /Applications/Vectorworks 2021 SP3/*/Rechtwinkelbemassung CW
0x15c2fd000 - 0x15c35fff3 +net.nemetschek.vectorworks.RenderSettings (1.0) <E84CF0D7-D77D-36E5-BB04-9BEBA8174C88> /Applications/Vectorworks 2021 SP3/*/RenderSettings
0x15c392000 - 0x15c5edfff +net.nemetschek.vectorworks.Renderworks (1.0) <9994C4A7-5125-3070-8AF5-2D3E9877EE4F> /Applications/Vectorworks 2021 SP3/*/Renderworks
0x15c7cb000 - 0x15c93affb +net.nemetschek.vectorworks.RenderworksCamera (1.0) <B9D2C4C2-E1F5-36ED-B062-3AB7D7625866> /Applications/Vectorworks 2021 SP3/*/RenderworksCamera
0x15ca14000 - 0x15cae9ff3 +net.nemetschek.vectorworks.Resize (1.0) <B9EECA63-D377-3D42-BAD3-5A2556C685A3> /Applications/Vectorworks 2021 SP3/*/Resize
0x15cb53000 - 0x15cd46ffb +net.nemetschek.vectorworks. (1.0) <2BBA3FD0-CF62-3E18-A68B-2E567CABCE65> /Applications/Vectorworks 2021 SP3/*/RevitLibrary
0x15ce74000 - 0x15da3effb +TB_Format2021Writers.tx (0) <4876E2CB-2276-391E-836F-1D87A419F782> /Applications/Vectorworks 2021 SP3/*/TB_Format2021Writers.tx
0x15ec9a000 - 0x15f426ffb +TB_Format2021Readers.tx (0) <93F4159C-002F-31A1-B55A-A50C1F0F7B76> /Applications/Vectorworks 2021 SP3/*/TB_Format2021Readers.tx
0x15ff55000 - 0x15ff66fff +TD_AssetXMLParser.tx (0) <9332A84F-6434-326E-8923-758E14A007C0> /Applications/Vectorworks 2021 SP3/*/TD_AssetXMLParser.tx
0x15ff71000 - 0x160543fff +TB_Format2021Classes.tx (0) <85D98CCB-B175-3BC4-98FD-ABF5894424F6> /Applications/Vectorworks 2021 SP3/*/TB_Format2021Classes.tx
0x1605f4000 - 0x1606c5fff +TB_Rebar.tx (0) <0CE36F66-EB5A-319C-A560-053A8F798F4C> /Applications/Vectorworks 2021 SP3/*/TB_Rebar.tx
0x1607af000 - 0x16093dff7 +liblibcrypto.dylib (0) <22D10CA5-13E4-3E8B-A27A-94F3974A260A> /Applications/Vectorworks 2021 SP3/*/liblibcrypto.dylib
0x1609ce000 - 0x160ba5ff3 +libOdBrepModeler.dylib (0) <152AD784-3A2B-3204-845D-43C0200F6261> /Applications/Vectorworks 2021 SP3/*/libOdBrepModeler.dylib
0x160c2b000 - 0x160c38ffb +liboless.dylib (0) <0DDC94B8-6E02-309E-9CBF-465D64177730> /Applications/Vectorworks 2021 SP3/*/liboless.dylib
0x160c3e000 - 0x160c5eff7 +libtbb.dylib (0) <496B712E-1478-373F-85E0-3B6544822F43> /Applications/Vectorworks 2021 SP3/*/libtbb.dylib
0x160c73000 - 0x160c88ff7 +libTD_Br.dylib (0) <684F19CC-0B6D-3D03-90C0-B7A06B5932D9> /Applications/Vectorworks 2021 SP3/*/libTD_Br.dylib
0x160ca0000 - 0x160cb8ffb +libTD_BrepBuilder.dylib (0) <E2B94A35-6EEB-3DCE-AEA9-9514F4518C01> /Applications/Vectorworks 2021 SP3/*/libTD_BrepBuilder.dylib
0x160cc4000 - 0x160cdfffb +libTD_BrepBuilderFiller.dylib (0) <1DED7398-A818-3CFF-B930-4518DE4D7177> /Applications/Vectorworks 2021 SP3/*/libTD_BrepBuilderFiller.dylib
0x160cef000 - 0x160d85ffb +libTD_BrepRenderer.dylib (0) <B3482DEF-0FDD-39F8-AE44-7F865915A677> /Applications/Vectorworks 2021 SP3/*/libTD_BrepRenderer.dylib
0x160db7000 - 0x160e6dffb +libTD_DbRoot.dylib (0) <21F9A2F1-89EB-339B-9087-AB3FB850D4B7> /Applications/Vectorworks 2021 SP3/*/libTD_DbRoot.dylib
0x160f1a000 - 0x161299fff +libTD_Ge.dylib (0) <B231FC2F-5ED1-39FB-A150-47AF388A1C66> /Applications/Vectorworks 2021 SP3/*/libTD_Ge.dylib
0x1613ed000 - 0x16161cfff +libTD_Gi.dylib (0) <53554070-AE6A-3317-A7EE-19E919AECE45> /Applications/Vectorworks 2021 SP3/*/libTD_Gi.dylib
0x16179a000 - 0x1618abfff +libTD_Gs.dylib (0) <78426146-C86F-3DDE-BD18-9209FAF1101B> /Applications/Vectorworks 2021 SP3/*/libTD_Gs.dylib
0x161991000 - 0x161a55ff3 +libTD_Root.dylib (0) <C394F4D1-182F-3294-A245-C8EDE5536EF6> /Applications/Vectorworks 2021 SP3/*/libTD_Root.dylib
0x161b0f000 - 0x161b17ff3 +libTD_SpatialIndex.dylib (0) <8A6EB75D-4398-3AB3-B232-57D1203ED1F5> /Applications/Vectorworks 2021 SP3/*/libTD_SpatialIndex.dylib
0x161b1e000 - 0x161b33ff3 +libTD_Zlib.dylib (0) <6039F057-C7E5-38F7-939B-A3F76390AC44> /Applications/Vectorworks 2021 SP3/*/libTD_Zlib.dylib
0x161b37000 - 0x161bddfff +TB_Analytical.tx (0) <59D16622-58F9-37CE-9AD2-5FCB0670DDA4> /Applications/Vectorworks 2021 SP3/*/TB_Analytical.tx
0x161ca3000 - 0x161ceaffb +TB_Architecture.tx (0) <64E9054C-E4C3-3EF2-86B0-3F40C0878A6A> /Applications/Vectorworks 2021 SP3/*/TB_Architecture.tx
0x161d43000 - 0x161ea5ffb +TB_Base.tx (0) <C7FD9D0F-1DA9-35DA-8F22-0AC36538B082> /Applications/Vectorworks 2021 SP3/*/TB_Base.tx
0x161ec4000 - 0x161fe1ffb +TB_Common.tx (0) <D0419499-3FF4-3EEF-86CF-447523341509> /Applications/Vectorworks 2021 SP3/*/TB_Common.tx
0x161fec000 - 0x16286bfff +TB_Database.tx (0) <90E812F6-C537-3D41-B647-64AFE9B854A6> /Applications/Vectorworks 2021 SP3/*/TB_Database.tx
0x163180000 - 0x163198fff +TB_ExLabelUtils.tx (0) <609E5B9D-6435-30EF-B993-947D2FC6F018> /Applications/Vectorworks 2021 SP3/*/TB_ExLabelUtils.tx
0x1631a6000 - 0x163287ff3 +TB_Family.tx (0) <51E446DE-D409-3F66-B628-F59E0F42C8B2> /Applications/Vectorworks 2021 SP3/*/TB_Family.tx
0x163342000 - 0x163798fff +TB_Format2011Classes.tx (0) <76B61ABD-88DD-3E84-AA51-A3A6B6F7A7DD> /Applications/Vectorworks 2021 SP3/*/TB_Format2011Classes.tx
0x163818000 - 0x163dafff7 +TB_Format2011Readers.tx (0) <00A7E0C6-EAA2-3370-95FF-FD8EDD7AB6E1> /Applications/Vectorworks 2021 SP3/*/TB_Format2011Readers.tx
0x164526000 - 0x1649ccff7 +TB_Format2012Classes.tx (0) <E3F1355F-850A-3D0E-B59D-BEF73EEDF327> /Applications/Vectorworks 2021 SP3/*/TB_Format2012Classes.tx
0x164a56000 - 0x165058ff7 +TB_Format2012Readers.tx (0) <3697F8FC-B7E7-36C7-B623-A0C504B63D0C> /Applications/Vectorworks 2021 SP3/*/TB_Format2012Readers.tx
0x165897000 - 0x165dd4fff +TB_Format2013Classes.tx (0) <98DC8351-04B3-351A-BCA8-EB5659CEE20D> /Applications/Vectorworks 2021 SP3/*/TB_Format2013Classes.tx
0x165e6d000 - 0x16651aff7 +TB_Format2013Readers.tx (0) <1FD9DB66-67D6-3211-BDC4-74F7B600F334> /Applications/Vectorworks 2021 SP3/*/TB_Format2013Readers.tx
0x166e4b000 - 0x16738fff7 +TB_Format2014Classes.tx (0) <CA3F97C2-87BE-319D-A8F4-2B3FFC73E513> /Applications/Vectorworks 2021 SP3/*/TB_Format2014Classes.tx
0x16742c000 - 0x167b05ff7 +TB_Format2014Readers.tx (0) <6F64E5FD-D6EC-3AA8-BA13-B8AE5DB5E576> /Applications/Vectorworks 2021 SP3/*/TB_Format2014Readers.tx
0x168495000 - 0x1689eaffb +TB_Format2015Classes.tx (0) <29D1A6CB-192B-3EF3-BFC3-7111902585FA> /Applications/Vectorworks 2021 SP3/*/TB_Format2015Classes.tx
0x168a8c000 - 0x169189ff7 +TB_Format2015Readers.tx (0) <7826204F-F4E3-31E5-B532-08DAF0183CD0> /Applications/Vectorworks 2021 SP3/*/TB_Format2015Readers.tx
0x169b74000 - 0x16a0dfffb +TB_Format2016Classes.tx (0) <1705F735-FA49-36D5-B65B-F96E82CD7A12> /Applications/Vectorworks 2021 SP3/*/TB_Format2016Classes.tx
0x16a185000 - 0x16a8aafff +TB_Format2016Readers.tx (0) <42C7E2E7-D044-3616-9133-7C00A3724EBD> /Applications/Vectorworks 2021 SP3/*/TB_Format2016Readers.tx
0x16b2e1000 - 0x16b861ff7 +TB_Format2017Classes.tx (0) <A396C28F-3C87-3F9B-8821-3D3AB941DF44> /Applications/Vectorworks 2021 SP3/*/TB_Format2017Classes.tx
0x16b909000 - 0x16c051ff7 +TB_Format2017Readers.tx (0) <30844BB6-5009-3ED7-9C38-B8D807AB2F6F> /Applications/Vectorworks 2021 SP3/*/TB_Format2017Readers.tx
0x16cacf000 - 0x16d06eff7 +TB_Format2018Classes.tx (0) <C03F006A-03AB-34FA-9A73-86C68154BF39> /Applications/Vectorworks 2021 SP3/*/TB_Format2018Classes.tx
0x16d11b000 - 0x16d888fff +TB_Format2018Readers.tx (0) <D7420221-AC51-3D25-A333-EFB675D56681> /Applications/Vectorworks 2021 SP3/*/TB_Format2018Readers.tx
0x16e34a000 - 0x16e8fbff7 +TB_Format2019Classes.tx (0) <92625D4F-9D9D-323D-A73A-583860AEF6F9> /Applications/Vectorworks 2021 SP3/*/TB_Format2019Classes.tx
0x16e9a9000 - 0x16f12eff7 +TB_Format2019Readers.tx (0) <BD634FDF-25F0-378D-9E86-3D3C89B60E2E> /Applications/Vectorworks 2021 SP3/*/TB_Format2019Readers.tx
0x16fc19000 - 0x1701ddffb +TB_Format2020Classes.tx (0) <6927841B-22CE-3715-8C2F-27F8DC9AF8EA> /Applications/Vectorworks 2021 SP3/*/TB_Format2020Classes.tx
0x17028d000 - 0x170a07ffb +TB_Format2020Readers.tx (0) <5DC0A3D0-D94E-3DA3-9CD1-5BFA7FC98A6A> /Applications/Vectorworks 2021 SP3/*/TB_Format2020Readers.tx
0x171516000 - 0x171947ffb +TB_FormatCommonClasses.tx (0) <B1023620-E224-33A4-9944-A59842C86A76> /Applications/Vectorworks 2021 SP3/*/TB_FormatCommonClasses.tx
0x17199a000 - 0x171f9aff7 +TB_FormatCommonReaders.tx (0) <BD79E17A-FC2B-3D42-ADCD-CA0041E3DF27> /Applications/Vectorworks 2021 SP3/*/TB_FormatCommonReaders.tx
0x172941000 - 0x172aa4fff +TB_Geometry.tx (0) <BEDDF527-FBE0-3D65-90FE-693F495DD6C5> /Applications/Vectorworks 2021 SP3/*/TB_Geometry.tx
0x172bde000 - 0x172c33ff7 +TB_GeometryUtils.tx (0) <8B1C6BB1-97C7-30E6-8ED3-E39F21EAF45E> /Applications/Vectorworks 2021 SP3/*/TB_GeometryUtils.tx
0x172c71000 - 0x172d72ff3 +TB_HostObj.tx (0) <92743FED-A5A4-372C-BBE3-A1791639336A> /Applications/Vectorworks 2021 SP3/*/TB_HostObj.tx
0x172e93000 - 0x173036ff3 +TB_Loader.tx (0) <1AC21A46-1249-36D7-A810-278BC1CB472A> /Applications/Vectorworks 2021 SP3/*/TB_Loader.tx
0x1730b5000 - 0x1730fefff +TB_LoaderBase.tx (0) <A3ADA6B3-F35B-358B-8F42-B99E932BC142> /Applications/Vectorworks 2021 SP3/*/TB_LoaderBase.tx
0x17313c000 - 0x1737b7fff +TB_Main.tx (0) <DF6E8976-268C-30CD-A6EE-9CCE6186E27B> /Applications/Vectorworks 2021 SP3/*/TB_Main.tx
0x1740c7000 - 0x174286ff7 +TB_MEP.tx (0) <5F2DD573-EB25-3F73-B77E-49A61C406C72> /Applications/Vectorworks 2021 SP3/*/TB_MEP.tx
0x1744ba000 - 0x1744dffff +TB_ModelerGeometry.tx (0) <6FF765DB-4CAA-3F0F-ADE0-CE5C29F2D6BE> /Applications/Vectorworks 2021 SP3/*/TB_ModelerGeometry.tx
0x174505000 - 0x174770ff3 +TB_StairsRamp.tx (0) <F5A14A5A-69AB-37E1-BAFE-CA32BEC088E8> /Applications/Vectorworks 2021 SP3/*/TB_StairsRamp.tx
0x174a67000 - 0x174a73ffb +TD_TfCore.tx (0) <3679588A-5D14-3258-806E-3BAFB431B916> /Applications/Vectorworks 2021 SP3/*/TD_TfCore.tx
0x174a83000 - 0x174a90fff +ThreadPool.tx (0) <F991E5C4-493F-392B-B23A-1EDC7B8EF686> /Applications/Vectorworks 2021 SP3/*/ThreadPool.tx
0x174a9e000 - 0x174d84ffb +de.computerworks.vectorworks.Rohrkoerper anlegen CW (D26.0.0 R1 505805+/11731+ - 1.0) <3F78F83F-C1CD-30D3-9149-B19269209923> /Applications/Vectorworks 2021 SP3/*/Rohrkoerper anlegen CW
0x1750c1000 - 0x175127ffb +net.nemetschek.vectorworks.Roofer (1.0) <8E9BD03E-D32D-3980-B80D-7E299B584922> /Applications/Vectorworks 2021 SP3/*/Roofer
0x175156000 - 0x1752baff7 +net.nemetschek.vectorworks.RoofFramer (1.0) <30FD2A7B-0BFF-3901-A9F5-EF92992C4FB8> /Applications/Vectorworks 2021 SP3/*/RoofFramer
0x17536d000 - 0x1756f3ffb +Schlitze Durchbr CW (D26.0.0 R1 505805+/11731+ - 1.0) <30BDB44D-2DCD-3C3B-B38E-87E279241F81> /Applications/Vectorworks 2021 SP3/*/Schlitze Durchbr CW
0x175a9d000 - 0x175c92ff3 +net.nemetschek.vectorworks.SeatingSection (1.0) <7AD53845-0236-34EF-A81A-CBB91CC492DF> /Applications/Vectorworks 2021 SP3/*/SeatingSection
0x175da5000 - 0x175e87ff7 +net.nemetschek.vectorworks.SectionLine (1.0) <FFBA7B79-F9DD-39F2-853B-96EBC32D23F0> /Applications/Vectorworks 2021 SP3/*/SectionLine
0x175f01000 - 0x17604efff +net.nemetschek.vectorworks. (1.0) <F3CA5337-D8B9-35B9-A576-9EDE01093D61> /Applications/Vectorworks 2021 SP3/*/Select Similar
0x17612f000 - 0x176203fff +net.nemetschek.vectorworks.Shear (1.0) <C4570DE7-A868-34FA-8A42-2EA4A2967A8F> /Applications/Vectorworks 2021 SP3/*/Shear
0x17626d000 - 0x1763b9fff +net.nemetschek.vectorworks.SimpleElevator (1.0) <FAC0C405-3CC9-37F4-AE14-08C026AE54C8> /Applications/Vectorworks 2021 SP3/*/SimpleElevator
0x176484000 - 0x1765f8ff7 +net.nemetschek.vectorworks.SketchUp (1.0) <BF785FFC-1AB5-3661-9F98-A0708688C3F1> /Applications/Vectorworks 2021 SP3/*/SketchUp
0x1766d0000 - 0x1768bffff +com.sketchup.slapi (0.0.1 - 0.0.1d1) <BD26182E-E49E-3AC0-8302-40927CADF4FA> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/SketchUpAPI
0x176a4a000 - 0x176a64ff7 +libCommonPreferences.dylib (0) <733D0E43-0BB6-3240-9B3A-535A61942A2D> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonPreferences.dylib
0x176a77000 - 0x176a7bff3 +libCommonUnits.dylib (0) <96A96E7A-9615-3515-A6C6-DBEB87153B9D> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonUnits.dylib
0x176a81000 - 0x176ab3ff7 +libCommonGeometry.dylib (0) <BD59836C-BECE-3E53-A49D-713C9ADCD716> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonGeometry.dylib
0x176ad7000 - 0x176ad9ff7 +libCommonGeoutils.dylib (0) <E20D31FD-2ECC-3DD5-A440-A39F45E14387> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonGeoutils.dylib
0x176add000 - 0x176d8dff7 +libCommonImage.dylib (0) <B949B981-CA51-3FC9-B467-3F3F2B81BD56> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonImage.dylib
0x176e27000 - 0x176e4aff7 +libCommonUtils.dylib (0) <EA16F159-32D9-30A2-85B1-9045EB56E683> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonUtils.dylib
0x176e6f000 - 0x176e87ffb +libCommonZip.dylib (0) <4BBD43A5-B164-3D56-BFCC-221A95492F95> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonZip.dylib
0x176e90000 - 0x177238ff7 +net.nemetschek.vectorworks.SpotlightModule (1.0) <AB8D1D68-84D7-38CF-9668-E07687F026B2> /Applications/Vectorworks 2021 SP3/*/Spotlight
0x1773e2000 - 0x177527ff7 +net.nemetschek.vectorworks.SpotlightVision (1.0) <7E82304C-3456-3503-ABCD-DC7C095F02E8> /Applications/Vectorworks 2021 SP3/*/SpotlightVision
0x1775cf000 - 0x177afdfff +org.qt-project.QtCore (5.12 - 5.12.3) <A5C2F78A-18AB-3684-BD15-0632EFCBA939> /Applications/Vectorworks 2021 SP3/*/QtCore.framework/Versions/5/QtCore
0x177bb8000 - 0x177be9fff +org.qt-project.QtXml (5.12 - 5.12.3) <BF8403B1-DB41-3C12-9E41-BF3B9BDF07AF> /Applications/Vectorworks 2021 SP3/*/QtXml.framework/Versions/5/QtXml
0x177bfa000 - 0x177c3bfff +libsVisionPlugin.dylib (0) <53D5C7B7-A072-3009-BD8F-3CC6684F4D19> /Applications/Vectorworks 2021 SP3/*/libsVisionPlugin.dylib
0x177c5a000 - 0x177c8eff3 +org.qt-project.QtOpenGL (5.12 - 5.12.3) <E5946179-8F8F-3B2E-9AE5-C9A30294D6BE> /Applications/Vectorworks 2021 SP3/*/QtOpenGL.framework/Versions/5/QtOpenGL
0x177caf000 - 0x1780edffb +org.qt-project.QtWidgets (5.12 - 5.12.3) <4B88FD5A-BF6D-3102-B095-32D1162AA630> /Applications/Vectorworks 2021 SP3/*/QtWidgets.framework/Versions/5/QtWidgets
0x178250000 - 0x178694fef +org.qt-project.QtGui (5.12 - 5.12.3) <0A0AE636-A8A3-3E17-B8F3-9C5D8EB21029> /Applications/Vectorworks 2021 SP3/*/QtGui.framework/Versions/5/QtGui
0x178797000 - 0x1788fcfff +libqcocoa.dylib (0) <A20B7E1A-FCA9-36DD-BE7A-1D36A920C878> /Applications/Vectorworks 2021 SP3/*/libqcocoa.dylib
0x178948000 - 0x1789a6fff +org.qt-project.QtDBus (5.12 - 5.12.3) <1794BF10-F5CF-3430-8628-70D3B1538A64> /Applications/Vectorworks 2021 SP3/*/QtDBus.framework/Versions/5/QtDBus
0x1789bf000 - 0x1789e8ff7 +org.qt-project.QtPrintSupport (5.12 - 5.12.3) <164F26B8-1B82-3DDF-B5E7-43FA02F95BF6> /Applications/Vectorworks 2021 SP3/*/QtPrintSupport.framework/Versions/5/QtPrintSupport
0x178a41000 - 0x178c0eff7 +net.nemetschek.vectorworks.TesterModule (1.0) <D17877FD-9F2F-3D95-A8DA-9F682862391E> /Applications/Vectorworks 2021 SP3/*/StructuralMember
0x178cf1000 - 0x178e31ff3 +net.nemetschek.vectorworks.StructuralProfile (1.0) <5D42D6E9-FD33-3BBE-84B6-A620C3812EA7> /Applications/Vectorworks 2021 SP3/*/StructuralProfile
0x178eed000 - 0x178f4eff3 +net.nemetschek.vectorworks.SunPosition (1.0) <F3BEFF80-18A7-3660-B22C-99B0C2ED88F7> /Applications/Vectorworks 2021 SP3/*/SunPosition
0x178f7d000 - 0x17953dff3 +net.nemetschek.vectorworks.Support (1.0) <022A442A-7271-3CA2-9A57-A9C22213EA54> /Applications/Vectorworks 2021 SP3/*/Support
0x17979b000 - 0x1797d1ff7 libiodbc.2.dylib (42.6) <3D64D3A4-171D-3649-B3BC-6B8EF0174C8B> /usr/lib/libiodbc.2.dylib
0x1797e4000 - 0x17992bff3 +net.nemetschek.vectorworks. (1.0) <4FF3A080-3BC5-34E6-9457-99268954BFD6> /Applications/Vectorworks 2021 SP3/*/Surface Array
0x1799e3000 - 0x179ab7ff3 +net.nemetschek.vectorworks.TapeMeasureTool (1.0) <AF3E12E4-2881-3A40-A719-FE4B82FEBCDA> /Applications/Vectorworks 2021 SP3/*/TapeMeasureTool
0x179b22000 - 0x179b9eff3 +net.nemetschek.vectorworks.TaperedExtrude (1.0) <E7385AA5-3CFF-3025-9A86-E47024CB1BE7> /Applications/Vectorworks 2021 SP3/*/TaperedExtrude
0x179bd9000 - 0x179ec9fff +de.computerworks.vectorworks.Teilwinkel CW (D26.0.0 R1 505805+/11731+ - 1.0) <E22402A9-810F-3042-BB50-85C7DE98722B> /Applications/Vectorworks 2021 SP3/*/Teilwinkel CW
0x17a1f2000 - 0x17a4f5fff +de.computerworks.vectorworks.Text suchen und aendern CW (D26.0.0 R1 505805+/11731+ - 1.0) <875FB89D-FBC9-380A-8390-9EC89544B005> /Applications/Vectorworks 2021 SP3/*/Text suchen und aendern CW
0x17a852000 - 0x17a8c8ffb +net.nemetschek.vectorworks.TextAlongPath (1.0) <3863352E-598E-3A6F-85C4-3E447659E20F> /Applications/Vectorworks 2021 SP3/*/TextAlongPath
0x17a902000 - 0x17a967ff3 +net.nemetschek.vectorworks. (1.0) <8C126937-ABDD-3AA7-B34B-F26C8A25266F> /Applications/Vectorworks 2021 SP3/*/Textured Prop
0x17a99c000 - 0x17ac96ff3 +net.nemetschek.vectorworks.TitleBlockBorder (1.0) <D84D3FBE-BE53-3DF4-892C-1F2D2B46A1DE> /Applications/Vectorworks 2021 SP3/*/TitleBlockBorder
0x17adca000 - 0x17b403ff3 +de.computerworks.vectorworks.Treppen (26.0.3 - 1.0) <9753DE74-B68F-3305-9110-D3444524F638> /Applications/Vectorworks 2021 SP3/*/Treppen
0x17ba67000 - 0x17bb3bfff +net.nemetschek.vectorworks. (1.0) <53DAC7C8-EBA0-3136-9AD9-65C6A30A99CE> /Applications/Vectorworks 2021 SP3/*/Trim Tool
0x17bba5000 - 0x17bc03fff +net.nemetschek.vectorworks. (1.0) <8439E865-EE52-3561-89B5-1D5CAC39A2A2> /Applications/Vectorworks 2021 SP3/*/TrueType To Polyline
0x17bc31000 - 0x17bd01ff3 +net.nemetschek.vectorworks.TrueType (1.0) <E8F9BA4B-AAB9-353D-8D10-C274F38437BB> /Applications/Vectorworks 2021 SP3/*/TrueType
0x17bd65000 - 0x17c57fff3 +de.computerworks.vectorworks.Tueren CW (D26.0.0 R1 505805+/11731+ - 1.0) <10C17BE8-986B-3C96-A5EB-457D75854D43> /Applications/Vectorworks 2021 SP3/*/Tueren CW
0x17ce99000 - 0x17d17cfff +Unterbrechen CW (D26.0.0 R1 505805+/11731+ - 1.0) <D9E03550-96E3-3F51-910F-88D83CBAC5AA> /Applications/Vectorworks 2021 SP3/*/Unterbrechen CW
0x17d49c000 - 0x17d7a0fff +de.computerworks.vectorworks.Unterteilen CW (D26.0.0 R1 505805+/11731+ - 1.0) <77571D14-D69A-33B0-8004-1470CD9B1438> /Applications/Vectorworks 2021 SP3/*/Unterteilen CW
0x17dadc000 - 0x17db39ff3 +net.nemetschek.vectorworks.UpdateCheck (1.0) <56958B9D-EBC9-3760-AA3A-C6EFF7AAFE82> /Applications/Vectorworks 2021 SP3/*/UpdateCheck
0x17db6a000 - 0x17dbe2fff +net.nemetschek.vectorworks.VCSClient (1.0) <9AB67E65-E495-3AC7-95AC-D2431E1CEBDD> /Applications/Vectorworks 2021 SP3/*/VCSClient
0x17dc26000 - 0x17dc87fff +net.nemetschek.vectorworks.VectorScriptEditor (1.0) <B7CB1DDE-A794-3A54-9A20-C244B474BB5B> /Applications/Vectorworks 2021 SP3/*/VectorScriptEditor
0x17dcb4000 - 0x17ddd7ff7 +com.sun.Scintilla (1.0) <A7F52E4B-72C7-3A34-8271-816113E9B7B0> /Applications/Vectorworks 2021 SP3/*/Scintilla.framework/Versions/A/Scintilla
0x17de3e000 - 0x17dfa2fff +net.nemetschek.vectorworks.VectorworksRemote (..) <8EF2BC1F-1B51-3DD9-BF31-D34752BBAB6D> /Applications/Vectorworks 2021 SP3/*/Vectorworks Remote
0x17e0c1000 - 0x17e3bfffb +Versetzen CW (D26.0.0 R1 505805+/11731+ - 1.0) <344C3CD0-CC86-3F49-B5A2-B092375B43BB> /Applications/Vectorworks 2021 SP3/*/Versetzen CW
0x17e6f4000 - 0x17e880ff7 +net.nemetschek.vectorworks.TesterModule (1.0) <ECC6C939-742E-3FBA-ABCB-7081B73111B4> /Applications/Vectorworks 2021 SP3/*/VGS_Datasmith
0x17e935000 - 0x1800e5fff +DatasmithSDK.dylib (0) <613A2859-0FB7-3B03-8894-C0B29E69C81D> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/DatasmithSDK.dylib
0x18142b000 - 0x1814faffb +net.nemetschek.vectorworks. (1.0) <2BD219C1-7D8C-32C8-94F6-8F485D2CD4FF> /Applications/Vectorworks 2021 SP3/*/VS Shared Library
0x18155f000 - 0x181824ffb +de.computerworks.vectorworks.VW Hilfe CW (D26.0.0 R1 505805+/11731+ - 1.0) <CF2FF047-C516-32DC-BB33-5A11C1D90C09> /Applications/Vectorworks 2021 SP3/*/VW Hilfe CW
0x181b36000 - 0x18207bff3 +com.deersoft.GDTFExport (1.0) <890B3D0A-4801-30DA-A91A-D9C354530DAB> /Applications/Vectorworks 2021 SP3/*/VWGDTFExchange
0x1823fe000 - 0x1825d6ff3 +net.nemetschek.vectorworks.VWGraphicsModule (1.0) <8661761B-7CFD-368C-91EC-4549512190DC> /Applications/Vectorworks 2021 SP3/*/VWGraphicsModule
0x182683000 - 0x18271cff3 +net.nemetschek.vectorworks.VWGraphicsXchange (1.0) <B1B03446-0FC4-3F2B-AFED-07F75DE3829A> /Applications/Vectorworks 2021 SP3/*/VWGraphicsXchange
0x182756000 - 0x182943ff7 +com.cesyam.VWLibrary (25.0 - 1.0) <6B4454A7-C80F-3D1D-A2E3-850601E16A6E> /Applications/Vectorworks 2021 SP3/*/VWLibrary
0x182a19000 - 0x182cf4ff3 +de.computerworks.vectorworks.Waende abschliessen CW (D26.0.0 R1 505805+/11731+ - 1.0) <F8CBB4AA-FA3C-3779-BA4A-FE998B97C386> /Applications/Vectorworks 2021 SP3/*/Waende abschliessen CW
0x18300f000 - 0x1832ecff7 +de.computerworks.vectorworks.Waende Wandseiten CW (D26.0.0 R1 505805+/11731+ - 1.0) <17091B8C-75A8-3B95-BF96-E7BB6A120AE5> /Applications/Vectorworks 2021 SP3/*/Waende Wandseiten CW
0x18360a000 - 0x18395eff3 +de.computerworks.vectorworks.Wandbild CW (D26.0.0 R1 505805+/11731+ - 1.0) <AE44F7A9-D3AC-36E7-8695-0684559264EE> /Applications/Vectorworks 2021 SP3/*/Wandbild CW
0x183ce7000 - 0x183e28ff7 +net.nemetschek.vectorworks. (1.0) <E350F809-A466-34CD-84AE-E1F88FAB677E> /Applications/Vectorworks 2021 SP3/*/Workspace Editor
0x183ecf000 - 0x183f4ffff +net.nemetschek.vectorworks.Workspaces (1.0) <619C69E4-AFFB-3366-99B0-36D735A85BE4> /Applications/Vectorworks 2021 SP3/*/Workspaces
0x183f9d000 - 0x184211ffb +de.extragroup.XGShelf (1.0) <722EA57A-29C0-3331-82F9-914D4405ABE2> /Applications/Vectorworks 2021 SP3/*/XGShelf
0x18448b000 - 0x184a15ffb +de.computerworks.vectorworks.XPlanung CW (D26.0.0 R1 505805+/11731+ - 1.0) <14834DF3-1AA5-394F-A888-0CC5C6AD70CB> /Applications/Vectorworks 2021 SP3/*/XPlanung CW
0x184e13000 - 0x184e15ff7 com.apple.textencoding.unicode (6.0 - 6.0) <67941F99-16D4-3281-B92A-17FD544E49B3> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x1b7834000 - 0x1b784cff3 com.apple.CIBarcode (2.0 - 940.9) <1B14976A-7057-307A-BA16-F4DC0156A6C6> /System/Library/CoreImage/CIBarcode.cifilter/Contents/MacOS/CIBarcode
0x1b7858000 - 0x1b7859fff com.apple.CIPassThrough (2.0 - 940.9) <4A6C228D-5CC5-30BE-88E6-C2434A205D76> /System/Library/CoreImage/CIPassThrough.cifilter/Contents/MacOS/CIPassThrough
0x1b7862000 - 0x1b78deff7 com.apple.PortraitFilters (1.0 - 30) <8A853BAB-5B3C-304E-AA5B-6F2797C9CEFE> /System/Library/CoreImage/PortraitFilters.cifilter/Contents/MacOS/PortraitFilters
0x1b790c000 - 0x1b7916fff +com.datalogics.DL150PDFlattener (15.0.0.0 - kShortVersStr) <84525506-0D4A-380F-974C-9DA638111E71> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150PDFlattener.ppi/Contents/MacOS/DL150PDFlattener
0x1b7936000 - 0x1b79b2ff7 +com.datalogics.DL150PDFProcessor (15.0.0.0 - kShortVersStr) <7E20A582-8581-3A41-B26C-A9F8692B66DD> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150PDFProcessor.ppi/Contents/MacOS/DL150PDFProcessor
0x1b85a1000 - 0x1b85a4fff com.apple.FileProviderOverride (304.1 - 304.1) <FF452DA5-75BC-3EF3-B372-F4FD9B7D57B9> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x1b85ad000 - 0x1b85c4ffb com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1298.7.1) <1911451B-5BA5-3A08-AB9F-2729A55BDE38> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x7fff2b2bc000 - 0x7fff2b509ff8 com.apple.RawCamera.bundle (9.02.0 - 1350.30) <EFE24C4B-D8BC-3992-BEB0-2EA84C574C96> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff2b946000 - 0x7fff2b97cfff ATIRadeonX6000SCLib.dylib (3.10.19) <B69A8D57-50D7-3777-A15B-9A4C21AE7F70> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/ATIRadeonX6000SCLib.dylib
0x7fff2b97d000 - 0x7fff2bbf2ffc com.apple.AMDRadeonX6000MTLDriver (3.10.19 - 3.1.0) <4B72032C-658F-3164-96E8-18BCBAF84C72> /System/Library/Extensions/AMDRadeonX6000MTLDriver.bundle/Contents/MacOS/AMDRadeonX6000MTLDriver
0x7fff2cb4b000 - 0x7fff2d4c8fff libSC.dylib (3.10.19) <6990D42E-C5F0-320A-8DBF-3728D99E54FA> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
0x7fff2fbc2000 - 0x7fff30bc9ff7 com.apple.driver.AppleIntelKBLGraphicsGLDriver (14.7.13 - 14.0.7) <B2E28088-9A54-3E2E-88DB-48466728C520> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
0x7fff30bca000 - 0x7fff30fc9ff1 com.apple.driver.AppleIntelKBLGraphicsMTLDriver (14.7.13 - 14.0.7) <52BFD489-4F4F-302F-8501-7CE6152F92CB> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
0x7fff33a64000 - 0x7fff33a68ffb com.apple.agl (3.3.3 - AGL-3.3.3) <29495233-9BD3-33AB-AF0F-8DE3E82EB7CE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff33a69000 - 0x7fff33c64ff8 com.apple.avfoundation (2.0 - 1855.3) <0837D912-3783-35D6-A94A-E474E18600CF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff33c65000 - 0x7fff33d31ffe com.apple.audio.AVFAudio (1.0 - 415.75) <CAC3CA5F-FCF6-37EB-8F1A-090340E2C38E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff33e51000 - 0x7fff33e51fff com.apple.Accelerate (1.11 - Accelerate 1.11) <4F9977AE-DBDB-3A16-A536-AC1F9938DCDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff33e52000 - 0x7fff33e68fef libCGInterfaces.dylib (524.2.1) <8FD09D09-BB19-36C5-ADE9-4F22DA235AEE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff33e69000 - 0x7fff344bffff com.apple.vImage (8.1 - 524.2.1) <EA6F5FF2-7A1B-35D5-A5A3-D2B3386ECB75> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff344c0000 - 0x7fff34727ff7 libBLAS.dylib (1303.60.1) <C6C2D42F-7456-3DBF-8BE2-9AA06EFC78FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff34728000 - 0x7fff34bfbfef libBNNS.dylib (144.100.2) <99C61C48-B14C-3DA6-8C31-6BF72DA0A3A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff34bfc000 - 0x7fff34f97fff libLAPACK.dylib (1303.60.1) <5E3E3867-50C3-3E6A-9A2E-007CE77A4641> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff34f98000 - 0x7fff34fadfec libLinearAlgebra.dylib (1303.60.1) <3D433800-0099-33E0-8C81-15F83247B2C9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff34fae000 - 0x7fff34fb3ff3 libQuadrature.dylib (7) <371F36A7-B12F-363E-8955-F24F7C2048F6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff34fb4000 - 0x7fff35024fff libSparse.dylib (103) <B8A10D0C-4577-343D-B310-A3E81265D107> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff35025000 - 0x7fff35037fef libSparseBLAS.dylib (1303.60.1) <B147FEF6-A0DB-3830-BF06-45BEC58DB576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff35038000 - 0x7fff3520ffd7 libvDSP.dylib (735.140.1) <D63DC0A5-B8B4-3562-A574-E73BC3B57407> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff35210000 - 0x7fff352d2fef libvMisc.dylib (735.140.1) <3601FDE3-B142-398D-987D-8151A51F0A96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff352d3000 - 0x7fff352d3fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <F6C5613D-2284-342B-9160-9731F78B4DE5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff352d4000 - 0x7fff35333ff0 com.apple.Accounts (113 - 113) <E2438070-30AB-3B89-AE63-1E485B92D108> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff3547d000 - 0x7fff3623dff2 com.apple.AppKit (6.9 - 1894.60.100) <763827BC-780B-30A9-B067-B04D8E90910B> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff3628d000 - 0x7fff3628dfff com.apple.ApplicationServices (48 - 50) <4758C933-0823-3B84-8E68-03DA706CC208> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff3628e000 - 0x7fff362f9fff com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <87EA5DE1-506A-39FD-88BE-D8A3416C9012> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff36392000 - 0x7fff363d0ff0 libFontRegistry.dylib (274.0.5.1) <F3461C05-0370-359B-9F03-5C1C1F7763EC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff3642b000 - 0x7fff3645afff com.apple.ATSUI (1.0 - 1) <5F513967-DDD7-3F22-AD14-8A38ABD9F2D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff3645b000 - 0x7fff3645fffb com.apple.ColorSyncLegacy (4.13.0 - 1) <72EE68DB-F069-37F5-AA2A-40D5FCF139F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff364f9000 - 0x7fff36550ffa com.apple.HIServices (1.22 - 676) <14DF4D42-E24D-3EBD-9A9D-93124D8D6AA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff36551000 - 0x7fff3655ffff com.apple.LangAnalysis (1.7.0 - 1.7.0) <01B8B6B3-E2C3-3607-B34A-8283A7E0E924> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff36560000 - 0x7fff365a5ffa com.apple.print.framework.PrintCore (15.4 - 516.2) <437BCF12-48D2-3770-8BC9-567718FB1BCA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff365a6000 - 0x7fff365b0ff7 com.apple.QD (4.0 - 413) <27A36D07-B5E9-32E6-87B6-3127F260F48D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff365b1000 - 0x7fff365beffc com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <75344F8F-32CA-3558-B4E6-F56D498250E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff365bf000 - 0x7fff366a0ff2 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <3A7E709F-DE6E-313B-82A1-1E9C8B734CF5> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff366a2000 - 0x7fff366a2fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <76010435-2167-3B23-9E2A-E73F7F6C1B25> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff36a39000 - 0x7fff36dc7ffa com.apple.CFNetwork (1128.1 - 1128.1) <81AE2F6D-46E2-36D9-ADCE-E79E7A869D1D> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff36e43000 - 0x7fff36e43fff com.apple.Carbon (160 - 162) <49582194-AEFB-3FE9-B9D0-DB4AD24EFEDC> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff36e44000 - 0x7fff36e47ff3 com.apple.CommonPanels (1.2.6 - 101) <9F6E13D9-374B-386F-8E15-FDD6CE967859> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff36e48000 - 0x7fff3713cff3 com.apple.HIToolbox (2.1.1 - 994.6) <EAF2DAC3-66B1-30BF-AF10-72DDA90D1044> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff3713d000 - 0x7fff37140ff3 com.apple.help (1.3.8 - 71) <36483951-6F3E-3F7E-8A5B-191C2357EF17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff37141000 - 0x7fff37146ff7 com.apple.ImageCapture (9.0 - 1600.65) <1A1F320E-3E85-3F3D-8AE0-B238C4E92D40> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff37147000 - 0x7fff37147fff com.apple.ink.framework (10.15 - 227) <284507AE-EF47-3ABC-86A4-669243DB1D33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff37148000 - 0x7fff37162ffa com.apple.openscripting (1.7 - 185.1) <B6E28747-5FC7-3461-8A71-864A969ED022> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff37183000 - 0x7fff37183fff com.apple.print.framework.Print (15 - 271) <0D9FB08F-EA87-3BE7-821B-C61BA5601050> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff37184000 - 0x7fff37186ff7 com.apple.securityhi (9.0 - 55008) <390C6FAA-99BF-3924-9180-9EAE41D9C6BE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff37187000 - 0x7fff3718dfff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9614A01E-8303-3422-A3BA-6CE27540E09A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff3718e000 - 0x7fff37326ffa com.apple.cloudkit.CloudKit (867 - 867) <1B851180-FC00-357F-B6C1-BB0EA7D6D5CA> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff37327000 - 0x7fff37327fff com.apple.Cocoa (6.11 - 23) <4C81A68B-4967-3688-BB6C-7C19E78EA20F> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff37335000 - 0x7fff3742bfff com.apple.ColorSync (4.13.0 - 3394.9) <A126406C-DA38-3FFE-8B25-BB9859EFD159> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff3742c000 - 0x7fff3751cff7 com.apple.combine (1.0 - 134.102) <02C5D48A-E70F-3D68-8555-4211853F9C3B> /System/Library/Frameworks/Combine.framework/Versions/A/Combine
0x7fff37716000 - 0x7fff37c1fffb com.apple.audio.CoreAudio (5.0 - 5.0) <47923B12-3D14-328A-9C86-27A3A2A73068> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff37c72000 - 0x7fff37caafff com.apple.CoreBluetooth (1.0 - 1) <23DBB313-A082-3C08-8E1F-2D31EE4247EF> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff37cab000 - 0x7fff38095fe8 com.apple.CoreData (120 - 977.3) <49AE61CA-C91E-31FE-9BD0-1AACFFB5181E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff38096000 - 0x7fff381c8ff6 com.apple.CoreDisplay (1.0 - 186.6.15) <213D7011-8180-3CF4-9BE7-FB8F75DCDB95> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff381c9000 - 0x7fff38649ff2 com.apple.CoreFoundation (6.9 - 1677.205) <83F301FE-DE7E-315D-B4EA-CDA62F114F0A> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff3864b000 - 0x7fff38cc0fe8 com.apple.CoreGraphics (2.0 - 1355.24) <041366C9-FE91-3B58-95DD-5800A817BAB6> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff38cce000 - 0x7fff39029ff0 com.apple.CoreImage (15.0.0 - 940.9) <69361069-01AB-342E-862B-73A74271A765> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff3902a000 - 0x7fff39093ff0 com.apple.corelocation (2394.0.22 - 2394.0.22) <75966124-2FB7-33C3-BE49-3DD5F327F911> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff39094000 - 0x7fff390e4ff6 com.apple.audio.midi.CoreMIDI (1.10 - 88) <017B0334-8AC4-304B-A5E2-C82C51BE1917> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x7fff390e7000 - 0x7fff393e9ff2 com.apple.CoreML (1.0 - 1) <FD17F9EB-1930-314C-B6B4-2A2E643AC771> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x7fff393ea000 - 0x7fff394c5ffc com.apple.CoreMedia (1.0 - 2625.9) <A3FF3AFC-8C1C-36E5-9179-66D8F075EE35> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff394c6000 - 0x7fff39528ffe com.apple.CoreMediaIO (1000.0 - 5125.6) <EE8EEB82-D382-3A18-BD4E-9896B7F5A9BA> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff395b2000 - 0x7fff395b2fff com.apple.CoreServices (1069.24 - 1069.24) <C7B6191A-C8E2-3BBF-B678-93C2E2AEBC9A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff395b3000 - 0x7fff39638fff com.apple.AE (838.1 - 838.1) <2E5FD5AE-8A7F-353F-9BD1-0241F3586181> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff39639000 - 0x7fff3991aff7 com.apple.CoreServices.CarbonCore (1217 - 1217) <BE379206-99FA-30CD-8391-2708473A633F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff3991b000 - 0x7fff39968ffd com.apple.DictionaryServices (1.2 - 323.6) <26B70C82-25BC-353A-858F-945B14C803A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff39969000 - 0x7fff39971ff7 com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <FC84DB48-A3CE-30F7-A918-B3587731ACC7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff39972000 - 0x7fff39bacff6 com.apple.LaunchServices (1069.24 - 1069.24) <9A5359D9-9148-3B18-B868-56A9DA5FB60C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff39bad000 - 0x7fff39c45ff1 com.apple.Metadata (10.7.0 - 2076.7) <0973F7E5-D58C-3574-A3CE-4F12CAC2D4C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff39c46000 - 0x7fff39c73fff com.apple.CoreServices.OSServices (1069.24 - 1069.24) <0E4F48AD-402C-3E9D-9CA9-6DD9479B28F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff39c74000 - 0x7fff39cdbfff com.apple.SearchKit (1.4.1 - 1.4.1) <2C5E1D85-E8B1-3DC5-91B9-E3EDB48E9369> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff39cdc000 - 0x7fff39d00ff5 com.apple.coreservices.SharedFileList (131.4 - 131.4) <02DE0D56-E371-3EF5-9BC1-FA435451B412> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff39f5d000 - 0x7fff3a024ffc com.apple.CoreTelephony (113 - 7560.1) <31D93EB1-0A20-3383-9680-090E441F25D8> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
0x7fff3a025000 - 0x7fff3a1dcffc com.apple.CoreText (643.1.5.5 - 643.1.5.5) <8573E719-F71C-3123-8394-701E4989E34A> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff3a1dd000 - 0x7fff3a221ffb com.apple.CoreVideo (1.8 - 344.3) <5314E70D-325F-3E98-99FC-00FDF520747E> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff3a222000 - 0x7fff3a2afffc com.apple.framework.CoreWLAN (13.0 - 1601.2) <6223BFD5-D451-3DE9-90F6-F609AC0B0027> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff3a46b000 - 0x7fff3a476ff7 com.apple.DirectoryService.Framework (10.15 - 220.40.1) <6EACB7D0-A013-3D2B-93D2-5113F7C2559D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff3a477000 - 0x7fff3a521ff0 com.apple.DiscRecording (9.0.3 - 9030.4.5) <BCF3AFB0-6E1A-3F28-A575-1FD2D74E7C19> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff3a546000 - 0x7fff3a54cfff com.apple.DiskArbitration (2.7 - 2.7) <14572D3E-7743-31E3-8777-A7BE2EAF518F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff3a722000 - 0x7fff3a724ff2 com.apple.ExceptionHandling (1.5 - 13) <6ACFE4A2-6483-3F5B-A623-4DC606183E35> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
0x7fff3a741000 - 0x7fff3a86fff6 com.apple.FileProvider (304.1 - 304.1) <E8BB1D4B-05D6-386C-865C-F8C750CEC308> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff3a884000 - 0x7fff3a886ff3 com.apple.ForceFeedback (1.0.6 - 1.0.6) <9B324178-4FAA-3686-9E01-634607F38493> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff3a887000 - 0x7fff3ac4cfff com.apple.Foundation (6.9 - 1677.205) <1D3A7414-141E-3170-9D18-69A53F1ACAAC> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff3acb9000 - 0x7fff3ad09ff7 com.apple.GSS (4.0 - 2.0) <1B6FCC64-7ED0-30E4-AD2D-AD35D621981D> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff3ad0a000 - 0x7fff3ad32ff4 com.apple.GameController (1.0 - 1) <2B7F0994-4B32-3B08-B58A-3FA5A5E65AF4> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
0x7fff3ae46000 - 0x7fff3af5aff3 com.apple.Bluetooth (7.0.6 - 7.0.6f8) <C7AF719C-51B4-3727-A947-EB01204272D9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff3afc0000 - 0x7fff3b064ff3 com.apple.framework.IOKit (2.0.2 - 1726.148.1) <0A9D244C-AECC-3D29-86DE-4F3B04F8DD25> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff3b066000 - 0x7fff3b077ffb com.apple.IOSurface (269.11 - 269.11) <BCD744D4-E17E-3C2E-B69C-F69C789892E9> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff3b095000 - 0x7fff3b0f5ff5 com.apple.ImageCaptureCore (1.0 - 1600.65) <281CE141-B350-30E2-B345-FC7E7DF1AA3A> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff3b0f6000 - 0x7fff3b253fe6 com.apple.ImageIO.framework (3.3.0 - 1976.11.6) <1B271746-8BFA-382B-A223-4D4B4AD12504> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff3b254000 - 0x7fff3b257fff libGIF.dylib (1976.11.6) <F6721850-6AEC-3C70-B90B-FBF7CB3C1265> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff3b258000 - 0x7fff3b311fe7 libJP2.dylib (1976.11.6) <56C503FB-B37D-352D-B77A-D8BF1160289B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff3b312000 - 0x7fff3b335fe3 libJPEG.dylib (1976.11.6) <B82AC9B8-3416-3E16-AF45-5F1B96FDB38F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff3b5b2000 - 0x7fff3b5ccfef libPng.dylib (1976.11.6) <7C2D2001-B75A-33AF-A498-0B7B0C5E4DAD> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff3b5cd000 - 0x7fff3b5cefff libRadiance.dylib (1976.11.6) <1BA2051B-890C-39B8-9489-6187D1C2F404> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff3b5cf000 - 0x7fff3b615fff libTIFF.dylib (1976.11.6) <A3AA8DCA-A06E-33A3-9EC0-9D9BAE6A9531> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff3b62e000 - 0x7fff3babdff8 com.apple.Intents (1.0 - 1) <B2884C7F-0D08-3E3C-91A3-7FB755BB5CB1> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
0x7fff3bac0000 - 0x7fff3cb60ff1 com.apple.JavaScriptCore (15609 - 15609.4.1) <18766B97-AB12-331C-984C-F1C7C9363E8B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff3cb77000 - 0x7fff3cb89ff3 com.apple.Kerberos (3.0 - 1) <03BB492B-016E-37BF-B020-39C2CF7487FE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff3cb8a000 - 0x7fff3cb8afff libHeimdalProxy.dylib (77) <0A2905EE-9533-3345-AF9B-AAC71513BDFD> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff3cb8b000 - 0x7fff3cbc1ff7 com.apple.LDAPFramework (2.4.28 - 194.5) <020B3FA5-C305-3B13-9DFB-1D526EC3C96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff3ccd5000 - 0x7fff3ccf7ffc com.apple.CoreAuthentication.SharedUtils (1.0 - 693.140.3) <A3F9CE45-4F7A-3F5D-865C-6EB9B6C3B3B4> /System/Library/Frameworks/LocalAuthentication.framework/Support/SharedUtils.framework/Versions/A/SharedUtils
0x7fff3ccf8000 - 0x7fff3cd0eff2 com.apple.LocalAuthentication (1.0 - 693.140.3) <5D391FD1-391B-390A-BBC1-62A537C8DAFE> /System/Library/Frameworks/LocalAuthentication.framework/Versions/A/LocalAuthentication
0x7fff3cf1c000 - 0x7fff3cf26ffb com.apple.MediaAccessibility (1.0 - 125.1) <98065EA1-3484-3A5A-B05C-D2FABED8CEA4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff3cf3a000 - 0x7fff3cff1ff7 com.apple.MediaPlayer (1.0 - 1.0) <FE739C02-1000-36C8-9FAD-26FF3D8240CB> /System/Library/Frameworks/MediaPlayer.framework/Versions/A/MediaPlayer
0x7fff3cff2000 - 0x7fff3d73fff2 com.apple.MediaToolbox (1.0 - 2625.9) <3A848992-9182-382A-BF7D-5CB9707BE27B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff3d741000 - 0x7fff3d80bfff com.apple.Metal (212.8 - 212.8) <98C944D6-62C8-355E-90F8-C1CA2429EF24> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff3d80d000 - 0x7fff3d827ff5 com.apple.MetalKit (141.2 - 141.2) <FAACD940-5CF2-300A-83F3-86ABA7FDC531> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff3d828000 - 0x7fff3d865ff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <7EBAC15D-7837-395D-B405-1E29F7DA68FA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff3d866000 - 0x7fff3d8f0fe2 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <B424FE0C-6E90-3BFA-A6E7-DD86C735AE90> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff3d8f1000 - 0x7fff3d916ff4 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <02006D92-E2AB-3892-A96B-37F6520C19BA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff3d917000 - 0x7fff3d92cffb com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <CAA5A368-DB71-34F6-AEF9-27A8BC298F53> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff3d92d000 - 0x7fff3da8bffc com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <05612E06-50CB-318F-9F8E-EF4D49FAB3B0> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff3da8c000 - 0x7fff3dadbff4 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B0B591F8-6875-351E-867F-8EB3CD38CD52> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff3dadc000 - 0x7fff3daddff5 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <F2921F9A-3041-3495-878D-64134267B847> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff3eb7d000 - 0x7fff3eb89ffe com.apple.NetFS (6.0 - 4.0) <57CABC68-0585-3989-9161-157DBB544B82> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff3eb8a000 - 0x7fff3ece1ff3 com.apple.Network (1.0 - 1) <4A0F3B93-4D23-3E74-9A3D-AD19E9C0E59E> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff3ece2000 - 0x7fff3ef42ffa com.apple.NetworkExtension (1.0 - 1) <3ED35C5A-B170-373E-8277-D4198E408810> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
0x7fff4170a000 - 0x7fff41712ff7 libcldcpuengine.dylib (2.14) <D20EF7DF-8508-3707-A9B3-B7D8190971F5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff41713000 - 0x7fff4176bfff com.apple.opencl (3.5 - 3.5) <C4847D3F-8BBB-3B6A-A997-C16042DCE2FA> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff4176c000 - 0x7fff41788fff com.apple.CFOpenDirectory (10.15 - 220.40.1) <7E6C88EB-3DD9-32B0-81FC-179552834FA9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff41789000 - 0x7fff41794ffd com.apple.OpenDirectory (10.15 - 220.40.1) <4A92D8D8-A9E5-3A9C-942F-28576F6BCDF5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff420fa000 - 0x7fff420fcfff libCVMSPluginSupport.dylib (17.10.22) <50071DF6-251A-3F7E-A9EC-0625BDD24F7F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff420fd000 - 0x7fff42102fff libCoreFSCache.dylib (176.16.1) <BAE3602F-5452-323B-B696-C049F64A2D60> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff42103000 - 0x7fff42107fff libCoreVMClient.dylib (176.16.1) <B41FD53F-5730-3832-BC45-12E3101FF5BE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff42108000 - 0x7fff42110ff7 libGFXShared.dylib (17.10.22) <7358D2D6-F046-3DA7-B80A-039F950BF484> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff42111000 - 0x7fff4211bfff libGL.dylib (17.10.22) <E5190CA0-0D87-3B0B-8D3C-B60C42BC18DA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff4211c000 - 0x7fff42150ff7 libGLImage.dylib (17.10.22) <FB5A6177-F299-371C-9296-71F60E6B3CF3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff42151000 - 0x7fff422e5ff7 libGLProgrammability.dylib (17.10.22) <60082B4C-9627-3A67-AA64-63924BFEC2D7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff422e6000 - 0x7fff42322fff libGLU.dylib (17.10.22) <66BCAD33-0264-31AB-966C-66DD4359EAF4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff42d5e000 - 0x7fff42d6dff7 com.apple.opengl (17.10.22 - 17.10.22) <5B337C5E-F97E-32F0-AD50-2C293BFCA7FB> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff42d6e000 - 0x7fff42ee7fff GLEngine (17.10.22) <95305DC1-908D-3FEB-AAB4-A04940756BD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff42ee8000 - 0x7fff42f10fff GLRendererFloat (17.10.22) <90DB1784-54CA-3646-AE57-F224EA3E5BB8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff42f1f000 - 0x7fff43012ff5 com.apple.PDFKit (1.0 - 845.4.1) <A58B3E4C-6B27-32A7-AC6E-35BCB5A45944> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff43013000 - 0x7fff4312aff9 com.apple.PencilKit (1.0 - 1) <95301D00-CE35-3F53-BAE1-6E6217706702> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
0x7fff433cb000 - 0x7fff433d1ff6 com.apple.PushKit (1.0 - 1) <AD547A25-1A0B-3FA6-8676-82C37F267A4A> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff434c6000 - 0x7fff434f1fff com.apple.QTKit (1.0 - 5) <A71258EB-241C-3AB2-BA89-303192C2A151> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff434f2000 - 0x7fff43738ff7 com.apple.imageKit (3.0 - 1081) <5F086EE2-5745-3E28-B292-1DE5E0652E36> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff43739000 - 0x7fff43bf8fff com.apple.QuartzComposer (5.1 - 378) <9C10ADF7-94B0-3779-AD44-5AF6394A32AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff43bf9000 - 0x7fff43c1effc com.apple.quartzfilters (1.10.0 - Tag) <876E8B28-9500-34C6-B297-EA404D89C903> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff43c1f000 - 0x7fff43d29ff7 com.apple.QuickLookUIFramework (5.0 - 906.3) <7128FB8C-83B0-3250-BF86-E8A1772CF1F5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff43d2a000 - 0x7fff43d2afff com.apple.quartzframework (1.5 - 23) <0E9BC89B-B86F-3E94-866A-AC0863522BF5> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff43d2b000 - 0x7fff43faeffb com.apple.QuartzCore (1.11 - 841.5) <26281BD1-499F-37C0-885C-58DD9245525D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff43faf000 - 0x7fff44008ff5 com.apple.QuickLookFramework (5.0 - 906.3) <959CE934-B541-3172-846F-4D1709353526> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff44009000 - 0x7fff4403effc com.apple.QuickLookThumbnailing (1.0 - 1) <9CCB50D8-AA39-3744-93FB-7B5B65467AB3> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff4450f000 - 0x7fff44529ffa com.apple.SafariServices.framework (15611 - 15611.1.21.161.7) <14B4BEBB-8528-3FA1-BF3A-C9EDE01521F3> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff44b31000 - 0x7fff44e7aff1 com.apple.security (7.0 - 59306.140.6) <A896EE58-D7EA-34E4-8832-93E38EA47831> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff44e7b000 - 0x7fff44f03ffb com.apple.securityfoundation (6.0 - 55236.60.1) <CCF58C3E-8953-3952-863B-0235054F0D40> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff44f04000 - 0x7fff44f31ff7 com.apple.securityinterface (10.0 - 55139.120.1) <72DC3440-6D3E-39DF-B8A8-85ADAE8D38FC> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff44f32000 - 0x7fff44f36ff8 com.apple.xpc.ServiceManagement (1.0 - 1) <0065A95F-0AEB-306D-94DC-6E7F70AA6EBD> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff45be2000 - 0x7fff45c5cff7 com.apple.SystemConfiguration (1.19 - 1.19) <84F9B3BB-F7AF-3B7C-8CD0-D3C22D19619F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff45edc000 - 0x7fff4625fff4 com.apple.VideoToolbox (1.0 - 2625.9) <6CF18E28-A7A8-3952-8171-7E4FF4FB37FA> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff46501000 - 0x7fff46c9eff7 libwebrtc.dylib (7609.4.1) <B3D98E65-2241-3DEC-9DEF-4628E4FBDDE6> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff46c9f000 - 0x7fff48f09ff3 com.apple.WebCore (15609 - 15609.4.1) <F7DC98BF-FB0A-39A4-ABA8-7C03364156BA> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff48f0a000 - 0x7fff49116ffb com.apple.WebKitLegacy (15609 - 15609.4.1) <99CAEE2D-8516-3B55-B29E-4F01340C84D3> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff49117000 - 0x7fff4981cffd com.apple.WebKit (15609 - 15609.4.1) <B514329D-F257-310E-B562-C23C20920075> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff49bcc000 - 0x7fff49c91fe7 com.apple.APFS (1412.141.2 - 1412.141.2) <FC81D7DC-5760-384E-A8FA-3CA56B8C1EE8> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff4a2dd000 - 0x7fff4a2e8ffc com.apple.accessibility.AXCoreUtilities (1.0 - 1) <7693F2BF-4DEB-3659-AA34-06322BAE38F8> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
0x7fff4ada6000 - 0x7fff4ada7ff1 com.apple.AggregateDictionary (1.0 - 1) <95A291F5-B69F-3C37-9483-C3B2EBF52AC1> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff4b072000 - 0x7fff4b1bdff5 com.apple.AnnotationKit (1.0 - 325.9) <9BB0EDB6-3808-30FC-B0ED-764DE5AAB893> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
0x7fff4b1be000 - 0x7fff4b1dbff4 com.apple.AppContainer (4.0 - 448.100.6) <87CEE13C-8585-3EFB-92CD-0852DFF0921B> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff4b230000 - 0x7fff4b23eff7 com.apple.AppSandbox (4.0 - 448.100.6) <0F49AA04-3400-349A-9096-6D4D7ED61027> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff4b6ba000 - 0x7fff4b6deffb com.apple.framework.Apple80211 (13.0 - 1610.1) <D94E03E8-4C38-3B2F-8DF4-473ACC5A7D71> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff4b99c000 - 0x7fff4b9abfd7 com.apple.AppleFSCompression (119.100.1 - 1.0) <466ABD77-2E52-36D1-8E39-77AE2CC61611> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff4baaa000 - 0x7fff4bab5ff7 com.apple.AppleIDAuthSupport (1.0 - 1) <74F6CD9C-27A7-39C7-A7EB-47E60D2517EB> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff4baf7000 - 0x7fff4bb3fff7 com.apple.AppleJPEG (1.0 - 1) <6DE30A07-C627-319B-A0DE-EB7A832BEB88> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff4bf02000 - 0x7fff4bf28ffb com.apple.aps.framework (4.0 - 4.0) <3ED300B6-43E3-31DC-B3C6-6A0FF41A2595> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff4bf29000 - 0x7fff4bf2dff7 com.apple.AppleSRP (5.0 - 1) <70C25EA9-F7A7-366C-97C6-EEE7845FFCC3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff4bf2e000 - 0x7fff4bf50fff com.apple.applesauce (1.0 - 16.25) <68E0364C-AEA7-3654-A030-136BF3CD92F3> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff4c00f000 - 0x7fff4c012fff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <67255151-F989-39F0-BC87-0C0BDAE70730> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff4c013000 - 0x7fff4c063ff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) <E8540613-F9C7-3665-AB6E-EA43A05B83B4> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff4c0ac000 - 0x7fff4c0bbff9 com.apple.AssertionServices (1.0 - 223.140.2) <48AD21CA-B81D-380E-A04F-90C48FDA5203> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff4c5fe000 - 0x7fff4c9f9ff8 com.apple.audio.AudioResourceArbitration (1.0 - 1) <2BD68521-C19C-3D67-B5EB-DE3E9A4DAF0A> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff4cc4f000 - 0x7fff4ce8fff8 com.apple.audio.AudioToolboxCore (1.0 - 1104.97) <E3B9D2AD-F256-38B5-93AC-6591E3787F7F> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff4ce93000 - 0x7fff4cfaffff com.apple.AuthKit (1.0 - 1) <DC1A27C5-0172-3C72-9B24-06996D0B6207> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff4d16c000 - 0x7fff4d175ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <A6877DAD-8F47-363C-983A-DC8DDE83B7B5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff4d176000 - 0x7fff4d217ff5 com.apple.backup.framework (1.11.7 - 1298.7.1) <C9DC35FA-E69F-3C64-9519-494126096337> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff4d218000 - 0x7fff4d2a4ff6 com.apple.BaseBoard (466.3 - 466.3) <10D0F3BB-E8F3-365E-8528-6AC996A9B0E7> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff4d3a6000 - 0x7fff4d3e2ff7 com.apple.bom (14.0 - 219.2) <79CBE5E7-054F-377B-9566-A86A9F120CF1> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff4d500000 - 0x7fff4d537ff5 com.apple.C2 (1.3 - 495) <4A7E2A63-E19A-3936-92F5-03F2FD602172> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff4df62000 - 0x7fff4dfb1fff com.apple.ChunkingLibrary (307 - 307) <5B09C30D-FD2B-3E98-8B64-C5EF470FC13C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff4e10c000 - 0x7fff4e197ff8 com.apple.CloudDocs (1.0 - 698.17) <900567ED-DEA4-30D5-A1C0-78BD53C58CD6> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff4ee5e000 - 0x7fff4ee6effb com.apple.CommonAuth (4.0 - 2.0) <7A6E5A56-7929-3E44-8FCC-FE1DC6751082> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff4ee82000 - 0x7fff4ee99fff com.apple.commonutilities (8.0 - 900) <F4C97244-E5D8-3F7D-8D94-4B6841C5A4EC> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff4f5a0000 - 0x7fff4f975fc8 com.apple.CoreAUC (283.0.0 - 283.0.0) <4341271C-D270-3F9F-8464-31A20D15158D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff4f976000 - 0x7fff4f9a3ff7 com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <C3CFDC68-C7D9-3C44-9E7C-801D45575C10> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff4f9c6000 - 0x7fff4f9e7ff4 com.apple.analyticsd (1.0 - 1) <7BAD537E-C905-330D-BABF-AA0AA0FE0E27> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff4faf0000 - 0x7fff4fb66ff7 com.apple.corebrightness (1.0 - 1) <BE927D79-1C49-3C0B-B8AD-055F34A35AE3> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff4fcf2000 - 0x7fff4fcfdff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <BB7D67B1-2102-3D71-9BB6-AEB8C6A6EBB2> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff4fcfe000 - 0x7fff4ff09ff1 com.apple.CoreDuet (1.0 - 1) <F899F217-FC31-3140-A0EB-92EAD22EEF71> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff4ff0a000 - 0x7fff4ff57ff3 com.apple.coreduetcontext (1.0 - 1) <72341E86-6921-35FE-89CA-7B04725ECC0F> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
0x7fff4ff58000 - 0x7fff4ff68ffe com.apple.CoreDuetDaemonProtocol (1.0 - 1) <5E31B761-4B30-39A8-9084-97ECFD268B6F> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff4ff6b000 - 0x7fff4ff6dfff com.apple.CoreDuetDebugLogging (1.0 - 1) <6D0113DB-61D8-3A21-95CB-9E30D8F929F9> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff4ff7e000 - 0x7fff4ff8eff3 com.apple.CoreEmoji (1.0 - 107.1) <7C2B3259-083B-31B8-BCDB-1BA360529936> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff50144000 - 0x7fff50291fff com.apple.CoreHandwriting (161 - 1.2) <21DAD964-51A7-3F38-9C91-EF46C0CFF12D> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
0x7fff505ce000 - 0x7fff50638ff0 com.apple.CoreNLP (1.0 - 213) <E70E2505-8078-324E-BAE1-01A2DA980E2C> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff508f6000 - 0x7fff508faffb com.apple.CoreOptimization (1.0 - 1) <0FFD7AA1-6E0B-395B-BCDC-73C1CCECC25B> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff508fb000 - 0x7fff50983ffe com.apple.CorePDF (4.0 - 518.4.1) <8F94505C-96C2-3694-BEC7-F3B5581A7AB9> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff50a66000 - 0x7fff50a6eff8 com.apple.CorePhoneNumbers (1.0 - 1) <E4DAD514-0B3B-3E0B-8AEA-39B320FAAF03> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff50a6f000 - 0x7fff50ac194b com.apple.CorePrediction (1.0 - 1) <CDF739BA-70AA-3FA2-9E0E-2E1BFC348A59> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff5145b000 - 0x7fff5147efff com.apple.CoreSVG (1.0 - 129.3) <F38189F9-C8F9-3D62-9D5F-3F520FB81724> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff5147f000 - 0x7fff514b2fff com.apple.CoreServicesInternal (446.7 - 446.7) <65F53A22-6B61-382C-AAC2-B2C53F8FFB44> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff514b3000 - 0x7fff514e1ffd com.apple.CSStore (1069.24 - 1069.24) <C2D67667-FA0B-3DB6-AA34-6999EE4346A0> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff51a06000 - 0x7fff51a9cff7 com.apple.CoreSymbolication (11.4 - 64535.33.2) <0B3BF87A-7F95-3D79-B4F8-421D6FAC4A6C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff51b34000 - 0x7fff51c60ff6 com.apple.coreui (2.1 - 609.4) <788818B7-7EBC-316D-9464-D12E365E3791> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff51c61000 - 0x7fff51e1affa com.apple.CoreUtils (6.2.4 - 624.7) <A74A1C65-6695-3F57-B703-0DEDE13E66C1> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff51f54000 - 0x7fff51f67ff1 com.apple.CrashReporterSupport (10.13 - 15016.1) <D584FFA6-32C5-328B-BE77-2C256B2B116C> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff52020000 - 0x7fff52032ff8 com.apple.framework.DFRFoundation (1.0 - 252.50.1) <8162057E-E856-3451-9160-04AEDDECFFA4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff52033000 - 0x7fff52038fff com.apple.DSExternalDisplay (3.1 - 380) <31ECB5FD-7660-33DB-BC5B-2B2A2AA7C686> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff520c2000 - 0x7fff5213cff0 com.apple.datadetectorscore (8.0 - 659) <B1534796-1000-3520-A641-A97A4AC5D39B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff52188000 - 0x7fff521c5ff8 com.apple.DebugSymbols (194 - 194) <040AE30B-CF2C-3798-A289-0929B8CAB10D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff521c6000 - 0x7fff5234eff6 com.apple.desktopservices (1.14.6 - 1281.6.1) <C2355E6B-C5F7-3E39-B778-B117BD4652C6> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff52364000 - 0x7fff52370ff8 com.apple.DeviceIdentity (1.0 - 1) <8700CB85-46A3-3388-977E-5A899FC58D20> /System/Library/PrivateFrameworks/DeviceIdentity.framework/Versions/A/DeviceIdentity
0x7fff525e7000 - 0x7fff526afffe com.apple.DiskImagesFramework (559.100.2 - 559.100.2) <65F24DF5-1B62-3F6B-9188-ED39634D2AE7> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff526b0000 - 0x7fff52783ff1 com.apple.DiskManagement (13.0 - 1648.140.2) <640DBACE-B6EC-3C72-9F73-F484E891534E> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff52784000 - 0x7fff52788ff1 com.apple.DisplayServicesFW (3.1 - 380) <4D71ADB3-B29D-3D20-B6DE-9E94061F86AC> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff527e2000 - 0x7fff52806ff7 com.apple.DuetActivityScheduler (1.0 - 1) <188C6793-A94C-3B49-A9F4-AF8A348C7E62> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
0x7fff52830000 - 0x7fff52865ff7 com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <D3F76E01-2F9F-33E1-B5C9-CAC6E01724C2> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
0x7fff52866000 - 0x7fff5286aff9 com.apple.EFILogin (2.0 - 2) <3BFE697B-469F-38F4-B380-4A4F4A37C836> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff533b4000 - 0x7fff53a1eff9 com.apple.vision.EspressoFramework (1.0 - 188.4) <70B1521B-1B24-3DA4-A41B-E727CF140F1F> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff53cf9000 - 0x7fff54114ff1 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <5D32F65D-2CD7-3204-975C-F4C9256E505F> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff5476c000 - 0x7fff5476cfff com.apple.FinderSyncPriv (1.0.7 - 1298.7.1) <5E08FCCF-B5AA-367F-BD08-DEFD32AB073F> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv
0x7fff547b3000 - 0x7fff548e9ffc libFontParser.dylib (277.2.6.6) <FABE97A5-398F-3015-B132-7DACC33344A2> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff548ea000 - 0x7fff5491efff libTrueTypeScaler.dylib (277.2.6.6) <653F9E57-5337-35CD-B1BE-165052FC9CF1> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff54982000 - 0x7fff54992ff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <202E45A7-B23F-3873-87CA-5D39D30D757F> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff57e73000 - 0x7fff57e74fff libmetal_timestamp.dylib (902.14.11) <C29C7125-A894-3718-8E1D-249C53BCC0B8> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff59522000 - 0x7fff5952dff7 libGPUSupportMercury.dylib (17.10.22) <AA625B41-C08E-35C0-A56C-E020DF33658B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff5952e000 - 0x7fff59534fff com.apple.GPUWrangler (5.2.7 - 5.2.7) <FA34760B-4E5C-3A18-A6C3-DBA68F9D1220> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff59853000 - 0x7fff59879ff1 com.apple.GenerationalStorage (2.0 - 314) <54483E50-20BB-3AF8-900F-992320C109B0> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff59892000 - 0x7fff5a87bff1 com.apple.GeoServices (1.0 - 1624.26.4.26.9) <F735575F-7DEF-3202-9151-589BEB162596> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff5a9a7000 - 0x7fff5a9b5ffb com.apple.GraphVisualizer (1.0 - 100.1) <507D5812-9CB4-3C94-938C-59ED2B370818> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff5a9b6000 - 0x7fff5a9c3ff3 com.apple.GraphicsServices (1.0 - 1.0) <5DAF38C9-53CF-319A-A853-C2EDC46F30EF> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
0x7fff5a9d3000 - 0x7fff5aa1dff8 com.apple.HDRProcessing (1.63.9 - 1.63.9) <051EAA90-51B4-3AFA-9BBC-7B5EF6035F8B> /System/Library/PrivateFrameworks/HDRProcessing.framework/Versions/A/HDRProcessing
0x7fff5aa1e000 - 0x7fff5aa2bff9 com.apple.HID (1.0 - 1) <0C27FC33-B645-3B7B-AAB5-E6F8F3A0A34D> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
0x7fff5ab54000 - 0x7fff5ac12ff4 com.apple.Heimdal (4.0 - 2.0) <6F292E47-3C40-33ED-9AD7-18FC9939E2CF> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5b60f000 - 0x7fff5b63eff8 com.apple.HelpData (2.3 - 199) <A62E7DB6-8960-3470-8281-293711C166D8> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff5cd94000 - 0x7fff5cd9dffe com.apple.IOAccelMemoryInfo (1.0 - 1) <ECAB1FBF-4756-3437-8C72-0F89294510CA> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff5cd9e000 - 0x7fff5cda6ff5 com.apple.IOAccelerator (438.7.4 - 438.7.4) <3C973800-3AE0-3908-9922-EFBC57C3F5B2> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5cdb3000 - 0x7fff5cdcafff com.apple.IOPresentment (47.10 - 37) <C97340B5-C71D-32CC-A519-30A5D7184BD3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5d152000 - 0x7fff5d19dff1 com.apple.IconServices (438.3 - 438.3) <0DADB4C3-46FF-3FDB-8A86-51E2067FC7F4> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5d33a000 - 0x7fff5d348fff com.apple.IntentsFoundation (1.0 - 1) <1BC7D355-E136-391A-8215-6982742645DD> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
0x7fff5d35b000 - 0x7fff5d362ff9 com.apple.InternationalSupport (1.0 - 45.4) <8D8D4A7D-FD35-36B8-A456-7C93030EDAB3> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff5d5ef000 - 0x7fff5d60effd com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <23F39683-FE1E-3295-BE65-2FB6694B7CBF> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff5d743000 - 0x7fff5d811ffd com.apple.LanguageModeling (1.0 - 215.1) <C456087D-5B3A-390E-A665-862FA284C59C> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5d812000 - 0x7fff5d85afff com.apple.Lexicon-framework (1.0 - 72) <41F208B9-8255-3EC7-9673-FE0925D071D3> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5d861000 - 0x7fff5d866ff3 com.apple.LinguisticData (1.0 - 353.18) <3B92F249-4602-325F-984B-D2DE61EEE4E1> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5d88d000 - 0x7fff5d8b1ffe com.apple.locationsupport (2394.0.22 - 2394.0.22) <CA6C86FD-051A-31BB-B3AF-3D02D6FD94B6> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff5d90a000 - 0x7fff5d90fff7 com.apple.LoginUICore (4.0 - 4.0) <25CA17AF-8A74-3CE3-84D8-67B4A2B76FEA> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff5e0ff000 - 0x7fff5e102fff com.apple.Mangrove (1.0 - 25) <482F300F-9B70-351F-A4DF-B440EEF7368D> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5e2c0000 - 0x7fff5e2e6ffc com.apple.MarkupUI (1.0 - 325.9) <A596E8D7-6DBD-3F01-89AD-B296C9D3B61E> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
0x7fff5e36b000 - 0x7fff5e3f5ff8 com.apple.MediaExperience (1.0 - 1) <0203AF27-AB5E-32FA-B529-AB7F29EEB887> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff5e3f6000 - 0x7fff5e429fff com.apple.MediaKit (16 - 923) <09FEE738-41E4-3A9C-AF1E-1DD00C56339D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff5e4ee000 - 0x7fff5e884ff9 com.apple.MediaRemote (1.0 - 1) <A0FF8D18-8BD3-3497-A53E-53CA3A072D5B> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
0x7fff5e885000 - 0x7fff5e8c1ffc com.apple.MediaServices (1.0 - 1) <EA82F76E-BF9B-37C3-9C8F-BEBC7D87D0CE> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
0x7fff5ebcf000 - 0x7fff5ec1bfff com.apple.spotlight.metadata.utilities (1.0 - 2076.7) <0237323B-EC78-3FBF-9FC7-5A1FE2B5CE25> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff5ec1c000 - 0x7fff5ecedffa com.apple.gpusw.MetalTools (1.0 - 1) <99876E08-37D7-3828-8796-56D90C9AFBDB> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff5ed4b000 - 0x7fff5ed64ff4 com.apple.MobileAssets (1.0 - 619.120.1) <07E116E6-7EBC-39F2-B5B4-31BAB6BAF852> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff5ef21000 - 0x7fff5ef3ffff com.apple.MobileKeyBag (2.0 - 1.0) <D5FA7041-297F-3ADC-8C7A-6EAAAB82EB68> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff5f00b000 - 0x7fff5f1a1ffd com.apple.Montreal (1.0 - 121.1) <E7881020-FCA6-3DFC-B0EB-9E539F80E821> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
0x7fff5f1a2000 - 0x7fff5f1d2ff7 com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <6794E1C8-9627-33DF-84F4-FDD02C97F383> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff5f6d2000 - 0x7fff5f6dcfff com.apple.NetAuth (6.2 - 6.2) <B0C03C41-87A3-352B-B130-96E1A6F94B47> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5f79e000 - 0x7fff5f7baff0 com.apple.network.statistics.framework (1.2 - 1) <B2F29251-A67A-36A9-B1E8-8652C59BADA1> /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistics
0x7fff600f3000 - 0x7fff6013effb com.apple.OTSVG (1.0 - 643.1.5.5) <01218F85-C43B-37A0-B124-90D0FA342210> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff6135b000 - 0x7fff61366ff2 com.apple.PerformanceAnalysis (1.243.3 - 243.3) <7B2C4193-68D7-3B95-ACA3-0FDD33A74D45> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff61367000 - 0x7fff6138fffb com.apple.persistentconnection (1.0 - 1.0) <5B2D87A8-2641-3F6D-ACEA-96B00F85AAB5> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff62e0a000 - 0x7fff62e3aff7 com.apple.pluginkit.framework (1.0 - 1) <EFBD7FE7-02CC-3E30-999D-B036F252F805> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff62e65000 - 0x7fff62e78ffc com.apple.PowerLog (1.0 - 1) <50B94781-D5BA-3F71-AFD4-583BD61F19F8> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff63cf4000 - 0x7fff63d4eff6 com.apple.ProtectedCloudStorage (1.0 - 1) <6F271388-3817-336D-9B96-08C7AAC4BA39> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff63d4f000 - 0x7fff63d68ffb com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <5A020941-C43C-303E-8DE8-230FC6A84DBC> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff63e7a000 - 0x7fff63e7dff4 com.apple.QuickLookNonBaseSystem (1.0 - 1) <8563CD18-DCFE-3868-912F-053FC8C34B9C> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
0x7fff63e7e000 - 0x7fff63ea1ff0 com.apple.quicklook.QuickLookSupport (1.0 - 1) <AFB0DFCC-6580-30E5-8984-831985F37A2C> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
0x7fff63ee8000 - 0x7fff63f61ff3 com.apple.Rapport (1.9.5 - 195.2) <AF01D899-3BF9-3586-860A-D95A837101DF> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
0x7fff641a8000 - 0x7fff641b4ff5 com.apple.xpc.RemoteServiceDiscovery (1.0 - 1738.140.3) <ECE50C94-D9D8-3ED1-80BD-95FDA964B716> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff641c8000 - 0x7fff641f1ff1 com.apple.RemoteViewServices (2.0 - 148) <D3AAC2BE-3423-3F18-9654-E35F1DD8DDB3> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff641f2000 - 0x7fff64207ffa com.apple.xpc.RemoteXPC (1.0 - 1738.140.3) <434E0734-59DA-3901-92F4-73B47A1FE1D3> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff64356000 - 0x7fff64391ff0 com.apple.RunningBoardServices (1.0 - 223.140.2) <96BB04BD-D6E0-3D70-8F36-89B46DA1DA30> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff650ba000 - 0x7fff65106ff9 com.apple.Safari.SafeBrowsing (15609 - 15609.4.1) <9B45B45B-9E12-3172-9799-BA1F8FF711EA> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
0x7fff65c72000 - 0x7fff65c75ff5 com.apple.SecCodeWrapper (4.0 - 448.100.6) <C4BF691D-A09E-37E8-A6CC-1145B79B8722> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff65de8000 - 0x7fff65f0ffff com.apple.Sharing (1526.37 - 1526.37) <CBDA0ADD-F1E7-3B06-9118-C5E183F0D3D6> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff65f68000 - 0x7fff65f86ff2 com.apple.shortcut (2.16 - 106) <9F669D19-13AD-3961-B247-ED728B7BFA19> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff65f87000 - 0x7fff65fa7ff5 com.apple.sidecar-core (1.0 - 209.40.4) <469E5222-A5C7-3B09-B617-EDB6E9E46B93> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff65fa8000 - 0x7fff65fbaff0 com.apple.sidecar-ui (1.0 - 209.40.4) <5CA517E3-4B92-30B1-96EF-77A7A2FBBEE4> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff67324000 - 0x7fff6761afff com.apple.SkyLight (1.600.0 - 451.5) <8847E3D3-C246-3D2E-9D04-48BBD71FCEDC> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff67e67000 - 0x7fff67e75ffb com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <4D6CAC2A-151B-3BBE-BDB7-E2BE72128691> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff67f37000 - 0x7fff681c3ffe com.apple.spotlight.index (10.7.0 - 2076.7) <932C7705-353B-395F-9A23-09D62EAFAD81> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff68551000 - 0x7fff68592ff9 com.apple.StreamingZip (1.0 - 1) <72CA32F8-4C96-3264-A655-623329EB3A28> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff686a9000 - 0x7fff686b2ff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.2) <C3D66901-7E31-3FDB-BD7A-441EB0520D1D> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff68723000 - 0x7fff6874dffe com.apple.framework.SystemAdministration (1.0 - 1.0) <087553CB-5BF3-3D3D-B620-CA36AD334D92> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff68969000 - 0x7fff68979ff3 com.apple.TCC (1.0 - 1) <C9EB52E3-099B-3597-9623-067C403FA525> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff68e9e000 - 0x7fff68f64ff0 com.apple.TextureIO (3.10.9 - 3.10.9) <EEDAB753-329A-396A-8119-5BEDF7DB5A56> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff690fb000 - 0x7fff690fcfff com.apple.TrustEvaluationAgent (2.0 - 33) <10E56F70-E234-31E0-9286-96D93A8ED17E> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff69134000 - 0x7fff6938cff0 com.apple.UIFoundation (1.0 - 662) <EC55B9E5-7E62-380A-9AB1-FC7BEF663653> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff69423000 - 0x7fff69429ffe com.apple.URLFormatting (119 - 119.18) <7F99D166-86DC-3F77-A34A-2DA7183D7160> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff6a01b000 - 0x7fff6a03bffc com.apple.UserManagement (1.0 - 1) <9F00880E-6EA6-3684-B208-455E14EC07C8> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff6ade7000 - 0x7fff6aed2ff2 com.apple.ViewBridge (468 - 468) <C02D0559-9C21-39C8-9E4B-E866CDBFD746> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff6b078000 - 0x7fff6b079fff com.apple.WatchdogClient.framework (1.0 - 67.120.2) <FFA17DA1-F6DD-34D3-A708-1F73C8BA7EA7> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff6b24c000 - 0x7fff6b24cfff com.apple.WebInspectorUI (15609 - 15609.4.1) <94A93FEF-0395-3053-9781-A8516C9F9040> /System/Library/PrivateFrameworks/WebInspectorUI.framework/Versions/A/WebInspectorUI
0x7fff6b408000 - 0x7fff6b443fff libAWDSupport.dylib (949) <EBE20139-E443-30DF-BCAD-2A6A8470F631> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
0x7fff6b444000 - 0x7fff6b724ff7 libAWDSupportFramework.dylib (3541.2) <D1EA2A4B-BC59-3FE2-BAA9-4448D6F8393F> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
0x7fff6b725000 - 0x7fff6b736fff libprotobuf-lite.dylib (3541.2) <578CA7D8-149E-3643-937B-DAD5501E4575> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
0x7fff6b737000 - 0x7fff6b790ffb libprotobuf.dylib (3541.2) <0CDB164D-E7C3-3D4F-BF11-47402D67D7B0> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x7fff6b791000 - 0x7fff6b7d5ff6 com.apple.awd (1.0 - 949) <9DA8A821-4354-3E24-BAA1-4519D2279F2B> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x7fff6bca9000 - 0x7fff6bcacffa com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <D459D628-58C5-39A6-B7E8-B691CBEECEC1> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff6bd26000 - 0x7fff6bd34ff5 com.apple.audio.caulk (1.0 - 32.3) <06D695EA-E2BC-31E4-9816-9C12542BA744> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff6c076000 - 0x7fff6c078ff3 com.apple.loginsupport (1.0 - 1) <12F77885-27DC-3837-9CE9-A25EBA75F833> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff6c079000 - 0x7fff6c08cffd com.apple.login (3.0 - 3.0) <C68367BA-2225-31DD-B2D8-16AC0A44421F> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff6c0be000 - 0x7fff6c0caffd com.apple.perfdata (1.0 - 51.100.6) <21760CFD-62FF-3466-B3AD-191D02411DA0> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
0x7fff6ea6a000 - 0x7fff6ea7fffe libAccessibility.dylib (2790.70) <3F824859-2E9B-3772-A475-73E4F88A15C2> /usr/lib/libAccessibility.dylib
0x7fff6eb4f000 - 0x7fff6eb5bff9 libAudioStatistics.dylib (1104.97) <910E0D16-7267-3B47-81F6-1420864A316C> /usr/lib/libAudioStatistics.dylib
0x7fff6eb5c000 - 0x7fff6eb8fffa libAudioToolboxUtility.dylib (1104.97) <8B76C584-A8B0-3599-A7D4-8BD75A11FEFF> /usr/lib/libAudioToolboxUtility.dylib
0x7fff6eb96000 - 0x7fff6ebcafff libCRFSuite.dylib (48) <5E5DE3CB-30DD-34DC-AEF8-FE8536A85E96> /usr/lib/libCRFSuite.dylib
0x7fff6ebcd000 - 0x7fff6ebd7fff libChineseTokenizer.dylib (34) <7F0DA183-1796-315A-B44A-2C234C7C50BE> /usr/lib/libChineseTokenizer.dylib
0x7fff6ebd8000 - 0x7fff6ec60fff libCoreStorage.dylib (551) <A457B0FE-D77F-30AA-99A4-70F6A98DFE59> /usr/lib/libCoreStorage.dylib
0x7fff6ec63000 - 0x7fff6ec65ff7 libDiagnosticMessagesClient.dylib (112) <C94F3B7B-1854-38EB-9778-834501C53B3F> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff6ecab000 - 0x7fff6ee62ffb libFosl_dynamic.dylib (100.4) <737573B2-190A-3BA1-8220-807AD0A2CE5E> /usr/lib/libFosl_dynamic.dylib
0x7fff6ee89000 - 0x7fff6ee8fff3 libIOReport.dylib (54) <75D177C4-BAD7-3285-B8E1-3019F49B3178> /usr/lib/libIOReport.dylib
0x7fff6ef71000 - 0x7fff6ef78fff libMatch.1.dylib (36) <5C6F3971-9D9E-3630-BDB6-60BFC5A665E0> /usr/lib/libMatch.1.dylib
0x7fff6efa7000 - 0x7fff6efc7ff7 libMobileGestalt.dylib (826.140.5) <2BE94E6A-FA61-312F-84A1-F764D71B7E39> /usr/lib/libMobileGestalt.dylib
0x7fff6f047000 - 0x7fff6f124ff7 libSMC.dylib (20) <5C9C17F2-1E6F-3A19-A440-86F74D82284F> /usr/lib/libSMC.dylib
0x7fff6f139000 - 0x7fff6f13afff libSystem.B.dylib (1281.100.1) <79E1F5B4-8B47-3718-A611-F9D14F3FB537> /usr/lib/libSystem.B.dylib
0x7fff6f13b000 - 0x7fff6f1c6ff7 libTelephonyUtilDynamic.dylib (5017.1) <174030B2-E35F-3F17-A9EF-DF8631F30CCF> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff6f1c7000 - 0x7fff6f1c8fff libThaiTokenizer.dylib (3) <4F4ADE99-0D09-3223-B7C0-C407AB6DE8DC> /usr/lib/libThaiTokenizer.dylib
0x7fff6f1e0000 - 0x7fff6f1f6fff libapple_nghttp2.dylib (1.39.2) <07FEC48A-87CF-32A3-8194-FA70B361713A> /usr/lib/libapple_nghttp2.dylib
0x7fff6f22b000 - 0x7fff6f29dff7 libarchive.2.dylib (72.140.2) <F9EA2883-5D5C-3FA6-B3F8-C5031BF88ABD> /usr/lib/libarchive.2.dylib
0x7fff6f29e000 - 0x7fff6f337fe5 libate.dylib (3.0.1) <76EA60FB-748C-313F-8951-B076540BEA97> /usr/lib/libate.dylib
0x7fff6f33b000 - 0x7fff6f33bff3 libauto.dylib (187) <B6124448-7690-34AE-8939-ED84AAC630CE> /usr/lib/libauto.dylib
0x7fff6f33c000 - 0x7fff6f400ffe libboringssl.dylib (283.120.1) <935DDB00-6514-3D0C-AEA5-C5FE6BCC0B61> /usr/lib/libboringssl.dylib
0x7fff6f401000 - 0x7fff6f411ffb libbsm.0.dylib (60.100.1) <00BFFB9A-2FFE-3C24-896A-251BC61917FD> /usr/lib/libbsm.0.dylib
0x7fff6f412000 - 0x7fff6f41efff libbz2.1.0.dylib (44) <14CC4988-B6D4-3879-AFC2-9A0DDC6388DE> /usr/lib/libbz2.1.0.dylib
0x7fff6f41f000 - 0x7fff6f471fff libc++.1.dylib (902.1) <59A8239F-C28A-3B59-B8FA-11340DC85EDC> /usr/lib/libc++.1.dylib
0x7fff6f472000 - 0x7fff6f487ffb libc++abi.dylib (902) <E692F14F-C65E-303B-9921-BB7E97D77855> /usr/lib/libc++abi.dylib
0x7fff6f488000 - 0x7fff6f488fff libcharset.1.dylib (59) <72447768-9244-39AB-8E79-2FA14EC0AD33> /usr/lib/libcharset.1.dylib
0x7fff6f489000 - 0x7fff6f49afff libcmph.dylib (8) <E72A20DB-2E86-378D-A237-EB9A1370F989> /usr/lib/libcmph.dylib
0x7fff6f49b000 - 0x7fff6f4b2fd7 libcompression.dylib (87) <64C91066-586D-38C0-A2F3-3E60A940F859> /usr/lib/libcompression.dylib
0x7fff6f78c000 - 0x7fff6f7a2ff7 libcoretls.dylib (167) <770A5B96-936E-34E3-B006-B1CEC299B5A5> /usr/lib/libcoretls.dylib
0x7fff6f7a3000 - 0x7fff6f7a4fff libcoretls_cfhelpers.dylib (167) <940BF370-FD0C-30A8-AA05-FF48DA44FA4C> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff6fc47000 - 0x7fff6fd4bfef libcrypto.44.dylib (47.140.1) <CB6B188A-1ADC-3C5D-AFFC-2ACD86E235EE> /usr/lib/libcrypto.44.dylib
0x7fff6fd4e000 - 0x7fff6fd59fff libcsfde.dylib (551) <CEE22AEF-4E77-36B1-B007-00303819965F> /usr/lib/libcsfde.dylib
0x7fff6fd61000 - 0x7fff6fdc0ff7 libcups.2.dylib (483.7) <821ED293-B7B3-3B37-88C9-7B6CA91DA7FA> /usr/lib/libcups.2.dylib
0x7fff6fdc2000 - 0x7fff6fe27ff7 libcurl.4.dylib (118.120.5) <854B4C52-1E58-3A61-A73D-431C5C65D8F9> /usr/lib/libcurl.4.dylib
0x7fff6feca000 - 0x7fff6fecafff libenergytrace.dylib (21) <162DFCC0-8F48-3DD0-914F-FA8653E27B26> /usr/lib/libenergytrace.dylib
0x7fff6fecb000 - 0x7fff6fee3fff libexpat.1.dylib (19.60.2) <FED7C38B-92D8-342D-AED7-871B12D1F7E7> /usr/lib/libexpat.1.dylib
0x7fff6fef1000 - 0x7fff6fef3fff libfakelink.dylib (149.1) <36146CB2-E6A5-37BB-9EE8-1B4034D8F3AD> /usr/lib/libfakelink.dylib
0x7fff6ff02000 - 0x7fff6ff07fff libgermantok.dylib (24) <D2AE5AC0-EDCE-3216-B8C9-CF59292A545F> /usr/lib/libgermantok.dylib
0x7fff6ff08000 - 0x7fff6ff11ff7 libheimdal-asn1.dylib (564.140.2) <F42CB310-DA54-3EF9-BFE3-0667E14E0133> /usr/lib/libheimdal-asn1.dylib
0x7fff6ff12000 - 0x7fff70002fff libiconv.2.dylib (59) <18311A67-E4EF-3CC7-95B3-C0EDEE3A282F> /usr/lib/libiconv.2.dylib
0x7fff70003000 - 0x7fff7025afff libicucore.A.dylib (64260.0.1) <8AC2CB07-E7E0-340D-A849-186FA1F27251> /usr/lib/libicucore.A.dylib
0x7fff70274000 - 0x7fff70275fff liblangid.dylib (133) <30CFC08C-EF36-3CF5-8AEA-C1CB070306B7> /usr/lib/liblangid.dylib
0x7fff70276000 - 0x7fff7028eff3 liblzma.5.dylib (16) <C131EF18-2CDD-3271-8A30-A8760D4FE166> /usr/lib/liblzma.5.dylib
0x7fff702a6000 - 0x7fff7034dff7 libmecab.dylib (883.11) <0D5BFD01-D4A7-3C8D-AA69-C329C1A69792> /usr/lib/libmecab.dylib
0x7fff7034e000 - 0x7fff705b0ff1 libmecabra.dylib (883.11) <E31DE74D-1B88-377F-ACD3-D789D29C3AE7> /usr/lib/libmecabra.dylib
0x7fff7091d000 - 0x7fff7094cfff libncurses.5.4.dylib (57) <995DFEEA-40F3-377F-B73D-D02AC59D591F> /usr/lib/libncurses.5.4.dylib
0x7fff70a7c000 - 0x7fff70ef8ff5 libnetwork.dylib (1880.120.4) <BA294A54-F309-398D-B308-F97032AFF555> /usr/lib/libnetwork.dylib
0x7fff70ef9000 - 0x7fff70f10fff libnetworkextension.dylib (1095.140.2) <D0E8454C-33A9-3F96-B3A0-EDB12C32283A> /usr/lib/libnetworkextension.dylib
0x7fff70f99000 - 0x7fff70fccfde libobjc.A.dylib (787.1) <6DF81160-5E7F-3E31-AA1E-C875E3B98AF6> /usr/lib/libobjc.A.dylib
0x7fff70fcd000 - 0x7fff70fceff7 libodfde.dylib (26) <33F49412-5106-35B8-AA60-5A497C3967E6> /usr/lib/libodfde.dylib
0x7fff70fdf000 - 0x7fff70fe3fff libpam.2.dylib (25.100.1) <0502F395-8EE6-3D2A-9239-06FD5622E19E> /usr/lib/libpam.2.dylib
0x7fff70fe6000 - 0x7fff7101cfff libpcap.A.dylib (89.120.2) <86DAA475-805A-3E01-86C5-6CAE4D1D9BC6> /usr/lib/libpcap.A.dylib
0x7fff7105c000 - 0x7fff7106aff9 libperfcheck.dylib (37.100.2) <9D9C4879-8A80-34C4-B0D2-BE341FD6D321> /usr/lib/libperfcheck.dylib
0x7fff7106b000 - 0x7fff7106eff3 libpmenergy.dylib (214.120.1) <B33FB1C8-EACB-39C5-9B71-283EAB72E7E2> /usr/lib/libpmenergy.dylib
0x7fff7106f000 - 0x7fff71071fff libpmsample.dylib (214.120.1) <F12D8EE0-9284-3E57-AE73-414266E11586> /usr/lib/libpmsample.dylib
0x7fff710a0000 - 0x7fff710b8fff libresolv.9.dylib (67.40.1) <C57EDFEF-D36A-310B-8D14-8C68A625B1E8> /usr/lib/libresolv.9.dylib
0x7fff710ba000 - 0x7fff710feff7 libsandbox.1.dylib (1217.141.2) <E8BA5E84-66AF-3995-8F8E-DDC93B0A88E1> /usr/lib/libsandbox.1.dylib
0x7fff710ff000 - 0x7fff71111ff7 libsasl2.2.dylib (213.120.1) <E7573AC1-83FD-305A-8FB8-03145BDA286B> /usr/lib/libsasl2.2.dylib
0x7fff71112000 - 0x7fff71113ff7 libspindump.dylib (281.3) <AE8C1AE9-5CBC-332F-BBE8-370A2A19FED6> /usr/lib/libspindump.dylib
0x7fff71114000 - 0x7fff712feff7 libsqlite3.dylib (308.6) <33057143-AB4E-348B-9650-98BC48866F34> /usr/lib/libsqlite3.dylib
0x7fff713f2000 - 0x7fff7141fffb libssl.46.dylib (47.140.1) <06932872-13DA-33E3-8C28-7B49FC582039> /usr/lib/libssl.46.dylib
0x7fff71422000 - 0x7fff7146cff7 libstdc++.6.dylib (104.1) <1AD78D98-D287-3A49-AFBB-4999CB334D2B> /usr/lib/libstdc++.6.dylib
0x7fff714f4000 - 0x7fff7154eff8 libusrtcp.dylib (1880.120.4) <05346A91-737C-33D0-B21B-F040950DFB28> /usr/lib/libusrtcp.dylib
0x7fff7154f000 - 0x7fff71552ffb libutil.dylib (57) <F01467F6-23A7-37EE-A170-33CE1577B41D> /usr/lib/libutil.dylib
0x7fff71553000 - 0x7fff71560ff7 libxar.1.dylib (425.2) <EE964412-9E25-30B3-BCC0-CCEFBCC8094B> /usr/lib/libxar.1.dylib
0x7fff71566000 - 0x7fff71648fff libxml2.2.dylib (33.8) <FE38B007-24AF-310D-B834-2C9466154CEC> /usr/lib/libxml2.2.dylib
0x7fff7164c000 - 0x7fff71674fff libxslt.1.dylib (16.11) <B2F38A15-4D4A-30F9-9660-F5738DE14BC2> /usr/lib/libxslt.1.dylib
0x7fff71675000 - 0x7fff71687ff3 libz.1.dylib (76) <793D9643-CD83-3AAC-8B96-88D548FAB620> /usr/lib/libz.1.dylib
0x7fff7173e000 - 0x7fff7175472f libswiftAppKit.dylib (??? - ???) <18802260-9EFC-3E31-B9EA-7767A8B6AB52> /usr/lib/swift/libswiftAppKit.dylib
0x7fff7177e000 - 0x7fff71b33437 libswiftCore.dylib (5.2 - 1103.8.25.8) <E56CCFCA-99E1-36E5-A6BC-F31F53C79910> /usr/lib/swift/libswiftCore.dylib
0x7fff71b40000 - 0x7fff71b48d7f libswiftCoreData.dylib (??? - ???) <5188E034-FC7D-3C6B-A42A-69375097E05B> /usr/lib/swift/libswiftCoreData.dylib
0x7fff71b49000 - 0x7fff71b4bfff libswiftCoreFoundation.dylib (??? - ???) <FBA4566B-AD2B-35D7-BC9A-48BE3D88B658> /usr/lib/swift/libswiftCoreFoundation.dylib
0x7fff71b4c000 - 0x7fff71b59fff libswiftCoreGraphics.dylib (??? - ???) <A8225B5F-F64D-32F8-AD91-D919DF614AA0> /usr/lib/swift/libswiftCoreGraphics.dylib
0x7fff71b5a000 - 0x7fff71b5dffb libswiftCoreImage.dylib (??? - ???) <1485E8EF-EDA9-3981-84D7-DF3BFE361929> /usr/lib/swift/libswiftCoreImage.dylib
0x7fff71bb8000 - 0x7fff71bbefff libswiftDarwin.dylib (??? - ???) <F3684684-8258-310F-B05B-BD8A696F0F29> /usr/lib/swift/libswiftDarwin.dylib
0x7fff71bbf000 - 0x7fff71bd6cdf libswiftDispatch.dylib (??? - ???) <94D67EF4-42B5-3F54-8D86-B6B2B16827DC> /usr/lib/swift/libswiftDispatch.dylib
0x7fff71bd7000 - 0x7fff71d5c277 libswiftFoundation.dylib (??? - ???) <0173898D-FDA6-378D-87E9-1F2A9BD227D3> /usr/lib/swift/libswiftFoundation.dylib
0x7fff71d6b000 - 0x7fff71d6dff3 libswiftIOKit.dylib (??? - ???) <FD313708-AE48-3C72-A154-53EC839A8D55> /usr/lib/swift/libswiftIOKit.dylib
0x7fff71d83000 - 0x7fff71d8af0f libswiftMetal.dylib (??? - ???) <B3C74138-DE3C-3676-9983-F12757819C9C> /usr/lib/swift/libswiftMetal.dylib
0x7fff71e06000 - 0x7fff71e09fe7 libswiftObjectiveC.dylib (??? - ???) <E668BD5D-E1D6-3C21-BA7E-5C3A672A964E> /usr/lib/swift/libswiftObjectiveC.dylib
0x7fff71e1b000 - 0x7fff71e20fbf libswiftQuartzCore.dylib (??? - ???) <101D3E4D-231A-3CD8-97B4-4E37F4081CD2> /usr/lib/swift/libswiftQuartzCore.dylib
0x7fff71f0a000 - 0x7fff71f0cfff libswiftXPC.dylib (??? - ???) <3CD547C3-7082-37EA-B289-F6BA6C4D4E26> /usr/lib/swift/libswiftXPC.dylib
0x7fff71f36000 - 0x7fff71f3bff3 libcache.dylib (83) <AF488D13-9E89-35E0-B078-BE37CC5B8586> /usr/lib/system/libcache.dylib
0x7fff71f3c000 - 0x7fff71f47fff libcommonCrypto.dylib (60165.120.1) <C7912BE5-993E-3581-B2A0-6AABDC8C5562> /usr/lib/system/libcommonCrypto.dylib
0x7fff71f48000 - 0x7fff71f4ffff libcompiler_rt.dylib (101.2) <49B8F644-5705-3F16-BBE0-6FFF9B17C36E> /usr/lib/system/libcompiler_rt.dylib
0x7fff71f50000 - 0x7fff71f59ff7 libcopyfile.dylib (166.40.1) <3C481225-21E7-370A-A30E-0CCFDD64A92C> /usr/lib/system/libcopyfile.dylib
0x7fff71f5a000 - 0x7fff71fecfdb libcorecrypto.dylib (866.140.2) <C2CFE656-BFA7-36E0-B8BB-1579F51AB6CF> /usr/lib/system/libcorecrypto.dylib
0x7fff720f9000 - 0x7fff72139ff0 libdispatch.dylib (1173.100.2) <CD9C059C-91D9-30E8-8926-5B9CD0D5D4F5> /usr/lib/system/libdispatch.dylib
0x7fff7213a000 - 0x7fff72170fff libdyld.dylib (750.6) <789A18C2-8AC7-3C88-813D-CD674376585D> /usr/lib/system/libdyld.dylib
0x7fff72171000 - 0x7fff72171ffb libkeymgr.dylib (30) <DB3337BE-01CA-3425-BD0C-87774FC0CDC0> /usr/lib/system/libkeymgr.dylib
0x7fff72172000 - 0x7fff7217eff3 libkxld.dylib (6153.141.28.1) <D0CD88A4-D750-384C-AEF4-463BE5D606B1> /usr/lib/system/libkxld.dylib
0x7fff7217f000 - 0x7fff7217fff7 liblaunch.dylib (1738.140.3) <0A07A8E8-EDA1-30C7-9414-0FCC070A45D8> /usr/lib/system/liblaunch.dylib
0x7fff72180000 - 0x7fff72185ff7 libmacho.dylib (959.0.1) <AA613A9C-961A-3B67-B696-4622FA59FC4E> /usr/lib/system/libmacho.dylib
0x7fff72186000 - 0x7fff72188ff3 libquarantine.dylib (110.40.3) <F234E51D-FD0B-3EE4-B679-AE3EE9C536C3> /usr/lib/system/libquarantine.dylib
0x7fff72189000 - 0x7fff7218aff7 libremovefile.dylib (48) <7C7EFC79-BD24-33EF-B073-06AED234593E> /usr/lib/system/libremovefile.dylib
0x7fff7218b000 - 0x7fff721a2ff3 libsystem_asl.dylib (377.60.2) <1563EE02-0657-3B78-99BE-A947C24122EF> /usr/lib/system/libsystem_asl.dylib
0x7fff721a3000 - 0x7fff721a3ff7 libsystem_blocks.dylib (74) <0D53847E-AF5F-3ACF-B51F-A15DEA4DEC58> /usr/lib/system/libsystem_blocks.dylib
0x7fff721a4000 - 0x7fff7222bfff libsystem_c.dylib (1353.100.2) <BBDED5E6-A646-3EED-B33A-91E4331EA063> /usr/lib/system/libsystem_c.dylib
0x7fff7222c000 - 0x7fff7222fffb libsystem_configuration.dylib (1061.141.1) <0EE84C33-64FD-372B-974A-AF7A136F2068> /usr/lib/system/libsystem_configuration.dylib
0x7fff72230000 - 0x7fff72233fff libsystem_coreservices.dylib (114) <A199156E-058D-3ABB-BCE9-4B9F20DCED0F> /usr/lib/system/libsystem_coreservices.dylib
0x7fff72234000 - 0x7fff7223cfff libsystem_darwin.dylib (1353.100.2) <5B12B5DB-3F30-37C1-8ECC-49A66B1F2864> /usr/lib/system/libsystem_darwin.dylib
0x7fff7223d000 - 0x7fff72244fff libsystem_dnssd.dylib (1096.100.3) <EBB4C2C2-E031-3094-B40A-E67BF261D295> /usr/lib/system/libsystem_dnssd.dylib
0x7fff72245000 - 0x7fff72246ffb libsystem_featureflags.dylib (17) <29FD922A-EC2C-3F25-BCCC-B58D716E60EC> /usr/lib/system/libsystem_featureflags.dylib
0x7fff72247000 - 0x7fff72294ff7 libsystem_info.dylib (538) <8A321605-5480-330B-AF9E-64E65DE61747> /usr/lib/system/libsystem_info.dylib
0x7fff72295000 - 0x7fff722c1ff7 libsystem_kernel.dylib (6153.141.28.1) <B3DC3FBB-4304-338C-A1E0-CAAFA78CDE2B> /usr/lib/system/libsystem_kernel.dylib
0x7fff722c2000 - 0x7fff72309fff libsystem_m.dylib (3178) <00F331F1-0D09-39B3-8736-1FE90E64E903> /usr/lib/system/libsystem_m.dylib
0x7fff7230a000 - 0x7fff72331fff libsystem_malloc.dylib (283.100.6) <8549294E-4C53-36EB-99F3-584A7393D8D5> /usr/lib/system/libsystem_malloc.dylib
0x7fff72332000 - 0x7fff7233fffb libsystem_networkextension.dylib (1095.140.2) <F06C65C5-2CBE-313C-96E1-A09240F9FE57> /usr/lib/system/libsystem_networkextension.dylib
0x7fff72340000 - 0x7fff72349ff7 libsystem_notify.dylib (241.100.2) <FA22F928-D91B-3AA5-96BB-3186AC0FB264> /usr/lib/system/libsystem_notify.dylib
0x7fff7234a000 - 0x7fff72352fef libsystem_platform.dylib (220.100.1) <009A7C1F-313A-318E-B9F2-30F4C06FEA5C> /usr/lib/system/libsystem_platform.dylib
0x7fff72353000 - 0x7fff7235dfff libsystem_pthread.dylib (416.100.3) <62CB1A98-0B8F-31E7-A02B-A1139927F61D> /usr/lib/system/libsystem_pthread.dylib
0x7fff7235e000 - 0x7fff72362ff3 libsystem_sandbox.dylib (1217.141.2) <051C4018-4345-3034-AC98-6DE42FB8273B> /usr/lib/system/libsystem_sandbox.dylib
0x7fff72363000 - 0x7fff72365fff libsystem_secinit.dylib (62.100.2) <F80872AA-E1FD-3D7E-8729-467656EC6561> /usr/lib/system/libsystem_secinit.dylib
0x7fff72366000 - 0x7fff7236dffb libsystem_symptoms.dylib (1238.120.2) <702D0910-5C34-3D43-9631-8BD215DE4FE1> /usr/lib/system/libsystem_symptoms.dylib
0x7fff7236e000 - 0x7fff72384ff2 libsystem_trace.dylib (1147.120.1) <BC141783-66D9-3137-A783-211B38E49ADB> /usr/lib/system/libsystem_trace.dylib
0x7fff72386000 - 0x7fff7238bff7 libunwind.dylib (35.4) <42B7B509-BAFE-365B-893A-72414C92F5BF> /usr/lib/system/libunwind.dylib
0x7fff7238c000 - 0x7fff723c1ffe libxpc.dylib (1738.140.3) <A3F5B6A0-DD96-3AC2-B610-F62E242F477C> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 4
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 1490
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=2.5G resident=0K(0%) swapped_out_or_unallocated=2.5G(100%)
Writable regions: Total=1.6G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.6G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
ATS (font support) 32.0M 90
ATS (font support) (reserved) 8K 2 reserved VM address space (unallocated)
Accelerate framework 1664K 13
Activity Tracing 256K 1
CG backing stores 3124K 6
CG image 1252K 38
CG raster data 8K 1
CoreAnimation 26.8M 427
CoreGraphics 8K 1
CoreImage 140K 29
CoreUI image data 2112K 31
Foundation 4K 1
IOKit 7940K 1
Image IO 532K 106
Kernel Alloc Once 8K 1
MALLOC 1.2G 1460
MALLOC guard page 32K 7
MALLOC_NANO (reserved) 128.0M 1 reserved VM address space (unallocated)
Mach message 8K 2
OpenGL GLSL 256K 3
STACK GUARD 56.3M 66
Stack 123.6M 72
VM_ALLOCATE 2704K 44
VM_ALLOCATE (reserved) 2048K 1 reserved VM address space (unallocated)
__DATA 207.7M 984
__DATA_CONST 773K 29
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 966.4M 346
__OBJC_RO 32.3M 1
__OBJC_RW 1908K 2
__TEXT 1.5G 770
__UNICODE 564K 1
mapped file 869.9M 359
shared memory 672K 23
TOTAL 5.2G 4921
TOTAL, minus reserved VM space 5.1G 4921
Model: MacBookPro16,1, BootROM XXXXXXXXXXX (iBridge: XXXXXXXXX), 8 processors, 8-Core Intel Core i9, 2,3 GHz, 16 GB, SMC
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Graphics: kHW_AMDRadeonPro5500MItem, AMD Radeon Pro 5500M, spdisplays_pcie_device, 8 GB
Memory Module: BANK 0/ChannelA-DIMM0, 8 GB, DDR4, 2667 MHz, Micron, 8ATF1G64HZ-2G6E1
Memory Module: BANK 2/ChannelB-DIMM0, 8 GB, DDR4, 2667 MHz, Micron, 8ATF1G64HZ-2G6E1
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Oct 28 2020 14:13:29 version 9.30.357.42.32.5.48 FWID 01-767f6cce
Bluetooth: Version 7.0.6f8, 3 services, 27 devices, 1 incoming serial ports
Network Service: USB 10/100/1000 LAN, Ethernet, en5
Network Service: Wi-Fi, AirPort, en0
USB Device: USB3.0 Hub
USB Device: Mass Storage Device
USB Device: USB3.1 Hub
USB Device: USB 10/100/1000 LAN
USB Device: USB 3.1 Bus
USB Device: USB2.0 Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: USB Billboard Device
USB Device: Apple T2 Bus
USB Device: Composite Device
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 55.3
Hi,
everyone's so glad about VW 2021 and its stability. Unfortunately me and my project colleagues don't share this happiness somehow.
Of course our file might be a part of the problem, however, sometimes VW 2021 SP3 crashes immediately after clicking on the "open server-based project sharing file" from the file menu (in german it's called "Serverbasiertes Projektdatei öffnen..." (as you can see in the attached screenshot)
That didn't happen for the first time, this morning... why?
Anyone able to read and interpretate the quoted crash dump text?
QuoteProcess: Vectorworks [920]
Path: /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/Vectorworks
Identifier: net.nemetschek.vectorworks
Version: 26.0.3 [588748] (26.0.3)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Vectorworks [920]
User ID: 502
Date/Time: 2021-05-19 09:08:09.895 +0200
OS Version: Mac OS X 10.15.7 (19H1030)
Report Version: 12
Bridge OS Version: 5.3 (18P4556)
Anonymous UUID: DF008156-D81C-0F7B-7656-2B9CD710AF70
Time Awake Since Boot: 1000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 CrBrowserMain Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
Pure virtual function called!
Application Specific Signatures:
{"sn“:“XXXXXX-XXXXXX-XXXXXX-XXXXXX“, "ts":"1798369e889", "platform":"MAC", "os_ver":"10.15.7", "vw_ver":"2021 SP3 R1 [26.0.3(588748)] (64-Bit app)", "error_reporting_mode":3}
Thread 0 Crashed:: CrBrowserMain Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff7229c33a __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff72358e60 pthread_kill + 430
2 libsystem_c.dylib 0x00007fff72223808 abort + 120
3 libc++abi.dylib 0x00007fff6f482458 abort_message + 231
4 libc++abi.dylib 0x00007fff6f481e92 __cxa_pure_virtual + 18
5 libTD_Root.dylib 0x0000000163d70766 OdRxClassImpl::reset() + 70
6 libTD_Root.dylib 0x0000000163d704b5 OdRxClass::~OdRxClass() + 37
7 libsystem_c.dylib 0x00007fff721fe13c __cxa_finalize_ranges + 319
8 libsystem_c.dylib 0x00007fff721fe412 exit + 55
9 com.apple.HIServices 0x00007fff36525052 ExitToShell + 11
10 net.nemetschek.vectorworks 0x000000010b8d3937 0x109f8b000 + 26511671
11 libc++abi.dylib 0x00007fff6f481887 std::__terminate(void (*)()) + 8
12 libc++abi.dylib 0x00007fff6f484387 __cxa_rethrow + 99
13 libobjc.A.dylib 0x00007fff70fac93d objc_exception_rethrow + 37
14 com.apple.AppKit 0x00007fff35861874 -[NSMenu performActionForItemAtIndex:] + 158
15 com.apple.AppKit 0x00007fff358617cd -[NSMenu _internalPerformActionForItemAtIndex:] + 82
16 com.apple.AppKit 0x00007fff35861617 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 101
17 com.apple.AppKit 0x00007fff357f1d30 NSSLMMenuEventHandler + 908
18 com.apple.HIToolbox 0x00007fff36e508ff DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1254
19 com.apple.HIToolbox 0x00007fff36e4fd8d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 329
20 com.apple.HIToolbox 0x00007fff36e6547e SendEventToEventTarget + 39
21 com.apple.HIToolbox 0x00007fff36ec540b SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 368
22 com.apple.HIToolbox 0x00007fff36eec065 SendMenuCommandWithContextAndModifiers + 45
23 com.apple.HIToolbox 0x00007fff36eec00d SendMenuItemSelectedEvent + 346
24 com.apple.HIToolbox 0x00007fff36eebe59 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96
25 com.apple.HIToolbox 0x00007fff36eec88e MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 603
26 com.apple.HIToolbox 0x00007fff36eec598 _HandleMenuSelection2 + 460
27 com.apple.AppKit 0x00007fff35694c0d _NSHandleCarbonMenuEvent + 215
28 com.apple.AppKit 0x00007fff35694a7a _DPSEventHandledByCarbon + 54
29 com.apple.AppKit 0x00007fff354bceca -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2962
30 net.nemetschek.vectorworks 0x000000010a3ce7e1 0x109f8b000 + 4470753
31 com.apple.AppKit 0x00007fff354ae58e -[NSApplication run] + 658
32 com.apple.AppKit 0x00007fff35480396 NSApplicationMain + 777
33 net.nemetschek.vectorworks 0x000000010a2c7381 0x109f8b000 + 3392385
34 libdyld.dylib 0x00007fff72154cc9 start + 1
Thread 1:: ThreadPoolServiceThread
0 libsystem_kernel.dylib 0x00007fff7229eb96 kevent64 + 10
1 org.chromium.ContentShell.framework 0x000000011d0804b8 cef_time_delta + 2912120
2 org.chromium.ContentShell.framework 0x000000011d080366 cef_time_delta + 2911782
3 org.chromium.ContentShell.framework 0x000000011d015993 cef_time_delta + 2475091
4 org.chromium.ContentShell.framework 0x000000011cfeb2b3 cef_time_delta + 2301299
5 org.chromium.ContentShell.framework 0x000000011d01e3bd cef_time_delta + 2510461
6 org.chromium.ContentShell.framework 0x000000011d030164 cef_time_delta + 2583588
7 org.chromium.ContentShell.framework 0x000000011d065637 cef_time_delta + 2801911
8 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
9 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 2:: ThreadPoolForegroundWorker
0 libsystem_kernel.dylib 0x00007fff72295dfa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff72296170 mach_msg + 60
2 org.chromium.ContentShell.framework 0x000000011d074183 cef_time_delta + 2862147
3 org.chromium.ContentShell.framework 0x000000011d027378 cef_time_delta + 2547256
4 org.chromium.ContentShell.framework 0x000000011d027ccd cef_time_delta + 2549645
5 org.chromium.ContentShell.framework 0x000000011d0278dd cef_time_delta + 2548637
6 org.chromium.ContentShell.framework 0x000000011d065637 cef_time_delta + 2801911
7 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
8 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 3:: ThreadPoolBackgroundWorker
5 org.chromium.ContentShell.framework 0x000000011d02784d cef_time_delta + 2548493
Thread 4:: Chrome_IOThread
5 org.chromium.ContentShell.framework 0x000000011bd746af cef_zip_reader_create + 26554431
Thread 5:: MemoryInfra
3 org.chromium.ContentShell.framework 0x000000011d073f7f cef_time_delta + 2861631
4 org.chromium.ContentShell.framework 0x000000011cfcb1b7 cef_time_delta + 2169975
5 org.chromium.ContentShell.framework 0x000000011d015993 cef_time_delta + 2475091
6 org.chromium.ContentShell.framework 0x000000011cfeb2b3 cef_time_delta + 2301299
7 org.chromium.ContentShell.framework 0x000000011d030164 cef_time_delta + 2583588
8 org.chromium.ContentShell.framework 0x000000011d065637 cef_time_delta + 2801911
9 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
10 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 6:: NetworkConfigWatcher
2 com.apple.CoreFoundation 0x00007fff3824d9d5 __CFRunLoopServiceMachPort + 247
3 com.apple.CoreFoundation 0x00007fff3824c4a2 __CFRunLoopRun + 1319
4 com.apple.CoreFoundation 0x00007fff3824b91e CFRunLoopRunSpecific + 462
5 com.apple.Foundation 0x00007fff3a8e71a8 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 212
6 org.chromium.ContentShell.framework 0x000000011d06e871 cef_time_delta + 2839345
7 org.chromium.ContentShell.framework 0x000000011d06d5d2 cef_time_delta + 2834578
8 org.chromium.ContentShell.framework 0x000000011d015993 cef_time_delta + 2475091
9 org.chromium.ContentShell.framework 0x000000011cfeb2b3 cef_time_delta + 2301299
10 org.chromium.ContentShell.framework 0x000000011d030164 cef_time_delta + 2583588
11 org.chromium.ContentShell.framework 0x000000011d065637 cef_time_delta + 2801911
12 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
13 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 7:: NetworkConfigWatcher
Thread 8:: CompositorTileWorker1
0 libsystem_kernel.dylib 0x00007fff72298882 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff72359425 _pthread_cond_wait + 698
2 org.chromium.ContentShell.framework 0x000000011d0647d4 cef_time_delta + 2798228
3 org.chromium.ContentShell.framework 0x000000011e29466d cef_time_delta + 21868845
4 org.chromium.ContentShell.framework 0x000000011d065637 cef_time_delta + 2801911
5 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
6 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 9:: ThreadPoolSingleThreadForegroundBlocking0
4 org.chromium.ContentShell.framework 0x000000011d02736a cef_time_delta + 2547242
5 org.chromium.ContentShell.framework 0x000000011d027ccd cef_time_delta + 2549645
6 org.chromium.ContentShell.framework 0x000000011d02793d cef_time_delta + 2548733
Thread 10:: ThreadPoolSingleThreadSharedBackgroundBlocking1
5 org.chromium.ContentShell.framework 0x000000011d027a48 cef_time_delta + 2549000
6 org.chromium.ContentShell.framework 0x000000011d02787d cef_time_delta + 2548541
Thread 11:: ThreadPoolSingleThreadSharedForegroundBlocking2
6 org.chromium.ContentShell.framework 0x000000011d02790d cef_time_delta + 2548685
Thread 12:
2 ThreadPool.tx 0x0000000176e1af6b OdRxThreadPoolImpl::OdApcThreadImpl::threadMain() + 139
3 ThreadPool.tx 0x0000000176e1aed9 OdRxThreadPoolImpl::OdApcThreadImpl::threadProc(void*) + 9
4 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
5 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff3565f954 _NSEventThread + 132
6 libsystem_pthread.dylib 0x00007fff72359109 _pthread_start + 148
7 libsystem_pthread.dylib 0x00007fff72354b8b thread_start + 15
Thread 29:
0 libsystem_kernel.dylib 0x00007fff72295e36 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff720fbaed _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff720fbfbf _dispatch_semaphore_wait_slow + 98
3 net.nemetschek.vectorworks 0x000000010b059145 0x109f8b000 + 17621317
4 net.nemetschek.vectorworks 0x000000010b05c874 0x109f8b000 + 17635444
5 net.nemetschek.vectorworks 0x000000010b05c256 0x109f8b000 + 17633878
6 net.nemetschek.vectorworks 0x000000010b059840 0x109f8b000 + 17623104
Thread 30:
4 net.nemetschek.vectorworks 0x000000010b05cb0e 0x109f8b000 + 17636110
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
0 libsystem_kernel.dylib 0x00007fff72298756 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff7221beea nanosleep + 196
2 libsystem_c.dylib 0x00007fff7221bde4 usleep + 53
3 net.nemetschek.vectorworks.Renderworks 0x000000015e916baa cineware::IpKillThread::Main() + 58
4 net.nemetschek.vectorworks.Renderworks 0x000000015e8d9c9e cineware::BaseThread::Action() + 62
5 net.nemetschek.vectorworks.Renderworks 0x000000015e8d9b99 cineware::BeginThread(void*) + 9
Thread 45:
1 com.datalogics.DL150PDFL 0x000000015693f2b0 CTThreading::OSSemaphore::Wait() + 16
2 com.datalogics.DL150PDFL 0x00000001568fc334 CTThreading::ThreadSafeQueue::Dequeue() + 22
3 com.datalogics.DL150PDFL 0x00000001568fc794 CTThreading::WorkerThread::Start() + 38
4 com.datalogics.DL150PDFL 0x00000001568fc0f6 CTThreading::PthreadStart(void*) + 14
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
Thread 51:
Thread 52:
Thread 53:
Thread 54:
Thread 55:
Thread 56:
Thread 57:
Thread 58:
Thread 59:
Thread 60:
Thread 61:
0 libsystem_kernel.dylib 0x00007fff7229a766 kevent + 10
1 net.nemetschek.vectorworks 0x000000010adfcbb6 0x109f8b000 + 15145910
2 net.nemetschek.vectorworks 0x000000010adfc7a5 0x109f8b000 + 15144869
3 net.nemetschek.vectorworks 0x000000010adfc451 0x109f8b000 + 15144017
4 net.nemetschek.vectorworks 0x000000010be38373 0x109f8b000 + 32166771
5 net.nemetschek.vectorworks 0x000000010be37d46 0x109f8b000 + 32165190
6 net.nemetschek.vectorworks 0x000000010be3dfde void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, std::__1::__bind<void (sio::client_impl::*)(), sio::client_impl*> > >(void*) + 62
Thread 62:
2 net.nemetschek.vectorworks 0x000000010adfc876 0x109f8b000 + 15145078
4 net.nemetschek.vectorworks 0x000000010adfff9f 0x109f8b000 + 15159199
5 net.nemetschek.vectorworks 0x000000010adfff30 boost_asio_detail_posix_thread_function + 16
Thread 63:
0 libsystem_pthread.dylib 0x00007fff72354b68 start_wqthread + 0
Thread 64:
Thread 65:
Thread 66:
Thread 67:
Thread 68:
Thread 69:
Thread 70:
Thread 71:
Thread 72:
Thread 73:
Thread 74:
Thread 75:
Thread 76:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x000000011628edc0 rcx: 0x00007ffee5c73998 rdx: 0x0000000000000000
rdi: 0x0000000000000307 rsi: 0x0000000000000006 rbp: 0x00007ffee5c739c0 rsp: 0x00007ffee5c73998
r8: 0x00007ffee5c73860 r9: 0x00007ffee5c73a30 r10: 0x000000011628edc0 r11: 0x0000000000000246
r12: 0x0000000000000307 r13: 0x0000003000000008 r14: 0x0000000000000006 r15: 0x0000000000000016
rip: 0x00007fff7229c33a rfl: 0x0000000000000246 cr2: 0x00000001632b77e0
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x109f8b000 - 0x10e7db6c7 +net.nemetschek.vectorworks (26.0.3 [588748] - 26.0.3) <3B1F86B4-7F81-3109-AD3B-C0D381117196> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/Vectorworks
0x10face000 - 0x1101ebfff +libdcu2d68.dylib (0) <34875B1B-E7D8-34EF-81F5-7AB310580706> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libdcu2d68.dylib
0x1104bd000 - 0x110813fdf +libPSServer.dylib (0) <268993E4-8BED-33DA-AA14-8E01809C2282> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libPSServer.dylib
0x110961000 - 0x110963fff +libboost_system.dylib (0) <FD3A0297-3214-3F2C-95BE-FAAC54953B5E> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libboost_system.dylib
0x11096f000 - 0x110994ff7 +libosdCPU.2.5.0.dylib (0) <D1EBC34A-EFA2-3362-A101-5EC18DE33AF7> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libosdCPU.2.5.0.dylib
0x1109b6000 - 0x110bebfff +org.python.python (3.8.2, [c] 2001-2019 Python Software Foundation. - 3.8.2) <D386999B-3D21-310C-8015-1D3910C0D271> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/Python.framework/Versions/3.8/Python
0x110d31000 - 0x110d36ff3 +net.nemetschek.VWMM (1.0 - 1) <9161DCCF-969B-3DF4-ACE1-AF90799E940F> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/VWMM.framework/Versions/A/VWMM
0x110d43000 - 0x113040ffb +libPDFNetC.dylib (0) <BA85CBD4-038A-34F5-AAD3-F391F4E2A192> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libPDFNetC.dylib
0x11338a000 - 0x11338ffff +libpsassemblyrep.dylib (0) <371326E4-7EFF-3CB4-B79A-FB72AC3A8868> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsassemblyrep.dylib
0x1133a1000 - 0x11348dff7 +libpsgeneric.dylib (0) <65D8D9EB-4A83-3226-9E80-EAF0D9DA8E58> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsgeneric.dylib
0x11353f000 - 0x113561ff7 +libpsiges.dylib (0) <105E4244-4FDC-3DCE-86D1-FE7B8651644E> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsiges.dylib
0x1135a3000 - 0x1135c7fff +libpsinterop.dylib (0) <230A5B0A-2A01-3041-8034-B811D5427172> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsinterop.dylib
0x113608000 - 0x11360bfff +libpspropertiesbase.dylib (0) <87F2D2A3-69F8-3B19-83BA-0F8434EDB065> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpspropertiesbase.dylib
0x11361c000 - 0x1136abfff +libpsxlatorbase.dylib (0) <E0300163-6169-321B-8C1F-B88C7FD65EFE> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsxlatorbase.dylib
0x113773000 - 0x113777fff +libpspropertiesbrepimporter.dylib (0) <5529F23C-F06C-3ACF-9838-63DF72C495D4> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpspropertiesbrepimporter.dylib
0x11378a000 - 0x113884ff7 +libpsxcore.dylib (0) <540B4087-333F-3F2B-AAFB-54348AF41D3D> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsxcore.dylib
0x113977000 - 0x113af4ff7 +libpsxiges.dylib (0) <781C9EB0-1A0A-3AEA-A5D3-F3135038B8AF> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsxiges.dylib
0x113c38000 - 0x113c5aff7 +libpsxmil.dylib (0) <12F432FD-C5F8-32DB-A50C-28CEA5AE70F9> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpsxmil.dylib
0x113c90000 - 0x113c93fff +libmessagehandler.dylib (0) <82C3A773-8BE3-3ED5-9313-2D65FEB1D161> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libmessagehandler.dylib
0x113c9e000 - 0x113cd6fff +libHSIMac.dylib (0) <6D170DB2-9A66-30AD-9F23-2E7B4950C8F9> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libHSIMac.dylib
0x1161c4000 - 0x116255f47 dyld (750.6) <1DCAF85D-70A4-3405-A868-25AF3DC1F32B> /usr/lib/dyld
0x1162c9000 - 0x11a007ffb +libpskernel.dylib (0) <E0EEFF6B-9BEE-351B-978D-CF397FF3AFCA> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/libpskernel.dylib
0x11a3b3000 - 0x122560f9f +org.chromium.ContentShell.framework (84.2.6.0 - 6.0) <C95E00B6-94B0-3E90-8755-9CD5B3E43624> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
0x1259e3000 - 0x1259e6047 libobjc-trampolines.dylib (787.1) <88F9B648-C455-36F8-BBB9-7D1A9F57D073> /usr/lib/libobjc-trampolines.dylib
0x125a5a000 - 0x125c1cff7 com.apple.AMDRadeonX6000GLDriver (3.10.19 - 3.1.0) <4D8D93FA-4065-3BAE-8EDD-FFA80770A2E8> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/AMDRadeonX6000GLDriver
0x125cfa000 - 0x125d4fff7 +net.nemetschek.vectorworks.DesignLayerViewport (1.0) <5D36F87E-7EAD-3C5E-ACF8-AA9E1248BCB0> /Applications/Vectorworks 2021 SP3/*/DesignLayerViewport
0x125d7d000 - 0x125d84fff +libjson-c.4.dylib (0) <D6C6E3AB-4359-391A-BA6D-3452B6825579> /Applications/Vectorworks 2021 SP3/*/libjson-c.4.dylib
0x125d89000 - 0x125dddfff +libwebp.7.dylib (0) <41532BC1-E0E7-35D2-9C48-8817CBA0F274> /Applications/Vectorworks 2021 SP3/*/libwebp.7.dylib
0x125dec000 - 0x125dedff3 +libTD_Alloc.dylib (0) <B481BEEC-F960-3A1E-81DF-D376CF096D9C> /Applications/Vectorworks 2021 SP3/*/libTD_Alloc.dylib
0x125fe0000 - 0x1262a9ff7 +de.computerworks.vectorworks.3D-Hilfspunkte auf Modell CW (D26.0.0 R1 505805+/11731+ - 1.0) <C57B6086-A361-397B-B1FF-623434EEF335> /Applications/Vectorworks 2021 SP3/*/3D-Hilfspunkte auf Modell CW
0x1265b8000 - 0x126714fff +net.nemetschek.vectorworks. (1.0) <4819D7BE-223C-3725-A6F5-E5D56D0B536F> /Applications/Vectorworks 2021 SP3/*/3DS Library
0x1267f6000 - 0x126af7fff +de.computerworks.vectorworks.Achsen CW (D26.0.0 R1 505805+/11731+ - 1.0) <E7904E1E-B982-30BB-B38B-F491BB5DE7FD> /Applications/Vectorworks 2021 SP3/*/Achsen CW
0x126e30000 - 0x126f6affb +net.nemetschek.vectorworks.AlignDistribute (1.0) <715BCA7F-5982-3C39-8BEC-C47F79159384> /Applications/Vectorworks 2021 SP3/*/AlignDistribute
0x127017000 - 0x127068fff +net.nemetschek.vectorworks.AlignLayerViews (1.0) <AE0369CC-FE6A-387C-871A-99D83BA17C7B> /Applications/Vectorworks 2021 SP3/*/AlignLayerViews
0x127092000 - 0x127244ff7 +net.nemetschek.vectorworks.Animation (1.0) <EE9873B9-83F1-3527-9928-FAAD8ADE9D29> /Applications/Vectorworks 2021 SP3/*/Animation
0x127338000 - 0x127602fff +de.computerworks.vectorworks.Ansichten CW (D26.0.0 R1 505805+/11731+ - 1.0) <9F8C4A76-49DD-3E28-9737-8ABD30A8B792> /Applications/Vectorworks 2021 SP3/*/Ansichten CW
0x12791f000 - 0x127c69ff7 +net.nemetschek.vectorworks.ArchitecturalObjects (1.0) <A5C0CF4B-0D82-3333-AB48-3BA40F0B4FDD> /Applications/Vectorworks 2021 SP3/*/ArchitecturalObjects
0x127da1000 - 0x127eddffb +com.ingenicad.ArtlantisExportEN (26.0.1 - 1.0) <3E7261D4-C660-35BB-ACC7-026BA82DA509> /Applications/Vectorworks 2021 SP3/*/Artlantis_Export_EN
0x127f81000 - 0x1280acff7 +com.abvent.fr.catl (9.0.0 - 9.0.0 for Artlantis 2020) <FF2281EE-7C45-314E-9D06-A73C389E2DB3> /Applications/Vectorworks 2021 SP3/*/CATL.framework/Versions/V9/CATL
0x12837c000 - 0x1284b8ffb +com.ingenicad.ArtlantisExport (25.0 - 1.0) <50BAC4E2-86E3-3E95-9F04-1AF6B34627C3> /Applications/Vectorworks 2021 SP3/*/Atl6_Export_Lib_2021_EN
0x12855e000 - 0x1286c8fff +com.abvent.fr.catl (6.5.0 - 6.5.0 for Artlantis 6.5) <3E96835D-DD4D-32A0-8DB1-142BFB36B451> /Applications/Vectorworks 2021 SP3/*/CATL.framework/Versions/V6.5/CATL
0x12880c000 - 0x128948ff7 +com.ingenicad.ArtlantisExport (25.0 - 1.0) <E0CA9167-0291-3746-9D89-EC395112C60F> /Applications/Vectorworks 2021 SP3/*/Atl8_Export_Lib_2021_EN
0x1289ee000 - 0x128b6cff7 +com.abvent.fr.catl (8.0.0 - 8.0.0 for Artlantis 2019) <24812299-F4A7-319A-931B-55FE9B990E0B> /Applications/Vectorworks 2021 SP3/*/CATL.framework/Versions/V8/CATL
0x128e4e000 - 0x129194ffb +de.computerworks.vectorworks.Attr suchen und aendern CW (D26.0.0 R1 505805+/11731+ - 1.0) <B915C483-DB41-3746-B3E5-35BA74C0B373> /Applications/Vectorworks 2021 SP3/*/Attr suchen und aendern CW
0x129532000 - 0x1297f3fff +de.computerworks.vectorworks.Attribute zu Grundeinst CW (D26.0.0 R1 505805+/11731+ - 1.0) <C4E0E0E5-84E7-331B-9EAB-8A0ADC436819> /Applications/Vectorworks 2021 SP3/*/Attribute zu Grundeinst CW
0x129af3000 - 0x129db1ff7 +de.computerworks.vectorworks.Attribute zu Klassenattr CW (D26.0.0 R1 505805+/11731+ - 1.0) <24AA765E-C4C1-3933-9EEC-4401E10C3CFD> /Applications/Vectorworks 2021 SP3/*/Attribute zu Klassenattr CW
0x12a0af000 - 0x12a3adff7 +Ausserh Bereich loeschen CW (D26.0.0 R1 505805+/11731+ - 1.0) <1C979AD6-B652-3808-B937-718752CDEE5E> /Applications/Vectorworks 2021 SP3/*/Ausserh Bereich loeschen CW
0x12a6e0000 - 0x12aa54fff +de.computerworks.vectorworks.Baugrube Aufschuettung CW (D26.0.0 R1 505805+/11731+ - 1.0) <8258A925-9068-3315-B281-78394245E4A6> /Applications/Vectorworks 2021 SP3/*/Baugrube Aufschuettung CW
0x12adec000 - 0x12b0c7ff3 +Baumgruppe CW (D26.0.0 R1 505805+/11731+ - 1.0) <4DF93DD2-72DD-346E-8DB6-F1B6CE34AC53> /Applications/Vectorworks 2021 SP3/*/Baumgruppe CW
0x12b3e1000 - 0x12b6a0ff7 +Bemassungsgenauigkeit um CW (D26.0.0 R1 505805+/11731+ - 1.0) <B67D0FF3-0E73-35B4-A509-9F9983C54C56> /Applications/Vectorworks 2021 SP3/*/Bemassungsgenauigkeit um CW
0x12b9a0000 - 0x12baf5ffb +net.nemetschek.vectorworks.BIMobject (1.0) <44934C0C-3254-322B-9753-AD4263D07C61> /Applications/Vectorworks 2021 SP3/*/BIMobject
0x12bbb4000 - 0x12be8bff3 +Blatt einrichten CW (D26.0.0 R1 505805+/11731+ - 1.0) <3F30CE47-1016-3D65-8E1A-6E4F6BA4B811> /Applications/Vectorworks 2021 SP3/*/Blatt einrichten CW
0x12c1a7000 - 0x12c1f5ffb +net.nemetschek.vectorworks.BluebeamConnect (1.0) <423F4281-3529-3809-9865-42E80433E2DB> /Applications/Vectorworks 2021 SP3/*/BluebeamConnect
0x12c21b000 - 0x12c534ff7 +Boeschung CW (D26.0.0 R1 505805+/11731+ - 1.0) <16510560-91C0-38B3-B321-4B86D16DF828> /Applications/Vectorworks 2021 SP3/*/Boeschung CW
0x12c87e000 - 0x12cc77fff +com.deersoft.braceworxs.braceworxsvwxplg (0.13.2) <C425A62F-E43F-3A22-9599-D13E5AB962A5> /Applications/Vectorworks 2021 SP3/*/BraceWorxsVwxPlg
0x12cea6000 - 0x12d201ffb +de.computerworks.vectorworks.buildup CW (D26.0.0 R1 505805+/11731+ - 1.0) <A28EB3B5-AB27-3246-AC24-428D9E3F8459> /Applications/Vectorworks 2021 SP3/*/buildup CW
0x12d580000 - 0x12d732ffb +com.deersoft.CableTools (1.0) <D8CBE759-70E0-34AA-8D62-F5F8B99402E6> /Applications/Vectorworks 2021 SP3/*/CableTools
0x12d86a000 - 0x12d9cdff3 +com.cesyam.ARLM (25.0 - 1.0) <6D898099-6883-3CF7-A21F-BB1498DB4D8A> /Applications/Vectorworks 2021 SP3/*/CE_ARLM
0x12da94000 - 0x12dc8ffe7 +com.cesyam.CE_Base (25.0.2 - 1.0) <4135F4C9-CE67-3598-9E2E-A4936D756217> /Applications/Vectorworks 2021 SP3/*/CE_Base
0x12dd73000 - 0x12deb4ffb +com.cesyam.Cotations (25.0 - 1.0) <7EBF7FB1-73E4-3B30-9DA6-F90F4231BC7B> /Applications/Vectorworks 2021 SP3/*/CE_Cotations
0x12df5f000 - 0x12e14afe7 +com.cesyam.infoslicence (25.0 - 1.0) <5C0C993D-910C-352E-8CCF-B48F958037BF> /Applications/Vectorworks 2021 SP3/*/CE_Infos_Licence
0x12e21e000 - 0x12e36fffb +com.cesyam.CE_PathPIM (25.0 - 1.0) <FA43A9C8-F910-37B0-8F80-FB358F660EDD> /Applications/Vectorworks 2021 SP3/*/CE_PathPIM
0x12e42a000 - 0x12e515fff +com.cesyam.CE_Tubages (25.0 - 1.0) <288C73F2-95B0-3C43-B802-489C9897E178> /Applications/Vectorworks 2021 SP3/*/CE_Tubages
0x12e584000 - 0x12e66cff3 +net.nemetschek.vectorworks.CeilingGrid (1.0) <48B13BF9-9458-33C1-8A06-114AB3CD7F40> /Applications/Vectorworks 2021 SP3/*/CeilingGrid
0x12e6e4000 - 0x12e735ffb +net.nemetschek.vectorworks.TesterModule (1.0) <F621059A-807D-3667-B3D5-83CE73DA1375> /Applications/Vectorworks 2021 SP3/*/CheckForUpdates
0x12e75f000 - 0x12e7d9fff +net.nemetschek.vectorworks.CheckSpelling (1.0) <F66DCD1A-B35D-3E3A-9BC8-E174F7C23448> /Applications/Vectorworks 2021 SP3/*/CheckSpelling
0x12e80f000 - 0x12e961ff3 +net.nemetschek.vectorworks.ColorPalettes (1.0) <8FEDB744-B401-34B0-8E1A-B34230984A90> /Applications/Vectorworks 2021 SP3/*/ColorPalettes
0x12ea12000 - 0x12ed60ff7 +com.connectcad.connectCAD (1.0) <E2EABB42-CD57-3FE9-85F5-CDFCFADB400B> /Applications/Vectorworks 2021 SP3/*/connectCAD
0x12efe8000 - 0x12f301ff3 +de.computerworks.vectorworks.CWLibrarySondereinheiten (D26.0.0 R1 505805+/11731+ - 1.0) <F16D308E-27B9-3F96-84C0-A214EB9ACAE7> /Applications/Vectorworks 2021 SP3/*/CWLibrarySondereinheiten
0x12f651000 - 0x12f937fff +de.computerworks.vectorworks.CWLibraryUniversal1 (D26.0.0 R1 505805+/11731+ - 1.0) <DE986672-4849-3CB5-BDFC-DE130F11166B> /Applications/Vectorworks 2021 SP3/*/CWLibraryUniversal1
0x12fc85000 - 0x13009bff3 +Daemmung CW (D26.0.0 R1 505805+/11731+ - 1.0) <276E1B8D-CDCC-317F-92AE-198BE40D699E> /Applications/Vectorworks 2021 SP3/*/Daemmung CW
0x13047d000 - 0x1306bcff7 +net.nemetschek.vectorworks.DataTag (1.0) <CDCDD99B-E252-3CC4-AF79-10A07E7C478F> /Applications/Vectorworks 2021 SP3/*/DataTag
0x130811000 - 0x130bb4ff7 +Datei Info CW (D26.0.0 R1 505805+/11731+ - 1.0) <89FA14B8-D0D0-3960-973D-C2CF7F408124> /Applications/Vectorworks 2021 SP3/*/Datei Info CW
0x130fb3000 - 0x13129aff3 +de.computerworks.vectorworks.Datenbank abgleichen CW (D26.0.0 R1 505805+/11731+ - 1.0) <6C34E83B-03B7-3795-9F1C-4F69796BCB9C> /Applications/Vectorworks 2021 SP3/*/Datenbank abgleichen CW
0x1315cf000 - 0x131876ff3 +net.nemetschek.vectorworks.DebugModule (1.0) <5970E116-0BCC-31DE-B46F-A56F08ED4A49> /Applications/Vectorworks 2021 SP3/*/DebugModule
0x1319cb000 - 0x131abcffb +net.nemetschek.vectorworks.DetailCallout (1.0) <C7D3BB28-7611-3734-B96D-214B4232F01A> /Applications/Vectorworks 2021 SP3/*/DetailCallout
0x131b3a000 - 0x131e08ffb +Dokument einrichten CW (D26.0.0 R1 505805+/11731+ - 1.0) <B1EE2119-468A-3CE4-862D-AB7D7882535A> /Applications/Vectorworks 2021 SP3/*/Dokument einrichten CW
0x132111000 - 0x1321f9ff7 +net.nemetschek.vectorworks. (1.0) <A410B1F5-3393-30BB-B729-0F55DDD4EB7D> /Applications/Vectorworks 2021 SP3/*/Duplicate Along Path
0x132267000 - 0x13233dffb +net.nemetschek.vectorworks. (1.0) <DC1DEC55-8A12-3E00-868F-71BFB976AFC6> /Applications/Vectorworks 2021 SP3/*/Duplicate Symbol In Wall
0x1323a8000 - 0x13269cff3 +de.computerworks.vectorworks.Duplizieren an Pfad CW (D26.0.0 R1 505805+/11731+ - 1.0) <1DE446DA-BD08-3D02-ACB9-760FC7805BB2> /Applications/Vectorworks 2021 SP3/*/Duplizieren an Pfad CW
0x1329d0000 - 0x132ca8ffb +de.computerworks.vectorworks.Duplizieren auf Ebenen CW (D26.0.0 R1 505805+/11731+ - 1.0) <15F48CCD-7CFB-3B97-ACC5-56049A8A5054> /Applications/Vectorworks 2021 SP3/*/Duplizieren auf Ebenen CW
0x132fc2000 - 0x133298ff3 +de.computerworks.vectorworks.Durch Symbol ersetzen CW (26.0.3 - 1.0) <12CDBC82-674A-35F3-9367-27FCC60B65CE> /Applications/Vectorworks 2021 SP3/*/Durch Symbol ersetzen CW
0x1335ab000 - 0x136694ff7 +net.nemetschek.vectorworks. (1.0) <953F5C77-88AE-3412-B67C-63238BBACFC6> /Applications/Vectorworks 2021 SP3/*/DWG Library
0x1378d4000 - 0x137c21ffb +EbenenKlassen Manager CW (D26.0.0 R1 505805+/11731+ - 1.0) <E0A33922-F995-3E9F-85CC-13F9AC519370> /Applications/Vectorworks 2021 SP3/*/EbenenKlassen Manager CW
0x137fa1000 - 0x137ff9ff3 +net.nemetschek.vectorworks.EditShader (1.0) <4E3B32F6-06EC-310E-8009-558BCC6E6EA7> /Applications/Vectorworks 2021 SP3/*/EditShader
0x138027000 - 0x1383d0ff7 +Einzelstempel CW (D26.0.0 R1 505805+/11731+ - 1.0) <8FB01A83-7D1F-34A8-B4B8-A7E9170B6FE2> /Applications/Vectorworks 2021 SP3/*/Einzelstempel CW
0x1387c9000 - 0x1389acff7 +de.computerworks.vectorworks.Electrics (1.0 - 1.0) <409425A3-4A25-38D1-912A-77FD10ED186C> /Applications/Vectorworks 2021 SP3/*/Electrics
0x138ac0000 - 0x138e90fff +net.nemetschek.vectorworks.EnergyAnalysis (1.0) <B4FA0312-7375-3198-8E3E-C9F9737E6AA9> /Applications/Vectorworks 2021 SP3/*/EnergyAnalysis
0x1390cf000 - 0x13a76bfff +net.nemetschek.ExcelLibrary (1.0 - 1) <E8C574F3-746C-3002-B6E8-5B4CD828B934> /Applications/Vectorworks 2021 SP3/*/ExcelLibrary
0x13b580000 - 0x13b9bbff7 +de.computerworks.vectorworks.Export AufmassKoordinaten (D26.0.0 R1 505805+/11731+ - 1.0) <3BB9F4D2-A1BB-306C-8D98-71A4781A3766> /Applications/Vectorworks 2021 SP3/*/Export AufmassKoordinaten
0x13be89000 - 0x13c172ff3 +de.computerworks.vectorworks.Export easyjob CW (D26.0.0 R1 505805+/11731+ - 1.0) <AC6CC7EB-C94B-323E-884D-0911B0F69BA3> /Applications/Vectorworks 2021 SP3/*/Export easyjob CW
0x13c495000 - 0x13c8cbffb +de.computerworks.vectorworks.Export Objektdaten CW (D26.0.0 R1 505805+/11731+ - 1.0) <D3AAB450-C549-3C67-9412-B894F6B5338A> /Applications/Vectorworks 2021 SP3/*/Export Objektdaten CW
0x13cd77000 - 0x13ceccff3 +net.nemetschek.vectorworks.Export3DPDF (1.0) <1E6D3807-4702-3547-9275-7BF3B41A23B3> /Applications/Vectorworks 2021 SP3/*/Export3DPDF
0x13cf80000 - 0x13d0f9ffb +net.nemetschek.vectorworks.TesterModule (1.0) <03870DFC-255B-3807-8CBC-BED54BEAFE69> /Applications/Vectorworks 2021 SP3/*/ExportWebGl
0x13d1ac000 - 0x13d2a1ff7 +net.nemetschek.vectorworks. (1.0) <E6104257-A0DC-3AFE-874A-807CEB8A970B> /Applications/Vectorworks 2021 SP3/*/ExtrudeAlongPath
0x13d31d000 - 0x13d461ffb +net.nemetschek.vectorworks. (1.0) <56832557-F5BD-3A72-A6B6-C2605AD469FD> /Applications/Vectorworks 2021 SP3/*/Eyedropper Tool
0x13d505000 - 0x13d7c6ff3 +de.computerworks.vectorworks.Farbtest CW (D26.0.0 R1 505805+/11731+ - 1.0) <C37957B6-2F90-3163-827F-848639921C13> /Applications/Vectorworks 2021 SP3/*/Farbtest CW
0x13dac2000 - 0x13dd84ffb +Farbverlauftest CW (D26.0.0 R1 505805+/11731+ - 1.0) <1E71098C-29CE-334D-98A4-939CF879B227> /Applications/Vectorworks 2021 SP3/*/Farbverlauftest CW
0x13e087000 - 0x13e8b8ffb +de.computerworks.vectorworks.Fenster CW (D26.0.0 R1 505805+/11731+ - 1.0) <D2D2B2ED-0F54-3B77-B3FF-1C5F6029A1BF> /Applications/Vectorworks 2021 SP3/*/Fenster CW
0x13f1e3000 - 0x13f234ff3 +net.nemetschek.vectorworks. (1.0) <0BF86EF0-498F-3588-9BC6-A7A6DF0D0340> /Applications/Vectorworks 2021 SP3/*/Fit To Objects
0x13f25e000 - 0x13f351ff7 +net.nemetschek.vectorworks.FitWallsToRoof (1.0) <B40E2949-A621-3EE6-A640-B4CB6732152F> /Applications/Vectorworks 2021 SP3/*/FitWallsToRoof
0x13f3be000 - 0x13f6a9ffb +de.computerworks.vectorworks.Fixieren CW (D26.0.0 R1 505805+/11731+ - 1.0) <F4CF4F19-CA77-3CE0-9FED-9947A7EFB8C0> /Applications/Vectorworks 2021 SP3/*/Fixieren CW
0x13f9da000 - 0x13fb4effb +net.nemetschek.vectorworks.FramingMember (1.0) <EB56F633-3E82-39BC-9455-56B34C181FEF> /Applications/Vectorworks 2021 SP3/*/FramingMember
0x13fc2f000 - 0x13feeeff7 +de.computerworks.vectorworks.Fuellmustertest CW (D26.0.0 R1 505805+/11731+ - 1.0) <C655F573-9706-3BAC-93CE-F61E64F2EFA9> /Applications/Vectorworks 2021 SP3/*/Fuellmustertest CW
0x1401f0000 - 0x1403bdff7 +net.nemetschek.vectorworks.Fundamentals (1.0) <BA4CF6FB-868D-33FE-9117-E04E7C3B6E1F> /Applications/Vectorworks 2021 SP3/*/Fundamentals
0x1404bf000 - 0x14095cff3 +Gebaeude CW (D26.0.0 R1 505805+/11731+ - 1.0) <46D190D1-3DF4-38E8-B533-D451406F8671> /Applications/Vectorworks 2021 SP3/*/Gebaeude CW
0x140dbc000 - 0x1410e7fff +Gefaelle Ansicht CW (D26.0.0 R1 505805+/11731+ - 1.0) <5F8D717F-8FA4-3B97-BA05-E07F821FC518> /Applications/Vectorworks 2021 SP3/*/Gefaelle Ansicht CW
0x141441000 - 0x1417b6ffb +de.computerworks.vectorworks.Gefaelle Grundriss CW (26.0.3 - 1.0) <BFE912CF-FE68-3F73-9962-E2BE2942A46F> /Applications/Vectorworks 2021 SP3/*/Gefaelle Grundriss CW
0x141b5b000 - 0x141ed8ff7 +de.computerworks.vectorworks.Gelaendeschnitt anlegen CW (D26.0.0 R1 505805+/11731+ - 1.0) <5EBDC479-FD21-3FCB-A3BB-891F4CBA46BB> /Applications/Vectorworks 2021 SP3/*/Gelaendeschnitt anlegen CW
0x14229e000 - 0x1423d4ff3 +net.nemetschek.vectorworks.GeometryLib (1.0) <BB77D9A5-15FF-3795-BF72-B5CFB45F4CCB> /Applications/Vectorworks 2021 SP3/*/GeometryLib
0x14245e000 - 0x14277fff7 +Gesamtflaeche CW (D26.0.0 R1 505805+/11731+ - 1.0) <D8E65BDD-ACDC-3EAA-B26A-505DB589486E> /Applications/Vectorworks 2021 SP3/*/Gesamtflaeche CW
0x142ad6000 - 0x142df6fff +Gesamtumfang CW (D26.0.0 R1 505805+/11731+ - 1.0) <665019EF-C4D0-344F-B4D3-28BEC8117EE8> /Applications/Vectorworks 2021 SP3/*/Gesamtumfang CW
0x14314d000 - 0x1433acff7 +net.nemetschek.vectorworks.GIS (1.0) <F2EDFF8B-B033-3D13-A24D-25C586727B05> /Applications/Vectorworks 2021 SP3/*/GIS
0x1434d9000 - 0x144949ff7 +libgdal.27.dylib (0) <7AFBEF2A-5F4B-3249-800B-336155E7DC28> /Applications/Vectorworks 2021 SP3/*/libgdal.27.dylib
0x144f59000 - 0x145112ff7 +libxerces-c-3.2.dylib (0) <C2E80F85-9838-340C-873F-A346CC6A186D> /Applications/Vectorworks 2021 SP3/*/libxerces-c-3.2.dylib
0x14526b000 - 0x1452a2ffb +libopenjp2.7.dylib (0) <924BA0E8-2E7E-3E3C-81F1-68FF596414E4> /Applications/Vectorworks 2021 SP3/*/libopenjp2.7.dylib
0x1452ac000 - 0x1454e1ff3 +net.nemetschek.vectorworks.GridAxis (1.0) <138236C2-C968-38B7-89D6-4173A6F4E299> /Applications/Vectorworks 2021 SP3/*/GridAxis
0x14561c000 - 0x1458eaffb +de.computerworks.vectorworks.Grundflaechenzahl CW (D26.0.0 R1 505805+/11731+ - 1.0) <2108267F-DF2F-3373-AEC0-4C3689EF379C> /Applications/Vectorworks 2021 SP3/*/Grundflaechenzahl CW
0x145bff000 - 0x145c50fff +net.nemetschek.vectorworks.Guides (1.0) <29659711-B281-3B0E-9A51-C728A8E567A2> /Applications/Vectorworks 2021 SP3/*/Guides
0x145c7a000 - 0x145dcdfff +net.nemetschek.vectorworks.Heliodon (1.0) <95403F91-3643-379B-A18D-0264E7E9A7E2> /Applications/Vectorworks 2021 SP3/*/Heliodon
0x145e96000 - 0x145ef2fff +net.nemetschek.vectorworks.HelixSpiral (1.0) <B18FA991-E892-37DF-B74F-C1C0715C2E02> /Applications/Vectorworks 2021 SP3/*/HelixSpiral
0x145f25000 - 0x146200ffb +de.computerworks.vectorworks.Hilfslinien CW (D26.0.0 R1 505805+/11731+ - 1.0) <B24ABAC1-B8C2-39F5-8971-F2FD85E80AC3> /Applications/Vectorworks 2021 SP3/*/Hilfslinien CW
0x14652d000 - 0x146624ff3 +net.nemetschek.vectorworks.HSETUEnergyExport (1.0 - 1.0) <9C364BF9-87A8-30D8-B42E-73CF2A75D77E> /Applications/Vectorworks 2021 SP3/*/HSETUEnergyExport
0x146695000 - 0x146827ff7 +net.nemetschek.vectorworks.HumanFigure (1.0) <80BC64B5-8622-3173-A657-B14D54FD9379> /Applications/Vectorworks 2021 SP3/*/HumanFigure
0x1468d2000 - 0x146c3fff7 +Hyperlink CW (26.0.3 - 1.0) <A7C1656E-E94A-30A9-BB72-4013A8B54958> /Applications/Vectorworks 2021 SP3/*/Hyperlink CW
0x146fe3000 - 0x1478bfffb +net.nemetschek.vectorworks.IFCLibrary (1.0) <D1C87729-F6D9-367A-A686-98F17921D643> /Applications/Vectorworks 2021 SP3/*/IFCLibrary
0x147b4f000 - 0x147f71fff +de.computerworks.vectorworks.Import AufmassKoordinaten (D26.0.0 R1 505805+/11731+ - 1.0) <A810DF8C-6CBD-3C9A-B5F6-C5D3FC05813B> /Applications/Vectorworks 2021 SP3/*/Import AufmassKoordinaten
0x14840b000 - 0x1486d2ffb +Import Farbpalette CW (D26.0.0 R1 505805+/11731+ - 1.0) <49804B83-1F6C-3D39-9C32-A7CB23A91AAB> /Applications/Vectorworks 2021 SP3/*/Import Farbpalette CW
0x1489db000 - 0x148cd4ff7 +de.computerworks.vectorworks.Import mtextur CW (26.0.3 - 1.0) <2E12B822-1878-3828-88E7-F0A5BD5D14D4> /Applications/Vectorworks 2021 SP3/*/Import mtextur CW
0x148ffe000 - 0x149183fff +net.nemetschek.vectorworks.ImportBCF (1.0) <718EFD35-B33A-300E-B5E7-98ADD7F56970> /Applications/Vectorworks 2021 SP3/*/ImportBCF
0x14923c000 - 0x149511ff3 +de.computerworks.vectorworks.In Kanten umwandeln CW (D26.0.0 R1 505805+/11731+ - 1.0) <9BD69C1C-AC73-3805-9BCB-1C7DF7EB7779> /Applications/Vectorworks 2021 SP3/*/In Kanten umwandeln CW
0x149823000 - 0x149b07ff7 +de.computerworks.vectorworks.In Polylinie umwandeln CW (D26.0.0 R1 505805+/11731+ - 1.0) <CD25E534-FD8F-31ED-BAB8-D206EF0F0D5F> /Applications/Vectorworks 2021 SP3/*/In Polylinie umwandeln CW
0x149e2d000 - 0x14a136ffb +de.computerworks.vectorworks.In Wand umwandeln CW (D26.0.0 R1 505805+/11731+ - 1.0) <3ABA8892-71FE-3439-9DE1-9A062749EBDA> /Applications/Vectorworks 2021 SP3/*/In Wand umwandeln CW
0x14a46e000 - 0x14a7b6fff +Info CW (D26.0.0 R1 505805+/11731+ - 1.0) <0E7A5974-E662-31AE-B15C-FD4E1F53AB3B> /Applications/Vectorworks 2021 SP3/*/Info CW
0x14ab2b000 - 0x14aea0ffb +de.computerworks.vectorworks.Kantenausbildung CW (D26.0.0 R1 505805+/11731+ - 1.0) <590E5E61-DF91-339B-95B4-F078F86D6B70> /Applications/Vectorworks 2021 SP3/*/Kantenausbildung CW
0x14b234000 - 0x14b514ff7 +de.computerworks.vectorworks.Klotoiden CW (D26.0.0 R1 505805+/11731+ - 1.0) <A65E71A8-1CA0-3C3B-BDD4-2181361E39CE> /Applications/Vectorworks 2021 SP3/*/Klotoiden CW
0x14b834000 - 0x14bb24ffb +de.computerworks.vectorworks.Korbbogen CW (D26.0.0 R1 505805+/11731+ - 1.0) <2A74DD0E-BC77-3C59-B502-6F63442F3BBC> /Applications/Vectorworks 2021 SP3/*/Korbbogen CW
0x14be57000 - 0x14c25bff3 +de.computerworks.vectorworks.Kotenbemassung CW (D26.0.0 R1 505805+/11731+ - 1.0) <C06882EA-6705-3DD5-B4B2-A4F0F927E095> /Applications/Vectorworks 2021 SP3/*/Kotenbemassung CW
0x14c695000 - 0x14ce96ff3 +net.nemetschek.vectorworks.LandscapeModule (1.0) <742C4178-D2B2-349C-BE0A-D21875D121CC> /Applications/Vectorworks 2021 SP3/*/Landscape
0x14d1b6000 - 0x14d438ffb +net.nemetschek.vectorworks.LandscapeIrrigation (1.0) <622D82CE-D5AE-3E4F-922B-17515D4E3645> /Applications/Vectorworks 2021 SP3/*/LandscapeIrrigation
0x14d57e000 - 0x14d95dff7 +Legende CW (D26.0.0 R1 505805+/11731+ - 1.0) <A727223A-9848-3224-92BE-E47BF3E8ED82> /Applications/Vectorworks 2021 SP3/*/Legende CW
0x14dd77000 - 0x14e0d7ff7 +de.computerworks.vectorworks.Lichtschacht CW (D26.0.0 R1 505805+/11731+ - 1.0) <BF212EB8-BABF-32DA-BEF9-D9D4E9998E23> /Applications/Vectorworks 2021 SP3/*/Lichtschacht CW
0x14e466000 - 0x14e5d8ff7 +com.BenghiatLighting.LightingPipe (2.0.2 - 78) <F161E8A9-7ED7-35F4-9B61-C39024D6DB64> /Applications/Vectorworks 2021 SP3/*/LightingPipe
0x14e6a7000 - 0x14e966ffb +Linienartentest CW (D26.0.0 R1 505805+/11731+ - 1.0) <37266C71-CAD9-37A3-A6D4-BA3A08145FF5> /Applications/Vectorworks 2021 SP3/*/Linienartentest CW
0x14ec65000 - 0x14ef22ff7 +de.computerworks.vectorworks.Linienendz skalieren CW (D26.0.0 R1 505805+/11731+ - 1.0) <62B7536B-2A08-34E5-AEC6-D3037DAD0B74> /Applications/Vectorworks 2021 SP3/*/Linienendz skalieren CW
0x14f220000 - 0x14f401ff3 +net.nemetschek.vectorworks.Marionette (1.0) <B96E7CB5-54F1-3120-81E8-0A71BFCF48FA> /Applications/Vectorworks 2021 SP3/*/Marionette
0x14f4fa000 - 0x14f85aff7 +net.nemetschek.vectorworks.Markers (1.0) <EDF95F2D-2EF3-36AB-83A5-5774FEDD1DA2> /Applications/Vectorworks 2021 SP3/*/Markers
0x14fbf1000 - 0x14ffc6ff7 +de.computerworks.vectorworks.Massendokumentation CW (D26.0.0 R1 505805+/11731+ - 1.0) <D4A149D9-13BE-3257-97B6-6BB1A68FB920> /Applications/Vectorworks 2021 SP3/*/Massendokumentation CW
0x1503a0000 - 0x15070aff3 +Massstabsbalken CW (D26.0.0 R1 505805+/11731+ - 1.0) <25A2279C-8763-30F4-B2FE-3F49E88DE691> /Applications/Vectorworks 2021 SP3/*/Massstabsbalken CW
0x150a94000 - 0x150d54ffb +de.computerworks.vectorworks.Material zu Klassen CW (D26.0.0 R1 505805+/11731+ - 1.0) <6E1BB1FF-DA4E-3A97-9B59-E650B22A069B> /Applications/Vectorworks 2021 SP3/*/Material zu Klassen CW
0x151056000 - 0x151367ffb +Mittelachse CW (D26.0.0 R1 505805+/11731+ - 1.0) <40E01168-2DE6-3B17-8E57-55729F4811AE> /Applications/Vectorworks 2021 SP3/*/Mittelachse CW
0x1516aa000 - 0x1517e6ffb +net.nemetschek.vectorworks.MOSAImport (1.0) <31203588-9BB6-3B06-901A-A265C68ADEC5> /Applications/Vectorworks 2021 SP3/*/MOSAImport
0x151888000 - 0x15195bfff +net.nemetschek.vectorworks.MovePage (1.0) <44F7BB72-3206-3FB8-B4DA-887023B3156A> /Applications/Vectorworks 2021 SP3/*/MovePage
0x1519c6000 - 0x151e60ff7 +de.computerworks.vectorworks.Multistempel CW (D26.0.0 R1 505805+/11731+ - 1.0) <B21EB2F2-6A44-3AA4-980C-60683300C6A9> /Applications/Vectorworks 2021 SP3/*/Multistempel CW
0x152390000 - 0x1524e1ff7 +net.nemetschek.vectorworks.NBSChorus (1.0) <F7831404-2B32-3771-A9F3-690DA01D2644> /Applications/Vectorworks 2021 SP3/*/NBSChorus
0x15258c000 - 0x152803ff3 +net.nemetschek.vectorworks.NotesManager (1.0) <C19F948B-2024-33DB-B2D2-3987BA85FCF8> /Applications/Vectorworks 2021 SP3/*/NotesManager
0x152924000 - 0x152c1aff7 +de.computerworks.vectorworks.Nullpunkte CW (D26.0.0 R1 505805+/11731+ - 1.0) <72EF4F63-FF74-35F0-A78C-EFC219147953> /Applications/Vectorworks 2021 SP3/*/Nullpunkte CW
0x152f5a000 - 0x15321bff3 +de.computerworks.vectorworks.Objektinformationen CW (D26.0.0 R1 505805+/11731+ - 1.0) <E6A1E83E-F928-3A0B-8306-99AA52B73675> /Applications/Vectorworks 2021 SP3/*/Objektinformationen CW
0x15351c000 - 0x153683fff +net.nemetschek.vectorworks.TesterModule (1.0) <2109A406-FEB6-3639-A153-90E865999ED8> /Applications/Vectorworks 2021 SP3/*/OBJExporter
0x15373b000 - 0x153af7ff3 +libexiv2.26.0.0.dylib (0) <A0D2724E-5C06-34F8-A2CE-FC59EAA59046> /Applications/Vectorworks 2021 SP3/*/libexiv2.26.0.0.dylib
0x153c52000 - 0x153d42ff7 +net.nemetschek.vectorworks. (1.0) <F5205C48-1146-380F-BEEA-71811F46EE48> /Applications/Vectorworks 2021 SP3/*/Offset Tool
0x153db2000 - 0x153e05ff3 +net.nemetschek.vectorworks.TesterModule (1.0) <D5333E9D-F866-3CE0-8697-F8DC06BB522B> /Applications/Vectorworks 2021 SP3/*/OnlineResources
0x153e32000 - 0x153f15ff3 +net.nemetschek.vectorworks.PDFPage (1.0) <98881FEB-F37F-3093-8497-AB73088FF6E2> /Applications/Vectorworks 2021 SP3/*/PDFPage
0x153f8c000 - 0x1540b0ff7 +net.nemetschek.vectorworks.PDFUtilityLib (1.0) <8AD6BACC-93AA-35CB-AFC9-2B676B3CEF44> /Applications/Vectorworks 2021 SP3/*/PDFUtilityLib
0x15412a000 - 0x154729fff +DL150AGM (150.4.5) <B7691260-B02D-3622-A950-30C5FD27DAB0> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150AGM.framework/Versions/A/DL150AGM
0x1549a0000 - 0x154ef1ff7 +com.datalogics.DL150CoolType (DL150CoolType 15.0.4.4 - 15.0.4.4) <519B6A8C-8F9D-3AB4-9131-1DDD1BD70417> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150CoolType.framework/Versions/A/DL150CoolType
0x1550e7000 - 0x155e2cfff +com.adobe.ICUData (4.0 - 4.0) <A60A8D26-47CF-3168-9AD1-B73BF8C00BCA> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x155e5d000 - 0x155e81ff7 +DL150BIBUtils (150.4) <55D27617-ECB8-3752-856B-9C1A30D6D973> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150BIBUtils.framework/Versions/A/DL150BIBUtils
0x155e9f000 - 0x155ebffff +DL150BIB (150.4.2) <FF98B725-5100-3A13-8C0C-9BA684408B93> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150BIB.framework/Versions/A/DL150BIB
0x155eda000 - 0x155fe3fff +DL150PDFPort (0) <D66B8CA9-8EDE-3CC8-8870-9259043A9F28> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150PDFPort.framework/Versions/A/DL150PDFPort
0x156037000 - 0x156179ff7 +com.datalogics.DL150ACE (DL150ACE 15.0.4.3 - 15.0.4.3) <1C8E3EB4-BA18-3D46-8778-BF8341E532DA> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150ACE.framework/Versions/A/DL150ACE
0x1561c5000 - 0x15627fff7 +com.adobe.ICUConverter (4.0 - 4.0) <4C37F627-6A96-3301-8889-28CCD7FF3DB6> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x1562ae000 - 0x1562e8ff7 +DL150ARE (150.4) <A740923E-D319-3FA7-BA78-24470FE5990F> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150ARE.framework/Versions/A/DL150ARE
0x15630e000 - 0x15632aff7 +DL150PDFSettings (1) <0527B161-E666-3BE4-87D6-288F708324E3> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150PDFSettings.framework/Versions/A/DL150PDFSettings
0x156343000 - 0x15639ffff +DL150AdobeXMP (150.4.1) <7BB747E6-0806-39E5-83EE-929A7CC0CB58> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150AdobeXMP.framework/Versions/A/DL150AdobeXMP
0x1563c3000 - 0x1563e3ff7 +DL150AXE8SharedExpat (150.4) <80786033-A108-35B8-8E5A-9BE5B3073984> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150AXE8SharedExpat.framework/Versions/A/DL150AXE8SharedExpat
0x1563f6000 - 0x156487ff7 +DL150JP2KLib (150.4.1) <2D461F81-8570-3C85-8E09-0C4DF584678B> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150JP2KLib.framework/Versions/A/DL150JP2KLib
0x1564a6000 - 0x156c09fff +com.datalogics.DL150PDFL (DL150PDFL 15.0.4.9 - 15.0.4.9) <27AF6E78-DCCD-3973-BE38-F4F002B8D176> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150PDFL.framework/Versions/A/DL150PDFL
0x156ebf000 - 0x157352ffb +Pflanze CW (26.0.3 - 1.0) <140B1893-B14E-342A-9FA7-22EFACCF1E1B> /Applications/Vectorworks 2021 SP3/*/Pflanze CW
0x1577f1000 - 0x157b50ffb +de.computerworks.vectorworks.Pflanze VBvisual CW (26.0.3 - 1.0) <CFCD7A60-6E89-3C63-948E-6B01A376D17E> /Applications/Vectorworks 2021 SP3/*/Pflanze VBvisual CW
0x157ed6000 - 0x157f27ffb +net.nemetschek.vectorworks. (1.0) <D47702E3-9E29-3E63-B119-7473A5FBD794> /Applications/Vectorworks 2021 SP3/*/Plug-In Support
0x157f52000 - 0x1591a9ff3 +net.nemetschek.vectorworks.PointCloud (1.0) <8F510CB1-65EA-37C2-8DE0-017294C3666E> /Applications/Vectorworks 2021 SP3/*/PointCloud
0x159cfe000 - 0x159d09ff7 +libboost_iostreams.dylib (0) <016DD517-E69F-3E7B-9018-FEEE409DBAA8> /Applications/Vectorworks 2021 SP3/*/libboost_iostreams.dylib
0x159d1d000 - 0x159d2bff7 +libboost_filesystem.dylib (0) <C0B2798E-A574-34AD-A26B-DAC75A957FE4> /Applications/Vectorworks 2021 SP3/*/libboost_filesystem.dylib
0x159d3b000 - 0x159d3ffff +libboost_date_time.dylib (0) <5D7561CA-432F-30FF-AC5B-5E5DC954E61C> /Applications/Vectorworks 2021 SP3/*/libboost_date_time.dylib
0x159d4d000 - 0x159d4effb +libboost_chrono.dylib (0) <8375BBCB-192F-30D8-B9D2-8EB41923457A> /Applications/Vectorworks 2021 SP3/*/libboost_chrono.dylib
0x159d56000 - 0x159d79ff7 +libboost_serialization.dylib (0) <D85DDBA8-89F3-3BB6-9F84-C7CCB59C4799> /Applications/Vectorworks 2021 SP3/*/libboost_serialization.dylib
0x159db5000 - 0x159db7fff +libboost_system.dylib (0) <E4B85D84-F1BC-37E1-BB95-E9648104446E> /Applications/Vectorworks 2021 SP3/*/libboost_system.dylib
0x159dbf000 - 0x159e94ff3 +net.nemetschek.vectorworks.TesterModule (1.0) <DC15B462-3CA3-30A9-9A8F-2385254C0823> /Applications/Vectorworks 2021 SP3/*/PointTools
0x159efe000 - 0x15a1e1fff +de.computerworks.vectorworks.Polygon oeffnen CW (D26.0.0 R1 505805+/11731+ - 1.0) <347B68EE-6E31-33A2-AE6C-E3A8123F1B6F> /Applications/Vectorworks 2021 SP3/*/Polygon oeffnen CW
0x15a4fc000 - 0x15a7bcff7 +de.computerworks.vectorworks.Polygone triangulieren CW (D26.0.0 R1 505805+/11731+ - 1.0) <1FDAA354-F271-3269-B274-D8DF9DC35F1B> /Applications/Vectorworks 2021 SP3/*/Polygone triangulieren CW
0x15aab8000 - 0x15ad79ff7 +de.computerworks.vectorworks.Polypunkte reduzieren CW (D26.0.0 R1 505805+/11731+ - 1.0) <6E577278-1439-3A64-8279-F59208C8ABD8> /Applications/Vectorworks 2021 SP3/*/Polypunkte reduzieren CW
0x15b07c000 - 0x15b345ff3 +de.computerworks.vectorworks.Polypunkte umnummerieren CW (D26.0.0 R1 505805+/11731+ - 1.0) <737BAA12-FDB5-3AEF-9B9F-8463C5745CD9> /Applications/Vectorworks 2021 SP3/*/Polypunkte umnummerieren CW
0x15b656000 - 0x15b72dfff +net.nemetschek.vectorworks. (1.0) <CA2CCAF6-A475-3F15-BB61-5B7AEFA0BFA8> /Applications/Vectorworks 2021 SP3/*/Protractor Tool
0x15b798000 - 0x15bb73ff7 +de.computerworks.vectorworks.Railing CW (26.0.3 - 1.0) <722C8C02-6BCD-3660-B800-4D39CB626D59> /Applications/Vectorworks 2021 SP3/*/Railing CW
0x15bf49000 - 0x15c344ffb +de.computerworks.vectorworks.Rampe CW (D26.0.0 R1 505805+/11731+ - 1.0) <C7046A1E-EF0B-334B-86C3-9973B5BC4356> /Applications/Vectorworks 2021 SP3/*/Rampe CW
0x15c6da000 - 0x15ca5dffb +de.computerworks.vectorworks.Raster CW (D26.0.0 R1 505805+/11731+ - 1.0) <B765D46B-354B-3B81-8177-729C98065E62> /Applications/Vectorworks 2021 SP3/*/Raster CW
0x15ce19000 - 0x15d0dffff +de.computerworks.vectorworks.Rasterbild einpassen CW (D26.0.0 R1 505805+/11731+ - 1.0) <9C091D29-DA79-3E02-AF21-E92A9BABEBA1> /Applications/Vectorworks 2021 SP3/*/Rasterbild einpassen CW
0x15d3e7000 - 0x15d9b2ff3 +Raum CW (26.0.3 - 1.0) <D9FE4FB7-6584-3A0A-976F-3D75887FB7B3> /Applications/Vectorworks 2021 SP3/*/Raum CW
0x15df38000 - 0x15e2d3ffb +de.computerworks.vectorworks.Rechtwinkelbemassung CW (D26.0.0 R1 505805+/11731+ - 1.0) <0731E812-0C62-3004-9CF9-FC36899077B2> /Applications/Vectorworks 2021 SP3/*/Rechtwinkelbemassung CW
0x15e690000 - 0x15e6f2ff3 +net.nemetschek.vectorworks.RenderSettings (1.0) <E84CF0D7-D77D-36E5-BB04-9BEBA8174C88> /Applications/Vectorworks 2021 SP3/*/RenderSettings
0x15e725000 - 0x15e980fff +net.nemetschek.vectorworks.Renderworks (1.0) <9994C4A7-5125-3070-8AF5-2D3E9877EE4F> /Applications/Vectorworks 2021 SP3/*/Renderworks
0x15eb5e000 - 0x15eccdffb +net.nemetschek.vectorworks.RenderworksCamera (1.0) <B9D2C4C2-E1F5-36ED-B062-3AB7D7625866> /Applications/Vectorworks 2021 SP3/*/RenderworksCamera
0x15eda7000 - 0x15ee7cff3 +net.nemetschek.vectorworks.Resize (1.0) <B9EECA63-D377-3D42-BAD3-5A2556C685A3> /Applications/Vectorworks 2021 SP3/*/Resize
0x15eee6000 - 0x15f0d9ffb +net.nemetschek.vectorworks. (1.0) <2BBA3FD0-CF62-3E18-A68B-2E567CABCE65> /Applications/Vectorworks 2021 SP3/*/RevitLibrary
0x15f207000 - 0x15fdd1ffb +TB_Format2021Writers.tx (0) <4876E2CB-2276-391E-836F-1D87A419F782> /Applications/Vectorworks 2021 SP3/*/TB_Format2021Writers.tx
0x16102d000 - 0x1617b9ffb +TB_Format2021Readers.tx (0) <93F4159C-002F-31A1-B55A-A50C1F0F7B76> /Applications/Vectorworks 2021 SP3/*/TB_Format2021Readers.tx
0x1622e8000 - 0x1622f9fff +TD_AssetXMLParser.tx (0) <9332A84F-6434-326E-8923-758E14A007C0> /Applications/Vectorworks 2021 SP3/*/TD_AssetXMLParser.tx
0x162304000 - 0x1628d6fff +TB_Format2021Classes.tx (0) <85D98CCB-B175-3BC4-98FD-ABF5894424F6> /Applications/Vectorworks 2021 SP3/*/TB_Format2021Classes.tx
0x162987000 - 0x162a58fff +TB_Rebar.tx (0) <0CE36F66-EB5A-319C-A560-053A8F798F4C> /Applications/Vectorworks 2021 SP3/*/TB_Rebar.tx
0x162b42000 - 0x162cd0ff7 +liblibcrypto.dylib (0) <22D10CA5-13E4-3E8B-A27A-94F3974A260A> /Applications/Vectorworks 2021 SP3/*/liblibcrypto.dylib
0x162d61000 - 0x162f38ff3 +libOdBrepModeler.dylib (0) <152AD784-3A2B-3204-845D-43C0200F6261> /Applications/Vectorworks 2021 SP3/*/libOdBrepModeler.dylib
0x162fbe000 - 0x162fcbffb +liboless.dylib (0) <0DDC94B8-6E02-309E-9CBF-465D64177730> /Applications/Vectorworks 2021 SP3/*/liboless.dylib
0x162fd1000 - 0x162ff1ff7 +libtbb.dylib (0) <496B712E-1478-373F-85E0-3B6544822F43> /Applications/Vectorworks 2021 SP3/*/libtbb.dylib
0x163006000 - 0x16301bff7 +libTD_Br.dylib (0) <684F19CC-0B6D-3D03-90C0-B7A06B5932D9> /Applications/Vectorworks 2021 SP3/*/libTD_Br.dylib
0x163033000 - 0x16304bffb +libTD_BrepBuilder.dylib (0) <E2B94A35-6EEB-3DCE-AEA9-9514F4518C01> /Applications/Vectorworks 2021 SP3/*/libTD_BrepBuilder.dylib
0x163057000 - 0x163072ffb +libTD_BrepBuilderFiller.dylib (0) <1DED7398-A818-3CFF-B930-4518DE4D7177> /Applications/Vectorworks 2021 SP3/*/libTD_BrepBuilderFiller.dylib
0x163082000 - 0x163118ffb +libTD_BrepRenderer.dylib (0) <B3482DEF-0FDD-39F8-AE44-7F865915A677> /Applications/Vectorworks 2021 SP3/*/libTD_BrepRenderer.dylib
0x16314a000 - 0x163200ffb +libTD_DbRoot.dylib (0) <21F9A2F1-89EB-339B-9087-AB3FB850D4B7> /Applications/Vectorworks 2021 SP3/*/libTD_DbRoot.dylib
0x1632ad000 - 0x16362cfff +libTD_Ge.dylib (0) <B231FC2F-5ED1-39FB-A150-47AF388A1C66> /Applications/Vectorworks 2021 SP3/*/libTD_Ge.dylib
0x163780000 - 0x1639affff +libTD_Gi.dylib (0) <53554070-AE6A-3317-A7EE-19E919AECE45> /Applications/Vectorworks 2021 SP3/*/libTD_Gi.dylib
0x163b2d000 - 0x163c3efff +libTD_Gs.dylib (0) <78426146-C86F-3DDE-BD18-9209FAF1101B> /Applications/Vectorworks 2021 SP3/*/libTD_Gs.dylib
0x163d24000 - 0x163de8ff3 +libTD_Root.dylib (0) <C394F4D1-182F-3294-A245-C8EDE5536EF6> /Applications/Vectorworks 2021 SP3/*/libTD_Root.dylib
0x163ea2000 - 0x163eaaff3 +libTD_SpatialIndex.dylib (0) <8A6EB75D-4398-3AB3-B232-57D1203ED1F5> /Applications/Vectorworks 2021 SP3/*/libTD_SpatialIndex.dylib
0x163eb1000 - 0x163ec6ff3 +libTD_Zlib.dylib (0) <6039F057-C7E5-38F7-939B-A3F76390AC44> /Applications/Vectorworks 2021 SP3/*/libTD_Zlib.dylib
0x163eca000 - 0x163f70fff +TB_Analytical.tx (0) <59D16622-58F9-37CE-9AD2-5FCB0670DDA4> /Applications/Vectorworks 2021 SP3/*/TB_Analytical.tx
0x164036000 - 0x16407dffb +TB_Architecture.tx (0) <64E9054C-E4C3-3EF2-86B0-3F40C0878A6A> /Applications/Vectorworks 2021 SP3/*/TB_Architecture.tx
0x1640d6000 - 0x164238ffb +TB_Base.tx (0) <C7FD9D0F-1DA9-35DA-8F22-0AC36538B082> /Applications/Vectorworks 2021 SP3/*/TB_Base.tx
0x164257000 - 0x164374ffb +TB_Common.tx (0) <D0419499-3FF4-3EEF-86CF-447523341509> /Applications/Vectorworks 2021 SP3/*/TB_Common.tx
0x16437f000 - 0x164bfefff +TB_Database.tx (0) <90E812F6-C537-3D41-B647-64AFE9B854A6> /Applications/Vectorworks 2021 SP3/*/TB_Database.tx
0x165513000 - 0x16552bfff +TB_ExLabelUtils.tx (0) <609E5B9D-6435-30EF-B993-947D2FC6F018> /Applications/Vectorworks 2021 SP3/*/TB_ExLabelUtils.tx
0x165539000 - 0x16561aff3 +TB_Family.tx (0) <51E446DE-D409-3F66-B628-F59E0F42C8B2> /Applications/Vectorworks 2021 SP3/*/TB_Family.tx
0x1656d5000 - 0x165b2bfff +TB_Format2011Classes.tx (0) <76B61ABD-88DD-3E84-AA51-A3A6B6F7A7DD> /Applications/Vectorworks 2021 SP3/*/TB_Format2011Classes.tx
0x165bab000 - 0x166142ff7 +TB_Format2011Readers.tx (0) <00A7E0C6-EAA2-3370-95FF-FD8EDD7AB6E1> /Applications/Vectorworks 2021 SP3/*/TB_Format2011Readers.tx
0x1668b9000 - 0x166d5fff7 +TB_Format2012Classes.tx (0) <E3F1355F-850A-3D0E-B59D-BEF73EEDF327> /Applications/Vectorworks 2021 SP3/*/TB_Format2012Classes.tx
0x166de9000 - 0x1673ebff7 +TB_Format2012Readers.tx (0) <3697F8FC-B7E7-36C7-B623-A0C504B63D0C> /Applications/Vectorworks 2021 SP3/*/TB_Format2012Readers.tx
0x167c2a000 - 0x168167fff +TB_Format2013Classes.tx (0) <98DC8351-04B3-351A-BCA8-EB5659CEE20D> /Applications/Vectorworks 2021 SP3/*/TB_Format2013Classes.tx
0x168200000 - 0x1688adff7 +TB_Format2013Readers.tx (0) <1FD9DB66-67D6-3211-BDC4-74F7B600F334> /Applications/Vectorworks 2021 SP3/*/TB_Format2013Readers.tx
0x1691de000 - 0x169722ff7 +TB_Format2014Classes.tx (0) <CA3F97C2-87BE-319D-A8F4-2B3FFC73E513> /Applications/Vectorworks 2021 SP3/*/TB_Format2014Classes.tx
0x1697bf000 - 0x169e98ff7 +TB_Format2014Readers.tx (0) <6F64E5FD-D6EC-3AA8-BA13-B8AE5DB5E576> /Applications/Vectorworks 2021 SP3/*/TB_Format2014Readers.tx
0x16a828000 - 0x16ad7dffb +TB_Format2015Classes.tx (0) <29D1A6CB-192B-3EF3-BFC3-7111902585FA> /Applications/Vectorworks 2021 SP3/*/TB_Format2015Classes.tx
0x16ae1f000 - 0x16b51cff7 +TB_Format2015Readers.tx (0) <7826204F-F4E3-31E5-B532-08DAF0183CD0> /Applications/Vectorworks 2021 SP3/*/TB_Format2015Readers.tx
0x16bf07000 - 0x16c472ffb +TB_Format2016Classes.tx (0) <1705F735-FA49-36D5-B65B-F96E82CD7A12> /Applications/Vectorworks 2021 SP3/*/TB_Format2016Classes.tx
0x16c518000 - 0x16cc3dfff +TB_Format2016Readers.tx (0) <42C7E2E7-D044-3616-9133-7C00A3724EBD> /Applications/Vectorworks 2021 SP3/*/TB_Format2016Readers.tx
0x16d674000 - 0x16dbf4ff7 +TB_Format2017Classes.tx (0) <A396C28F-3C87-3F9B-8821-3D3AB941DF44> /Applications/Vectorworks 2021 SP3/*/TB_Format2017Classes.tx
0x16dc9c000 - 0x16e3e4ff7 +TB_Format2017Readers.tx (0) <30844BB6-5009-3ED7-9C38-B8D807AB2F6F> /Applications/Vectorworks 2021 SP3/*/TB_Format2017Readers.tx
0x16ee62000 - 0x16f401ff7 +TB_Format2018Classes.tx (0) <C03F006A-03AB-34FA-9A73-86C68154BF39> /Applications/Vectorworks 2021 SP3/*/TB_Format2018Classes.tx
0x16f4ae000 - 0x16fc1bfff +TB_Format2018Readers.tx (0) <D7420221-AC51-3D25-A333-EFB675D56681> /Applications/Vectorworks 2021 SP3/*/TB_Format2018Readers.tx
0x1706dd000 - 0x170c8eff7 +TB_Format2019Classes.tx (0) <92625D4F-9D9D-323D-A73A-583860AEF6F9> /Applications/Vectorworks 2021 SP3/*/TB_Format2019Classes.tx
0x170d3c000 - 0x1714c1ff7 +TB_Format2019Readers.tx (0) <BD634FDF-25F0-378D-9E86-3D3C89B60E2E> /Applications/Vectorworks 2021 SP3/*/TB_Format2019Readers.tx
0x171fac000 - 0x172570ffb +TB_Format2020Classes.tx (0) <6927841B-22CE-3715-8C2F-27F8DC9AF8EA> /Applications/Vectorworks 2021 SP3/*/TB_Format2020Classes.tx
0x172620000 - 0x172d9affb +TB_Format2020Readers.tx (0) <5DC0A3D0-D94E-3DA3-9CD1-5BFA7FC98A6A> /Applications/Vectorworks 2021 SP3/*/TB_Format2020Readers.tx
0x1738a9000 - 0x173cdaffb +TB_FormatCommonClasses.tx (0) <B1023620-E224-33A4-9944-A59842C86A76> /Applications/Vectorworks 2021 SP3/*/TB_FormatCommonClasses.tx
0x173d2d000 - 0x17432dff7 +TB_FormatCommonReaders.tx (0) <BD79E17A-FC2B-3D42-ADCD-CA0041E3DF27> /Applications/Vectorworks 2021 SP3/*/TB_FormatCommonReaders.tx
0x174cd4000 - 0x174e37fff +TB_Geometry.tx (0) <BEDDF527-FBE0-3D65-90FE-693F495DD6C5> /Applications/Vectorworks 2021 SP3/*/TB_Geometry.tx
0x174f71000 - 0x174fc6ff7 +TB_GeometryUtils.tx (0) <8B1C6BB1-97C7-30E6-8ED3-E39F21EAF45E> /Applications/Vectorworks 2021 SP3/*/TB_GeometryUtils.tx
0x175004000 - 0x175105ff3 +TB_HostObj.tx (0) <92743FED-A5A4-372C-BBE3-A1791639336A> /Applications/Vectorworks 2021 SP3/*/TB_HostObj.tx
0x175226000 - 0x1753c9ff3 +TB_Loader.tx (0) <1AC21A46-1249-36D7-A810-278BC1CB472A> /Applications/Vectorworks 2021 SP3/*/TB_Loader.tx
0x175448000 - 0x175491fff +TB_LoaderBase.tx (0) <A3ADA6B3-F35B-358B-8F42-B99E932BC142> /Applications/Vectorworks 2021 SP3/*/TB_LoaderBase.tx
0x1754cf000 - 0x175b4afff +TB_Main.tx (0) <DF6E8976-268C-30CD-A6EE-9CCE6186E27B> /Applications/Vectorworks 2021 SP3/*/TB_Main.tx
0x17645a000 - 0x176619ff7 +TB_MEP.tx (0) <5F2DD573-EB25-3F73-B77E-49A61C406C72> /Applications/Vectorworks 2021 SP3/*/TB_MEP.tx
0x17684d000 - 0x176872fff +TB_ModelerGeometry.tx (0) <6FF765DB-4CAA-3F0F-ADE0-CE5C29F2D6BE> /Applications/Vectorworks 2021 SP3/*/TB_ModelerGeometry.tx
0x176898000 - 0x176b03ff3 +TB_StairsRamp.tx (0) <F5A14A5A-69AB-37E1-BAFE-CA32BEC088E8> /Applications/Vectorworks 2021 SP3/*/TB_StairsRamp.tx
0x176dfa000 - 0x176e06ffb +TD_TfCore.tx (0) <3679588A-5D14-3258-806E-3BAFB431B916> /Applications/Vectorworks 2021 SP3/*/TD_TfCore.tx
0x176e16000 - 0x176e23fff +ThreadPool.tx (0) <F991E5C4-493F-392B-B23A-1EDC7B8EF686> /Applications/Vectorworks 2021 SP3/*/ThreadPool.tx
0x176e31000 - 0x177117ffb +de.computerworks.vectorworks.Rohrkoerper anlegen CW (D26.0.0 R1 505805+/11731+ - 1.0) <3F78F83F-C1CD-30D3-9149-B19269209923> /Applications/Vectorworks 2021 SP3/*/Rohrkoerper anlegen CW
0x177454000 - 0x1774baffb +net.nemetschek.vectorworks.Roofer (1.0) <8E9BD03E-D32D-3980-B80D-7E299B584922> /Applications/Vectorworks 2021 SP3/*/Roofer
0x1774e9000 - 0x17764dff7 +net.nemetschek.vectorworks.RoofFramer (1.0) <30FD2A7B-0BFF-3901-A9F5-EF92992C4FB8> /Applications/Vectorworks 2021 SP3/*/RoofFramer
0x177700000 - 0x177a86ffb +Schlitze Durchbr CW (D26.0.0 R1 505805+/11731+ - 1.0) <30BDB44D-2DCD-3C3B-B38E-87E279241F81> /Applications/Vectorworks 2021 SP3/*/Schlitze Durchbr CW
0x177e30000 - 0x178025ff3 +net.nemetschek.vectorworks.SeatingSection (1.0) <7AD53845-0236-34EF-A81A-CBB91CC492DF> /Applications/Vectorworks 2021 SP3/*/SeatingSection
0x178138000 - 0x17821aff7 +net.nemetschek.vectorworks.SectionLine (1.0) <FFBA7B79-F9DD-39F2-853B-96EBC32D23F0> /Applications/Vectorworks 2021 SP3/*/SectionLine
0x178294000 - 0x1783e1fff +net.nemetschek.vectorworks. (1.0) <F3CA5337-D8B9-35B9-A576-9EDE01093D61> /Applications/Vectorworks 2021 SP3/*/Select Similar
0x1784c2000 - 0x178596fff +net.nemetschek.vectorworks.Shear (1.0) <C4570DE7-A868-34FA-8A42-2EA4A2967A8F> /Applications/Vectorworks 2021 SP3/*/Shear
0x178600000 - 0x17874cfff +net.nemetschek.vectorworks.SimpleElevator (1.0) <FAC0C405-3CC9-37F4-AE14-08C026AE54C8> /Applications/Vectorworks 2021 SP3/*/SimpleElevator
0x178817000 - 0x17898bff7 +net.nemetschek.vectorworks.SketchUp (1.0) <BF785FFC-1AB5-3661-9F98-A0708688C3F1> /Applications/Vectorworks 2021 SP3/*/SketchUp
0x178a63000 - 0x178c52fff +com.sketchup.slapi (0.0.1 - 0.0.1d1) <BD26182E-E49E-3AC0-8302-40927CADF4FA> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/SketchUpAPI
0x178ddd000 - 0x178df7ff7 +libCommonPreferences.dylib (0) <733D0E43-0BB6-3240-9B3A-535A61942A2D> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonPreferences.dylib
0x178e0a000 - 0x178e0eff3 +libCommonUnits.dylib (0) <96A96E7A-9615-3515-A6C6-DBEB87153B9D> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonUnits.dylib
0x178e14000 - 0x178e46ff7 +libCommonGeometry.dylib (0) <BD59836C-BECE-3E53-A49D-713C9ADCD716> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonGeometry.dylib
0x178e6a000 - 0x178e6cff7 +libCommonGeoutils.dylib (0) <E20D31FD-2ECC-3DD5-A440-A39F45E14387> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonGeoutils.dylib
0x178e70000 - 0x179120ff7 +libCommonImage.dylib (0) <B949B981-CA51-3FC9-B467-3F3F2B81BD56> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonImage.dylib
0x1791ba000 - 0x1791ddff7 +libCommonUtils.dylib (0) <EA16F159-32D9-30A2-85B1-9045EB56E683> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonUtils.dylib
0x179202000 - 0x17921affb +libCommonZip.dylib (0) <4BBD43A5-B164-3D56-BFCC-221A95492F95> /Applications/Vectorworks 2021 SP3/*/SketchUpAPI.framework/Versions/A/Libraries/libCommonZip.dylib
0x179223000 - 0x1795cbff7 +net.nemetschek.vectorworks.SpotlightModule (1.0) <AB8D1D68-84D7-38CF-9668-E07687F026B2> /Applications/Vectorworks 2021 SP3/*/Spotlight
0x179775000 - 0x1798baff7 +net.nemetschek.vectorworks.SpotlightVision (1.0) <7E82304C-3456-3503-ABCD-DC7C095F02E8> /Applications/Vectorworks 2021 SP3/*/SpotlightVision
0x179962000 - 0x179e90fff +org.qt-project.QtCore (5.12 - 5.12.3) <A5C2F78A-18AB-3684-BD15-0632EFCBA939> /Applications/Vectorworks 2021 SP3/*/QtCore.framework/Versions/5/QtCore
0x179f4b000 - 0x179f7cfff +org.qt-project.QtXml (5.12 - 5.12.3) <BF8403B1-DB41-3C12-9E41-BF3B9BDF07AF> /Applications/Vectorworks 2021 SP3/*/QtXml.framework/Versions/5/QtXml
0x179f8d000 - 0x179fcefff +libsVisionPlugin.dylib (0) <53D5C7B7-A072-3009-BD8F-3CC6684F4D19> /Applications/Vectorworks 2021 SP3/*/libsVisionPlugin.dylib
0x179fed000 - 0x17a021ff3 +org.qt-project.QtOpenGL (5.12 - 5.12.3) <E5946179-8F8F-3B2E-9AE5-C9A30294D6BE> /Applications/Vectorworks 2021 SP3/*/QtOpenGL.framework/Versions/5/QtOpenGL
0x17a042000 - 0x17a480ffb +org.qt-project.QtWidgets (5.12 - 5.12.3) <4B88FD5A-BF6D-3102-B095-32D1162AA630> /Applications/Vectorworks 2021 SP3/*/QtWidgets.framework/Versions/5/QtWidgets
0x17a5e3000 - 0x17aa27fef +org.qt-project.QtGui (5.12 - 5.12.3) <0A0AE636-A8A3-3E17-B8F3-9C5D8EB21029> /Applications/Vectorworks 2021 SP3/*/QtGui.framework/Versions/5/QtGui
0x17ab2a000 - 0x17ac8ffff +libqcocoa.dylib (0) <A20B7E1A-FCA9-36DD-BE7A-1D36A920C878> /Applications/Vectorworks 2021 SP3/*/libqcocoa.dylib
0x17acdb000 - 0x17ad39fff +org.qt-project.QtDBus (5.12 - 5.12.3) <1794BF10-F5CF-3430-8628-70D3B1538A64> /Applications/Vectorworks 2021 SP3/*/QtDBus.framework/Versions/5/QtDBus
0x17ad52000 - 0x17ad7bff7 +org.qt-project.QtPrintSupport (5.12 - 5.12.3) <164F26B8-1B82-3DDF-B5E7-43FA02F95BF6> /Applications/Vectorworks 2021 SP3/*/QtPrintSupport.framework/Versions/5/QtPrintSupport
0x17add4000 - 0x17afa1ff7 +net.nemetschek.vectorworks.TesterModule (1.0) <D17877FD-9F2F-3D95-A8DA-9F682862391E> /Applications/Vectorworks 2021 SP3/*/StructuralMember
0x17b084000 - 0x17b1c4ff3 +net.nemetschek.vectorworks.StructuralProfile (1.0) <5D42D6E9-FD33-3BBE-84B6-A620C3812EA7> /Applications/Vectorworks 2021 SP3/*/StructuralProfile
0x17b280000 - 0x17b2e1ff3 +net.nemetschek.vectorworks.SunPosition (1.0) <F3BEFF80-18A7-3660-B22C-99B0C2ED88F7> /Applications/Vectorworks 2021 SP3/*/SunPosition
0x17b310000 - 0x17b8d0ff3 +net.nemetschek.vectorworks.Support (1.0) <022A442A-7271-3CA2-9A57-A9C22213EA54> /Applications/Vectorworks 2021 SP3/*/Support
0x17bb2e000 - 0x17bb64ff7 libiodbc.2.dylib (42.6) <3D64D3A4-171D-3649-B3BC-6B8EF0174C8B> /usr/lib/libiodbc.2.dylib
0x17bb77000 - 0x17bcbeff3 +net.nemetschek.vectorworks. (1.0) <4FF3A080-3BC5-34E6-9457-99268954BFD6> /Applications/Vectorworks 2021 SP3/*/Surface Array
0x17bd76000 - 0x17be4aff3 +net.nemetschek.vectorworks.TapeMeasureTool (1.0) <AF3E12E4-2881-3A40-A719-FE4B82FEBCDA> /Applications/Vectorworks 2021 SP3/*/TapeMeasureTool
0x17beb5000 - 0x17bf31ff3 +net.nemetschek.vectorworks.TaperedExtrude (1.0) <E7385AA5-3CFF-3025-9A86-E47024CB1BE7> /Applications/Vectorworks 2021 SP3/*/TaperedExtrude
0x17bf6c000 - 0x17c25cfff +de.computerworks.vectorworks.Teilwinkel CW (D26.0.0 R1 505805+/11731+ - 1.0) <E22402A9-810F-3042-BB50-85C7DE98722B> /Applications/Vectorworks 2021 SP3/*/Teilwinkel CW
0x17c585000 - 0x17c888fff +de.computerworks.vectorworks.Text suchen und aendern CW (D26.0.0 R1 505805+/11731+ - 1.0) <875FB89D-FBC9-380A-8390-9EC89544B005> /Applications/Vectorworks 2021 SP3/*/Text suchen und aendern CW
0x17cbe5000 - 0x17cc5bffb +net.nemetschek.vectorworks.TextAlongPath (1.0) <3863352E-598E-3A6F-85C4-3E447659E20F> /Applications/Vectorworks 2021 SP3/*/TextAlongPath
0x17cc95000 - 0x17ccfaff3 +net.nemetschek.vectorworks. (1.0) <8C126937-ABDD-3AA7-B34B-F26C8A25266F> /Applications/Vectorworks 2021 SP3/*/Textured Prop
0x17cd2f000 - 0x17d029ff3 +net.nemetschek.vectorworks.TitleBlockBorder (1.0) <D84D3FBE-BE53-3DF4-892C-1F2D2B46A1DE> /Applications/Vectorworks 2021 SP3/*/TitleBlockBorder
0x17d15d000 - 0x17d796ff3 +de.computerworks.vectorworks.Treppen (26.0.3 - 1.0) <9753DE74-B68F-3305-9110-D3444524F638> /Applications/Vectorworks 2021 SP3/*/Treppen
0x17ddfa000 - 0x17decefff +net.nemetschek.vectorworks. (1.0) <53DAC7C8-EBA0-3136-9AD9-65C6A30A99CE> /Applications/Vectorworks 2021 SP3/*/Trim Tool
0x17df38000 - 0x17df96fff +net.nemetschek.vectorworks. (1.0) <8439E865-EE52-3561-89B5-1D5CAC39A2A2> /Applications/Vectorworks 2021 SP3/*/TrueType To Polyline
0x17dfc4000 - 0x17e094ff3 +net.nemetschek.vectorworks.TrueType (1.0) <E8F9BA4B-AAB9-353D-8D10-C274F38437BB> /Applications/Vectorworks 2021 SP3/*/TrueType
0x17e0f8000 - 0x17e912ff3 +de.computerworks.vectorworks.Tueren CW (D26.0.0 R1 505805+/11731+ - 1.0) <10C17BE8-986B-3C96-A5EB-457D75854D43> /Applications/Vectorworks 2021 SP3/*/Tueren CW
0x17f22c000 - 0x17f50ffff +Unterbrechen CW (D26.0.0 R1 505805+/11731+ - 1.0) <D9E03550-96E3-3F51-910F-88D83CBAC5AA> /Applications/Vectorworks 2021 SP3/*/Unterbrechen CW
0x17f82f000 - 0x17fb33fff +de.computerworks.vectorworks.Unterteilen CW (D26.0.0 R1 505805+/11731+ - 1.0) <77571D14-D69A-33B0-8004-1470CD9B1438> /Applications/Vectorworks 2021 SP3/*/Unterteilen CW
0x17fe6f000 - 0x17feccff3 +net.nemetschek.vectorworks.UpdateCheck (1.0) <56958B9D-EBC9-3760-AA3A-C6EFF7AAFE82> /Applications/Vectorworks 2021 SP3/*/UpdateCheck
0x17fefd000 - 0x17ff75fff +net.nemetschek.vectorworks.VCSClient (1.0) <9AB67E65-E495-3AC7-95AC-D2431E1CEBDD> /Applications/Vectorworks 2021 SP3/*/VCSClient
0x17ffb9000 - 0x18001afff +net.nemetschek.vectorworks.VectorScriptEditor (1.0) <B7CB1DDE-A794-3A54-9A20-C244B474BB5B> /Applications/Vectorworks 2021 SP3/*/VectorScriptEditor
0x180047000 - 0x18016aff7 +com.sun.Scintilla (1.0) <A7F52E4B-72C7-3A34-8271-816113E9B7B0> /Applications/Vectorworks 2021 SP3/*/Scintilla.framework/Versions/A/Scintilla
0x1801d1000 - 0x180335fff +net.nemetschek.vectorworks.VectorworksRemote (..) <8EF2BC1F-1B51-3DD9-BF31-D34752BBAB6D> /Applications/Vectorworks 2021 SP3/*/Vectorworks Remote
0x180454000 - 0x180752ffb +Versetzen CW (D26.0.0 R1 505805+/11731+ - 1.0) <344C3CD0-CC86-3F49-B5A2-B092375B43BB> /Applications/Vectorworks 2021 SP3/*/Versetzen CW
0x180a87000 - 0x180c13ff7 +net.nemetschek.vectorworks.TesterModule (1.0) <ECC6C939-742E-3FBA-ABCB-7081B73111B4> /Applications/Vectorworks 2021 SP3/*/VGS_Datasmith
0x180cc8000 - 0x182478fff +DatasmithSDK.dylib (0) <613A2859-0FB7-3B03-8894-C0B29E69C81D> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/MacOS/DatasmithSDK.dylib
0x183422000 - 0x183424ff7 com.apple.textencoding.unicode (6.0 - 6.0) <67941F99-16D4-3281-B92A-17FD544E49B3> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x1837cb000 - 0x18389affb +net.nemetschek.vectorworks. (1.0) <2BD219C1-7D8C-32C8-94F6-8F485D2CD4FF> /Applications/Vectorworks 2021 SP3/*/VS Shared Library
0x1838ff000 - 0x183bc4ffb +de.computerworks.vectorworks.VW Hilfe CW (D26.0.0 R1 505805+/11731+ - 1.0) <CF2FF047-C516-32DC-BB33-5A11C1D90C09> /Applications/Vectorworks 2021 SP3/*/VW Hilfe CW
0x183ed6000 - 0x18441bff3 +com.deersoft.GDTFExport (1.0) <890B3D0A-4801-30DA-A91A-D9C354530DAB> /Applications/Vectorworks 2021 SP3/*/VWGDTFExchange
0x18479e000 - 0x184976ff3 +net.nemetschek.vectorworks.VWGraphicsModule (1.0) <8661761B-7CFD-368C-91EC-4549512190DC> /Applications/Vectorworks 2021 SP3/*/VWGraphicsModule
0x184a23000 - 0x184abcff3 +net.nemetschek.vectorworks.VWGraphicsXchange (1.0) <B1B03446-0FC4-3F2B-AFED-07F75DE3829A> /Applications/Vectorworks 2021 SP3/*/VWGraphicsXchange
0x184af6000 - 0x184ce3ff7 +com.cesyam.VWLibrary (25.0 - 1.0) <6B4454A7-C80F-3D1D-A2E3-850601E16A6E> /Applications/Vectorworks 2021 SP3/*/VWLibrary
0x184db9000 - 0x185094ff3 +de.computerworks.vectorworks.Waende abschliessen CW (D26.0.0 R1 505805+/11731+ - 1.0) <F8CBB4AA-FA3C-3779-BA4A-FE998B97C386> /Applications/Vectorworks 2021 SP3/*/Waende abschliessen CW
0x1853af000 - 0x18568cff7 +de.computerworks.vectorworks.Waende Wandseiten CW (D26.0.0 R1 505805+/11731+ - 1.0) <17091B8C-75A8-3B95-BF96-E7BB6A120AE5> /Applications/Vectorworks 2021 SP3/*/Waende Wandseiten CW
0x1859aa000 - 0x185cfeff3 +de.computerworks.vectorworks.Wandbild CW (D26.0.0 R1 505805+/11731+ - 1.0) <AE44F7A9-D3AC-36E7-8695-0684559264EE> /Applications/Vectorworks 2021 SP3/*/Wandbild CW
0x186087000 - 0x1861c8ff7 +net.nemetschek.vectorworks. (1.0) <E350F809-A466-34CD-84AE-E1F88FAB677E> /Applications/Vectorworks 2021 SP3/*/Workspace Editor
0x18626f000 - 0x1862effff +net.nemetschek.vectorworks.Workspaces (1.0) <619C69E4-AFFB-3366-99B0-36D735A85BE4> /Applications/Vectorworks 2021 SP3/*/Workspaces
0x18633d000 - 0x1865b1ffb +de.extragroup.XGShelf (1.0) <722EA57A-29C0-3331-82F9-914D4405ABE2> /Applications/Vectorworks 2021 SP3/*/XGShelf
0x18682b000 - 0x186db5ffb +de.computerworks.vectorworks.XPlanung CW (D26.0.0 R1 505805+/11731+ - 1.0) <14834DF3-1AA5-394F-A888-0CC5C6AD70CB> /Applications/Vectorworks 2021 SP3/*/XPlanung CW
0x1b8732000 - 0x1b8733fff com.apple.CIPassThrough (2.0 - 940.9) <4A6C228D-5CC5-30BE-88E6-C2434A205D76> /System/Library/CoreImage/CIPassThrough.cifilter/Contents/MacOS/CIPassThrough
0x1b9c7e000 - 0x1b9c96ff3 com.apple.CIBarcode (2.0 - 940.9) <1B14976A-7057-307A-BA16-F4DC0156A6C6> /System/Library/CoreImage/CIBarcode.cifilter/Contents/MacOS/CIBarcode
0x1b9ca2000 - 0x1b9d1eff7 com.apple.PortraitFilters (1.0 - 30) <8A853BAB-5B3C-304E-AA5B-6F2797C9CEFE> /System/Library/CoreImage/PortraitFilters.cifilter/Contents/MacOS/PortraitFilters
0x1b9d42000 - 0x1b9d4cfff +com.datalogics.DL150PDFlattener (15.0.0.0 - kShortVersStr) <84525506-0D4A-380F-974C-9DA638111E71> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150PDFlattener.ppi/Contents/MacOS/DL150PDFlattener
0x1b9d6c000 - 0x1b9de8ff7 +com.datalogics.DL150PDFProcessor (15.0.0.0 - kShortVersStr) <7E20A582-8581-3A41-B26C-A9F8692B66DD> /Applications/Vectorworks 2021 SP3/Vectorworks 2021.app/Contents/Frameworks/DL150PDFProcessor.ppi/Contents/MacOS/DL150PDFProcessor
0x1ba9a3000 - 0x1ba9a5ff3 com.apple.CloudDocsFileProvider (1.0 - 698.17) <C03D572A-4C6B-3DFA-8AA9-064B4808BA72> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
0x1ba9ae000 - 0x1ba9b1fff com.apple.FileProviderOverride (304.1 - 304.1) <FF452DA5-75BC-3EF3-B372-F4FD9B7D57B9> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x1ba9ba000 - 0x1ba9d1ffb com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1298.7.1) <1911451B-5BA5-3A08-AB9F-2729A55BDE38> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x7fff2b2bc000 - 0x7fff2b509ff8 com.apple.RawCamera.bundle (9.02.0 - 1350.30) <EFE24C4B-D8BC-3992-BEB0-2EA84C574C96> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff2b946000 - 0x7fff2b97cfff ATIRadeonX6000SCLib.dylib (3.10.19) <B69A8D57-50D7-3777-A15B-9A4C21AE7F70> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/ATIRadeonX6000SCLib.dylib
0x7fff2b97d000 - 0x7fff2bbf2ffc com.apple.AMDRadeonX6000MTLDriver (3.10.19 - 3.1.0) <4B72032C-658F-3164-96E8-18BCBAF84C72> /System/Library/Extensions/AMDRadeonX6000MTLDriver.bundle/Contents/MacOS/AMDRadeonX6000MTLDriver
0x7fff2cb4b000 - 0x7fff2d4c8fff libSC.dylib (3.10.19) <6990D42E-C5F0-320A-8DBF-3728D99E54FA> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
0x7fff2fbc2000 - 0x7fff30bc9ff7 com.apple.driver.AppleIntelKBLGraphicsGLDriver (14.7.13 - 14.0.7) <B2E28088-9A54-3E2E-88DB-48466728C520> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
0x7fff30bca000 - 0x7fff30fc9ff1 com.apple.driver.AppleIntelKBLGraphicsMTLDriver (14.7.13 - 14.0.7) <52BFD489-4F4F-302F-8501-7CE6152F92CB> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
0x7fff33a64000 - 0x7fff33a68ffb com.apple.agl (3.3.3 - AGL-3.3.3) <29495233-9BD3-33AB-AF0F-8DE3E82EB7CE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff33a69000 - 0x7fff33c64ff8 com.apple.avfoundation (2.0 - 1855.3) <0837D912-3783-35D6-A94A-E474E18600CF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff33c65000 - 0x7fff33d31ffe com.apple.audio.AVFAudio (1.0 - 415.75) <CAC3CA5F-FCF6-37EB-8F1A-090340E2C38E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff33e51000 - 0x7fff33e51fff com.apple.Accelerate (1.11 - Accelerate 1.11) <4F9977AE-DBDB-3A16-A536-AC1F9938DCDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff33e52000 - 0x7fff33e68fef libCGInterfaces.dylib (524.2.1) <8FD09D09-BB19-36C5-ADE9-4F22DA235AEE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff33e69000 - 0x7fff344bffff com.apple.vImage (8.1 - 524.2.1) <EA6F5FF2-7A1B-35D5-A5A3-D2B3386ECB75> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff344c0000 - 0x7fff34727ff7 libBLAS.dylib (1303.60.1) <C6C2D42F-7456-3DBF-8BE2-9AA06EFC78FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff34728000 - 0x7fff34bfbfef libBNNS.dylib (144.100.2) <99C61C48-B14C-3DA6-8C31-6BF72DA0A3A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff34bfc000 - 0x7fff34f97fff libLAPACK.dylib (1303.60.1) <5E3E3867-50C3-3E6A-9A2E-007CE77A4641> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff34f98000 - 0x7fff34fadfec libLinearAlgebra.dylib (1303.60.1) <3D433800-0099-33E0-8C81-15F83247B2C9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff34fae000 - 0x7fff34fb3ff3 libQuadrature.dylib (7) <371F36A7-B12F-363E-8955-F24F7C2048F6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff34fb4000 - 0x7fff35024fff libSparse.dylib (103) <B8A10D0C-4577-343D-B310-A3E81265D107> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff35025000 - 0x7fff35037fef libSparseBLAS.dylib (1303.60.1) <B147FEF6-A0DB-3830-BF06-45BEC58DB576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff35038000 - 0x7fff3520ffd7 libvDSP.dylib (735.140.1) <D63DC0A5-B8B4-3562-A574-E73BC3B57407> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff35210000 - 0x7fff352d2fef libvMisc.dylib (735.140.1) <3601FDE3-B142-398D-987D-8151A51F0A96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff352d3000 - 0x7fff352d3fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <F6C5613D-2284-342B-9160-9731F78B4DE5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff352d4000 - 0x7fff35333ff0 com.apple.Accounts (113 - 113) <E2438070-30AB-3B89-AE63-1E485B92D108> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff3547d000 - 0x7fff3623dff2 com.apple.AppKit (6.9 - 1894.60.100) <763827BC-780B-30A9-B067-B04D8E90910B> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff3628d000 - 0x7fff3628dfff com.apple.ApplicationServices (48 - 50) <4758C933-0823-3B84-8E68-03DA706CC208> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff3628e000 - 0x7fff362f9fff com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <87EA5DE1-506A-39FD-88BE-D8A3416C9012> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff36392000 - 0x7fff363d0ff0 libFontRegistry.dylib (274.0.5.1) <F3461C05-0370-359B-9F03-5C1C1F7763EC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff3642b000 - 0x7fff3645afff com.apple.ATSUI (1.0 - 1) <5F513967-DDD7-3F22-AD14-8A38ABD9F2D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff3645b000 - 0x7fff3645fffb com.apple.ColorSyncLegacy (4.13.0 - 1) <72EE68DB-F069-37F5-AA2A-40D5FCF139F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff364f9000 - 0x7fff36550ffa com.apple.HIServices (1.22 - 676) <14DF4D42-E24D-3EBD-9A9D-93124D8D6AA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff36551000 - 0x7fff3655ffff com.apple.LangAnalysis (1.7.0 - 1.7.0) <01B8B6B3-E2C3-3607-B34A-8283A7E0E924> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff36560000 - 0x7fff365a5ffa com.apple.print.framework.PrintCore (15.4 - 516.2) <437BCF12-48D2-3770-8BC9-567718FB1BCA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff365a6000 - 0x7fff365b0ff7 com.apple.QD (4.0 - 413) <27A36D07-B5E9-32E6-87B6-3127F260F48D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff365b1000 - 0x7fff365beffc com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <75344F8F-32CA-3558-B4E6-F56D498250E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff365bf000 - 0x7fff366a0ff2 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <3A7E709F-DE6E-313B-82A1-1E9C8B734CF5> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff366a2000 - 0x7fff366a2fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <76010435-2167-3B23-9E2A-E73F7F6C1B25> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff36a39000 - 0x7fff36dc7ffa com.apple.CFNetwork (1128.1 - 1128.1) <81AE2F6D-46E2-36D9-ADCE-E79E7A869D1D> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff36e43000 - 0x7fff36e43fff com.apple.Carbon (160 - 162) <49582194-AEFB-3FE9-B9D0-DB4AD24EFEDC> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff36e44000 - 0x7fff36e47ff3 com.apple.CommonPanels (1.2.6 - 101) <9F6E13D9-374B-386F-8E15-FDD6CE967859> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff36e48000 - 0x7fff3713cff3 com.apple.HIToolbox (2.1.1 - 994.6) <EAF2DAC3-66B1-30BF-AF10-72DDA90D1044> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff3713d000 - 0x7fff37140ff3 com.apple.help (1.3.8 - 71) <36483951-6F3E-3F7E-8A5B-191C2357EF17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff37141000 - 0x7fff37146ff7 com.apple.ImageCapture (9.0 - 1600.65) <1A1F320E-3E85-3F3D-8AE0-B238C4E92D40> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff37147000 - 0x7fff37147fff com.apple.ink.framework (10.15 - 227) <284507AE-EF47-3ABC-86A4-669243DB1D33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff37148000 - 0x7fff37162ffa com.apple.openscripting (1.7 - 185.1) <B6E28747-5FC7-3461-8A71-864A969ED022> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff37183000 - 0x7fff37183fff com.apple.print.framework.Print (15 - 271) <0D9FB08F-EA87-3BE7-821B-C61BA5601050> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff37184000 - 0x7fff37186ff7 com.apple.securityhi (9.0 - 55008) <390C6FAA-99BF-3924-9180-9EAE41D9C6BE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff37187000 - 0x7fff3718dfff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9614A01E-8303-3422-A3BA-6CE27540E09A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff3718e000 - 0x7fff37326ffa com.apple.cloudkit.CloudKit (867 - 867) <1B851180-FC00-357F-B6C1-BB0EA7D6D5CA> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff37327000 - 0x7fff37327fff com.apple.Cocoa (6.11 - 23) <4C81A68B-4967-3688-BB6C-7C19E78EA20F> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff37335000 - 0x7fff3742bfff com.apple.ColorSync (4.13.0 - 3394.9) <A126406C-DA38-3FFE-8B25-BB9859EFD159> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff3742c000 - 0x7fff3751cff7 com.apple.combine (1.0 - 134.102) <02C5D48A-E70F-3D68-8555-4211853F9C3B> /System/Library/Frameworks/Combine.framework/Versions/A/Combine
0x7fff37716000 - 0x7fff37c1fffb com.apple.audio.CoreAudio (5.0 - 5.0) <47923B12-3D14-328A-9C86-27A3A2A73068> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff37c72000 - 0x7fff37caafff com.apple.CoreBluetooth (1.0 - 1) <23DBB313-A082-3C08-8E1F-2D31EE4247EF> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff37cab000 - 0x7fff38095fe8 com.apple.CoreData (120 - 977.3) <49AE61CA-C91E-31FE-9BD0-1AACFFB5181E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff38096000 - 0x7fff381c8ff6 com.apple.CoreDisplay (1.0 - 186.6.15) <213D7011-8180-3CF4-9BE7-FB8F75DCDB95> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff381c9000 - 0x7fff38649ff2 com.apple.CoreFoundation (6.9 - 1677.205) <83F301FE-DE7E-315D-B4EA-CDA62F114F0A> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff3864b000 - 0x7fff38cc0fe8 com.apple.CoreGraphics (2.0 - 1355.24) <041366C9-FE91-3B58-95DD-5800A817BAB6> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff38cce000 - 0x7fff39029ff0 com.apple.CoreImage (15.0.0 - 940.9) <69361069-01AB-342E-862B-73A74271A765> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff3902a000 - 0x7fff39093ff0 com.apple.corelocation (2394.0.22 - 2394.0.22) <75966124-2FB7-33C3-BE49-3DD5F327F911> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff39094000 - 0x7fff390e4ff6 com.apple.audio.midi.CoreMIDI (1.10 - 88) <017B0334-8AC4-304B-A5E2-C82C51BE1917> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x7fff390e7000 - 0x7fff393e9ff2 com.apple.CoreML (1.0 - 1) <FD17F9EB-1930-314C-B6B4-2A2E643AC771> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x7fff393ea000 - 0x7fff394c5ffc com.apple.CoreMedia (1.0 - 2625.9) <A3FF3AFC-8C1C-36E5-9179-66D8F075EE35> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff394c6000 - 0x7fff39528ffe com.apple.CoreMediaIO (1000.0 - 5125.6) <EE8EEB82-D382-3A18-BD4E-9896B7F5A9BA> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff395b2000 - 0x7fff395b2fff com.apple.CoreServices (1069.24 - 1069.24) <C7B6191A-C8E2-3BBF-B678-93C2E2AEBC9A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff395b3000 - 0x7fff39638fff com.apple.AE (838.1 - 838.1) <2E5FD5AE-8A7F-353F-9BD1-0241F3586181> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff39639000 - 0x7fff3991aff7 com.apple.CoreServices.CarbonCore (1217 - 1217) <BE379206-99FA-30CD-8391-2708473A633F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff3991b000 - 0x7fff39968ffd com.apple.DictionaryServices (1.2 - 323.6) <26B70C82-25BC-353A-858F-945B14C803A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff39969000 - 0x7fff39971ff7 com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <FC84DB48-A3CE-30F7-A918-B3587731ACC7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff39972000 - 0x7fff39bacff6 com.apple.LaunchServices (1069.24 - 1069.24) <9A5359D9-9148-3B18-B868-56A9DA5FB60C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff39bad000 - 0x7fff39c45ff1 com.apple.Metadata (10.7.0 - 2076.7) <0973F7E5-D58C-3574-A3CE-4F12CAC2D4C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff39c46000 - 0x7fff39c73fff com.apple.CoreServices.OSServices (1069.24 - 1069.24) <0E4F48AD-402C-3E9D-9CA9-6DD9479B28F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff39c74000 - 0x7fff39cdbfff com.apple.SearchKit (1.4.1 - 1.4.1) <2C5E1D85-E8B1-3DC5-91B9-E3EDB48E9369> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff39cdc000 - 0x7fff39d00ff5 com.apple.coreservices.SharedFileList (131.4 - 131.4) <02DE0D56-E371-3EF5-9BC1-FA435451B412> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff39f5d000 - 0x7fff3a024ffc com.apple.CoreTelephony (113 - 7560.1) <31D93EB1-0A20-3383-9680-090E441F25D8> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
0x7fff3a025000 - 0x7fff3a1dcffc com.apple.CoreText (643.1.5.5 - 643.1.5.5) <8573E719-F71C-3123-8394-701E4989E34A> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff3a1dd000 - 0x7fff3a221ffb com.apple.CoreVideo (1.8 - 344.3) <5314E70D-325F-3E98-99FC-00FDF520747E> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff3a222000 - 0x7fff3a2afffc com.apple.framework.CoreWLAN (13.0 - 1601.2) <6223BFD5-D451-3DE9-90F6-F609AC0B0027> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff3a46b000 - 0x7fff3a476ff7 com.apple.DirectoryService.Framework (10.15 - 220.40.1) <6EACB7D0-A013-3D2B-93D2-5113F7C2559D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff3a477000 - 0x7fff3a521ff0 com.apple.DiscRecording (9.0.3 - 9030.4.5) <BCF3AFB0-6E1A-3F28-A575-1FD2D74E7C19> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff3a546000 - 0x7fff3a54cfff com.apple.DiskArbitration (2.7 - 2.7) <14572D3E-7743-31E3-8777-A7BE2EAF518F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff3a722000 - 0x7fff3a724ff2 com.apple.ExceptionHandling (1.5 - 13) <6ACFE4A2-6483-3F5B-A623-4DC606183E35> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
0x7fff3a741000 - 0x7fff3a86fff6 com.apple.FileProvider (304.1 - 304.1) <E8BB1D4B-05D6-386C-865C-F8C750CEC308> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff3a884000 - 0x7fff3a886ff3 com.apple.ForceFeedback (1.0.6 - 1.0.6) <9B324178-4FAA-3686-9E01-634607F38493> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff3a887000 - 0x7fff3ac4cfff com.apple.Foundation (6.9 - 1677.205) <1D3A7414-141E-3170-9D18-69A53F1ACAAC> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff3acb9000 - 0x7fff3ad09ff7 com.apple.GSS (4.0 - 2.0) <1B6FCC64-7ED0-30E4-AD2D-AD35D621981D> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff3ad0a000 - 0x7fff3ad32ff4 com.apple.GameController (1.0 - 1) <2B7F0994-4B32-3B08-B58A-3FA5A5E65AF4> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
0x7fff3ae46000 - 0x7fff3af5aff3 com.apple.Bluetooth (7.0.6 - 7.0.6f8) <C7AF719C-51B4-3727-A947-EB01204272D9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff3afc0000 - 0x7fff3b064ff3 com.apple.framework.IOKit (2.0.2 - 1726.148.1) <0A9D244C-AECC-3D29-86DE-4F3B04F8DD25> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff3b066000 - 0x7fff3b077ffb com.apple.IOSurface (269.11 - 269.11) <BCD744D4-E17E-3C2E-B69C-F69C789892E9> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff3b095000 - 0x7fff3b0f5ff5 com.apple.ImageCaptureCore (1.0 - 1600.65) <281CE141-B350-30E2-B345-FC7E7DF1AA3A> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff3b0f6000 - 0x7fff3b253fe6 com.apple.ImageIO.framework (3.3.0 - 1976.11.6) <1B271746-8BFA-382B-A223-4D4B4AD12504> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff3b254000 - 0x7fff3b257fff libGIF.dylib (1976.11.6) <F6721850-6AEC-3C70-B90B-FBF7CB3C1265> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff3b258000 - 0x7fff3b311fe7 libJP2.dylib (1976.11.6) <56C503FB-B37D-352D-B77A-D8BF1160289B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff3b312000 - 0x7fff3b335fe3 libJPEG.dylib (1976.11.6) <B82AC9B8-3416-3E16-AF45-5F1B96FDB38F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff3b5b2000 - 0x7fff3b5ccfef libPng.dylib (1976.11.6) <7C2D2001-B75A-33AF-A498-0B7B0C5E4DAD> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff3b5cd000 - 0x7fff3b5cefff libRadiance.dylib (1976.11.6) <1BA2051B-890C-39B8-9489-6187D1C2F404> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff3b5cf000 - 0x7fff3b615fff libTIFF.dylib (1976.11.6) <A3AA8DCA-A06E-33A3-9EC0-9D9BAE6A9531> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff3b62e000 - 0x7fff3babdff8 com.apple.Intents (1.0 - 1) <B2884C7F-0D08-3E3C-91A3-7FB755BB5CB1> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
0x7fff3bac0000 - 0x7fff3cb60ff1 com.apple.JavaScriptCore (15609 - 15609.4.1) <18766B97-AB12-331C-984C-F1C7C9363E8B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff3cb77000 - 0x7fff3cb89ff3 com.apple.Kerberos (3.0 - 1) <03BB492B-016E-37BF-B020-39C2CF7487FE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff3cb8a000 - 0x7fff3cb8afff libHeimdalProxy.dylib (77) <0A2905EE-9533-3345-AF9B-AAC71513BDFD> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff3cb8b000 - 0x7fff3cbc1ff7 com.apple.LDAPFramework (2.4.28 - 194.5) <020B3FA5-C305-3B13-9DFB-1D526EC3C96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff3ccd5000 - 0x7fff3ccf7ffc com.apple.CoreAuthentication.SharedUtils (1.0 - 693.140.3) <A3F9CE45-4F7A-3F5D-865C-6EB9B6C3B3B4> /System/Library/Frameworks/LocalAuthentication.framework/Support/SharedUtils.framework/Versions/A/SharedUtils
0x7fff3ccf8000 - 0x7fff3cd0eff2 com.apple.LocalAuthentication (1.0 - 693.140.3) <5D391FD1-391B-390A-BBC1-62A537C8DAFE> /System/Library/Frameworks/LocalAuthentication.framework/Versions/A/LocalAuthentication
0x7fff3cf1c000 - 0x7fff3cf26ffb com.apple.MediaAccessibility (1.0 - 125.1) <98065EA1-3484-3A5A-B05C-D2FABED8CEA4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff3cf3a000 - 0x7fff3cff1ff7 com.apple.MediaPlayer (1.0 - 1.0) <FE739C02-1000-36C8-9FAD-26FF3D8240CB> /System/Library/Frameworks/MediaPlayer.framework/Versions/A/MediaPlayer
0x7fff3cff2000 - 0x7fff3d73fff2 com.apple.MediaToolbox (1.0 - 2625.9) <3A848992-9182-382A-BF7D-5CB9707BE27B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff3d741000 - 0x7fff3d80bfff com.apple.Metal (212.8 - 212.8) <98C944D6-62C8-355E-90F8-C1CA2429EF24> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff3d80d000 - 0x7fff3d827ff5 com.apple.MetalKit (141.2 - 141.2) <FAACD940-5CF2-300A-83F3-86ABA7FDC531> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff3d828000 - 0x7fff3d865ff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <7EBAC15D-7837-395D-B405-1E29F7DA68FA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff3d866000 - 0x7fff3d8f0fe2 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <B424FE0C-6E90-3BFA-A6E7-DD86C735AE90> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff3d8f1000 - 0x7fff3d916ff4 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <02006D92-E2AB-3892-A96B-37F6520C19BA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff3d917000 - 0x7fff3d92cffb com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <CAA5A368-DB71-34F6-AEF9-27A8BC298F53> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff3d92d000 - 0x7fff3da8bffc com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <05612E06-50CB-318F-9F8E-EF4D49FAB3B0> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff3da8c000 - 0x7fff3dadbff4 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B0B591F8-6875-351E-867F-8EB3CD38CD52> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff3dadc000 - 0x7fff3daddff5 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <F2921F9A-3041-3495-878D-64134267B847> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff3eb7d000 - 0x7fff3eb89ffe com.apple.NetFS (6.0 - 4.0) <57CABC68-0585-3989-9161-157DBB544B82> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff3eb8a000 - 0x7fff3ece1ff3 com.apple.Network (1.0 - 1) <4A0F3B93-4D23-3E74-9A3D-AD19E9C0E59E> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff3ece2000 - 0x7fff3ef42ffa com.apple.NetworkExtension (1.0 - 1) <3ED35C5A-B170-373E-8277-D4198E408810> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
0x7fff4170a000 - 0x7fff41712ff7 libcldcpuengine.dylib (2.14) <D20EF7DF-8508-3707-A9B3-B7D8190971F5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff41713000 - 0x7fff4176bfff com.apple.opencl (3.5 - 3.5) <C4847D3F-8BBB-3B6A-A997-C16042DCE2FA> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff4176c000 - 0x7fff41788fff com.apple.CFOpenDirectory (10.15 - 220.40.1) <7E6C88EB-3DD9-32B0-81FC-179552834FA9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff41789000 - 0x7fff41794ffd com.apple.OpenDirectory (10.15 - 220.40.1) <4A92D8D8-A9E5-3A9C-942F-28576F6BCDF5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff420fa000 - 0x7fff420fcfff libCVMSPluginSupport.dylib (17.10.22) <50071DF6-251A-3F7E-A9EC-0625BDD24F7F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff420fd000 - 0x7fff42102fff libCoreFSCache.dylib (176.16.1) <BAE3602F-5452-323B-B696-C049F64A2D60> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff42103000 - 0x7fff42107fff libCoreVMClient.dylib (176.16.1) <B41FD53F-5730-3832-BC45-12E3101FF5BE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff42108000 - 0x7fff42110ff7 libGFXShared.dylib (17.10.22) <7358D2D6-F046-3DA7-B80A-039F950BF484> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff42111000 - 0x7fff4211bfff libGL.dylib (17.10.22) <E5190CA0-0D87-3B0B-8D3C-B60C42BC18DA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff4211c000 - 0x7fff42150ff7 libGLImage.dylib (17.10.22) <FB5A6177-F299-371C-9296-71F60E6B3CF3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff42151000 - 0x7fff422e5ff7 libGLProgrammability.dylib (17.10.22) <60082B4C-9627-3A67-AA64-63924BFEC2D7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff422e6000 - 0x7fff42322fff libGLU.dylib (17.10.22) <66BCAD33-0264-31AB-966C-66DD4359EAF4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff42d5e000 - 0x7fff42d6dff7 com.apple.opengl (17.10.22 - 17.10.22) <5B337C5E-F97E-32F0-AD50-2C293BFCA7FB> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff42d6e000 - 0x7fff42ee7fff GLEngine (17.10.22) <95305DC1-908D-3FEB-AAB4-A04940756BD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff42ee8000 - 0x7fff42f10fff GLRendererFloat (17.10.22) <90DB1784-54CA-3646-AE57-F224EA3E5BB8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff42f1f000 - 0x7fff43012ff5 com.apple.PDFKit (1.0 - 845.4.1) <A58B3E4C-6B27-32A7-AC6E-35BCB5A45944> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff43013000 - 0x7fff4312aff9 com.apple.PencilKit (1.0 - 1) <95301D00-CE35-3F53-BAE1-6E6217706702> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
0x7fff433cb000 - 0x7fff433d1ff6 com.apple.PushKit (1.0 - 1) <AD547A25-1A0B-3FA6-8676-82C37F267A4A> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff434c6000 - 0x7fff434f1fff com.apple.QTKit (1.0 - 5) <A71258EB-241C-3AB2-BA89-303192C2A151> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff434f2000 - 0x7fff43738ff7 com.apple.imageKit (3.0 - 1081) <5F086EE2-5745-3E28-B292-1DE5E0652E36> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff43739000 - 0x7fff43bf8fff com.apple.QuartzComposer (5.1 - 378) <9C10ADF7-94B0-3779-AD44-5AF6394A32AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff43bf9000 - 0x7fff43c1effc com.apple.quartzfilters (1.10.0 - Tag) <876E8B28-9500-34C6-B297-EA404D89C903> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff43c1f000 - 0x7fff43d29ff7 com.apple.QuickLookUIFramework (5.0 - 906.3) <7128FB8C-83B0-3250-BF86-E8A1772CF1F5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff43d2a000 - 0x7fff43d2afff com.apple.quartzframework (1.5 - 23) <0E9BC89B-B86F-3E94-866A-AC0863522BF5> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff43d2b000 - 0x7fff43faeffb com.apple.QuartzCore (1.11 - 841.5) <26281BD1-499F-37C0-885C-58DD9245525D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff43faf000 - 0x7fff44008ff5 com.apple.QuickLookFramework (5.0 - 906.3) <959CE934-B541-3172-846F-4D1709353526> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff44009000 - 0x7fff4403effc com.apple.QuickLookThumbnailing (1.0 - 1) <9CCB50D8-AA39-3744-93FB-7B5B65467AB3> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff4450f000 - 0x7fff44529ffa com.apple.SafariServices.framework (15611 - 15611.1.21.161.7) <14B4BEBB-8528-3FA1-BF3A-C9EDE01521F3> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff44b31000 - 0x7fff44e7aff1 com.apple.security (7.0 - 59306.140.6) <A896EE58-D7EA-34E4-8832-93E38EA47831> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff44e7b000 - 0x7fff44f03ffb com.apple.securityfoundation (6.0 - 55236.60.1) <CCF58C3E-8953-3952-863B-0235054F0D40> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff44f04000 - 0x7fff44f31ff7 com.apple.securityinterface (10.0 - 55139.120.1) <72DC3440-6D3E-39DF-B8A8-85ADAE8D38FC> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff44f32000 - 0x7fff44f36ff8 com.apple.xpc.ServiceManagement (1.0 - 1) <0065A95F-0AEB-306D-94DC-6E7F70AA6EBD> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff45be2000 - 0x7fff45c5cff7 com.apple.SystemConfiguration (1.19 - 1.19) <84F9B3BB-F7AF-3B7C-8CD0-D3C22D19619F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff45edc000 - 0x7fff4625fff4 com.apple.VideoToolbox (1.0 - 2625.9) <6CF18E28-A7A8-3952-8171-7E4FF4FB37FA> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff46501000 - 0x7fff46c9eff7 libwebrtc.dylib (7609.4.1) <B3D98E65-2241-3DEC-9DEF-4628E4FBDDE6> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff46c9f000 - 0x7fff48f09ff3 com.apple.WebCore (15609 - 15609.4.1) <F7DC98BF-FB0A-39A4-ABA8-7C03364156BA> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff48f0a000 - 0x7fff49116ffb com.apple.WebKitLegacy (15609 - 15609.4.1) <99CAEE2D-8516-3B55-B29E-4F01340C84D3> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff49117000 - 0x7fff4981cffd com.apple.WebKit (15609 - 15609.4.1) <B514329D-F257-310E-B562-C23C20920075> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff49bcc000 - 0x7fff49c91fe7 com.apple.APFS (1412.141.2 - 1412.141.2) <FC81D7DC-5760-384E-A8FA-3CA56B8C1EE8> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff4a2dd000 - 0x7fff4a2e8ffc com.apple.accessibility.AXCoreUtilities (1.0 - 1) <7693F2BF-4DEB-3659-AA34-06322BAE38F8> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
0x7fff4ada6000 - 0x7fff4ada7ff1 com.apple.AggregateDictionary (1.0 - 1) <95A291F5-B69F-3C37-9483-C3B2EBF52AC1> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff4b072000 - 0x7fff4b1bdff5 com.apple.AnnotationKit (1.0 - 325.9) <9BB0EDB6-3808-30FC-B0ED-764DE5AAB893> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
0x7fff4b1be000 - 0x7fff4b1dbff4 com.apple.AppContainer (4.0 - 448.100.6) <87CEE13C-8585-3EFB-92CD-0852DFF0921B> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff4b230000 - 0x7fff4b23eff7 com.apple.AppSandbox (4.0 - 448.100.6) <0F49AA04-3400-349A-9096-6D4D7ED61027> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff4b6ba000 - 0x7fff4b6deffb com.apple.framework.Apple80211 (13.0 - 1610.1) <D94E03E8-4C38-3B2F-8DF4-473ACC5A7D71> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff4b99c000 - 0x7fff4b9abfd7 com.apple.AppleFSCompression (119.100.1 - 1.0) <466ABD77-2E52-36D1-8E39-77AE2CC61611> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff4baaa000 - 0x7fff4bab5ff7 com.apple.AppleIDAuthSupport (1.0 - 1) <74F6CD9C-27A7-39C7-A7EB-47E60D2517EB> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff4baf7000 - 0x7fff4bb3fff7 com.apple.AppleJPEG (1.0 - 1) <6DE30A07-C627-319B-A0DE-EB7A832BEB88> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff4bf02000 - 0x7fff4bf28ffb com.apple.aps.framework (4.0 - 4.0) <3ED300B6-43E3-31DC-B3C6-6A0FF41A2595> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff4bf29000 - 0x7fff4bf2dff7 com.apple.AppleSRP (5.0 - 1) <70C25EA9-F7A7-366C-97C6-EEE7845FFCC3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff4bf2e000 - 0x7fff4bf50fff com.apple.applesauce (1.0 - 16.25) <68E0364C-AEA7-3654-A030-136BF3CD92F3> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff4c00f000 - 0x7fff4c012fff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <67255151-F989-39F0-BC87-0C0BDAE70730> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff4c013000 - 0x7fff4c063ff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) <E8540613-F9C7-3665-AB6E-EA43A05B83B4> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff4c0ac000 - 0x7fff4c0bbff9 com.apple.AssertionServices (1.0 - 223.140.2) <48AD21CA-B81D-380E-A04F-90C48FDA5203> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff4c5fe000 - 0x7fff4c9f9ff8 com.apple.audio.AudioResourceArbitration (1.0 - 1) <2BD68521-C19C-3D67-B5EB-DE3E9A4DAF0A> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff4cc4f000 - 0x7fff4ce8fff8 com.apple.audio.AudioToolboxCore (1.0 - 1104.97) <E3B9D2AD-F256-38B5-93AC-6591E3787F7F> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff4ce93000 - 0x7fff4cfaffff com.apple.AuthKit (1.0 - 1) <DC1A27C5-0172-3C72-9B24-06996D0B6207> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff4d16c000 - 0x7fff4d175ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <A6877DAD-8F47-363C-983A-DC8DDE83B7B5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff4d176000 - 0x7fff4d217ff5 com.apple.backup.framework (1.11.7 - 1298.7.1) <C9DC35FA-E69F-3C64-9519-494126096337> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff4d218000 - 0x7fff4d2a4ff6 com.apple.BaseBoard (466.3 - 466.3) <10D0F3BB-E8F3-365E-8528-6AC996A9B0E7> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff4d3a6000 - 0x7fff4d3e2ff7 com.apple.bom (14.0 - 219.2) <79CBE5E7-054F-377B-9566-A86A9F120CF1> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff4d500000 - 0x7fff4d537ff5 com.apple.C2 (1.3 - 495) <4A7E2A63-E19A-3936-92F5-03F2FD602172> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff4df62000 - 0x7fff4dfb1fff com.apple.ChunkingLibrary (307 - 307) <5B09C30D-FD2B-3E98-8B64-C5EF470FC13C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff4e10c000 - 0x7fff4e197ff8 com.apple.CloudDocs (1.0 - 698.17) <900567ED-DEA4-30D5-A1C0-78BD53C58CD6> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff4ee5e000 - 0x7fff4ee6effb com.apple.CommonAuth (4.0 - 2.0) <7A6E5A56-7929-3E44-8FCC-FE1DC6751082> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff4ee82000 - 0x7fff4ee99fff com.apple.commonutilities (8.0 - 900) <F4C97244-E5D8-3F7D-8D94-4B6841C5A4EC> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff4f5a0000 - 0x7fff4f975fc8 com.apple.CoreAUC (283.0.0 - 283.0.0) <4341271C-D270-3F9F-8464-31A20D15158D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff4f976000 - 0x7fff4f9a3ff7 com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <C3CFDC68-C7D9-3C44-9E7C-801D45575C10> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff4f9c6000 - 0x7fff4f9e7ff4 com.apple.analyticsd (1.0 - 1) <7BAD537E-C905-330D-BABF-AA0AA0FE0E27> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff4faf0000 - 0x7fff4fb66ff7 com.apple.corebrightness (1.0 - 1) <BE927D79-1C49-3C0B-B8AD-055F34A35AE3> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff4fcf2000 - 0x7fff4fcfdff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <BB7D67B1-2102-3D71-9BB6-AEB8C6A6EBB2> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff4fcfe000 - 0x7fff4ff09ff1 com.apple.CoreDuet (1.0 - 1) <F899F217-FC31-3140-A0EB-92EAD22EEF71> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff4ff0a000 - 0x7fff4ff57ff3 com.apple.coreduetcontext (1.0 - 1) <72341E86-6921-35FE-89CA-7B04725ECC0F> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
0x7fff4ff58000 - 0x7fff4ff68ffe com.apple.CoreDuetDaemonProtocol (1.0 - 1) <5E31B761-4B30-39A8-9084-97ECFD268B6F> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff4ff6b000 - 0x7fff4ff6dfff com.apple.CoreDuetDebugLogging (1.0 - 1) <6D0113DB-61D8-3A21-95CB-9E30D8F929F9> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff4ff7e000 - 0x7fff4ff8eff3 com.apple.CoreEmoji (1.0 - 107.1) <7C2B3259-083B-31B8-BCDB-1BA360529936> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff50144000 - 0x7fff50291fff com.apple.CoreHandwriting (161 - 1.2) <21DAD964-51A7-3F38-9C91-EF46C0CFF12D> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
0x7fff505ce000 - 0x7fff50638ff0 com.apple.CoreNLP (1.0 - 213) <E70E2505-8078-324E-BAE1-01A2DA980E2C> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff508f6000 - 0x7fff508faffb com.apple.CoreOptimization (1.0 - 1) <0FFD7AA1-6E0B-395B-BCDC-73C1CCECC25B> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff508fb000 - 0x7fff50983ffe com.apple.CorePDF (4.0 - 518.4.1) <8F94505C-96C2-3694-BEC7-F3B5581A7AB9> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff50a66000 - 0x7fff50a6eff8 com.apple.CorePhoneNumbers (1.0 - 1) <E4DAD514-0B3B-3E0B-8AEA-39B320FAAF03> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff50a6f000 - 0x7fff50ac194b com.apple.CorePrediction (1.0 - 1) <CDF739BA-70AA-3FA2-9E0E-2E1BFC348A59> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff5145b000 - 0x7fff5147efff com.apple.CoreSVG (1.0 - 129.3) <F38189F9-C8F9-3D62-9D5F-3F520FB81724> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff5147f000 - 0x7fff514b2fff com.apple.CoreServicesInternal (446.7 - 446.7) <65F53A22-6B61-382C-AAC2-B2C53F8FFB44> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff514b3000 - 0x7fff514e1ffd com.apple.CSStore (1069.24 - 1069.24) <C2D67667-FA0B-3DB6-AA34-6999EE4346A0> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff51a06000 - 0x7fff51a9cff7 com.apple.CoreSymbolication (11.4 - 64535.33.2) <0B3BF87A-7F95-3D79-B4F8-421D6FAC4A6C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff51b34000 - 0x7fff51c60ff6 com.apple.coreui (2.1 - 609.4) <788818B7-7EBC-316D-9464-D12E365E3791> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff51c61000 - 0x7fff51e1affa com.apple.CoreUtils (6.2.4 - 624.7) <A74A1C65-6695-3F57-B703-0DEDE13E66C1> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff51f54000 - 0x7fff51f67ff1 com.apple.CrashReporterSupport (10.13 - 15016.1) <D584FFA6-32C5-328B-BE77-2C256B2B116C> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff52020000 - 0x7fff52032ff8 com.apple.framework.DFRFoundation (1.0 - 252.50.1) <8162057E-E856-3451-9160-04AEDDECFFA4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff52033000 - 0x7fff52038fff com.apple.DSExternalDisplay (3.1 - 380) <31ECB5FD-7660-33DB-BC5B-2B2A2AA7C686> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff520c2000 - 0x7fff5213cff0 com.apple.datadetectorscore (8.0 - 659) <B1534796-1000-3520-A641-A97A4AC5D39B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff52188000 - 0x7fff521c5ff8 com.apple.DebugSymbols (194 - 194) <040AE30B-CF2C-3798-A289-0929B8CAB10D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff521c6000 - 0x7fff5234eff6 com.apple.desktopservices (1.14.6 - 1281.6.1) <C2355E6B-C5F7-3E39-B778-B117BD4652C6> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff52364000 - 0x7fff52370ff8 com.apple.DeviceIdentity (1.0 - 1) <8700CB85-46A3-3388-977E-5A899FC58D20> /System/Library/PrivateFrameworks/DeviceIdentity.framework/Versions/A/DeviceIdentity
0x7fff525e7000 - 0x7fff526afffe com.apple.DiskImagesFramework (559.100.2 - 559.100.2) <65F24DF5-1B62-3F6B-9188-ED39634D2AE7> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff526b0000 - 0x7fff52783ff1 com.apple.DiskManagement (13.0 - 1648.140.2) <640DBACE-B6EC-3C72-9F73-F484E891534E> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff52784000 - 0x7fff52788ff1 com.apple.DisplayServicesFW (3.1 - 380) <4D71ADB3-B29D-3D20-B6DE-9E94061F86AC> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff527e2000 - 0x7fff52806ff7 com.apple.DuetActivityScheduler (1.0 - 1) <188C6793-A94C-3B49-A9F4-AF8A348C7E62> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
0x7fff52830000 - 0x7fff52865ff7 com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <D3F76E01-2F9F-33E1-B5C9-CAC6E01724C2> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
0x7fff52866000 - 0x7fff5286aff9 com.apple.EFILogin (2.0 - 2) <3BFE697B-469F-38F4-B380-4A4F4A37C836> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff533b4000 - 0x7fff53a1eff9 com.apple.vision.EspressoFramework (1.0 - 188.4) <70B1521B-1B24-3DA4-A41B-E727CF140F1F> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff53cf9000 - 0x7fff54114ff1 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <5D32F65D-2CD7-3204-975C-F4C9256E505F> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff5476c000 - 0x7fff5476cfff com.apple.FinderSyncPriv (1.0.7 - 1298.7.1) <5E08FCCF-B5AA-367F-BD08-DEFD32AB073F> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv
0x7fff547b3000 - 0x7fff548e9ffc libFontParser.dylib (277.2.6.6) <FABE97A5-398F-3015-B132-7DACC33344A2> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff548ea000 - 0x7fff5491efff libTrueTypeScaler.dylib (277.2.6.6) <653F9E57-5337-35CD-B1BE-165052FC9CF1> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff54982000 - 0x7fff54992ff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <202E45A7-B23F-3873-87CA-5D39D30D757F> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff57e73000 - 0x7fff57e74fff libmetal_timestamp.dylib (902.14.11) <C29C7125-A894-3718-8E1D-249C53BCC0B8> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff59522000 - 0x7fff5952dff7 libGPUSupportMercury.dylib (17.10.22) <AA625B41-C08E-35C0-A56C-E020DF33658B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff5952e000 - 0x7fff59534fff com.apple.GPUWrangler (5.2.7 - 5.2.7) <FA34760B-4E5C-3A18-A6C3-DBA68F9D1220> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff59853000 - 0x7fff59879ff1 com.apple.GenerationalStorage (2.0 - 314) <54483E50-20BB-3AF8-900F-992320C109B0> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff59892000 - 0x7fff5a87bff1 com.apple.GeoServices (1.0 - 1624.26.4.26.9) <F735575F-7DEF-3202-9151-589BEB162596> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff5a9a7000 - 0x7fff5a9b5ffb com.apple.GraphVisualizer (1.0 - 100.1) <507D5812-9CB4-3C94-938C-59ED2B370818> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff5a9b6000 - 0x7fff5a9c3ff3 com.apple.GraphicsServices (1.0 - 1.0) <5DAF38C9-53CF-319A-A853-C2EDC46F30EF> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
0x7fff5a9d3000 - 0x7fff5aa1dff8 com.apple.HDRProcessing (1.63.9 - 1.63.9) <051EAA90-51B4-3AFA-9BBC-7B5EF6035F8B> /System/Library/PrivateFrameworks/HDRProcessing.framework/Versions/A/HDRProcessing
0x7fff5aa1e000 - 0x7fff5aa2bff9 com.apple.HID (1.0 - 1) <0C27FC33-B645-3B7B-AAB5-E6F8F3A0A34D> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
0x7fff5ab54000 - 0x7fff5ac12ff4 com.apple.Heimdal (4.0 - 2.0) <6F292E47-3C40-33ED-9AD7-18FC9939E2CF> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5b60f000 - 0x7fff5b63eff8 com.apple.HelpData (2.3 - 199) <A62E7DB6-8960-3470-8281-293711C166D8> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff5cd94000 - 0x7fff5cd9dffe com.apple.IOAccelMemoryInfo (1.0 - 1) <ECAB1FBF-4756-3437-8C72-0F89294510CA> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff5cd9e000 - 0x7fff5cda6ff5 com.apple.IOAccelerator (438.7.4 - 438.7.4) <3C973800-3AE0-3908-9922-EFBC57C3F5B2> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5cdb3000 - 0x7fff5cdcafff com.apple.IOPresentment (47.10 - 37) <C97340B5-C71D-32CC-A519-30A5D7184BD3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5d152000 - 0x7fff5d19dff1 com.apple.IconServices (438.3 - 438.3) <0DADB4C3-46FF-3FDB-8A86-51E2067FC7F4> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5d33a000 - 0x7fff5d348fff com.apple.IntentsFoundation (1.0 - 1) <1BC7D355-E136-391A-8215-6982742645DD> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
0x7fff5d35b000 - 0x7fff5d362ff9 com.apple.InternationalSupport (1.0 - 45.4) <8D8D4A7D-FD35-36B8-A456-7C93030EDAB3> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff5d5ef000 - 0x7fff5d60effd com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <23F39683-FE1E-3295-BE65-2FB6694B7CBF> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff5d743000 - 0x7fff5d811ffd com.apple.LanguageModeling (1.0 - 215.1) <C456087D-5B3A-390E-A665-862FA284C59C> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5d812000 - 0x7fff5d85afff com.apple.Lexicon-framework (1.0 - 72) <41F208B9-8255-3EC7-9673-FE0925D071D3> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5d861000 - 0x7fff5d866ff3 com.apple.LinguisticData (1.0 - 353.18) <3B92F249-4602-325F-984B-D2DE61EEE4E1> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5d88d000 - 0x7fff5d8b1ffe com.apple.locationsupport (2394.0.22 - 2394.0.22) <CA6C86FD-051A-31BB-B3AF-3D02D6FD94B6> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff5d90a000 - 0x7fff5d90fff7 com.apple.LoginUICore (4.0 - 4.0) <25CA17AF-8A74-3CE3-84D8-67B4A2B76FEA> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff5e0ff000 - 0x7fff5e102fff com.apple.Mangrove (1.0 - 25) <482F300F-9B70-351F-A4DF-B440EEF7368D> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5e2c0000 - 0x7fff5e2e6ffc com.apple.MarkupUI (1.0 - 325.9) <A596E8D7-6DBD-3F01-89AD-B296C9D3B61E> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
0x7fff5e36b000 - 0x7fff5e3f5ff8 com.apple.MediaExperience (1.0 - 1) <0203AF27-AB5E-32FA-B529-AB7F29EEB887> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff5e3f6000 - 0x7fff5e429fff com.apple.MediaKit (16 - 923) <09FEE738-41E4-3A9C-AF1E-1DD00C56339D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff5e4ee000 - 0x7fff5e884ff9 com.apple.MediaRemote (1.0 - 1) <A0FF8D18-8BD3-3497-A53E-53CA3A072D5B> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
0x7fff5e885000 - 0x7fff5e8c1ffc com.apple.MediaServices (1.0 - 1) <EA82F76E-BF9B-37C3-9C8F-BEBC7D87D0CE> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
0x7fff5ebcf000 - 0x7fff5ec1bfff com.apple.spotlight.metadata.utilities (1.0 - 2076.7) <0237323B-EC78-3FBF-9FC7-5A1FE2B5CE25> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff5ec1c000 - 0x7fff5ecedffa com.apple.gpusw.MetalTools (1.0 - 1) <99876E08-37D7-3828-8796-56D90C9AFBDB> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff5ed4b000 - 0x7fff5ed64ff4 com.apple.MobileAssets (1.0 - 619.120.1) <07E116E6-7EBC-39F2-B5B4-31BAB6BAF852> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff5ef21000 - 0x7fff5ef3ffff com.apple.MobileKeyBag (2.0 - 1.0) <D5FA7041-297F-3ADC-8C7A-6EAAAB82EB68> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff5f00b000 - 0x7fff5f1a1ffd com.apple.Montreal (1.0 - 121.1) <E7881020-FCA6-3DFC-B0EB-9E539F80E821> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
0x7fff5f1a2000 - 0x7fff5f1d2ff7 com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <6794E1C8-9627-33DF-84F4-FDD02C97F383> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff5f6d2000 - 0x7fff5f6dcfff com.apple.NetAuth (6.2 - 6.2) <B0C03C41-87A3-352B-B130-96E1A6F94B47> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5f79e000 - 0x7fff5f7baff0 com.apple.network.statistics.framework (1.2 - 1) <B2F29251-A67A-36A9-B1E8-8652C59BADA1> /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistics
0x7fff600f3000 - 0x7fff6013effb com.apple.OTSVG (1.0 - 643.1.5.5) <01218F85-C43B-37A0-B124-90D0FA342210> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff6135b000 - 0x7fff61366ff2 com.apple.PerformanceAnalysis (1.243.3 - 243.3) <7B2C4193-68D7-3B95-ACA3-0FDD33A74D45> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff61367000 - 0x7fff6138fffb com.apple.persistentconnection (1.0 - 1.0) <5B2D87A8-2641-3F6D-ACEA-96B00F85AAB5> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff62e0a000 - 0x7fff62e3aff7 com.apple.pluginkit.framework (1.0 - 1) <EFBD7FE7-02CC-3E30-999D-B036F252F805> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff62e65000 - 0x7fff62e78ffc com.apple.PowerLog (1.0 - 1) <50B94781-D5BA-3F71-AFD4-583BD61F19F8> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff63cf4000 - 0x7fff63d4eff6 com.apple.ProtectedCloudStorage (1.0 - 1) <6F271388-3817-336D-9B96-08C7AAC4BA39> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff63d4f000 - 0x7fff63d68ffb com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <5A020941-C43C-303E-8DE8-230FC6A84DBC> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff63e7a000 - 0x7fff63e7dff4 com.apple.QuickLookNonBaseSystem (1.0 - 1) <8563CD18-DCFE-3868-912F-053FC8C34B9C> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
0x7fff63e7e000 - 0x7fff63ea1ff0 com.apple.quicklook.QuickLookSupport (1.0 - 1) <AFB0DFCC-6580-30E5-8984-831985F37A2C> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
0x7fff63ee8000 - 0x7fff63f61ff3 com.apple.Rapport (1.9.5 - 195.2) <AF01D899-3BF9-3586-860A-D95A837101DF> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
0x7fff641a8000 - 0x7fff641b4ff5 com.apple.xpc.RemoteServiceDiscovery (1.0 - 1738.140.3) <ECE50C94-D9D8-3ED1-80BD-95FDA964B716> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff641c8000 - 0x7fff641f1ff1 com.apple.RemoteViewServices (2.0 - 148) <D3AAC2BE-3423-3F18-9654-E35F1DD8DDB3> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff641f2000 - 0x7fff64207ffa com.apple.xpc.RemoteXPC (1.0 - 1738.140.3) <434E0734-59DA-3901-92F4-73B47A1FE1D3> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff64356000 - 0x7fff64391ff0 com.apple.RunningBoardServices (1.0 - 223.140.2) <96BB04BD-D6E0-3D70-8F36-89B46DA1DA30> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff650ba000 - 0x7fff65106ff9 com.apple.Safari.SafeBrowsing (15609 - 15609.4.1) <9B45B45B-9E12-3172-9799-BA1F8FF711EA> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
0x7fff65c72000 - 0x7fff65c75ff5 com.apple.SecCodeWrapper (4.0 - 448.100.6) <C4BF691D-A09E-37E8-A6CC-1145B79B8722> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff65de8000 - 0x7fff65f0ffff com.apple.Sharing (1526.37 - 1526.37) <CBDA0ADD-F1E7-3B06-9118-C5E183F0D3D6> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff65f68000 - 0x7fff65f86ff2 com.apple.shortcut (2.16 - 106) <9F669D19-13AD-3961-B247-ED728B7BFA19> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff65f87000 - 0x7fff65fa7ff5 com.apple.sidecar-core (1.0 - 209.40.4) <469E5222-A5C7-3B09-B617-EDB6E9E46B93> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff65fa8000 - 0x7fff65fbaff0 com.apple.sidecar-ui (1.0 - 209.40.4) <5CA517E3-4B92-30B1-96EF-77A7A2FBBEE4> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff67324000 - 0x7fff6761afff com.apple.SkyLight (1.600.0 - 451.5) <8847E3D3-C246-3D2E-9D04-48BBD71FCEDC> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff67e67000 - 0x7fff67e75ffb com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <4D6CAC2A-151B-3BBE-BDB7-E2BE72128691> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff67f37000 - 0x7fff681c3ffe com.apple.spotlight.index (10.7.0 - 2076.7) <932C7705-353B-395F-9A23-09D62EAFAD81> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff68551000 - 0x7fff68592ff9 com.apple.StreamingZip (1.0 - 1) <72CA32F8-4C96-3264-A655-623329EB3A28> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff686a9000 - 0x7fff686b2ff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.2) <C3D66901-7E31-3FDB-BD7A-441EB0520D1D> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff68723000 - 0x7fff6874dffe com.apple.framework.SystemAdministration (1.0 - 1.0) <087553CB-5BF3-3D3D-B620-CA36AD334D92> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff68969000 - 0x7fff68979ff3 com.apple.TCC (1.0 - 1) <C9EB52E3-099B-3597-9623-067C403FA525> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff68e9e000 - 0x7fff68f64ff0 com.apple.TextureIO (3.10.9 - 3.10.9) <EEDAB753-329A-396A-8119-5BEDF7DB5A56> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff690fb000 - 0x7fff690fcfff com.apple.TrustEvaluationAgent (2.0 - 33) <10E56F70-E234-31E0-9286-96D93A8ED17E> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff69134000 - 0x7fff6938cff0 com.apple.UIFoundation (1.0 - 662) <EC55B9E5-7E62-380A-9AB1-FC7BEF663653> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff69423000 - 0x7fff69429ffe com.apple.URLFormatting (119 - 119.18) <7F99D166-86DC-3F77-A34A-2DA7183D7160> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff6a01b000 - 0x7fff6a03bffc com.apple.UserManagement (1.0 - 1) <9F00880E-6EA6-3684-B208-455E14EC07C8> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff6ade7000 - 0x7fff6aed2ff2 com.apple.ViewBridge (468 - 468) <C02D0559-9C21-39C8-9E4B-E866CDBFD746> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff6b078000 - 0x7fff6b079fff com.apple.WatchdogClient.framework (1.0 - 67.120.2) <FFA17DA1-F6DD-34D3-A708-1F73C8BA7EA7> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff6b24c000 - 0x7fff6b24cfff com.apple.WebInspectorUI (15609 - 15609.4.1) <94A93FEF-0395-3053-9781-A8516C9F9040> /System/Library/PrivateFrameworks/WebInspectorUI.framework/Versions/A/WebInspectorUI
0x7fff6b408000 - 0x7fff6b443fff libAWDSupport.dylib (949) <EBE20139-E443-30DF-BCAD-2A6A8470F631> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
0x7fff6b444000 - 0x7fff6b724ff7 libAWDSupportFramework.dylib (3541.2) <D1EA2A4B-BC59-3FE2-BAA9-4448D6F8393F> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
0x7fff6b725000 - 0x7fff6b736fff libprotobuf-lite.dylib (3541.2) <578CA7D8-149E-3643-937B-DAD5501E4575> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
0x7fff6b737000 - 0x7fff6b790ffb libprotobuf.dylib (3541.2) <0CDB164D-E7C3-3D4F-BF11-47402D67D7B0> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x7fff6b791000 - 0x7fff6b7d5ff6 com.apple.awd (1.0 - 949) <9DA8A821-4354-3E24-BAA1-4519D2279F2B> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x7fff6bca9000 - 0x7fff6bcacffa com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <D459D628-58C5-39A6-B7E8-B691CBEECEC1> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff6bd26000 - 0x7fff6bd34ff5 com.apple.audio.caulk (1.0 - 32.3) <06D695EA-E2BC-31E4-9816-9C12542BA744> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff6c076000 - 0x7fff6c078ff3 com.apple.loginsupport (1.0 - 1) <12F77885-27DC-3837-9CE9-A25EBA75F833> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff6c079000 - 0x7fff6c08cffd com.apple.login (3.0 - 3.0) <C68367BA-2225-31DD-B2D8-16AC0A44421F> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff6c0be000 - 0x7fff6c0caffd com.apple.perfdata (1.0 - 51.100.6) <21760CFD-62FF-3466-B3AD-191D02411DA0> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
0x7fff6ea6a000 - 0x7fff6ea7fffe libAccessibility.dylib (2790.70) <3F824859-2E9B-3772-A475-73E4F88A15C2> /usr/lib/libAccessibility.dylib
0x7fff6eb4f000 - 0x7fff6eb5bff9 libAudioStatistics.dylib (1104.97) <910E0D16-7267-3B47-81F6-1420864A316C> /usr/lib/libAudioStatistics.dylib
0x7fff6eb5c000 - 0x7fff6eb8fffa libAudioToolboxUtility.dylib (1104.97) <8B76C584-A8B0-3599-A7D4-8BD75A11FEFF> /usr/lib/libAudioToolboxUtility.dylib
0x7fff6eb96000 - 0x7fff6ebcafff libCRFSuite.dylib (48) <5E5DE3CB-30DD-34DC-AEF8-FE8536A85E96> /usr/lib/libCRFSuite.dylib
0x7fff6ebcd000 - 0x7fff6ebd7fff libChineseTokenizer.dylib (34) <7F0DA183-1796-315A-B44A-2C234C7C50BE> /usr/lib/libChineseTokenizer.dylib
0x7fff6ebd8000 - 0x7fff6ec60fff libCoreStorage.dylib (551) <A457B0FE-D77F-30AA-99A4-70F6A98DFE59> /usr/lib/libCoreStorage.dylib
0x7fff6ec63000 - 0x7fff6ec65ff7 libDiagnosticMessagesClient.dylib (112) <C94F3B7B-1854-38EB-9778-834501C53B3F> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff6ecab000 - 0x7fff6ee62ffb libFosl_dynamic.dylib (100.4) <737573B2-190A-3BA1-8220-807AD0A2CE5E> /usr/lib/libFosl_dynamic.dylib
0x7fff6ee89000 - 0x7fff6ee8fff3 libIOReport.dylib (54) <75D177C4-BAD7-3285-B8E1-3019F49B3178> /usr/lib/libIOReport.dylib
0x7fff6ef71000 - 0x7fff6ef78fff libMatch.1.dylib (36) <5C6F3971-9D9E-3630-BDB6-60BFC5A665E0> /usr/lib/libMatch.1.dylib
0x7fff6efa7000 - 0x7fff6efc7ff7 libMobileGestalt.dylib (826.140.5) <2BE94E6A-FA61-312F-84A1-F764D71B7E39> /usr/lib/libMobileGestalt.dylib
0x7fff6f047000 - 0x7fff6f124ff7 libSMC.dylib (20) <5C9C17F2-1E6F-3A19-A440-86F74D82284F> /usr/lib/libSMC.dylib
0x7fff6f139000 - 0x7fff6f13afff libSystem.B.dylib (1281.100.1) <79E1F5B4-8B47-3718-A611-F9D14F3FB537> /usr/lib/libSystem.B.dylib
0x7fff6f13b000 - 0x7fff6f1c6ff7 libTelephonyUtilDynamic.dylib (5017.1) <174030B2-E35F-3F17-A9EF-DF8631F30CCF> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff6f1c7000 - 0x7fff6f1c8fff libThaiTokenizer.dylib (3) <4F4ADE99-0D09-3223-B7C0-C407AB6DE8DC> /usr/lib/libThaiTokenizer.dylib
0x7fff6f1e0000 - 0x7fff6f1f6fff libapple_nghttp2.dylib (1.39.2) <07FEC48A-87CF-32A3-8194-FA70B361713A> /usr/lib/libapple_nghttp2.dylib
0x7fff6f22b000 - 0x7fff6f29dff7 libarchive.2.dylib (72.140.2) <F9EA2883-5D5C-3FA6-B3F8-C5031BF88ABD> /usr/lib/libarchive.2.dylib
0x7fff6f29e000 - 0x7fff6f337fe5 libate.dylib (3.0.1) <76EA60FB-748C-313F-8951-B076540BEA97> /usr/lib/libate.dylib
0x7fff6f33b000 - 0x7fff6f33bff3 libauto.dylib (187) <B6124448-7690-34AE-8939-ED84AAC630CE> /usr/lib/libauto.dylib
0x7fff6f33c000 - 0x7fff6f400ffe libboringssl.dylib (283.120.1) <935DDB00-6514-3D0C-AEA5-C5FE6BCC0B61> /usr/lib/libboringssl.dylib
0x7fff6f401000 - 0x7fff6f411ffb libbsm.0.dylib (60.100.1) <00BFFB9A-2FFE-3C24-896A-251BC61917FD> /usr/lib/libbsm.0.dylib
0x7fff6f412000 - 0x7fff6f41efff libbz2.1.0.dylib (44) <14CC4988-B6D4-3879-AFC2-9A0DDC6388DE> /usr/lib/libbz2.1.0.dylib
0x7fff6f41f000 - 0x7fff6f471fff libc++.1.dylib (902.1) <59A8239F-C28A-3B59-B8FA-11340DC85EDC> /usr/lib/libc++.1.dylib
0x7fff6f472000 - 0x7fff6f487ffb libc++abi.dylib (902) <E692F14F-C65E-303B-9921-BB7E97D77855> /usr/lib/libc++abi.dylib
0x7fff6f488000 - 0x7fff6f488fff libcharset.1.dylib (59) <72447768-9244-39AB-8E79-2FA14EC0AD33> /usr/lib/libcharset.1.dylib
0x7fff6f489000 - 0x7fff6f49afff libcmph.dylib (8) <E72A20DB-2E86-378D-A237-EB9A1370F989> /usr/lib/libcmph.dylib
0x7fff6f49b000 - 0x7fff6f4b2fd7 libcompression.dylib (87) <64C91066-586D-38C0-A2F3-3E60A940F859> /usr/lib/libcompression.dylib
0x7fff6f78c000 - 0x7fff6f7a2ff7 libcoretls.dylib (167) <770A5B96-936E-34E3-B006-B1CEC299B5A5> /usr/lib/libcoretls.dylib
0x7fff6f7a3000 - 0x7fff6f7a4fff libcoretls_cfhelpers.dylib (167) <940BF370-FD0C-30A8-AA05-FF48DA44FA4C> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff6fc47000 - 0x7fff6fd4bfef libcrypto.44.dylib (47.140.1) <CB6B188A-1ADC-3C5D-AFFC-2ACD86E235EE> /usr/lib/libcrypto.44.dylib
0x7fff6fd4e000 - 0x7fff6fd59fff libcsfde.dylib (551) <CEE22AEF-4E77-36B1-B007-00303819965F> /usr/lib/libcsfde.dylib
0x7fff6fd61000 - 0x7fff6fdc0ff7 libcups.2.dylib (483.7) <821ED293-B7B3-3B37-88C9-7B6CA91DA7FA> /usr/lib/libcups.2.dylib
0x7fff6fdc2000 - 0x7fff6fe27ff7 libcurl.4.dylib (118.120.5) <854B4C52-1E58-3A61-A73D-431C5C65D8F9> /usr/lib/libcurl.4.dylib
0x7fff6feca000 - 0x7fff6fecafff libenergytrace.dylib (21) <162DFCC0-8F48-3DD0-914F-FA8653E27B26> /usr/lib/libenergytrace.dylib
0x7fff6fecb000 - 0x7fff6fee3fff libexpat.1.dylib (19.60.2) <FED7C38B-92D8-342D-AED7-871B12D1F7E7> /usr/lib/libexpat.1.dylib
0x7fff6fef1000 - 0x7fff6fef3fff libfakelink.dylib (149.1) <36146CB2-E6A5-37BB-9EE8-1B4034D8F3AD> /usr/lib/libfakelink.dylib
0x7fff6ff02000 - 0x7fff6ff07fff libgermantok.dylib (24) <D2AE5AC0-EDCE-3216-B8C9-CF59292A545F> /usr/lib/libgermantok.dylib
0x7fff6ff08000 - 0x7fff6ff11ff7 libheimdal-asn1.dylib (564.140.2) <F42CB310-DA54-3EF9-BFE3-0667E14E0133> /usr/lib/libheimdal-asn1.dylib
0x7fff6ff12000 - 0x7fff70002fff libiconv.2.dylib (59) <18311A67-E4EF-3CC7-95B3-C0EDEE3A282F> /usr/lib/libiconv.2.dylib
0x7fff70003000 - 0x7fff7025afff libicucore.A.dylib (64260.0.1) <8AC2CB07-E7E0-340D-A849-186FA1F27251> /usr/lib/libicucore.A.dylib
0x7fff70274000 - 0x7fff70275fff liblangid.dylib (133) <30CFC08C-EF36-3CF5-8AEA-C1CB070306B7> /usr/lib/liblangid.dylib
0x7fff70276000 - 0x7fff7028eff3 liblzma.5.dylib (16) <C131EF18-2CDD-3271-8A30-A8760D4FE166> /usr/lib/liblzma.5.dylib
0x7fff702a6000 - 0x7fff7034dff7 libmecab.dylib (883.11) <0D5BFD01-D4A7-3C8D-AA69-C329C1A69792> /usr/lib/libmecab.dylib
0x7fff7034e000 - 0x7fff705b0ff1 libmecabra.dylib (883.11) <E31DE74D-1B88-377F-ACD3-D789D29C3AE7> /usr/lib/libmecabra.dylib
0x7fff7091d000 - 0x7fff7094cfff libncurses.5.4.dylib (57) <995DFEEA-40F3-377F-B73D-D02AC59D591F> /usr/lib/libncurses.5.4.dylib
0x7fff70a7c000 - 0x7fff70ef8ff5 libnetwork.dylib (1880.120.4) <BA294A54-F309-398D-B308-F97032AFF555> /usr/lib/libnetwork.dylib
0x7fff70ef9000 - 0x7fff70f10fff libnetworkextension.dylib (1095.140.2) <D0E8454C-33A9-3F96-B3A0-EDB12C32283A> /usr/lib/libnetworkextension.dylib
0x7fff70f99000 - 0x7fff70fccfde libobjc.A.dylib (787.1) <6DF81160-5E7F-3E31-AA1E-C875E3B98AF6> /usr/lib/libobjc.A.dylib
0x7fff70fcd000 - 0x7fff70fceff7 libodfde.dylib (26) <33F49412-5106-35B8-AA60-5A497C3967E6> /usr/lib/libodfde.dylib
0x7fff70fdf000 - 0x7fff70fe3fff libpam.2.dylib (25.100.1) <0502F395-8EE6-3D2A-9239-06FD5622E19E> /usr/lib/libpam.2.dylib
0x7fff70fe6000 - 0x7fff7101cfff libpcap.A.dylib (89.120.2) <86DAA475-805A-3E01-86C5-6CAE4D1D9BC6> /usr/lib/libpcap.A.dylib
0x7fff7105c000 - 0x7fff7106aff9 libperfcheck.dylib (37.100.2) <9D9C4879-8A80-34C4-B0D2-BE341FD6D321> /usr/lib/libperfcheck.dylib
0x7fff7106b000 - 0x7fff7106eff3 libpmenergy.dylib (214.120.1) <B33FB1C8-EACB-39C5-9B71-283EAB72E7E2> /usr/lib/libpmenergy.dylib
0x7fff7106f000 - 0x7fff71071fff libpmsample.dylib (214.120.1) <F12D8EE0-9284-3E57-AE73-414266E11586> /usr/lib/libpmsample.dylib
0x7fff710a0000 - 0x7fff710b8fff libresolv.9.dylib (67.40.1) <C57EDFEF-D36A-310B-8D14-8C68A625B1E8> /usr/lib/libresolv.9.dylib
0x7fff710ba000 - 0x7fff710feff7 libsandbox.1.dylib (1217.141.2) <E8BA5E84-66AF-3995-8F8E-DDC93B0A88E1> /usr/lib/libsandbox.1.dylib
0x7fff710ff000 - 0x7fff71111ff7 libsasl2.2.dylib (213.120.1) <E7573AC1-83FD-305A-8FB8-03145BDA286B> /usr/lib/libsasl2.2.dylib
0x7fff71112000 - 0x7fff71113ff7 libspindump.dylib (281.3) <AE8C1AE9-5CBC-332F-BBE8-370A2A19FED6> /usr/lib/libspindump.dylib
0x7fff71114000 - 0x7fff712feff7 libsqlite3.dylib (308.6) <33057143-AB4E-348B-9650-98BC48866F34> /usr/lib/libsqlite3.dylib
0x7fff713f2000 - 0x7fff7141fffb libssl.46.dylib (47.140.1) <06932872-13DA-33E3-8C28-7B49FC582039> /usr/lib/libssl.46.dylib
0x7fff71422000 - 0x7fff7146cff7 libstdc++.6.dylib (104.1) <1AD78D98-D287-3A49-AFBB-4999CB334D2B> /usr/lib/libstdc++.6.dylib
0x7fff714f4000 - 0x7fff7154eff8 libusrtcp.dylib (1880.120.4) <05346A91-737C-33D0-B21B-F040950DFB28> /usr/lib/libusrtcp.dylib
0x7fff7154f000 - 0x7fff71552ffb libutil.dylib (57) <F01467F6-23A7-37EE-A170-33CE1577B41D> /usr/lib/libutil.dylib
0x7fff71553000 - 0x7fff71560ff7 libxar.1.dylib (425.2) <EE964412-9E25-30B3-BCC0-CCEFBCC8094B> /usr/lib/libxar.1.dylib
0x7fff71566000 - 0x7fff71648fff libxml2.2.dylib (33.8) <FE38B007-24AF-310D-B834-2C9466154CEC> /usr/lib/libxml2.2.dylib
0x7fff7164c000 - 0x7fff71674fff libxslt.1.dylib (16.11) <B2F38A15-4D4A-30F9-9660-F5738DE14BC2> /usr/lib/libxslt.1.dylib
0x7fff71675000 - 0x7fff71687ff3 libz.1.dylib (76) <793D9643-CD83-3AAC-8B96-88D548FAB620> /usr/lib/libz.1.dylib
0x7fff7173e000 - 0x7fff7175472f libswiftAppKit.dylib (??? - ???) <18802260-9EFC-3E31-B9EA-7767A8B6AB52> /usr/lib/swift/libswiftAppKit.dylib
0x7fff7177e000 - 0x7fff71b33437 libswiftCore.dylib (5.2 - 1103.8.25.8) <E56CCFCA-99E1-36E5-A6BC-F31F53C79910> /usr/lib/swift/libswiftCore.dylib
0x7fff71b40000 - 0x7fff71b48d7f libswiftCoreData.dylib (??? - ???) <5188E034-FC7D-3C6B-A42A-69375097E05B> /usr/lib/swift/libswiftCoreData.dylib
0x7fff71b49000 - 0x7fff71b4bfff libswiftCoreFoundation.dylib (??? - ???) <FBA4566B-AD2B-35D7-BC9A-48BE3D88B658> /usr/lib/swift/libswiftCoreFoundation.dylib
0x7fff71b4c000 - 0x7fff71b59fff libswiftCoreGraphics.dylib (??? - ???) <A8225B5F-F64D-32F8-AD91-D919DF614AA0> /usr/lib/swift/libswiftCoreGraphics.dylib
0x7fff71b5a000 - 0x7fff71b5dffb libswiftCoreImage.dylib (??? - ???) <1485E8EF-EDA9-3981-84D7-DF3BFE361929> /usr/lib/swift/libswiftCoreImage.dylib
0x7fff71bb8000 - 0x7fff71bbefff libswiftDarwin.dylib (??? - ???) <F3684684-8258-310F-B05B-BD8A696F0F29> /usr/lib/swift/libswiftDarwin.dylib
0x7fff71bbf000 - 0x7fff71bd6cdf libswiftDispatch.dylib (??? - ???) <94D67EF4-42B5-3F54-8D86-B6B2B16827DC> /usr/lib/swift/libswiftDispatch.dylib
0x7fff71bd7000 - 0x7fff71d5c277 libswiftFoundation.dylib (??? - ???) <0173898D-FDA6-378D-87E9-1F2A9BD227D3> /usr/lib/swift/libswiftFoundation.dylib
0x7fff71d6b000 - 0x7fff71d6dff3 libswiftIOKit.dylib (??? - ???) <FD313708-AE48-3C72-A154-53EC839A8D55> /usr/lib/swift/libswiftIOKit.dylib
0x7fff71d83000 - 0x7fff71d8af0f libswiftMetal.dylib (??? - ???) <B3C74138-DE3C-3676-9983-F12757819C9C> /usr/lib/swift/libswiftMetal.dylib
0x7fff71e06000 - 0x7fff71e09fe7 libswiftObjectiveC.dylib (??? - ???) <E668BD5D-E1D6-3C21-BA7E-5C3A672A964E> /usr/lib/swift/libswiftObjectiveC.dylib
0x7fff71e1b000 - 0x7fff71e20fbf libswiftQuartzCore.dylib (??? - ???) <101D3E4D-231A-3CD8-97B4-4E37F4081CD2> /usr/lib/swift/libswiftQuartzCore.dylib
0x7fff71f0a000 - 0x7fff71f0cfff libswiftXPC.dylib (??? - ???) <3CD547C3-7082-37EA-B289-F6BA6C4D4E26> /usr/lib/swift/libswiftXPC.dylib
0x7fff71f36000 - 0x7fff71f3bff3 libcache.dylib (83) <AF488D13-9E89-35E0-B078-BE37CC5B8586> /usr/lib/system/libcache.dylib
0x7fff71f3c000 - 0x7fff71f47fff libcommonCrypto.dylib (60165.120.1) <C7912BE5-993E-3581-B2A0-6AABDC8C5562> /usr/lib/system/libcommonCrypto.dylib
0x7fff71f48000 - 0x7fff71f4ffff libcompiler_rt.dylib (101.2) <49B8F644-5705-3F16-BBE0-6FFF9B17C36E> /usr/lib/system/libcompiler_rt.dylib
0x7fff71f50000 - 0x7fff71f59ff7 libcopyfile.dylib (166.40.1) <3C481225-21E7-370A-A30E-0CCFDD64A92C> /usr/lib/system/libcopyfile.dylib
0x7fff71f5a000 - 0x7fff71fecfdb libcorecrypto.dylib (866.140.2) <C2CFE656-BFA7-36E0-B8BB-1579F51AB6CF> /usr/lib/system/libcorecrypto.dylib
0x7fff720f9000 - 0x7fff72139ff0 libdispatch.dylib (1173.100.2) <CD9C059C-91D9-30E8-8926-5B9CD0D5D4F5> /usr/lib/system/libdispatch.dylib
0x7fff7213a000 - 0x7fff72170fff libdyld.dylib (750.6) <789A18C2-8AC7-3C88-813D-CD674376585D> /usr/lib/system/libdyld.dylib
0x7fff72171000 - 0x7fff72171ffb libkeymgr.dylib (30) <DB3337BE-01CA-3425-BD0C-87774FC0CDC0> /usr/lib/system/libkeymgr.dylib
0x7fff72172000 - 0x7fff7217eff3 libkxld.dylib (6153.141.28.1) <D0CD88A4-D750-384C-AEF4-463BE5D606B1> /usr/lib/system/libkxld.dylib
0x7fff7217f000 - 0x7fff7217fff7 liblaunch.dylib (1738.140.3) <0A07A8E8-EDA1-30C7-9414-0FCC070A45D8> /usr/lib/system/liblaunch.dylib
0x7fff72180000 - 0x7fff72185ff7 libmacho.dylib (959.0.1) <AA613A9C-961A-3B67-B696-4622FA59FC4E> /usr/lib/system/libmacho.dylib
0x7fff72186000 - 0x7fff72188ff3 libquarantine.dylib (110.40.3) <F234E51D-FD0B-3EE4-B679-AE3EE9C536C3> /usr/lib/system/libquarantine.dylib
0x7fff72189000 - 0x7fff7218aff7 libremovefile.dylib (48) <7C7EFC79-BD24-33EF-B073-06AED234593E> /usr/lib/system/libremovefile.dylib
0x7fff7218b000 - 0x7fff721a2ff3 libsystem_asl.dylib (377.60.2) <1563EE02-0657-3B78-99BE-A947C24122EF> /usr/lib/system/libsystem_asl.dylib
0x7fff721a3000 - 0x7fff721a3ff7 libsystem_blocks.dylib (74) <0D53847E-AF5F-3ACF-B51F-A15DEA4DEC58> /usr/lib/system/libsystem_blocks.dylib
0x7fff721a4000 - 0x7fff7222bfff libsystem_c.dylib (1353.100.2) <BBDED5E6-A646-3EED-B33A-91E4331EA063> /usr/lib/system/libsystem_c.dylib
0x7fff7222c000 - 0x7fff7222fffb libsystem_configuration.dylib (1061.141.1) <0EE84C33-64FD-372B-974A-AF7A136F2068> /usr/lib/system/libsystem_configuration.dylib
0x7fff72230000 - 0x7fff72233fff libsystem_coreservices.dylib (114) <A199156E-058D-3ABB-BCE9-4B9F20DCED0F> /usr/lib/system/libsystem_coreservices.dylib
0x7fff72234000 - 0x7fff7223cfff libsystem_darwin.dylib (1353.100.2) <5B12B5DB-3F30-37C1-8ECC-49A66B1F2864> /usr/lib/system/libsystem_darwin.dylib
0x7fff7223d000 - 0x7fff72244fff libsystem_dnssd.dylib (1096.100.3) <EBB4C2C2-E031-3094-B40A-E67BF261D295> /usr/lib/system/libsystem_dnssd.dylib
0x7fff72245000 - 0x7fff72246ffb libsystem_featureflags.dylib (17) <29FD922A-EC2C-3F25-BCCC-B58D716E60EC> /usr/lib/system/libsystem_featureflags.dylib
0x7fff72247000 - 0x7fff72294ff7 libsystem_info.dylib (538) <8A321605-5480-330B-AF9E-64E65DE61747> /usr/lib/system/libsystem_info.dylib
0x7fff72295000 - 0x7fff722c1ff7 libsystem_kernel.dylib (6153.141.28.1) <B3DC3FBB-4304-338C-A1E0-CAAFA78CDE2B> /usr/lib/system/libsystem_kernel.dylib
0x7fff722c2000 - 0x7fff72309fff libsystem_m.dylib (3178) <00F331F1-0D09-39B3-8736-1FE90E64E903> /usr/lib/system/libsystem_m.dylib
0x7fff7230a000 - 0x7fff72331fff libsystem_malloc.dylib (283.100.6) <8549294E-4C53-36EB-99F3-584A7393D8D5> /usr/lib/system/libsystem_malloc.dylib
0x7fff72332000 - 0x7fff7233fffb libsystem_networkextension.dylib (1095.140.2) <F06C65C5-2CBE-313C-96E1-A09240F9FE57> /usr/lib/system/libsystem_networkextension.dylib
0x7fff72340000 - 0x7fff72349ff7 libsystem_notify.dylib (241.100.2) <FA22F928-D91B-3AA5-96BB-3186AC0FB264> /usr/lib/system/libsystem_notify.dylib
0x7fff7234a000 - 0x7fff72352fef libsystem_platform.dylib (220.100.1) <009A7C1F-313A-318E-B9F2-30F4C06FEA5C> /usr/lib/system/libsystem_platform.dylib
0x7fff72353000 - 0x7fff7235dfff libsystem_pthread.dylib (416.100.3) <62CB1A98-0B8F-31E7-A02B-A1139927F61D> /usr/lib/system/libsystem_pthread.dylib
0x7fff7235e000 - 0x7fff72362ff3 libsystem_sandbox.dylib (1217.141.2) <051C4018-4345-3034-AC98-6DE42FB8273B> /usr/lib/system/libsystem_sandbox.dylib
0x7fff72363000 - 0x7fff72365fff libsystem_secinit.dylib (62.100.2) <F80872AA-E1FD-3D7E-8729-467656EC6561> /usr/lib/system/libsystem_secinit.dylib
0x7fff72366000 - 0x7fff7236dffb libsystem_symptoms.dylib (1238.120.2) <702D0910-5C34-3D43-9631-8BD215DE4FE1> /usr/lib/system/libsystem_symptoms.dylib
0x7fff7236e000 - 0x7fff72384ff2 libsystem_trace.dylib (1147.120.1) <BC141783-66D9-3137-A783-211B38E49ADB> /usr/lib/system/libsystem_trace.dylib
0x7fff72386000 - 0x7fff7238bff7 libunwind.dylib (35.4) <42B7B509-BAFE-365B-893A-72414C92F5BF> /usr/lib/system/libunwind.dylib
0x7fff7238c000 - 0x7fff723c1ffe libxpc.dylib (1738.140.3) <A3F5B6A0-DD96-3AC2-B610-F62E242F477C> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 592
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=2.5G resident=0K(0%) swapped_out_or_unallocated=2.5G(100%)
Writable regions: Total=1.6G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.6G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
ATS (font support) 32.0M 90
ATS (font support) (reserved) 8K 2 reserved VM address space (unallocated)
Accelerate framework 1536K 12
Activity Tracing 256K 1
CG backing stores 3468K 7
CG image 264K 38
CG raster data 8K 1
CoreAnimation 18.8M 425
CoreGraphics 8K 1
CoreImage 136K 29
CoreUI image data 2112K 31
Foundation 4K 1
IOKit 7940K 1
Image IO 532K 106
Kernel Alloc Once 8K 1
MALLOC 1.2G 1459
MALLOC guard page 32K 7
MALLOC_NANO (reserved) 128.0M 1 reserved VM address space (unallocated)
Mach message 8K 2
OpenGL GLSL 256K 3
STACK GUARD 56.3M 77
Stack 129.1M 81
VM_ALLOCATE 2692K 42
VM_ALLOCATE (reserved) 2048K 1 reserved VM address space (unallocated)
__DATA 207.7M 984
__DATA_CONST 773K 29
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 966.4M 346
__OBJC_RO 32.3M 1
__OBJC_RW 1908K 2
__TEXT 1.5G 770
__UNICODE 564K 1
mapped file 863.5M 359
shared memory 688K 26
TOTAL 5.1G 4939
TOTAL, minus reserved VM space 5.0G 4939
Model: MacBookPro16,1, BootROM XXXXXXXXXXX (iBridge: XXXXXXXX), 8 processors, 8-Core Intel Core i9, 2,3 GHz, 16 GB, SMC
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Graphics: kHW_AMDRadeonPro5500MItem, AMD Radeon Pro 5500M, spdisplays_pcie_device, 8 GB
Memory Module: BANK 0/ChannelA-DIMM0, 8 GB, DDR4, 2667 MHz, Micron, 8ATF1G64HZ-2G6E1
Memory Module: BANK 2/ChannelB-DIMM0, 8 GB, DDR4, 2667 MHz, Micron, 8ATF1G64HZ-2G6E1
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Oct 28 2020 14:13:29 version 9.30.357.42.32.5.48 FWID 01-767f6cce
Bluetooth: Version 7.0.6f8, 3 services, 27 devices, 1 incoming serial ports
Network Service: USB 10/100/1000 LAN, Ethernet, en5
Network Service: Wi-Fi, AirPort, en0
USB Device: USB3.0 Hub
USB Device: Mass Storage Device
USB Device: USB3.1 Hub
USB Device: USB 10/100/1000 LAN
USB Device: USB 3.1 Bus
USB Device: USB2.0 Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: USB Billboard Device
USB Device: Apple T2 Bus
USB Device: Composite Device
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 55.3
Hi,
is it possible to merge more collinear walls in 1 wall-object? cmd+shif+j doesn't work for example. The only solution I actually know is delete all walls and keep one of them. If there are objects inside that wall (e.g. windows, doors,...) pull them out of the wall, after that extend the wall to the wanted length and reinsert all objects you first pulled out of the wall and be happy...
But, a single simple shortcut for merging more walls in one wall-object would be great...
- 2
I created a new design-layer and moved it in another position. Now VW asks me to check out Sheet Titles. Why??!?!?
Works as designed, of course, but, however doesn't make any sense to me...
VW 2021 SP3 crash's quite often on more of our machines...
I already tried to exclude some reasons (I can't change the graphics driver on a mac that easily, however I keep our machines quite up to date...
My MB Pro 16" 2019 - macOS Catalina 10.15.7 - Updatet for the last time - yesterday
iMac 27" 2015, 2017 with actual macOS 10.14...
could still be sth in the project file, however not sure...
(I already changed the setting to "send all crash data (or sth like this) as you can see in the attached screenshot, unfortunately german Vectorworks, however the dropdown-menu location is the same like in an english vwx-version)
QUESTION:
Where do I find all VW Crash dump-files?
Datamanager VW2022 - Find function?
in Troubleshooting
Posted
aaand, it seems to me, that "FIND" doesn't exist any more... 😖
