Thanks All however, none of those solutions solve the problem. I work in BIM so, 3D and 2D. I often have to do site plans and landscape calcs. at 20' or 30' scale. I also have to do planting plans, irrigation plans, and hardscape layouts at 10' scale or less. Up until VW 22 the standard best management practice was to set your design layer scale to the same scale you you wanted to print your sheet layers at, thus preserving line weights and font size. I could easily set the civil or architectural base at 30' scale on one layer and put my planting plan on another layer at 10' scale, turn on unified view and presto magic.
However, now unified view no longer has a setting to ignore different scales because it has been made a legacy item. It does still allow me to view my 30' scale plan from my 10' plant layer, but because I can't give it the option to ignore the scale difference my plants symbols are huge and civil plan is small, and when I switch back over to my 30' scale plan my plant symbols are super tiny.
See the attached screen shot of the Unified View Options from VW 21 and VW 22. Note the Ignore Layers with different scales option in VW 21. I imagine I am not alone in needing that back. The only other solution that I can see now is to either set up tedious design layer viewports at different scales, create a series of annotated texts styles for different scales, or manually adjust every sheet layer viewport setting to accommodate line weights and fonts. So, all the reasons I left CAD and switched to VW in the first place.
