A LOT of fixtures in the library do not have fixture modes included in the dropdown menu. Is there a particular spot where I can edit the record or database to include the proper modes?
Really, I just want the DMX footprint to be populated correctly, without having to double check each fixture footprint from the manual, or from its MA console profile.
Someone on Facebook had mentioned that the Fixture mode is used for export to Vision, and that's is fine, but I DO NOT care about the fixtures' function in VISION, as I do not and will never use Vision. I just need it to populate the DMX footprint field so I can patch easily. As a side note, if this is true, Vision must have a terribly lacking fixture library.
Someone on Facebook recommended using GDTF instead. While I would have to make files for a lot of fixtures, I am not opposed to doing it, however it Vectorworks does not keep the proper modes for each fixture in the dropdown menu. Instead, you must click "other" and then navigate a separate menu. Is there a way to keep just the modes for each symbol in the GDTF dropdown? Is there a way to select a default GDTF or Fixture mode when I add the fixture to my document? (I have reset the record for default DMX footprint to my most commonly used mode, but this seems like a legacy issue, that should be replaced with fixture mode or GDTF).
