Content Count
25 -
Speaker tool second bumper
gmulder replied to gmulder's question in Wishlist - Feature and Content Requests
Hi Andrew, Thanks for the quick reply. My post was focused on the secondary bumper. I also thought of the workaround, but in the case like my example, that won't work. If you are using a main bumper and 3 speaker types, you will need a fourth speaker type for the underhang bumper. The secondary bumper would be a very nice extra feature in the tool.- 3 replies
- spotlight
- speaker array
(and 2 more)
Tagged with:
Hi All, When using the speaker tool, you can only add one main bumper within the speaker array tool. It's kind of weird that you are able to use three speaker types with no bumper between them. For example, a configuration with a 4 x K1-SB, 16 x K1, and 4 x K2 underhang. The K1 and K2 connection officially needs a underhang bumper. Would be nice to see this feature in the new service pack or the software release.
- 3 replies
- spotlight
- speaker array
(and 2 more)
Tagged with:
@JustinVH Well... that's making sense... thanks for the quick help! We made a copy of the VWX library (prolyte / eurotruss / interall) 2 years ago and implement this in our workgroup for the whole company (16 licences). We did made some adjustments to line weight, copy full library in a black version, classes etc. Never looked at the connection types, but it's clear that we have to adjust this. We're also not using any coupler sections except on spacers, specific tube parts and base plates. Connection type neutral on all situations will work the best. I tested it with truss and plates. I have some work to do... Thanks!
VWX file attached. Base plates 30x30.vwx
Hello, I'm trying to make a Prolyte H30V top plate 30x30cm. I already made a base version, and that works fine. Now i'm trying to make a upside down version which not work properly. When trying to connect to the truss, the plate automaticly rotates with the pins facing up. I was already playing with starting / endpoints but unfortunately it doesn't work out. Has anybody a solution or experiences on this subject?
gmulder changed their profile photo
Hello! Does somebody know if VWX will update their Speaker tool of Landru? Or will make VWX their own? Hope to hear!
Turn Layer & Class On/Off All Viewports
gmulder replied to Jim Smith's question in Wishlist - Feature and Content Requests
Picking tool can do the job as well! -
LenLindhout started following gmulder
I'm looking for the same thing.. Can anybody help me to make a simple worksheets of the colour meanings?
Well... It's a bug then, because now I don't see them anymore. Using SP3.. Have to update I know
Solved, thanks.
Hi All, Does anybody knows what the arrows are about? It's in no class, and you don't see it while printing, but it's always visible in your viewport. Seems to be a setting or anything..
Love to hear this news.. Can't wait:-)
Is there any updates about the DWG export subject? This is a must in the industry to export to C4D & other programs.
@scottmoore hi scott,well this is were i’m know working on.. problem with an own invetory is that if VWX something changes on the plugin or symbols in there yearly update, you can start over.. but for know I have my own workgroup with duplicates of the VWX symbols in the correct classes (including prefix), correct line weight, correct name, and correct color.
