HI,
Does anybody know how to solve this SILL Problem in VWX 2023 ?
Trying to move from 2D to 3D and encountering the following problems with Sills. Am testing V 2023 and Window Sills within Splayed Wall.
IN 2D
1. Unwanted Lines from external wall across sill EXTERNALLY
2. Unwanted Lines across Sill INTERNALLY
3. Cannot Control Internal Sill shape or dims - Length is exactly the same as external sill offsets
4. Void in 2D between Splayed Wall and Cill.
IN 3D
1. Unwanted Lines to sill Externally
2. NO sill INTERNALLY unless Jamb extension used
3. If Jamb Extension used it extends externally into void
4. Cannot see anywhere to control the Shape, Dims, extend of Sills independently. - for Inside and Outside or remove unwanted lines.
The only way I can see to do this is for 2D graphic to draw polygons internally and externally for EACH WINDOW , but this won't read using Clip Cube so the manual process needs to be repeated in all sections.
Surely this laborious workflow ( if only option) goes against what they're trying to achieve with more interactive, time efficient design workflow ? -
Any assistance gratefully accepted .
Frank
