Mojo65
    35
Reputation
6 Neutral
Personal Information
  • Location
    United Kingdom
Recent Profile Visitors
  1. Let's see if this works better. Thank you for your advice. I did repair on the updater and removed the generateImage.
  2. My Vectorworks crashes a lot since I installed the 2024 version. Any suggestions?
  3. I have a Mac desktop, iMac and the VW version is the 2024(Update 3) for Architects
  4. Since I have installed the 2024 version, VW crashes a lot which is very annoying. Anything I can do?
  5. Thank you for your reply, but I can't find the Advanced Section Properties dialog
  6. I create a section or detail viewport and don't get the details shown. What do I have to do? previous sections worked fine, so I don't understand. I have detail level setting on high.
  7. Mojo65
    Unified view
    thank you, it works.
  8. I seem to have unclicked my unified view and now when I go into Orbit to view the model, it only rotates the ground floor plan in 3D and the rest stays in plan view. Where do I find the unified view again? Thank you
  9. Looks like I have to live with it if this is a bug with VW2020. Not intending to upgrade yet to VW2022.
  10. I have the issue since upgrading to Monterey that when open a file from the Vectorworks menu, it won't let me reduce the open box so I can see the 'open' or 'cancel' button at the bottom right. It is very annoying. I have to move the whole box off the page to the left to get there. Any advice?
  11. Thank you, that is what I have done, put two pieces of stair together. In the end, I have found another solution, an U-winder solution which works much better. It is a complex scenario, client wants a toilet below the stair, plus space in a hall for a door and the upper floor opening is restricted due to heritage. Thank you for your help and suggestion.
  12. Thank you for your help, it seems impossible to make it work. I drew in the end two stairs and it works.
  13. Hi I would like to create a Triple L stair but without landing and instead winders. Can I do this with the standard configuration. Or how can I manipulate this. Or do I create two seperate L-Stair winder stairs to achieve this outcome?
  14. Thank you both, it works. Very relieved.
